TDA4VH-Q1: Ethfw 驱动在8.2 SDK上无法在我们定制的电路板上工作, 虽然Ethfw在RTOS端log显示工作正常,但是在Linux端用Ifconfig无法发现并且会卡住, 请帮助解决。
Part Number: TDA4VH-Q1
现打印logRTOS的信息如下
root@j784s4-evm:~# source /opt/vision_apps/vision_apps_init.sh
root@j784s4-evm:~# [MCU2_0] 4.063294 s: CIO: Init ... Done !!!
[MCU2_0] 4.063349 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0] 4.063384 s: APP: Init ... !!!
[MCU2_0] 4.063403 s: SCICLIENT: Init ... !!!
[MCU2_0] 4.063542 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU2_0] 4.063577 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_0] 4.063605 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0] 4.063635 s: SCICLIENT: Init ... Done !!!
[MCU2_0] 4.063659 s: UDMA: Init ... !!!
[MCU2_0] 4.064624 s: UDMA: Init ... Done !!!
[MCU2_0] 4.064659 s: UDMA: Init ... !!!
[MCU2_0] 4.065174 s: UDMA: Init for CSITX/CSIRX ... Done !!!
[MCU2_0] 4.065211 s: MEM: Init ... !!!
[MCU2_0] 4.065244 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
[MCU2_0] 4.065302 s: MEM: Init ... Done !!!
[MCU2_0] 4.065324 s: IPC: Init ... !!!
[MCU2_0] 4.065374 s: IPC: 11 CPUs participating in IPC !!!
[MCU2_0] 4.065416 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0] 18.317520 s: IPC: HLOS is ready !!!
[MCU2_0] 18.340748 s: IPC: Init ... Done !!!
[MCU2_0] 18.340795 s: APP: Syncing with 10 CPUs ... !!!
[MCU2_0] 19.262984 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU2_0] 19.263030 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0] 19.264775 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0] 19.264820 s: ETHFW: Init ... !!!
[MCU2_0] 19.272461 s: Warning: Using 6 MAC address(es) from static pool
[MCU2_0] 19.272554 s: ETHFW: Shared multicasts (software fanout):
[MCU2_0] 19.272591 s: 01:00:5e:00:00:01
[MCU2_0] 19.272635 s: 01:00:5e:00:00:fb
[MCU2_0] 19.272676 s: 01:00:5e:00:00:fc
[MCU2_0] 19.272717 s: 33:33:00:00:00:01
[MCU2_0] 19.272758 s: 33:33:ff:1d:92:c2
[MCU2_0] 19.272799 s: 01:80:c2:00:00:00
[MCU2_0] 19.272840 s: 01:80:c2:00:00:03
[MCU2_0] 19.272882 s: ETHFW: Reserved multicasts:
[MCU2_0] 19.272906 s: 01:80:c2:00:00:0e
[MCU2_0] 19.272947 s: 01:1b:19:00:00:00
[MCU2_0] 19.273162 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0] 19.288233 s: PHY 1 is alive
[MCU2_0] 19.288295 s: PHY 2 is alive
[MCU2_0] 19.288917 s: M88Q2221_isMacModeSupported: M88Q2221_isMacModeSupported::----------
[MCU2_0] 19.288987 s: EnetPhy_bindDriver: PHY 2: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221' : OK
[MCU2_0] 19.289613 s: M88Q2221_isMacModeSupported: M88Q2221_isMacModeSupported::----------
[MCU2_0] 19.289674 s: EnetPhy_bindDriver: PHY 1: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221' : OK
[MCU2_0] 19.292576 s:
[MCU2_0] ETHFW Version : 0.02.00
[MCU2_0] 19.292625 s: ETHFW Build Date: May 29, 2023
[MCU2_0] 19.292651 s: ETHFW Build Time: 16:40:10
[MCU2_0] 19.292674 s: ETHFW Commit SHA: f2e96942
[MCU2_0] 19.292731 s: ETHFW: Init ... DONE !!!
[MCU2_0] 19.292755 s: ETHFW: Remove server Init ... !!!
[MCU2_0] 19.292910 s: CpswProxyServer: Virtual port configuration:
[MCU2_0] 19.292952 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
[MCU2_0] 19.292990 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
[MCU2_0] 19.293797 s: CpswProxyServer: initialization completed (core: mcu2_0)
[MCU2_0] 19.293842 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0] 19.294829 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0] 19.300959 s: Host MAC address: 70:ff:76:1d:92:c2
[MCU2_0] 19.304377 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
[MCU2_0] 19.338075 s: [LWIPIF_LWIP_IC] Interface started successfully
[MCU2_0] 19.338170 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
[MCU2_0] 19.345090 s: FVID2: Init ... !!!
[MCU2_0] 19.345156 s: FVID2: Init ... Done !!!
[MCU2_0] 19.345184 s: SCICLIENT: Sciclient_pmSetModuleState module=275 state=2
[MCU2_0] 19.345291 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345338 s: DSS: Init ... !!!
[MCU2_0] 19.345360 s: DSS: Display type is eDP !!!
[MCU2_0] 19.345384 s: DSS: SoC init ... !!!
[MCU2_0] 19.345406 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
[MCU2_0] 19.345476 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345505 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
[MCU2_0] 19.345569 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345596 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
[MCU2_0] 19.345658 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345686 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
[MCU2_0] 19.345744 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345770 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
[MCU2_0] 19.345828 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345854 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
[MCU2_0] 19.345915 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.345943 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=218 clk=3 freq=148500000
[MCU2_0] 19.346942 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0] 19.346974 s: SCICLIENT: Sciclient_pmModuleClkRequest module=218 clk=3 state=2 flag=2
[MCU2_0] 19.347117 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0] 19.347150 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2
[MCU2_0] 19.347290 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.347318 s: DSS: SoC init ... Done !!!
[MCU2_0] 19.347340 s: DSS: Board init ... !!!
[MCU2_0] 19.347361 s: DSS: Board init ... Done !!!
[MCU2_0] 19.366866 s: DSS: Init ... Done !!!
[MCU2_0] 19.366913 s: VHWA: VPAC Init ... !!!
[MCU2_0] 19.366937 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2
[MCU2_0] 19.367068 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.367194 s: VHWA: LDC Init ... !!!
[MCU2_0] 19.369358 s: VHWA: LDC Init ... Done !!!
[MCU2_0] 19.369403 s: VHWA: MSC Init ... !!!
[MCU2_0] 19.376949 s: VHWA: MSC Init ... Done !!!
[MCU2_0] 19.376990 s: VHWA: NF Init ... !!!
[MCU2_0] 19.378154 s: VHWA: NF Init ... Done !!!
[MCU2_0] 19.378194 s: VHWA: VISS Init ... !!!
[MCU2_0] 19.386039 s: VHWA: VISS Init ... Done !!!
[MCU2_0] 19.386139 s: VHWA: VPAC Init ... Done !!!
[MCU2_0] 19.386181 s: VX_ZONE_INIT:Enabled
[MCU2_0] 19.386206 s: VX_ZONE_ERROR:Enabled
[MCU2_0] 19.386228 s: VX_ZONE_WARNING:Enabled
[MCU2_0] 19.387273 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-0
[MCU2_0] 19.387494 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_NF
[MCU2_0] 19.387680 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_LDC1
[MCU2_0] 19.387868 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC1
[MCU2_0] 19.388062 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC2
[MCU2_0] 19.388409 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_VISS1
[MCU2_0] 19.388627 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE1
[MCU2_0] 19.388840 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE2
[MCU2_0] 19.389036 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY1
[MCU2_0] 19.389311 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY2
[MCU2_0] 19.389505 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CSITX
[MCU2_0] 19.389705 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE3
[MCU2_0] 19.389895 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE4
[MCU2_0] 19.390152 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE5
[MCU2_0] 19.390361 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE6
[MCU2_0] 19.390564 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE7
[MCU2_0] 19.390759 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE8
[MCU2_0] 19.390953 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M1
[MCU2_0] 19.391232 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M2
[MCU2_0] 19.391443 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M3
[MCU2_0] 19.391623 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M4
[MCU2_0] 19.391836 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE9
[MCU2_0] 19.392043 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE10
[MCU2_0] 19.392332 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE11
[MCU2_0] 19.392549 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE12
[MCU2_0] 19.392593 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_0] 19.392623 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0] 19.415884 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0] 19.415930 s: CSI2RX: Init ... !!!
[MCU2_0] 19.415952 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
[MCU2_0] 19.416039 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416070 s: SCICLIENT: Sciclient_pmSetModuleState module=72 state=2
[MCU2_0] 19.416257 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416287 s: SCICLIENT: Sciclient_pmSetModuleState module=73 state=2
[MCU2_0] 19.416379 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416405 s: SCICLIENT: Sciclient_pmSetModuleState module=74 state=2
[MCU2_0] 19.416489 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416515 s: SCICLIENT: Sciclient_pmSetModuleState module=212 state=2
[MCU2_0] 19.416590 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416615 s: SCICLIENT: Sciclient_pmSetModuleState module=213 state=2
[MCU2_0] 19.416683 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416728 s: SCICLIENT: Sciclient_pmSetModuleState module=214 state=2
[MCU2_0] 19.416793 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416820 s: SCICLIENT: Sciclient_pmSetModuleState module=270 state=2
[MCU2_0] 19.416909 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.416936 s: SCICLIENT: Sciclient_pmSetModuleState module=271 state=2
[MCU2_0] 19.417011 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.417037 s: SCICLIENT: Sciclient_pmSetModuleState module=274 state=2
[MCU2_0] 19.417124 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.417747 s: CSI2RX: Init ... Done !!!
[MCU2_0] 19.417787 s: CSI2TX: Init ... !!!
[MCU2_0] 19.417810 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
[MCU2_0] 19.417883 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.417911 s: SCICLIENT: Sciclient_pmSetModuleState module=75 state=2
[MCU2_0] 19.417995 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.418022 s: SCICLIENT: Sciclient_pmSetModuleState module=76 state=2
[MCU2_0] 19.418165 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.418198 s: SCICLIENT: Sciclient_pmSetModuleState module=402 state=2
[MCU2_0] 19.418269 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 19.418684 s: CSI2TX: Init ... Done !!!
[MCU2_0] 19.418718 s: ISS: Init ... !!!
[MCU2_0] 19.418816 s: [Imaging]: Initializing Des[0] on I2C4@0x29
[MCU2_0] 19.442032 s: [LWIPIF_LWIP_IC] Interface started successfully
[MCU2_0] 19.442137 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
[MCU2_0] 19.442221 s: Added interface 'br4', IP is 0.0.0.0
[MCU2_0] 19.526809 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
[MCU2_0] 19.618140 s: [Imaging]: Failed to initialize Des0 on I2C4@0x29
[MCU2_0] 19.618180 s: ERROR: Unable to setup SerDes
[MCU2_0] 19.618205 s: ISS: ERROR: Init failed !!!
[MCU2_0] 20.949678 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3b2c69c,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:114, FlowIdxOffset:0
[MCU2_0] 20.955307 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:1
[MCU2_1] 4.014028 s: CIO: Init ... Done !!!
[MCU2_1] 4.014077 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1] 4.014110 s: APP: Init ... !!!
[MCU2_1] 4.014130 s: SCICLIENT: Init ... !!!
[MCU2_1] 4.014279 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU2_1] 4.014313 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_1] 4.014341 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1] 4.014371 s: SCICLIENT: Init ... Done !!!
[MCU2_1] 4.014394 s: UDMA: Init ... !!!
[MCU2_1] 4.015493 s: UDMA: Init ... Done !!!
[MCU2_1] 4.015530 s: MEM: Init ... !!!
[MCU2_1] 4.015562 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e3000000 of size 16777216 bytes !!!
[MCU2_1] 4.015622 s: MEM: Init ... Done !!!
[MCU2_1] 4.015647 s: IPC: Init ... !!!
[MCU2_1] 4.015694 s: IPC: 11 CPUs participating in IPC !!!
[MCU2_1] 4.015734 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1] 18.700304 s: IPC: HLOS is ready !!!
[MCU2_1] 18.723184 s: IPC: Init ... Done !!!
[MCU2_1] 18.723235 s: APP: Syncing with 10 CPUs ... !!!
[MCU2_1] 19.262983 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU2_1] 19.263028 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1] 19.264795 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1] 19.264839 s: FVID2: Init ... !!!
[MCU2_1] 19.264904 s: FVID2: Init ... Done !!!
[MCU2_1] 19.264930 s: VHWA: DMPAC: Init ... !!!
[MCU2_1] 19.264952 s: SCICLIENT: Sciclient_pmSetModuleState module=92 state=2
[MCU2_1] 19.265076 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 19.265109 s: SCICLIENT: Sciclient_pmSetModuleState module=96 state=2
[MCU2_1] 19.265235 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 19.265271 s: VHWA: DOF Init ... !!!
[MCU2_1] 19.271123 s: VHWA: DOF Init ... Done !!!
[MCU2_1] 19.271168 s: VHWA: SDE Init ... !!!
[MCU2_1] 19.273711 s: VHWA: SDE Init ... Done !!!
[MCU2_1] 19.273748 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1] 19.273785 s: VX_ZONE_INIT:Enabled
[MCU2_1] 19.273814 s: VX_ZONE_ERROR:Enabled
[MCU2_1] 19.273837 s: VX_ZONE_WARNING:Enabled
[MCU2_1] 19.274819 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_SDE
[MCU2_1] 19.275010 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_DOF
[MCU2_1] 19.275198 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-1
[MCU2_1] 19.275244 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_1] 19.275275 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1] 19.275522 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1] 19.275557 s: APP: Init ... Done !!!
[MCU2_1] 19.275581 s: APP: Run ... !!!
[MCU2_1] 19.275602 s: IPC: Starting echo test ...
[MCU2_1] 19.280111 s: APP: Run ... Done !!!
[MCU2_1] 19.281394 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU2_1] 19.281512 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU2_1] 19.281619 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU2_1] 19.281729 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU2_1] 19.281834 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
[MCU2_1] 19.281939 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU2_1] 19.282047 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU2_1] 19.316353 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_0] 4.046538 s: CIO: Init ... Done !!!
[MCU3_0] 4.046590 s: ### CPU Frequency = 1000000000 Hz
[MCU3_0] 4.046621 s: APP: Init ... !!!
[MCU3_0] 4.046641 s: SCICLIENT: Init ... !!!
[MCU3_0] 4.046786 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU3_0] 4.046817 s: SCICLIENT: DMSC FW revision 0x8
[MCU3_0] 4.046844 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU3_0] 4.046874 s: SCICLIENT: Init ... Done !!!
[MCU3_0] 4.046897 s: MEM: Init ... !!!
[MCU3_0] 4.046928 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4000000 of size 8388608 bytes !!!
[MCU3_0] 4.046982 s: MEM: Init ... Done !!!
[MCU3_0] 4.047004 s: IPC: Init ... !!!
[MCU3_0] 4.047047 s: IPC: 11 CPUs participating in IPC !!!
[MCU3_0] 4.047085 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU3_0] 18.830107 s: IPC: HLOS is ready !!!
[MCU3_0] 18.853088 s: IPC: Init ... Done !!!
[MCU3_0] 18.853135 s: APP: Syncing with 10 CPUs ... !!!
[MCU3_0] 19.262983 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU3_0] 19.263028 s: REMOTE_SERVICE: Init ... !!!
[MCU3_0] 19.264809 s: REMOTE_SERVICE: Init ... Done !!!
[MCU3_0] 19.264872 s: VX_ZONE_INIT:Enabled
[MCU3_0] 19.264898 s: VX_ZONE_ERROR:Enabled
[MCU3_0] 19.264923 s: VX_ZONE_WARNING:Enabled
[MCU3_0] 19.266089 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU3-0
[MCU3_0] 19.266145 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU3_0] 19.266184 s: APP: OpenVX Target kernel init ... !!!
[MCU3_0] 19.266210 s: APP: OpenVX Target kernel init ... Done !!!
[MCU3_0] 19.266236 s: APP: Init ... Done !!!
[MCU3_0] 19.266261 s: APP: Run ... !!!
[MCU3_0] 19.266283 s: IPC: Starting echo test ...
[MCU3_0] 19.270855 s: APP: Run ... Done !!!
[MCU3_0] 19.272056 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU3_0] 19.272193 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
[MCU3_0] 19.272315 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU3_0] 19.272442 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_0] 19.272622 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_0] 19.272727 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_0] 19.280708 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_0] 19.316385 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_1] 4.080544 s: CIO: Init ... Done !!!
[MCU3_1] 4.080598 s: ### CPU Frequency = 1000000000 Hz
[MCU3_1] 4.080630 s: APP: Init ... !!!
[MCU3_1] 4.080651 s: SCICLIENT: Init ... !!!
[MCU3_1] 4.080796 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU3_1] 4.080830 s: SCICLIENT: DMSC FW revision 0x8
[MCU3_1] 4.080857 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU3_1] 4.080887 s: SCICLIENT: Init ... Done !!!
[MCU3_1] 4.080910 s: MEM: Init ... !!!
[MCU3_1] 4.080943 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4800000 of size 8388608 bytes !!!
[MCU3_1] 4.080998 s: MEM: Init ... Done !!!
[MCU3_1] 4.081020 s: IPC: Init ... !!!
[MCU3_1] 4.081062 s: IPC: 11 CPUs participating in IPC !!!
[MCU3_1] 4.081100 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU3_1] 18.931466 s: IPC: HLOS is ready !!!
[MCU3_1] 18.954431 s: IPC: Init ... Done !!!
[MCU3_1] 18.954475 s: APP: Syncing with 10 CPUs ... !!!
[MCU3_1] 19.262982 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU3_1] 19.263024 s: REMOTE_SERVICE: Init ... !!!
[MCU3_1] 19.264809 s: REMOTE_SERVICE: Init ... Done !!!
[MCU3_1] 19.264870 s: VX_ZONE_INIT:Enabled
[MCU3_1] 19.264898 s: VX_ZONE_ERROR:Enabled
[MCU3_1] 19.264922 s: VX_ZONE_WARNING:Enabled
[MCU3_1] 19.266084 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU3-1
[MCU3_1] 19.266137 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU3_1] 19.266174 s: APP: OpenVX Target kernel init ... !!!
[MCU3_1] 19.266201 s: APP: OpenVX Target kernel init ... Done !!!
[MCU3_1] 19.266226 s: APP: Init ... Done !!!
[MCU3_1] 19.266249 s: APP: Run ... !!!
[MCU3_1] 19.266270 s: IPC: Starting echo test ...
[MCU3_1] 19.270840 s: APP: Run ... Done !!!
[MCU3_1] 19.272067 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU3_1] 19.272198 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[.] c7x_3[P] c7x_4[.]
[MCU3_1] 19.272329 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU3_1] 19.272536 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_1] 19.272673 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_1] 19.272778 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_1] 19.280738 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU3_1] 19.316401 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_0] 4.161614 s: CIO: Init ... Done !!!
[MCU4_0] 4.161669 s: ### CPU Frequency = 1000000000 Hz
[MCU4_0] 4.161700 s: APP: Init ... !!!
[MCU4_0] 4.161720 s: SCICLIENT: Init ... !!!
[MCU4_0] 4.161871 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU4_0] 4.161905 s: SCICLIENT: DMSC FW revision 0x8
[MCU4_0] 4.161932 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU4_0] 4.161964 s: SCICLIENT: Init ... Done !!!
[MCU4_0] 4.161987 s: UDMA: Init ... !!!
[MCU4_0] 4.163042 s: UDMA: Init ... Done !!!
[MCU4_0] 4.163077 s: MEM: Init ... !!!
[MCU4_0] 4.163110 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5000000 of size 8388608 bytes !!!
[MCU4_0] 4.163170 s: MEM: Init ... Done !!!
[MCU4_0] 4.163191 s: IPC: Init ... !!!
[MCU4_0] 4.163247 s: IPC: 11 CPUs participating in IPC !!!
[MCU4_0] 4.163287 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU4_0] 19.089517 s: IPC: HLOS is ready !!!
[MCU4_0] 19.112388 s: IPC: Init ... Done !!!
[MCU4_0] 19.112431 s: APP: Syncing with 10 CPUs ... !!!
[MCU4_0] 19.262985 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU4_0] 19.263029 s: REMOTE_SERVICE: Init ... !!!
[MCU4_0] 19.264874 s: REMOTE_SERVICE: Init ... Done !!!
[MCU4_0] 19.264913 s: FVID2: Init ... !!!
[MCU4_0] 19.264968 s: FVID2: Init ... Done !!!
[MCU4_0] 19.264993 s: VHWA: VPAC Init ... !!!
[MCU4_0] 19.265016 s: SCICLIENT: Sciclient_pmSetModuleState module=400 state=2
[MCU4_0] 19.265202 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU4_0] 19.265246 s: VHWA: LDC Init ... !!!
[MCU4_0] 19.268972 s: VHWA: LDC Init ... Done !!!
[MCU4_0] 19.269014 s: VHWA: MSC Init ... !!!
[MCU4_0] 19.277842 s: VHWA: MSC Init ... Done !!!
[MCU4_0] 19.277885 s: VHWA: NF Init ... !!!
[MCU4_0] 19.278926 s: VHWA: NF Init ... Done !!!
[MCU4_0] 19.278960 s: VHWA: VISS Init ... !!!
[MCU4_0] 19.286728 s: VHWA: VISS Init ... Done !!!
[MCU4_0] 19.286778 s: VHWA: VPAC Init ... Done !!!
[MCU4_0] 19.286816 s: VX_ZONE_INIT:Enabled
[MCU4_0] 19.286840 s: VX_ZONE_ERROR:Enabled
[MCU4_0] 19.286862 s: VX_ZONE_WARNING:Enabled
[MCU4_0] 19.287763 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC2_NF
[MCU4_0] 19.287952 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC2_LDC1
[MCU4_0] 19.288137 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC2_MSC1
[MCU4_0] 19.288334 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC2_MSC2
[MCU4_0] 19.288590 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC2_VISS1
[MCU4_0] 19.288781 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU4-0
[MCU4_0] 19.288823 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU4_0] 19.288852 s: APP: OpenVX Target kernel init ... !!!
[MCU4_0] 19.311057 s: APP: OpenVX Target kernel init ... Done !!!
[MCU4_0] 19.311097 s: VISS REMOTE SERVICE: Init ... !!!
[MCU4_0] 19.311159 s: VISS REMOTE SERVICE: Init ... Done !!!
[MCU4_0] 19.311188 s: APP: Init ... Done !!!
[MCU4_0] 19.311213 s: APP: Run ... !!!
[MCU4_0] 19.311238 s: IPC: Starting echo test ...
[MCU4_0] 19.315734 s: APP: Run ... Done !!!
[MCU4_0] 19.317151 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317274 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[P] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317382 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317490 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317595 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317700 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
[MCU4_0] 19.317805 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU4_0] 19.317907 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_1] 4.166148 s: CIO: Init ... Done !!!
[MCU4_1] 4.166202 s: ### CPU Frequency = 1000000000 Hz
[MCU4_1] 4.166234 s: APP: Init ... !!!
[MCU4_1] 4.166254 s: SCICLIENT: Init ... !!!
[MCU4_1] 4.166399 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[MCU4_1] 4.166432 s: SCICLIENT: DMSC FW revision 0x8
[MCU4_1] 4.166460 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU4_1] 4.166490 s: SCICLIENT: Init ... Done !!!
[MCU4_1] 4.166514 s: MEM: Init ... !!!
[MCU4_1] 4.166546 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5800000 of size 8388608 bytes !!!
[MCU4_1] 4.166602 s: MEM: Init ... Done !!!
[MCU4_1] 4.166623 s: IPC: Init ... !!!
[MCU4_1] 4.166666 s: IPC: 11 CPUs participating in IPC !!!
[MCU4_1] 4.166705 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU4_1] 19.240070 s: IPC: HLOS is ready !!!
[MCU4_1] 19.262898 s: IPC: Init ... Done !!!
[MCU4_1] 19.262944 s: APP: Syncing with 10 CPUs ... !!!
[MCU4_1] 19.262984 s: APP: Syncing with 10 CPUs ... Done !!!
[MCU4_1] 19.263022 s: REMOTE_SERVICE: Init ... !!!
[MCU4_1] 19.264871 s: REMOTE_SERVICE: Init ... Done !!!
[MCU4_1] 19.264926 s: VX_ZONE_INIT:Enabled
[MCU4_1] 19.264950 s: VX_ZONE_ERROR:Enabled
[MCU4_1] 19.264973 s: VX_ZONE_WARNING:Enabled
[MCU4_1] 19.266117 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU4-1
[MCU4_1] 19.266167 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU4_1] 19.266197 s: APP: OpenVX Target kernel init ... !!!
[MCU4_1] 19.266222 s: APP: OpenVX Target kernel init ... Done !!!
[MCU4_1] 19.266248 s: APP: Init ... Done !!!
[MCU4_1] 19.266272 s: APP: Run ... !!!
[MCU4_1] 19.266293 s: IPC: Starting echo test ...
[MCU4_1] 19.270862 s: APP: Run ... Done !!!
[MCU4_1] 19.271996 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[.] c7x_2[P] c7x_3[.] c7x_4[.]
[MCU4_1] 19.272118 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[.] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU4_1] 19.272223 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
[MCU4_1] 19.272330 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_1] 19.272874 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_1] 19.272981 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_1] 19.280767 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[MCU4_1] 19.316411 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 4.420841 s: CIO: Init ... Done !!!
[C7x_1 ] 4.420856 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ] 4.420868 s: APP: Init ... !!!
[C7x_1 ] 4.420876 s: SCICLIENT: Init ... !!!
[C7x_1 ] 4.421007 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[C7x_1 ] 4.421022 s: SCICLIENT: DMSC FW revision 0x8
[C7x_1 ] 4.421034 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ] 4.421045 s: SCICLIENT: Init ... Done !!!
[C7x_1 ] 4.421054 s: UDMA: Init ... !!!
[C7x_1 ] 4.422041 s: UDMA: Init ... Done !!!
[C7x_1 ] 4.422056 s: MEM: Init ... !!!
[C7x_1 ] 4.422067 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e6000000 of size 134217728 bytes !!!
[C7x_1 ] 4.422089 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 68000000 of size 3145728 bytes !!!
[C7x_1 ] 4.422107 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
[C7x_1 ] 4.422126 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[C7x_1 ] 4.422144 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ee000000 of size 134217728 bytes !!!
[C7x_1 ] 4.422163 s: MEM: Init ... Done !!!
[C7x_1 ] 4.422171 s: IPC: Init ... !!!
[C7x_1 ] 4.422186 s: IPC: 11 CPUs participating in IPC !!!
[C7x_1 ] 4.422203 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ] 17.739007 s: IPC: HLOS is ready !!!
[C7x_1 ] 17.744132 s: IPC: Init ... Done !!!
[C7x_1 ] 17.744149 s: APP: Syncing with 10 CPUs ... !!!
[C7x_1 ] 19.262985 s: APP: Syncing with 10 CPUs ... Done !!!
[C7x_1 ] 19.263016 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ] 19.263259 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ] 19.263294 s: VX_ZONE_INIT:Enabled
[C7x_1 ] 19.263310 s: VX_ZONE_ERROR:Enabled
[C7x_1 ] 19.263322 s: VX_ZONE_WARNING:Enabled
[C7x_1 ] 19.263721 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
[C7x_1 ] 19.263841 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
[C7x_1 ] 19.263912 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
[C7x_1 ] 19.263981 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
[C7x_1 ] 19.264050 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
[C7x_1 ] 19.264120 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
[C7x_1 ] 19.264191 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
[C7x_1 ] 19.264260 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
[C7x_1 ] 19.264294 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_1 ] 19.264310 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ] 19.265075 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ] 19.265093 s: APP: Init ... Done !!!
[C7x_1 ] 19.265103 s: APP: Run ... !!!
[C7x_1 ] 19.265113 s: IPC: Starting echo test ...
[C7x_1 ] 19.265307 s: APP: Run ... Done !!!
[C7x_1 ] 19.266155 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[x] c7x_3[.] c7x_4[P]
[C7x_1 ] 19.266243 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.268150 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.271773 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.272005 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.272503 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.280738 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_1 ] 19.316405 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
[C7x_2 ] 4.725892 s: CIO: Init ... Done !!!
[C7x_2 ] 4.725909 s: ### CPU Frequency = 1000000000 Hz
[C7x_2 ] 4.725922 s: APP: Init ... !!!
[C7x_2 ] 4.725932 s: SCICLIENT: Init ... !!!
[C7x_2 ] 4.726062 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[C7x_2 ] 4.726078 s: SCICLIENT: DMSC FW revision 0x8
[C7x_2 ] 4.726090 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_2 ] 4.726103 s: SCICLIENT: Init ... Done !!!
[C7x_2 ] 4.726115 s: UDMA: Init ... !!!
[C7x_2 ] 4.727109 s: UDMA: Init ... Done !!!
[C7x_2 ] 4.727123 s: MEM: Init ... !!!
[C7x_2 ] 4.727135 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 100000000 of size 134217728 bytes !!!
[C7x_2 ] 4.727159 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 69000000 of size 3145728 bytes !!!
[C7x_2 ] 4.727179 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
[C7x_2 ] 4.727197 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
[C7x_2 ] 4.727216 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 108000000 of size 134217728 bytes !!!
[C7x_2 ] 4.727236 s: MEM: Init ... Done !!!
[C7x_2 ] 4.727246 s: IPC: Init ... !!!
[C7x_2 ] 4.727263 s: IPC: 11 CPUs participating in IPC !!!
[C7x_2 ] 4.727280 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_2 ] 17.897357 s: IPC: HLOS is ready !!!
[C7x_2 ] 17.902647 s: IPC: Init ... Done !!!
[C7x_2 ] 17.902666 s: APP: Syncing with 10 CPUs ... !!!
[C7x_2 ] 19.262985 s: APP: Syncing with 10 CPUs ... Done !!!
[C7x_2 ] 19.263015 s: REMOTE_SERVICE: Init ... !!!
[C7x_2 ] 19.263267 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_2 ] 19.263297 s: VX_ZONE_INIT:Enabled
[C7x_2 ] 19.263315 s: VX_ZONE_ERROR:Enabled
[C7x_2 ] 19.263329 s: VX_ZONE_WARNING:Enabled
[C7x_2 ] 19.264363 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2
[C7x_2 ] 19.264434 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_2
[C7x_2 ] 19.264498 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_3
[C7x_2 ] 19.264566 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_4
[C7x_2 ] 19.264633 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_5
[C7x_2 ] 19.264700 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_6
[C7x_2 ] 19.264766 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_7
[C7x_2 ] 19.264850 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_8
[C7x_2 ] 19.264881 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_2 ] 19.264898 s: APP: OpenVX Target kernel init ... !!!
[C7x_2 ] 19.267250 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_2 ] 19.267273 s: APP: Init ... Done !!!
[C7x_2 ] 19.267287 s: APP: Run ... !!!
[C7x_2 ] 19.267299 s: IPC: Starting echo test ...
[C7x_2 ] 19.267426 s: APP: Run ... Done !!!
[C7x_2 ] 19.268161 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
[C7x_2 ] 19.268229 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[.]
[C7x_2 ] 19.268284 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_2 ] 19.271889 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_2 ] 19.272013 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_2 ] 19.272558 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_2 ] 19.280757 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_2 ] 19.316424 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
[C7x_3 ] 5.009537 s: CIO: Init ... Done !!!
[C7x_3 ] 5.009551 s: ### CPU Frequency = 1000000000 Hz
[C7x_3 ] 5.009563 s: APP: Init ... !!!
[C7x_3 ] 5.009571 s: SCICLIENT: Init ... !!!
[C7x_3 ] 5.009708 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[C7x_3 ] 5.009723 s: SCICLIENT: DMSC FW revision 0x8
[C7x_3 ] 5.009734 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_3 ] 5.009746 s: SCICLIENT: Init ... Done !!!
[C7x_3 ] 5.009756 s: UDMA: Init ... !!!
[C7x_3 ] 5.010782 s: UDMA: Init ... Done !!!
[C7x_3 ] 5.010796 s: MEM: Init ... !!!
[C7x_3 ] 5.010809 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 110000000 of size 134217728 bytes !!!
[C7x_3 ] 5.010830 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6a000000 of size 3145728 bytes !!!
[C7x_3 ] 5.010849 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 66800000 of size 458752 bytes !!!
[C7x_3 ] 5.010866 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 66e00000 of size 16384 bytes !!!
[C7x_3 ] 5.010884 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 118000000 of size 134217728 bytes !!!
[C7x_3 ] 5.010903 s: MEM: Init ... Done !!!
[C7x_3 ] 5.010911 s: IPC: Init ... !!!
[C7x_3 ] 5.010928 s: IPC: 11 CPUs participating in IPC !!!
[C7x_3 ] 5.010957 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_3 ] 17.995176 s: IPC: HLOS is ready !!!
[C7x_3 ] 17.999862 s: IPC: Init ... Done !!!
[C7x_3 ] 17.999881 s: APP: Syncing with 10 CPUs ... !!!
[C7x_3 ] 19.262986 s: APP: Syncing with 10 CPUs ... Done !!!
[C7x_3 ] 19.263017 s: REMOTE_SERVICE: Init ... !!!
[C7x_3 ] 19.263285 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_3 ] 19.263315 s: VX_ZONE_INIT:Enabled
[C7x_3 ] 19.263330 s: VX_ZONE_ERROR:Enabled
[C7x_3 ] 19.263343 s: VX_ZONE_WARNING:Enabled
[C7x_3 ] 19.263768 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3
[C7x_3 ] 19.263895 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_2
[C7x_3 ] 19.263972 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_3
[C7x_3 ] 19.264051 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_4
[C7x_3 ] 19.264128 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_5
[C7x_3 ] 19.264203 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_6
[C7x_3 ] 19.264285 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_7
[C7x_3 ] 19.264363 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_8
[C7x_3 ] 19.264397 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_3 ] 19.264423 s: APP: OpenVX Target kernel init ... !!!
[C7x_3 ] 19.265125 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_3 ] 19.265143 s: APP: Init ... Done !!!
[C7x_3 ] 19.265155 s: APP: Run ... !!!
[C7x_3 ] 19.265166 s: IPC: Starting echo test ...
[C7x_3 ] 19.265367 s: APP: Run ... Done !!!
[C7x_3 ] 19.266074 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[.]
[C7x_3 ] 19.266252 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.268165 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.271962 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.272049 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.272521 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.280786 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_3 ] 19.316437 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
[C7x_4 ] 5.293131 s: CIO: Init ... Done !!!
[C7x_4 ] 5.293145 s: ### CPU Frequency = 1000000000 Hz
[C7x_4 ] 5.293157 s: APP: Init ... !!!
[C7x_4 ] 5.293165 s: SCICLIENT: Init ... !!!
[C7x_4 ] 5.293306 s: SCICLIENT: DMSC FW version [8.4.5--v08.04.05 (Jolly Jellyfi]
[C7x_4 ] 5.293321 s: SCICLIENT: DMSC FW revision 0x8
[C7x_4 ] 5.293332 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_4 ] 5.293344 s: SCICLIENT: Init ... Done !!!
[C7x_4 ] 5.293353 s: UDMA: Init ... !!!
[C7x_4 ] 5.294360 s: UDMA: Init ... Done !!!
[C7x_4 ] 5.294373 s: MEM: Init ... !!!
[C7x_4 ] 5.294385 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 120000000 of size 134217728 bytes !!!
[C7x_4 ] 5.294407 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6b000000 of size 3145728 bytes !!!
[C7x_4 ] 5.294426 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 67800000 of size 458752 bytes !!!
[C7x_4 ] 5.294443 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 67e00000 of size 16384 bytes !!!
[C7x_4 ] 5.294461 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 128000000 of size 134217728 bytes !!!
[C7x_4 ] 5.294480 s: MEM: Init ... Done !!!
[C7x_4 ] 5.294489 s: IPC: Init ... !!!
[C7x_4 ] 5.294505 s: IPC: 11 CPUs participating in IPC !!!
[C7x_4 ] 5.294522 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_4 ] 18.125831 s: IPC: HLOS is ready !!!
[C7x_4 ] 18.130383 s: IPC: Init ... Done !!!
[C7x_4 ] 18.130400 s: APP: Syncing with 10 CPUs ... !!!
[C7x_4 ] 19.262986 s: APP: Syncing with 10 CPUs ... Done !!!
[C7x_4 ] 19.263023 s: REMOTE_SERVICE: Init ... !!!
[C7x_4 ] 19.263270 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_4 ] 19.263302 s: VX_ZONE_INIT:Enabled
[C7x_4 ] 19.263318 s: VX_ZONE_ERROR:Enabled
[C7x_4 ] 19.263331 s: VX_ZONE_WARNING:Enabled
[C7x_4 ] 19.263637 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4
[C7x_4 ] 19.263856 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_2
[C7x_4 ] 19.263935 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_3
[C7x_4 ] 19.264021 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_4
[C7x_4 ] 19.264103 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_5
[C7x_4 ] 19.264182 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_6
[C7x_4 ] 19.264258 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_7
[C7x_4 ] 19.264338 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_8
[C7x_4 ] 19.264366 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_4 ] 19.264387 s: APP: OpenVX Target kernel init ... !!!
[C7x_4 ] 19.265092 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_4 ] 19.265112 s: APP: Init ... Done !!!
[C7x_4 ] 19.265124 s: APP: Run ... !!!
[C7x_4 ] 19.265135 s: IPC: Starting echo test ...
[C7x_4 ] 19.265330 s: APP: Run ... Done !!!
[C7x_4 ] 19.266046 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[.] c7x_4[s]
[C7x_4 ] 19.266275 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.268172 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.271805 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.272046 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.272580 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.280769 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
[C7x_4 ] 19.316449 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
程序在原有设计的电路板上可以工作,也可以ifconfig看到千兆以太网口,该电路板在以太网千兆设计上没有改变,仅仅是内存大小变化为32G,原来是16G。在新的电路板上,我们不用RTOS板的Ethfw驱动,换用固件来运行EThfw Stack, 则可以发现设备,而且可以开通以太网并用ifconfig来测试。但是我们无法用这种方法覆盖所有的测试功能,最好还是希望Ethfw可以在RTOS上运行,并且被VisionAPPs 程序调用
