Part Number: SK-TDA4VM
你好,
运行编译好的yolov5s时会出现如下错误
libtidl_onnxrt_EP loaded 0x23ebc470
Final number of subgraphs created are : 3, - Offloaded Nodes - 196, Total Nodes - 236
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
165.858162 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
165.858182 s: VX_ZONE_INIT:Enabled
165.858185 s: VX_ZONE_ERROR:Enabled
165.858187 s: VX_ZONE_WARNING:Enabled
165.858780 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
165.859005 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
165.875596 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.875603 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.875608 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.875611 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.875614 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.875618 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.875625 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.875627 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
165.998258 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.998265 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.998268 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.998272 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.998274 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.998279 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.998284 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.998287 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
166.019533 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
166.019540 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
166.019544 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
166.019546 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
166.019549 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
166.019552 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
166.019557 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
166.019559 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
请问是哪里出问题了?
