Part Number: SK-AM62
Other Parts Discussed in Thread: HD3SS3220, INA3221, LM90, PCM3168A
你好:
如何安装自己编译的driver.ko文件?
将自己编译的driver.ko文件直接cp到SD卡的根目录下/lib/modules/5.10.168-rt83-gc1a1291911后,执行modprobe挂载驱动为什么还是提示无法找到.KO文件,有可能是什么原因?
在使用,modprobe前使用depmod,出现bad version
driver程序如下:
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/fs.h>
#include <linux/slab.h>
#include <linux/cdev.h>
#include <linux/device.h>
#include <linux/of.h>
#include <linux/of_address.h>
#include <linux/of_irq.h>
#include <linux/gpio.h>
#include <linux/of_gpio.h>
#include <linux/string.h>
#include <linux/irq.h>
#include <asm/uaccess.h>
#include <asm/io.h>
#include <linux/interrupt.h>
#include <linux/poll.h>
#include <linux/fcntl.h>
#include <linux/ide.h>
#include <linux/platform_device.h>
static int mygpio_probe(struct platform_device *dev)
printk("mygpio_probe\r\n");
return 0;
static int mygpio_remove(struct platform_device *dev)
printk("mygpio_remove\r\n");
return 0;
struct of_device_id mygpio_of_match[] = {
{.compatible = "mygpio-driver-test"},
{/*sentinel */},
struct platform_driver mydriver = {
.driver ={
.name = "mygpio-driver",
.of_match_table = mygpio_of_match,
.probe = mygpio_probe,
.remove =mygpio_remove,
/*mound driver */
static int __init my_gpio_driver_init(void)
return platform_driver_register(&mydriver);
/*umound driver*/
static void __exit my_gpio_driver_exit(void)
platform_driver_unregister(&mydriver);
module_init(my_gpio_driver_init);
module_exit(my_gpio_driver_exit);
MODULE_LICENSE("GPL v2");
MODULE_AUTHOR("wu");
尝试在内核源码中使用
sudo make ARCH=arm64 INSTALL_MOD_PATH=/media/rootfs modules_install
提示没有modules.order,将编译。KO文件时生成的modules.order复制到内核目录下后出现如下错误
ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
.ko文件并没有被install到<uname -r>x下
请看下面e2e工程师最新的回复。
I haven't built out-of-tree kernel drivers for many years, so I cannot tell exactly what is missing. The customer's driver Makefile looks okay to me, but please ask the customer to ensure
1) the SDK kernel has to be built first, and use "make modules_install" to install all kernel modules to the rootfs
2) the customer's driver Makefile seems missing "make modules_install" entry to install mytest.ko to rootfs
3) the SDK kernel Image should be copied to rootfs as well.
还请帮忙回复一下
目前使用自己makefile生成.ko文件,通过cp到/lib/modules/<uname -a>使用insmod挂载,使用modprobe出现not found in /lib/modules/uname-a
遵照之前回复,将mytest.c文件放在/driver/misc下,通过make modules 编译生成了.ko。使用make modules install 成功安装了mytest.ko,但是在linux中使用lsmod并没有找到,在/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc下使用modprobe还是出现错误如下
请看下面e2e工程师的回复。
Your description and the console log are confusing. I don't fully understand.
In general, modprobe command can only load modules which are installed by "make modules_install" command. modprobe command won't be able to find modules which are "cp"ed to the root filesystem.
The console log shows "depmod mytest.ko" failed, which generally means the running kernel Image is mismatch with the kernel module. When you do 'make modules_install" to install all the built kernel modules to the rootfs, you also have to copy the new kernel Image to the rootfs as well. Basically, the kernel image and modules on the rootfs should come from the same kernel build.
你好:还请帮回复一下
还是没可以是否漏掉了哪个环节,执行命令顺序如下:
make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- clean
make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- Image
make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- ti/k3-am625-sk.dtb
make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
sudo make ARCH=arm64 INSTALL_MOD_PATH=/home/ubuntu/rootfs modules_install
在执行make moduleinstall出现如下提示,但是.ko文件都成功出现在了rootfs中
arch/arm64/Makefile:25: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
将image和dtb都移植到SD中rootfs中,上电执行depmod还是bad version
你好:
还行麻烦帮回复一下:
在SDK下make 编译 进入linux源码下使用make install后依旧出现出现arch/arm64/Makefile:25: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
在linux中同样无法使用modprobe挂载,使用depmod出现bad version,使用系统的pci_endpoint_test.ko同样如此。不确定是我哪个步骤有问题。
唯一变化就是,使用SDK下的makefil编译后在Linux中使用depmod出现如下:
root@am62xx-evm:/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc#
root@am62xx-evm:/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc# depmod mytest
depmod: ERROR: Bad version passed mytest
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/fs/cifs/cifs.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/fs/btrfs/btrfs.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/core/snd-hwdep.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/core/snd-rawmidi.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/usb/snd-usb-audio.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/usb/snd-usbmidi-lib.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-pcm3168a.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-pcm3168a-i2c.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-tlv320aic31xx.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-tlv320aic3x.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-wcd934x.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-wm8904.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-wsa881x.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/codecs/snd-soc-simple-amplifier.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/generic/snd-soc-simple-card-utils.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/generic/snd-soc-simple-card.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/generic/snd-soc-audio-graph-card.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/sound/soc/ti/snd-soc-j721e-evm.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/samples/rpmsg/rpmsg_client_sample.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/netfilter/nf_conntrack.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/xfrm/xfrm_algo.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/xfrm/xfrm_user.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/xfrm/xfrm_ipcomp.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/ipv6/ipv6.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/wireless/cfg80211.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/bridge/bridge.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/bluetooth/bluetooth.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/sctp/sctp.ko: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.10.168-rt83-gc1a1291911/kernel/net/mac80211/mac80211.ko: Invalid argument
root@am62xx-evm:/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc# modprobe mytest.ko
modprobe: FATAL: Module mytest.ko not found in directory /lib/modules/5.10.168-rt83-gc1a1291911
root@am62xx-evm:/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc# ls
eeprom mytest.ko pci_endpoint_test.ko uacce
root@am62xx-evm:/lib/modules/5.10.168-rt83-gc1a1291911/kernel/drivers/misc# depmod pci_endpoint_test.ko
depmod: ERROR: Bad version passed pci_endpoint_test.ko
你好:
还行麻烦帮回复一下,谢谢
这是执行的所有命令:
594 history
595 export PATH=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
596 echo $PATH
597 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- clean
598 cp '/home/ubuntu/SDK/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/mytest.c' ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/
599 vi ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/Makefile
600 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
601 cd ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/
602 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
603 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- Image
604 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
605 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
606 sudo umount /media/ubuntu/root
607 sudo mount /dev/sdb2 /home/ubuntu/rootfs
608 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- ti/k3-am625-sk.dtb
609 sudo rm -f /home/ubuntu/rootfs/boot/*
610 sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/Image' /home/ubuntu/rootfs/boot
611 sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/dts/ti/k3-am625-sk.dtb' /home/ubuntu/rootfs/boot
612 sudo make ARCH=arm64 INSTALL_MOD_PATH=/home/ubuntu/rootfs modules_install
613 sudo umount /home/ubuntu/rootfs
614 history
在driver/misc/makefile中添加如下:
obj-m += mytest.o
最后还是出现bad version
完整编译日志如下:
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ history -c
594 history
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ export PATH=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ echo $PATH
/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- clean
Cleaning the Linux Kernel
make -C /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911 ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- mrproper
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911'
CLEAN arch/arm64/crypto
CLEAN arch/arm64/kernel/vdso
CLEAN certs
CLEAN drivers/firmware/efi/libstub
CLEAN drivers/scsi
CLEAN drivers/tty/vt
CLEAN drivers/video/logo
CLEAN kernel
CLEAN lib/raid6
CLEAN lib
CLEAN net/wireless
CLEAN usr
CLEAN arch/arm64/boot
CLEAN vmlinux.symvers modules-only.symvers modules.builtin modules.builtin.modinfo
CLEAN scripts/basic
CLEAN scripts/dtc
CLEAN scripts/genksyms
CLEAN scripts/kconfig
CLEAN scripts/mod
CLEAN scripts
CLEAN include/config include/generated arch/arm64/include/generated .config .version Module.symvers
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911'
Cleaning Matrix GUI
NOTHING TO DO.
Cleaning ARM Benchmarks
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3'
for dir in dhrystone whetstone linpack; do \
make -C $dir clean; \
done
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/dhrystone'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/dhrystone'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/whetstone'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/whetstone'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/linpack'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3/linpack'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/arm-benchmarks-1.3'
Cleaning AM Sysinfo
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/am-sysinfo-git'
for dir in mem_util; do \
done
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/am-sysinfo-git/mem_util'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/am-sysinfo-git/mem_util'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/am-sysinfo-git'
Cleaning OProfile Example
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/oprofile-example'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/oprofile-example'
Cleaning Matrix GUI Browser
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/matrix-gui-browser-2.0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/matrix-gui-browser-2.0'
rm -f moc_predefs.h
rm -f moc_MatrixWebView.cpp
rm -f main.o MatrixWebView.o moc_MatrixWebView.o
rm -f *~ core *.core
rm -f matrix_browser
rm -f .qmake.stash
rm -f Makefile
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/matrix-gui-browser-2.0'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/matrix-gui-browser-2.0'
Cleaning Refresh Screen
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/refresh-screen-2.0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/refresh-screen-2.0'
rm -f moc_predefs.h
rm -f moc_mainwindow.cpp
rm -f ui_mainwindow.h
rm -f main.o mainwindow.o moc_mainwindow.o
rm -f refresh_screen
rm -f .qmake.stash
rm -f Makefile
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/refresh-screen-2.0'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/refresh-screen-2.0'
Cleaning QT Thermostat App
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/qt-tstat-2.0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/qt-tstat-2.0'
rm -f Images/qrc_thermostatdemo.cpp
rm -f moc_predefs.h
rm -f moc_weatherwidget.cpp moc_thermostatwidget.cpp moc_optionswidget.cpp moc_webdata.cpp moc_awayscreen.cpp moc_mainwindow.cpp moc_schedulescreen.cpp moc_schedulepoint.cpp moc_keyboard.cpp moc_settingscreen.cpp moc_qkeyboardlineedit.cpp moc_forecastdatawidget.cpp moc_weatherdatawidget.cpp moc_webdataengine.cpp moc_openweathermapdataengine.cpp moc_wundergrounddataengine.cpp moc_remoteaccessmanager.cpp
rm -f ui_keyboard.h
rm -f main.o weatherwidget.o thermostatwidget.o optionswidget.o webdata.o awayscreen.o mainwindow.o schedulescreen.o schedulepoint.o keyboard.o settingscreen.o globalsettings.o qkeyboardlineedit.o weatherdata.o forecastdata.o forecastdatawidget.o utilities.o weatherdatawidget.o webdataengine.o openweathermapdataengine.o wundergrounddataengine.o remoteaccessmanager.o qrc_thermostatdemo.o moc_weatherwidget.o moc_thermostatwidget.o moc_optionswidget.o moc_webdata.o moc_awayscreen.o moc_mainwindow.o moc_schedulescreen.o moc_schedulepoint.o moc_keyboard.o moc_settingscreen.o moc_qkeyboardlineedit.o moc_forecastdatawidget.o moc_weatherdatawidget.o moc_webdataengine.o moc_openweathermapdataengine.o moc_wundergrounddataengine.o moc_remoteaccessmanager.o
rm -f ThermostatDemo
rm -f .qmake.stash
rm -f Makefile
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/qt-tstat-2.0'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/qt-tstat-2.0'
Cleaining U-boot for A53
make -C /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot-* CROSS_COMPILE=aarch64-none-linux-gnu- \
O=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/a53 distclean
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot-2021.01+gitAUTOINC+2ee8efd654-g2ee8efd654'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/a53'
CLEAN scripts/basic
CLEAN .config .config.old include/config.h
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/a53'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot-2021.01+gitAUTOINC+2ee8efd654-g2ee8efd654'
Cleaining U-boot for R5
make -C /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot-* CROSS_COMPILE=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-none-linux-gnueabihf- \
O=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/r5 distclean
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/r5'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/u-boot_build/r5'
Cleaning the Linux Kernel DTBs
Nothing to do
Cleaning cryptodev-linux
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/cryptodev-module-1.10'
make -C /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911 M=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/cryptodev-module-1.10 ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- clean
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911'
rm -f *~
CFLAGS= KERNEL_DIR=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911 make -C tests clean
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/cryptodev-module-1.10/tests'
rm -f *.o *~ cipher cipher-aead hmac speed async_cipher async_hmac async_speed sha_speed hashcrypt_speed fullspeed cipher-gcm cipher-aead-srtp cipher_comp hash_comp hmac_comp
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/cryptodev-module-1.10/tests'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/cryptodev-module-1.10'
Cleaning SYSFW Image
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/k3-image-gen-2022.01'
rm -f out/soc/am62x/evm/sysfw.bin-gp out/soc/am62x/evm/board-cfg.bin out/soc/am62x/evm/pm-cfg.bin out/soc/am62x/evm/rm-cfg.bin out/soc/am62x/evm/sec-cfg.bin out/soc/am62x/evm/board-cfg.o-pre-validated out/soc/am62x/evm/pm-cfg.o-pre-validated out/soc/am62x/evm/rm-cfg.o-pre-validated out/soc/am62x/evm/sec-cfg.o-pre-validated out/soc/am62x/evm/board-cfg.o.log out/soc/am62x/evm/pm-cfg.o.log out/soc/am62x/evm/rm-cfg.o.log out/soc/am62x/evm/sec-cfg.o.log
rm -f out/soc/am62x/evm/combined-sysfw-cfg.bin out/soc/am62x/evm/combined-tifs-cfg.bin out/soc/am62x/evm/combined-dm-cfg.bin
rm -f ./sysfw-am62x-evm.itb ./sysfw.itb
rm -f out/soc/am62x/evm/sysfw-am62x-evm.its
rm -f ./tiboot3-am62x-gp-evm.bin ./tiboot3.bin
rm -f ti-fs-firmware-am62x-gp-certs.bin
rm -df .
rm: cannot remove '.': Directory not empty
Makefile:261: recipe for target 'clean' failed
make[1]: [clean] Error 1 (ignored)
rm -df out/soc/am62x/evm && \
rm -df out/soc/am62x && \
rm -df out/soc && \
rm -df out
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/k3-image-gen-2022.01'
If you wish to build IPC, please install
Processor SDK RTOS live for am62xx-evm
and set TI_RTOS_PATH in Rules.make
Cleaning PRU-ICSS
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_access_const_table'
Cleaning project: PRU_access_const_table
Removing files in the "gen" directory
Finished cleaning project: PRU_access_const_table
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_access_const_table'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_ADC_onChip'
Cleaning project: PRU_ADC_onChip
Finished cleaning project: PRU_ADC_onChip
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_ADC_onChip'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Direct_Connect0'
Cleaning project: PRU_Direct_Connect0
Finished cleaning project: PRU_Direct_Connect0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Direct_Connect1'
Cleaning project: PRU_Direct_Connect1
Finished cleaning project: PRU_Direct_Connect1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Direct_Connect1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_edmaConfig'
Cleaning project: PRU_edmaConfig
Finished cleaning project: PRU_edmaConfig
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_edmaConfig'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_gpioToggle'
Cleaning project: PRU_gpioToggle
Finished cleaning project: PRU_gpioToggle
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_gpioToggle'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Hardware_UART'
Cleaning project: PRU_Hardware_UART
Finished cleaning project: PRU_Hardware_UART
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Hardware_UART'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_IEP'
Cleaning project: PRU_IEP
Finished cleaning project: PRU_IEP
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_IEP'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_MAC_Multiply_Accum'
Cleaning project: PRU_MAC_Multiply_Accum
Finished cleaning project: PRU_MAC_Multiply_Accum
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_RPMsg_Echo_Interrupt0'
Cleaning project: PRU_RPMsg_Echo_Interrupt0
Finished cleaning project: PRU_RPMsg_Echo_Interrupt0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_RPMsg_Echo_Interrupt1'
Cleaning project: PRU_RPMsg_Echo_Interrupt1
Finished cleaning project: PRU_RPMsg_Echo_Interrupt1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Halt'
Cleaning project: PRU_Halt
Finished cleaning project: PRU_Halt
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x/PRU_Halt'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am335x'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_access_const_table'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_access_const_table'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Direct_Connect1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_edmaConfig'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_edmaConfig'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_gpioToggle'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_gpioToggle'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Hardware_UART'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Hardware_UART'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_IEP'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_IEP'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt1_0'
Cleaning project: PRU_RPMsg_Echo_Interrupt1_0
Finished cleaning project: PRU_RPMsg_Echo_Interrupt1_0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt1_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt1_1'
Cleaning project: PRU_RPMsg_Echo_Interrupt1_1
Finished cleaning project: PRU_RPMsg_Echo_Interrupt1_1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt0_0'
Cleaning project: PRU_RPMsg_Echo_Interrupt0_0
Finished cleaning project: PRU_RPMsg_Echo_Interrupt0_0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt0_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt0_1'
Cleaning project: PRU_RPMsg_Echo_Interrupt0_1
Finished cleaning project: PRU_RPMsg_Echo_Interrupt0_1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_RPMsg_Echo_Interrupt0_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x/PRU_Halt'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am437x'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt1_0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt1_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt2_0'
Cleaning project: PRU_RPMsg_Echo_Interrupt2_0
Finished cleaning project: PRU_RPMsg_Echo_Interrupt2_0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt2_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt2_1'
Cleaning project: PRU_RPMsg_Echo_Interrupt2_1
Finished cleaning project: PRU_RPMsg_Echo_Interrupt2_1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_RPMsg_Echo_Interrupt2_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Direct_Connect1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x/PRU_Halt'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am572x'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt0_0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt0_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt0_1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt0_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt1_0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt1_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Direct_Connect1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g/PRU_Halt'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/k2g'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_RPMsg_Echo_Interrupt0'
Removing files in the "gen/icssg0" directory
Removing files in the "gen/icssg1" directory
Removing files in the "gen/icssg2" directory
Removing the generated "gen" directory
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_RPMsg_Echo_Interrupt0'
Cleaning project: RTU_RPMsg_Echo_Interrupt0
Finished cleaning project: RTU_RPMsg_Echo_Interrupt0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_RPMsg_Echo_Interrupt1'
Cleaning project: RTU_RPMsg_Echo_Interrupt1
Finished cleaning project: RTU_RPMsg_Echo_Interrupt1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Halt'
Removing files in the "gen/PRU0" directory
Removing files in the "gen/PRU1" directory
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_Halt'
Cleaning project: RTU_Halt
Removing files in the "gen/RTU0" directory
Removing files in the "gen/RTU1" directory
Finished cleaning project: RTU_Halt
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/TX_PRU_Halt'
Cleaning project: TX_PRU_Halt
Removing files in the "gen/TX_PRU0" directory
Removing files in the "gen/TX_PRU1" directory
Finished cleaning project: TX_PRU_Halt
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/TX_PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_MAC_Multiply_Accum'
Cleaning project: RTU_MAC_Multiply_Accum
Finished cleaning project: RTU_MAC_Multiply_Accum
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/RTU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x/PRU_Direct_Connect1'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am65x'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_RPMsg_Echo_Interrupt0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_RPMsg_Echo_Interrupt0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/RTU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/TX_PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e/TX_PRU_Halt'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/j721e'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_RPMsg_Echo_Interrupt0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/TX_PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/TX_PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/RTU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x/PRU_Direct_Connect1'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am64x'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_RPMsg_Echo_Interrupt0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_MAC_Multiply_Accum'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_MAC_Multiply_Accum'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Direct_Connect0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Direct_Connect0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Direct_Connect1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x/PRU_Direct_Connect1'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples/am62x'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/examples'
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Audio'
Cleaning project: PRU_Audio
Finished cleaning project: PRU_Audio
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Audio'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Hardware_UART'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Hardware_UART'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_HDQ_TempSensor0'
Cleaning project: PRU_HDQ_TempSensor0
Finished cleaning project: PRU_HDQ_TempSensor0
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_HDQ_TempSensor0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_HDQ_TempSensor1'
Cleaning project: PRU_HDQ_TempSensor1
Finished cleaning project: PRU_HDQ_TempSensor1
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_HDQ_TempSensor1'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_LED0'
Cleaning project: PRU_LED0
Finished cleaning project: PRU_LED0
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_LED0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_LED1'
Cleaning project: PRU_LED1
Finished cleaning project: PRU_LED1
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_LED1'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_RPMsg_LED0'
Cleaning project: PRU_RPMsg_LED0
Finished cleaning project: PRU_RPMsg_LED0
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_RPMsg_LED0'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Switch'
Cleaning project: PRU_Switch
Finished cleaning project: PRU_Switch
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw/PRU_Switch'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/pru_cape/pru_fw'
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/lib/src'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/lib/src/rpmsg_lib'
Cleaning project: rpmsg_lib
Finished cleaning project: rpmsg_lib
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/lib/src/rpmsg_lib'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/lib/src'
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am335x'
Cleaning project: am335x
Finished cleaning project: am335x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am335x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am437x'
Cleaning project: am437x
Finished cleaning project: am437x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am437x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am572x'
Cleaning project: am572x
Finished cleaning project: am572x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am572x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am62x'
Cleaning project: am62x
Finished cleaning project: am62x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am62x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am64x'
Cleaning project: am64x
Finished cleaning project: am64x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am64x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am65x'
Cleaning project: am65x
Finished cleaning project: am65x
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/assembly_code/solution/am65x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am335x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am335x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am437x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am437x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am572x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am572x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am62x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am62x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am64x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am64x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am65x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_assembly/solution/am65x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am335x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am335x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am437x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am437x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am572x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am572x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am62x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am62x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am64x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am64x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am65x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_and_inline_assembly/solution/am65x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am335x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am335x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am437x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am437x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am572x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am572x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am62x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am62x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am64x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am64x'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am65x'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs/c_code/solution/am65x'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Getting_Started_Labs'
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_1/solution/toggle_led'
Cleaning project: toggle_led
Finished cleaning project: toggle_led
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_1/solution/toggle_led'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_2/solution/button_led_0'
Cleaning project: button_led_0
Finished cleaning project: button_led_0
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_2/solution/button_led_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_2/solution/button_led_1'
Cleaning project: button_led_1
Finished cleaning project: button_led_1
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_2/solution/button_led_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_3/solution/PRU_HDQ_TempSensor0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_3/solution/PRU_HDQ_TempSensor0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_3/solution/PRU_HDQ_TempSensor1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_3/solution/PRU_HDQ_TempSensor1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_4/solution/button_led_0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_4/solution/button_led_0'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_4/solution/button_led_1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_4/solution/button_led_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am335x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am335x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am437x/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am437x/PRU_RPMsg_Echo_Interrupt1_1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am572x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am572x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am64x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am64x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am65x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am65x/PRU_RPMsg_Echo_Interrupt1'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am335x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am335x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am437x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am437x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am572x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am572x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am64x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am64x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am65x/PRU_Halt'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_5/solution/am65x/PRU_Halt'
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_6/solution/PRU_RPMsg_LED0'
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs/lab_6/solution/PRU_RPMsg_LED0'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs/Hands_on_Labs'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/example-applications/pru-icss-6.1.0/labs'
Cleaning ti-img-rogue-driver
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109'
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/amba: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/avf: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/bcma: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/byteorder: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/can: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/ceph: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/clk: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/crush: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/decompress: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/device: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/dma: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/dsa: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/extcon: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/firmware: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/fpga: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/fsl: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/gpio: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/greybus: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/hsi: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/i3c: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/iio: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/input: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/irqchip: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/isdn: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/lockd: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mailbox: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mdio: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mfd: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mlx4: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mlx5: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mmc: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mtd: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/mux: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/net: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/netfilter: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/netfilter_arp: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/netfilter_bridge: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/netfilter_ipv4: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/netfilter_ipv6: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/pcs: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/perf: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/phy: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/pinctrl: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/platform_data: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/power: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/qed: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/raid: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/regulator: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/remoteproc: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/reset: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/rpmsg: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/rpmsg-remotedev: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/rtc: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/sched: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/soc: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/soundwire: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/spi: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/ssb: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/sunrpc: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/ulpi: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/unaligned: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/usb: Is a directory
grep: /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/include/linux/wimax: Is a directory
RM binary_am62_linux_wayland_release/target_neutral binary_am62_linux_wayland_release/doc
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109'
Cleaning signed images and fitImage
cd /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/dts; \
for DTB in ti/k3-am625-sk.dtb ti/k3-am625-skeleton.dtb ti/k3-am625-sk-lpmdemo.dtb ti/k3-am625-sk-csi2-ov5640.dtbo ti/k3-am625-sk-csi2-tevi-ov5640.dtbo ti/k3-am625-sk-ecap-capture.dtbo ti/k3-am625-sk-hdmi-audio.dtbo ti/k3-am625-sk-mcan.dtbo ti/k3-am625-sk-oldi-panel.dtbo ; do \
rm -rf $DTB.sec; \
done;
cd /home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911; rm -rf linux.bin.sec fitImage
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ cp '/home/ubuntu/SDK/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/mytest.c' ./
02ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42-Linux-x86-Install.bin
bin/
board-support/
docs/
filesystem/
.gdbinit
linux-devkit/
linux-devkit.sh
Makefile
Make-kernel.shell
Rules.make
setup.sh
.targetfs
targetNFS/
targetNFS.07072023_12.50/
targetNFS.07072023_13.34/
targetNFS.07212023_10.19/
.tftproot
Ti-compilation-path.shell
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ cp '/home/ubuntu/SDK/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/mytest.c' ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ vi ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/
ad525x_dpot.c fastrpc.c ocxl/
ad525x_dpot.h genwqe/ pch_phub.c
ad525x_dpot-i2c.c habanalabs/ pci_endpoint_test.c
ad525x_dpot-spi.c hisi_hikey_usb.c phantom.c
altera-stapl/ hmc6352.c pti.c
apds9802als.c hpilo.c pvpanic.c
apds990x.c hpilo.h qcom-coincell.c
atmel-ssc.c ibmasm/ sgi-gru/
atmel_tclib.c ibmvmc.c sgi-xp/
bh1770glc.c ibmvmc.h sram.c
c2port/ ics932s401.c sram-dma-heap.c
cardreader/ isl29003.c sram-exec.c
cb710/ isl29020.c sram.h
cs5535-mfgpt.c Kconfig tifm_7xx1.c
cxl/ kgdbts.c tifm_core.c
dma-buf-phys.c lattice-ecp3-config.c ti-st/
ds1682.c lis3lv02d/ tsl2550.c
dummy-irq.c lkdtm/ uacce/
echo/ Makefile vmw_balloon.c
eeprom/ mei/ vmw_vmci/
enclosure.c mytest.c xilinx_sdfec.c
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ vi ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/Makefile
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
make: *** No rule to make target 'tisdk_am62xx-evm-rt_defconfig'. Stop.
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42$ cd ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTCC scripts/kconfig/util.o
HOSTLD scripts/kconfig/conf
# configuration written to .config
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- Image
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/dtc/libfdt/fdt.o
HOSTCC scripts/dtc/libfdt/fdt_ro.o
HOSTCC scripts/dtc/libfdt/fdt_wip.o
HOSTCC scripts/dtc/libfdt/fdt_sw.o
HOSTCC scripts/dtc/libfdt/fdt_rw.o
HOSTCC scripts/dtc/libfdt/fdt_strerror.o
HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o
HOSTCC scripts/dtc/libfdt/fdt_addresses.o
HOSTCC scripts/dtc/libfdt/fdt_overlay.o
HOSTCC scripts/dtc/fdtoverlay.o
HOSTLD scripts/dtc/fdtoverlay
HOSTCC scripts/genksyms/genksyms.o
YACC scripts/genksyms/parse.tab.[ch]
HOSTCC scripts/genksyms/parse.tab.o
LEX scripts/genksyms/lex.lex.c
HOSTCC scripts/genksyms/lex.lex.o
HOSTLD scripts/genksyms/genksyms
HOSTCC scripts/kallsyms
HOSTCC scripts/sorttable
HOSTCC scripts/asn1_compiler
HOSTCC scripts/extract-cert
WRAP arch/arm64/include/generated/uapi/asm/kvm_para.h
WRAP arch/arm64/include/generated/uapi/asm/errno.h
WRAP arch/arm64/include/generated/uapi/asm/ioctl.h
WRAP arch/arm64/include/generated/uapi/asm/ioctls.h
WRAP arch/arm64/include/generated/uapi/asm/ipcbuf.h
WRAP arch/arm64/include/generated/uapi/asm/msgbuf.h
WRAP arch/arm64/include/generated/uapi/asm/poll.h
WRAP arch/arm64/include/generated/uapi/asm/resource.h
WRAP arch/arm64/include/generated/uapi/asm/sembuf.h
WRAP arch/arm64/include/generated/uapi/asm/shmbuf.h
WRAP arch/arm64/include/generated/uapi/asm/siginfo.h
WRAP arch/arm64/include/generated/uapi/asm/socket.h
WRAP arch/arm64/include/generated/uapi/asm/sockios.h
WRAP arch/arm64/include/generated/uapi/asm/stat.h
WRAP arch/arm64/include/generated/uapi/asm/swab.h
WRAP arch/arm64/include/generated/uapi/asm/termbits.h
WRAP arch/arm64/include/generated/uapi/asm/termios.h
WRAP arch/arm64/include/generated/uapi/asm/types.h
WRAP arch/arm64/include/generated/asm/early_ioremap.h
WRAP arch/arm64/include/generated/asm/mcs_spinlock.h
WRAP arch/arm64/include/generated/asm/qrwlock.h
WRAP arch/arm64/include/generated/asm/qspinlock.h
WRAP arch/arm64/include/generated/asm/set_memory.h
WRAP arch/arm64/include/generated/asm/user.h
WRAP arch/arm64/include/generated/asm/bugs.h
WRAP arch/arm64/include/generated/asm/delay.h
WRAP arch/arm64/include/generated/asm/div64.h
WRAP arch/arm64/include/generated/asm/dma-mapping.h
WRAP arch/arm64/include/generated/asm/dma.h
WRAP arch/arm64/include/generated/asm/emergency-restart.h
WRAP arch/arm64/include/generated/asm/hw_irq.h
WRAP arch/arm64/include/generated/asm/irq_regs.h
WRAP arch/arm64/include/generated/asm/kdebug.h
WRAP arch/arm64/include/generated/asm/kmap_size.h
WRAP arch/arm64/include/generated/asm/local.h
WRAP arch/arm64/include/generated/asm/local64.h
WRAP arch/arm64/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm64/include/generated/asm/mmiowb.h
WRAP arch/arm64/include/generated/asm/msi.h
WRAP arch/arm64/include/generated/asm/rwonce.h
WRAP arch/arm64/include/generated/asm/serial.h
WRAP arch/arm64/include/generated/asm/switch_to.h
WRAP arch/arm64/include/generated/asm/trace_clock.h
WRAP arch/arm64/include/generated/asm/unaligned.h
WRAP arch/arm64/include/generated/asm/vga.h
UPD include/config/kernel.release
UPD include/generated/uapi/linux/version.h
UPD include/generated/utsrelease.h
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/modpost.o
CC scripts/mod/devicetable-offsets.s
UPD scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
CC kernel/bounds.s
UPD include/generated/bounds.h
UPD include/generated/timeconst.h
CC arch/arm64/kernel/asm-offsets.s
UPD include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CALL scripts/atomic/check-atomics.sh
LDS arch/arm64/kernel/vdso/vdso.lds
CC arch/arm64/kernel/vdso/vgettimeofday.o
AS arch/arm64/kernel/vdso/note.o
AS arch/arm64/kernel/vdso/sigreturn.o
LD arch/arm64/kernel/vdso/vdso.so.dbg
VDSOSYM include/generated/vdso-offsets.h
CC init/main.o
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
CC init/do_mounts.o
CC init/do_mounts_rd.o
CC init/do_mounts_initrd.o
CC init/initramfs.o
CC init/calibrate.o
CC init/init_task.o
AR init/built-in.a
HOSTCC usr/gen_init_cpio
GEN usr/initramfs_data.cpio
SHIPPED usr/initramfs_inc_data
AS usr/initramfs_data.o
AR usr/built-in.a
OBJCOPY arch/arm64/kernel/vdso/vdso.so
AS arch/arm64/kernel/vdso/vdso.o
AR arch/arm64/kernel/vdso/built-in.a
AR arch/arm64/kernel/probes/built-in.a
AS arch/arm64/kernel/head.o
LDS arch/arm64/kernel/vmlinux.lds
CC arch/arm64/kernel/debug-monitors.o
AS arch/arm64/kernel/entry.o
CC arch/arm64/kernel/irq.o
CC arch/arm64/kernel/fpsimd.o
CC arch/arm64/kernel/entry-common.o
AS arch/arm64/kernel/entry-fpsimd.o
CC arch/arm64/kernel/process.o
CC arch/arm64/kernel/ptrace.o
CC arch/arm64/kernel/setup.o
CC arch/arm64/kernel/signal.o
CC arch/arm64/kernel/sys.o
CC arch/arm64/kernel/stacktrace.o
CC arch/arm64/kernel/time.o
CC arch/arm64/kernel/traps.o
CC arch/arm64/kernel/io.o
CC arch/arm64/kernel/vdso.o
AS arch/arm64/kernel/hyp-stub.o
CC arch/arm64/kernel/psci.o
CC arch/arm64/kernel/cpu_ops.o
CC arch/arm64/kernel/insn.o
CC arch/arm64/kernel/return_address.o
CC arch/arm64/kernel/cpuinfo.o
CC arch/arm64/kernel/cpu_errata.o
CC arch/arm64/kernel/cpufeature.o
CC arch/arm64/kernel/alternative.o
CC arch/arm64/kernel/cacheinfo.o
CC arch/arm64/kernel/smp.o
CC arch/arm64/kernel/smp_spin_table.o
CC arch/arm64/kernel/topology.o
AS arch/arm64/kernel/smccc-call.o
CC arch/arm64/kernel/syscall.o
CC arch/arm64/kernel/proton-pack.o
CC arch/arm64/kernel/sys32.o
CC arch/arm64/kernel/signal32.o
CC arch/arm64/kernel/sys_compat.o
AS arch/arm64/kernel/sigreturn32.o
AS arch/arm64/kernel/kuser32.o
CC arch/arm64/kernel/module.o
CC arch/arm64/kernel/module-plts.o
CC arch/arm64/kernel/perf_regs.o
CC arch/arm64/kernel/perf_callchain.o
CC arch/arm64/kernel/perf_event.o
CC arch/arm64/kernel/hw_breakpoint.o
CC arch/arm64/kernel/jump_label.o
CC arch/arm64/kernel/efi.o
AS arch/arm64/kernel/efi-entry.o
OBJCOPY arch/arm64/kernel/efi-entry.stub.o
AS arch/arm64/kernel/efi-rt-wrapper.o
CC arch/arm64/kernel/pci.o
CC arch/arm64/kernel/kaslr.o
CC arch/arm64/kernel/machine_kexec.o
AS arch/arm64/kernel/relocate_kernel.o
AS arch/arm64/kernel/cpu-reset.o
CC arch/arm64/kernel/machine_kexec_file.o
CC arch/arm64/kernel/kexec_image.o
CC arch/arm64/kernel/crash_core.o
CC arch/arm64/kernel/pointer_auth.o
CC arch/arm64/kernel/mte.o
AR arch/arm64/kernel/built-in.a
CC arch/arm64/mm/dma-mapping.o
CC arch/arm64/mm/extable.o
CC arch/arm64/mm/fault.o
CC arch/arm64/mm/init.o
AS arch/arm64/mm/cache.o
CC arch/arm64/mm/copypage.o
CC arch/arm64/mm/flush.o
CC arch/arm64/mm/ioremap.o
CC arch/arm64/mm/mmap.o
CC arch/arm64/mm/pgd.o
CC arch/arm64/mm/mmu.o
CC arch/arm64/mm/context.o
AS arch/arm64/mm/proc.o
CC arch/arm64/mm/pageattr.o
CC arch/arm64/mm/hugetlbpage.o
CC arch/arm64/mm/mteswap.o
AR arch/arm64/mm/built-in.a
CC arch/arm64/net/bpf_jit_comp.o
AR arch/arm64/net/built-in.a
CC arch/arm64/crypto/sha1-ce-glue.o
AS arch/arm64/crypto/sha1-ce-core.o
CC arch/arm64/crypto/sha2-ce-glue.o
AS arch/arm64/crypto/sha2-ce-core.o
CC arch/arm64/crypto/ghash-ce-glue.o
AS arch/arm64/crypto/ghash-ce-core.o
AS arch/arm64/crypto/aes-ce-core.o
CC arch/arm64/crypto/aes-ce-glue.o
CC arch/arm64/crypto/aes-ce-ccm-glue.o
AS arch/arm64/crypto/aes-ce-ccm-core.o
CC arch/arm64/crypto/aes-glue-ce.o
AS arch/arm64/crypto/aes-ce.o
CC arch/arm64/crypto/sha256-glue.o
SHIPPED arch/arm64/crypto/sha256-core.S
AS arch/arm64/crypto/sha256-core.o
AS arch/arm64/crypto/aes-cipher-core.o
CC arch/arm64/crypto/aes-cipher-glue.o
AR arch/arm64/crypto/built-in.a
AR arch/arm64/built-in.a
CC kernel/sched/core.o
CC kernel/sched/loadavg.o
CC kernel/sched/clock.o
CC kernel/sched/cputime.o
CC kernel/sched/idle.o
CC kernel/sched/fair.o
CC kernel/sched/rt.o
CC kernel/sched/deadline.o
CC kernel/sched/wait.o
CC kernel/sched/wait_bit.o
CC kernel/sched/swait.o
CC kernel/sched/completion.o
CC kernel/sched/cpupri.o
CC kernel/sched/cpudeadline.o
CC kernel/sched/topology.o
CC kernel/sched/stop_task.o
CC kernel/sched/pelt.o
CC kernel/sched/autogroup.o
CC kernel/sched/stats.o
CC kernel/sched/debug.o
CC kernel/sched/cpuacct.o
CC kernel/sched/membarrier.o
CC kernel/sched/isolation.o
AR kernel/sched/built-in.a
CC kernel/locking/semaphore.o
CC kernel/locking/rwsem.o
CC kernel/locking/percpu-rwsem.o
CC kernel/locking/spinlock.o
CC kernel/locking/qspinlock.o
CC kernel/locking/rtmutex.o
CC kernel/locking/mutex-rt.o
CC kernel/locking/rwsem-rt.o
CC kernel/locking/rwlock-rt.o
AR kernel/locking/built-in.a
CC kernel/power/qos.o
CC kernel/power/main.o
CC kernel/power/process.o
CC kernel/power/poweroff.o
AR kernel/power/built-in.a
CC kernel/printk/printk.o
CC kernel/printk/printk_ringbuffer.o
AR kernel/printk/built-in.a
CC kernel/irq/irqdesc.o
CC kernel/irq/handle.o
CC kernel/irq/manage.o
CC kernel/irq/spurious.o
CC kernel/irq/resend.o
CC kernel/irq/chip.o
CC kernel/irq/dummychip.o
CC kernel/irq/devres.o
CC kernel/irq/autoprobe.o
CC kernel/irq/irqdomain.o
CC kernel/irq/proc.o
CC kernel/irq/cpuhotplug.o
CC kernel/irq/msi.o
CC kernel/irq/ipi.o
CC kernel/irq/affinity.o
AR kernel/irq/built-in.a
CC kernel/rcu/update.o
CC kernel/rcu/sync.o
CC kernel/rcu/srcutree.o
CC kernel/rcu/tree.o
CC kernel/rcu/rcu_segcblist.o
AR kernel/rcu/built-in.a
AR kernel/livepatch/built-in.a
CC kernel/dma/mapping.o
CC kernel/dma/direct.o
CC kernel/dma/ops_helpers.o
CC kernel/dma/dummy.o
CC kernel/dma/contiguous.o
CC kernel/dma/coherent.o
CC kernel/dma/swiotlb.o
CC kernel/dma/pool.o
CC kernel/dma/remap.o
AR kernel/dma/built-in.a
AR kernel/entry/built-in.a
CC kernel/time/time.o
CC kernel/time/timer.o
CC kernel/time/hrtimer.o
CC kernel/time/timekeeping.o
CC kernel/time/ntp.o
CC kernel/time/clocksource.o
CC kernel/time/jiffies.o
CC kernel/time/timer_list.o
CC kernel/time/timeconv.o
CC kernel/time/timecounter.o
CC kernel/time/alarmtimer.o
CC kernel/time/posix-timers.o
CC kernel/time/posix-cpu-timers.o
CC kernel/time/posix-clock.o
CC kernel/time/itimer.o
CC kernel/time/clockevents.o
CC kernel/time/tick-common.o
CC kernel/time/tick-broadcast.o
CC kernel/time/tick-broadcast-hrtimer.o
CC kernel/time/sched_clock.o
CC kernel/time/tick-oneshot.o
CC kernel/time/tick-sched.o
CC kernel/time/vsyscall.o
CC kernel/time/timekeeping_debug.o
CC kernel/time/namespace.o
AR kernel/time/built-in.a
CC kernel/futex/core.o
AR kernel/futex/built-in.a
CC kernel/cgroup/cgroup.o
CC kernel/cgroup/rstat.o
CC kernel/cgroup/namespace.o
CC kernel/cgroup/cgroup-v1.o
CC kernel/cgroup/freezer.o
CC kernel/cgroup/legacy_freezer.o
CC kernel/cgroup/pids.o
CC kernel/cgroup/cpuset.o
AR kernel/cgroup/built-in.a
CC kernel/trace/trace_clock.o
AR kernel/trace/built-in.a
CC kernel/bpf/core.o
CC kernel/bpf/syscall.o
CC kernel/bpf/verifier.o
CC kernel/bpf/inode.o
CC kernel/bpf/helpers.o
CC kernel/bpf/tnum.o
CC kernel/bpf/bpf_iter.o
CC kernel/bpf/map_iter.o
CC kernel/bpf/task_iter.o
CC kernel/bpf/prog_iter.o
CC kernel/bpf/hashtab.o
CC kernel/bpf/arraymap.o
CC kernel/bpf/percpu_freelist.o
CC kernel/bpf/bpf_lru_list.o
CC kernel/bpf/lpm_trie.o
CC kernel/bpf/map_in_map.o
CC kernel/bpf/local_storage.o
CC kernel/bpf/queue_stack_maps.o
CC kernel/bpf/ringbuf.o
CC kernel/bpf/disasm.o
CC kernel/bpf/trampoline.o
CC kernel/bpf/btf.o
CC kernel/bpf/dispatcher.o
CC kernel/bpf/devmap.o
CC kernel/bpf/cpumap.o
CC kernel/bpf/bpf_local_storage.o
CC kernel/bpf/offload.o
CC kernel/bpf/net_namespace.o
CC kernel/bpf/stackmap.o
CC kernel/bpf/cgroup.o
CC kernel/bpf/reuseport_array.o
CC kernel/bpf/bpf_struct_ops.o
AR kernel/bpf/built-in.a
CC kernel/events/core.o
CC kernel/events/ring_buffer.o
CC kernel/events/callchain.o
CC kernel/events/hw_breakpoint.o
AR kernel/events/built-in.a
CC kernel/fork.o
CC kernel/exec_domain.o
CC kernel/panic.o
CC kernel/cpu.o
CC kernel/exit.o
CC kernel/softirq.o
CC kernel/resource.o
CC kernel/sysctl.o
CC kernel/capability.o
CC kernel/ptrace.o
CC kernel/user.o
CC kernel/signal.o
CC kernel/sys.o
CC kernel/umh.o
CC kernel/workqueue.o
CC kernel/pid.o
CC kernel/task_work.o
CC kernel/extable.o
CC kernel/params.o
CC kernel/kthread.o
CC kernel/sys_ni.o
CC kernel/nsproxy.o
CC kernel/notifier.o
CC kernel/ksysfs.o
CC kernel/cred.o
CC kernel/reboot.o
CC kernel/async.o
CC kernel/range.o
CC kernel/smpboot.o
CC kernel/ucount.o
CC kernel/regset.o
CC kernel/kmod.o
CC kernel/groups.o
CC kernel/kcmp.o
CC kernel/freezer.o
CC kernel/smp.o
CC kernel/uid16.o
CC kernel/module.o
CC kernel/kallsyms.o
CC kernel/acct.o
CC kernel/crash_core.o
CC kernel/kexec_core.o
CC kernel/kexec_file.o
CC kernel/compat.o
CC kernel/utsname.o
CC kernel/user_namespace.o
CC kernel/pid_namespace.o
UPD kernel/config_data
GZIP kernel/config_data.gz
CC kernel/configs.o
CC kernel/stop_machine.o
CC kernel/seccomp.o
CC kernel/utsname_sysctl.o
CC kernel/irq_work.o
CC kernel/jump_label.o
CC kernel/iomem.o
CC kernel/rseq.o
AR kernel/built-in.a
CC certs/system_keyring.o
EXTRACT_CERTS
AS certs/system_certificates.o
CC certs/common.o
AR certs/built-in.a
CC mm/filemap.o
CC mm/mempool.o
CC mm/oom_kill.o
CC mm/fadvise.o
CC mm/maccess.o
CC mm/page-writeback.o
CC mm/readahead.o
CC mm/swap.o
CC mm/truncate.o
CC mm/vmscan.o
CC mm/shmem.o
CC mm/util.o
CC mm/mmzone.o
CC mm/vmstat.o
CC mm/backing-dev.o
CC mm/mm_init.o
CC mm/percpu.o
CC mm/slab_common.o
CC mm/compaction.o
CC mm/vmacache.o
CC mm/interval_tree.o
CC mm/list_lru.o
CC mm/workingset.o
CC mm/debug.o
CC mm/gup.o
CC mm/highmem.o
CC mm/memory.o
CC mm/mincore.o
CC mm/mlock.o
CC mm/mmap.o
CC mm/mmu_gather.o
CC mm/mprotect.o
CC mm/mremap.o
CC mm/msync.o
CC mm/page_vma_mapped.o
CC mm/pagewalk.o
CC mm/pgtable-generic.o
CC mm/rmap.o
CC mm/vmalloc.o
CC mm/ioremap.o
CC mm/process_vm_access.o
CC mm/page_alloc.o
CC mm/init-mm.o
CC mm/memblock.o
CC mm/madvise.o
CC mm/page_io.o
CC mm/swap_state.o
CC mm/swapfile.o
CC mm/swap_slots.o
CC mm/dmapool.o
CC mm/hugetlb.o
CC mm/sparse.o
CC mm/sparse-vmemmap.o
CC mm/ksm.o
CC mm/slub.o
CC mm/memtest.o
CC mm/migrate.o
CC mm/page_counter.o
CC mm/memcontrol.o
CC mm/vmpressure.o
CC mm/swap_cgroup.o
CC mm/hugetlb_cgroup.o
CC mm/memory-failure.o
CC mm/page_isolation.o
CC mm/early_ioremap.o
CC mm/cma.o
CC mm/balloon_compaction.o
CC mm/frame_vector.o
CC mm/memfd.o
CC mm/page_reporting.o
AR mm/built-in.a
CC fs/notify/dnotify/dnotify.o
AR fs/notify/dnotify/built-in.a
CC fs/notify/inotify/inotify_fsnotify.o
CC fs/notify/inotify/inotify_user.o
AR fs/notify/inotify/built-in.a
CC fs/notify/fanotify/fanotify.o
CC fs/notify/fanotify/fanotify_user.o
AR fs/notify/fanotify/built-in.a
CC fs/notify/fsnotify.o
CC fs/notify/notification.o
CC fs/notify/group.o
CC fs/notify/mark.o
CC fs/notify/fdinfo.o
AR fs/notify/built-in.a
CC fs/nfs_common/grace.o
CC fs/nfs_common/nfs_ssc.o
AR fs/nfs_common/built-in.a
CC fs/iomap/trace.o
CC fs/iomap/apply.o
CC fs/iomap/buffered-io.o
CC fs/iomap/direct-io.o
CC fs/iomap/fiemap.o
CC fs/iomap/seek.o
CC fs/iomap/swapfile.o
AR fs/iomap/built-in.a
CC fs/quota/dquot.o
CC fs/quota/quota.o
CC fs/quota/kqid.o
AR fs/quota/built-in.a
CC fs/proc/task_mmu.o
CC fs/proc/inode.o
CC fs/proc/root.o
CC fs/proc/base.o
CC fs/proc/generic.o
CC fs/proc/array.o
CC fs/proc/fd.o
CC fs/proc/proc_tty.o
CC fs/proc/cmdline.o
CC fs/proc/consoles.o
CC fs/proc/cpuinfo.o
CC fs/proc/devices.o
CC fs/proc/interrupts.o
CC fs/proc/loadavg.o
CC fs/proc/meminfo.o
CC fs/proc/stat.o
CC fs/proc/uptime.o
CC fs/proc/util.o
CC fs/proc/version.o
CC fs/proc/softirqs.o
CC fs/proc/namespaces.o
CC fs/proc/self.o
CC fs/proc/thread_self.o
CC fs/proc/proc_sysctl.o
CC fs/proc/proc_net.o
CC fs/proc/kmsg.o
CC fs/proc/page.o
AR fs/proc/built-in.a
CC fs/kernfs/mount.o
CC fs/kernfs/inode.o
CC fs/kernfs/dir.o
CC fs/kernfs/file.o
CC fs/kernfs/symlink.o
AR fs/kernfs/built-in.a
CC fs/sysfs/file.o
CC fs/sysfs/dir.o
CC fs/sysfs/symlink.o
CC fs/sysfs/mount.o
CC fs/sysfs/group.o
AR fs/sysfs/built-in.a
CC fs/configfs/inode.o
CC fs/configfs/file.o
CC fs/configfs/dir.o
CC fs/configfs/symlink.o
CC fs/configfs/mount.o
CC fs/configfs/item.o
AR fs/configfs/built-in.a
CC fs/devpts/inode.o
AR fs/devpts/built-in.a
CC fs/ext4/balloc.o
CC fs/ext4/bitmap.o
CC fs/ext4/block_validity.o
CC fs/ext4/dir.o
CC fs/ext4/ext4_jbd2.o
CC fs/ext4/extents.o
CC fs/ext4/extents_status.o
CC fs/ext4/file.o
CC fs/ext4/fsmap.o
CC fs/ext4/fsync.o
CC fs/ext4/hash.o
CC fs/ext4/ialloc.o
CC fs/ext4/indirect.o
CC fs/ext4/inline.o
CC fs/ext4/inode.o
CC fs/ext4/ioctl.o
CC fs/ext4/mballoc.o
CC fs/ext4/migrate.o
CC fs/ext4/mmp.o
CC fs/ext4/move_extent.o
CC fs/ext4/namei.o
CC fs/ext4/page-io.o
CC fs/ext4/readpage.o
CC fs/ext4/resize.o
CC fs/ext4/super.o
CC fs/ext4/symlink.o
CC fs/ext4/sysfs.o
CC fs/ext4/xattr.o
CC fs/ext4/xattr_hurd.o
CC fs/ext4/xattr_trusted.o
CC fs/ext4/xattr_user.o
CC fs/ext4/fast_commit.o
CC fs/ext4/acl.o
CC fs/ext4/xattr_security.o
AR fs/ext4/built-in.a
CC fs/ext2/balloc.o
CC fs/ext2/dir.o
CC fs/ext2/file.o
CC fs/ext2/ialloc.o
CC fs/ext2/inode.o
CC fs/ext2/ioctl.o
CC fs/ext2/namei.o
CC fs/ext2/super.o
CC fs/ext2/symlink.o
AR fs/ext2/built-in.a
CC fs/jbd2/transaction.o
CC fs/jbd2/commit.o
CC fs/jbd2/recovery.o
CC fs/jbd2/checkpoint.o
CC fs/jbd2/revoke.o
CC fs/jbd2/journal.o
AR fs/jbd2/built-in.a
CC fs/squashfs/block.o
CC fs/squashfs/cache.o
CC fs/squashfs/dir.o
CC fs/squashfs/export.o
CC fs/squashfs/file.o
CC fs/squashfs/fragment.o
CC fs/squashfs/id.o
CC fs/squashfs/inode.o
CC fs/squashfs/namei.o
CC fs/squashfs/super.o
CC fs/squashfs/symlink.o
CC fs/squashfs/decompressor.o
CC fs/squashfs/file_cache.o
CC fs/squashfs/decompressor_single.o
CC fs/squashfs/zlib_wrapper.o
AR fs/squashfs/built-in.a
CC fs/ramfs/inode.o
CC fs/ramfs/file-mmu.o
AR fs/ramfs/built-in.a
CC fs/hugetlbfs/inode.o
AR fs/hugetlbfs/built-in.a
CC fs/fat/cache.o
CC fs/fat/dir.o
CC fs/fat/fatent.o
CC fs/fat/file.o
CC fs/fat/inode.o
CC fs/fat/misc.o
CC fs/fat/nfs.o
CC fs/fat/namei_vfat.o
AR fs/fat/built-in.a
CC fs/nfs/filelayout/filelayout.o
CC fs/nfs/filelayout/filelayoutdev.o
AR fs/nfs/filelayout/built-in.a
CC fs/nfs/flexfilelayout/flexfilelayout.o
CC fs/nfs/flexfilelayout/flexfilelayoutdev.o
AR fs/nfs/flexfilelayout/built-in.a
CC fs/nfs/client.o
CC fs/nfs/dir.o
CC fs/nfs/file.o
CC fs/nfs/getroot.o
CC fs/nfs/inode.o
CC fs/nfs/super.o
CC fs/nfs/io.o
CC fs/nfs/direct.o
CC fs/nfs/pagelist.o
CC fs/nfs/read.o
CC fs/nfs/symlink.o
CC fs/nfs/unlink.o
CC fs/nfs/write.o
CC fs/nfs/namespace.o
CC fs/nfs/mount_clnt.o
CC fs/nfs/nfstrace.o
CC fs/nfs/export.o
CC fs/nfs/sysfs.o
CC fs/nfs/fs_context.o
CC fs/nfs/nfsroot.o
CC fs/nfs/sysctl.o
CC fs/nfs/nfs2super.o
CC fs/nfs/proc.o
CC fs/nfs/nfs2xdr.o
CC fs/nfs/nfs3super.o
CC fs/nfs/nfs3client.o
CC fs/nfs/nfs3proc.o
CC fs/nfs/nfs3xdr.o
CC fs/nfs/nfs4proc.o
CC fs/nfs/nfs4xdr.o
CC fs/nfs/nfs4state.o
CC fs/nfs/nfs4renewd.o
CC fs/nfs/nfs4super.o
CC fs/nfs/nfs4file.o
CC fs/nfs/delegation.o
CC fs/nfs/nfs4idmap.o
CC fs/nfs/callback.o
CC fs/nfs/callback_xdr.o
CC fs/nfs/callback_proc.o
CC fs/nfs/nfs4namespace.o
CC fs/nfs/nfs4getroot.o
CC fs/nfs/nfs4client.o
CC fs/nfs/nfs4session.o
CC fs/nfs/dns_resolve.o
CC fs/nfs/nfs4trace.o
CC fs/nfs/nfs4sysctl.o
CC fs/nfs/pnfs.o
CC fs/nfs/pnfs_dev.o
CC fs/nfs/pnfs_nfs.o
CC fs/nfs/nfs42proc.o
CC fs/nfs/nfs42xattr.o
AR fs/nfs/built-in.a
CC fs/exportfs/expfs.o
AR fs/exportfs/built-in.a
CC fs/lockd/clntlock.o
CC fs/lockd/clntproc.o
CC fs/lockd/clntxdr.o
CC fs/lockd/host.o
CC fs/lockd/svc.o
CC fs/lockd/svclock.o
CC fs/lockd/svcshare.o
CC fs/lockd/svcproc.o
CC fs/lockd/svcsubs.o
CC fs/lockd/mon.o
CC fs/lockd/xdr.o
CC fs/lockd/clnt4xdr.o
CC fs/lockd/xdr4.o
CC fs/lockd/svc4proc.o
CC fs/lockd/procfs.o
AR fs/lockd/built-in.a
CC fs/nls/nls_base.o
CC fs/nls/nls_cp437.o
CC fs/nls/nls_iso8859-1.o
AR fs/nls/built-in.a
CC fs/ubifs/shrinker.o
CC fs/ubifs/journal.o
CC fs/ubifs/file.o
CC fs/ubifs/dir.o
CC fs/ubifs/super.o
CC fs/ubifs/sb.o
CC fs/ubifs/io.o
CC fs/ubifs/tnc.o
CC fs/ubifs/master.o
CC fs/ubifs/scan.o
CC fs/ubifs/replay.o
CC fs/ubifs/log.o
CC fs/ubifs/commit.o
CC fs/ubifs/gc.o
CC fs/ubifs/orphan.o
CC fs/ubifs/budget.o
CC fs/ubifs/find.o
CC fs/ubifs/tnc_commit.o
CC fs/ubifs/compress.o
CC fs/ubifs/lpt.o
CC fs/ubifs/lprops.o
CC fs/ubifs/recovery.o
CC fs/ubifs/ioctl.o
CC fs/ubifs/lpt_commit.o
CC fs/ubifs/tnc_misc.o
CC fs/ubifs/debug.o
CC fs/ubifs/misc.o
CC fs/ubifs/xattr.o
AR fs/ubifs/built-in.a
CC fs/autofs/init.o
CC fs/autofs/inode.o
CC fs/autofs/root.o
CC fs/autofs/symlink.o
CC fs/autofs/waitq.o
CC fs/autofs/expire.o
CC fs/autofs/dev-ioctl.o
AR fs/autofs/built-in.a
CC fs/9p/vfs_super.o
CC fs/9p/vfs_inode.o
CC fs/9p/vfs_inode_dotl.o
CC fs/9p/vfs_addr.o
CC fs/9p/vfs_file.o
CC fs/9p/vfs_dir.o
CC fs/9p/vfs_dentry.o
CC fs/9p/v9fs.o
CC fs/9p/fid.o
CC fs/9p/xattr.o
AR fs/9p/built-in.a
CC fs/debugfs/inode.o
CC fs/debugfs/file.o
AR fs/debugfs/built-in.a
CC fs/efivarfs/inode.o
CC fs/efivarfs/file.o
CC fs/efivarfs/super.o
AR fs/efivarfs/built-in.a
CC fs/open.o
CC fs/read_write.o
CC fs/file_table.o
CC fs/super.o
CC fs/char_dev.o
CC fs/stat.o
CC fs/exec.o
CC fs/pipe.o
CC fs/namei.o
CC fs/fcntl.o
CC fs/ioctl.o
CC fs/readdir.o
CC fs/select.o
CC fs/dcache.o
CC fs/inode.o
CC fs/attr.o
CC fs/bad_inode.o
CC fs/file.o
CC fs/filesystems.o
CC fs/namespace.o
CC fs/seq_file.o
CC fs/xattr.o
CC fs/libfs.o
CC fs/fs-writeback.o
CC fs/pnode.o
CC fs/splice.o
CC fs/sync.o
CC fs/utimes.o
CC fs/d_path.o
CC fs/stack.o
CC fs/fs_struct.o
CC fs/statfs.o
CC fs/fs_pin.o
CC fs/nsfs.o
CC fs/fs_types.o
CC fs/fs_context.o
CC fs/fs_parser.o
CC fs/fsopen.o
CC fs/init.o
CC fs/kernel_read_file.o
CC fs/remap_range.o
CC fs/buffer.o
CC fs/block_dev.o
CC fs/direct-io.o
CC fs/mpage.o
CC fs/proc_namespace.o
CC fs/eventpoll.o
CC fs/anon_inodes.o
CC fs/signalfd.o
CC fs/timerfd.o
CC fs/eventfd.o
CC fs/aio.o
CC fs/locks.o
CC fs/binfmt_script.o
CC fs/binfmt_elf.o
CC fs/compat_binfmt_elf.o
CC fs/mbcache.o
CC fs/posix_acl.o
CC fs/coredump.o
CC fs/drop_caches.o
CC fs/fhandle.o
AR fs/built-in.a
CC ipc/compat.o
CC ipc/util.o
CC ipc/msgutil.o
CC ipc/msg.o
CC ipc/sem.o
CC ipc/shm.o
CC ipc/syscall.o
CC ipc/ipc_sysctl.o
CC ipc/mqueue.o
CC ipc/namespace.o
CC ipc/mq_sysctl.o
AR ipc/built-in.a
CC security/keys/gc.o
CC security/keys/key.o
CC security/keys/keyring.o
CC security/keys/keyctl.o
CC security/keys/permission.o
CC security/keys/process_keys.o
CC security/keys/request_key.o
CC security/keys/request_key_auth.o
CC security/keys/user_defined.o
CC security/keys/compat.o
CC security/keys/proc.o
CC security/keys/sysctl.o
CC security/keys/keyctl_pkey.o
AR security/keys/built-in.a
CC security/integrity/iint.o
AR security/integrity/built-in.a
CC security/commoncap.o
CC security/min_addr.o
CC security/security.o
CC security/inode.o
CC security/lsm_audit.o
CC security/device_cgroup.o
AR security/built-in.a
CC crypto/asymmetric_keys/asymmetric_type.o
CC crypto/asymmetric_keys/restrict.o
CC crypto/asymmetric_keys/signature.o
CC crypto/asymmetric_keys/public_key.o
ASN.1 crypto/asymmetric_keys/x509.asn1.[ch]
CC crypto/asymmetric_keys/x509.asn1.o
ASN.1 crypto/asymmetric_keys/x509_akid.asn1.[ch]
CC crypto/asymmetric_keys/x509_akid.asn1.o
CC crypto/asymmetric_keys/x509_cert_parser.o
CC crypto/asymmetric_keys/x509_public_key.o
ASN.1 crypto/asymmetric_keys/pkcs7.asn1.[ch]
CC crypto/asymmetric_keys/pkcs7.asn1.o
CC crypto/asymmetric_keys/pkcs7_parser.o
CC crypto/asymmetric_keys/pkcs7_trust.o
CC crypto/asymmetric_keys/pkcs7_verify.o
AR crypto/asymmetric_keys/built-in.a
CC crypto/api.o
CC crypto/cipher.o
CC crypto/compress.o
CC crypto/algapi.o
CC crypto/scatterwalk.o
CC crypto/proc.o
CC crypto/aead.o
CC crypto/geniv.o
CC crypto/skcipher.o
CC crypto/echainiv.o
CC crypto/ahash.o
CC crypto/shash.o
CC crypto/akcipher.o
CC crypto/kpp.o
ASN.1 crypto/rsapubkey.asn1.[ch]
CC crypto/rsapubkey.asn1.o
ASN.1 crypto/rsaprivkey.asn1.[ch]
CC crypto/rsaprivkey.asn1.o
CC crypto/rsa.o
CC crypto/rsa_helper.o
CC crypto/rsa-pkcs1pad.o
CC crypto/acompress.o
CC crypto/scompress.o
CC crypto/algboss.o
CC crypto/testmgr.o
CC crypto/hmac.o
CC crypto/crypto_null.o
CC crypto/sha1_generic.o
CC crypto/sha256_generic.o
CC crypto/gf128mul.o
CC crypto/cryptd.o
CC crypto/aes_generic.o
CC crypto/deflate.o
CC crypto/crc32c_generic.o
CC crypto/crct10dif_common.o
CC crypto/crct10dif_generic.o
CC crypto/lzo.o
CC crypto/lzo-rle.o
CC crypto/rng.o
CC crypto/ansi_cprng.o
CC crypto/drbg.o
CC crypto/jitterentropy.o
CC crypto/jitterentropy-kcapi.o
CC crypto/zstd.o
CC crypto/hash_info.o
CC crypto/simd.o
AR crypto/built-in.a
CC block/partitions/core.o
CC block/partitions/msdos.o
CC block/partitions/efi.o
AR block/partitions/built-in.a
CC block/bio.o
CC block/elevator.o
CC block/blk-core.o
CC block/blk-sysfs.o
CC block/blk-flush.o
CC block/blk-settings.o
CC block/blk-ioc.o
CC block/blk-map.o
CC block/blk-exec.o
CC block/blk-merge.o
CC block/blk-timeout.o
CC block/blk-lib.o
CC block/blk-mq.o
CC block/blk-mq-tag.o
CC block/blk-stat.o
CC block/blk-mq-sysfs.o
CC block/blk-mq-cpumap.o
CC block/blk-mq-sched.o
CC block/ioctl.o
CC block/genhd.o
CC block/ioprio.o
CC block/badblocks.o
CC block/blk-rq-qos.o
CC block/bounce.o
CC block/scsi_ioctl.o
CC block/bsg.o
CC block/bsg-lib.o
CC block/blk-cgroup.o
CC block/mq-deadline.o
CC block/kyber-iosched.o
CC block/bio-integrity.o
CC block/blk-integrity.o
CC block/t10-pi.o
CC block/blk-mq-pci.o
CC block/blk-mq-virtio.o
CC block/blk-mq-debugfs.o
CC block/blk-pm.o
AR block/built-in.a
CC io_uring/io_uring.o
CC io_uring/io-wq.o
AR io_uring/built-in.a
CC drivers/irqchip/irqchip.o
CC drivers/irqchip/irq-gic.o
CC drivers/irqchip/irq-gic-common.o
CC drivers/irqchip/irq-gic-v2m.o
CC drivers/irqchip/irq-gic-v3.o
CC drivers/irqchip/irq-gic-v3-mbi.o
CC drivers/irqchip/irq-gic-v3-its.o
CC drivers/irqchip/irq-gic-v3-its-platform-msi.o
CC drivers/irqchip/irq-gic-v4.o
CC drivers/irqchip/irq-gic-v3-its-pci-msi.o
CC drivers/irqchip/irq-partition-percpu.o
CC drivers/irqchip/irq-ti-sci-intr.o
CC drivers/irqchip/irq-ti-sci-inta.o
AR drivers/irqchip/built-in.a
CC drivers/bus/simple-pm-bus.o
AR drivers/bus/built-in.a
AR drivers/phy/allwinner/built-in.a
AR drivers/phy/amlogic/built-in.a
AR drivers/phy/broadcom/built-in.a
CC drivers/phy/cadence/phy-cadence-torrent.o
CC drivers/phy/cadence/phy-cadence-sierra.o
AR drivers/phy/cadence/built-in.a
AR drivers/phy/freescale/built-in.a
AR drivers/phy/hisilicon/built-in.a
AR drivers/phy/intel/built-in.a
AR drivers/phy/lantiq/built-in.a
AR drivers/phy/marvell/built-in.a
AR drivers/phy/mediatek/built-in.a
AR drivers/phy/motorola/built-in.a
AR drivers/phy/mscc/built-in.a
AR drivers/phy/qualcomm/built-in.a
AR drivers/phy/ralink/built-in.a
AR drivers/phy/renesas/built-in.a
AR drivers/phy/rockchip/built-in.a
AR drivers/phy/samsung/built-in.a
AR drivers/phy/socionext/built-in.a
AR drivers/phy/st/built-in.a
AR drivers/phy/tegra/built-in.a
CC drivers/phy/ti/phy-am654-serdes.o
CC drivers/phy/ti/phy-gmii-sel.o
CC drivers/phy/ti/phy-j721e-wiz.o
AR drivers/phy/ti/built-in.a
AR drivers/phy/xilinx/built-in.a
CC drivers/phy/phy-core.o
CC drivers/phy/phy-core-mipi-dphy.o
CC drivers/phy/phy-xgene.o
AR drivers/phy/built-in.a
AR drivers/pinctrl/actions/built-in.a
AR drivers/pinctrl/bcm/built-in.a
AR drivers/pinctrl/freescale/built-in.a
AR drivers/pinctrl/mvebu/built-in.a
AR drivers/pinctrl/nomadik/built-in.a
AR drivers/pinctrl/sprd/built-in.a
AR drivers/pinctrl/ti/built-in.a
AR drivers/pinctrl/mediatek/built-in.a
AR drivers/pinctrl/cirrus/built-in.a
CC drivers/pinctrl/core.o
CC drivers/pinctrl/pinctrl-utils.o
CC drivers/pinctrl/pinmux.o
CC drivers/pinctrl/pinconf.o
CC drivers/pinctrl/devicetree.o
CC drivers/pinctrl/pinconf-generic.o
CC drivers/pinctrl/pinctrl-max77620.o
CC drivers/pinctrl/pinctrl-single.o
AR drivers/pinctrl/built-in.a
CC drivers/gpio/gpiolib.o
CC drivers/gpio/gpiolib-devres.o
CC drivers/gpio/gpiolib-legacy.o
CC drivers/gpio/gpiolib-of.o
CC drivers/gpio/gpiolib-cdev.o
CC drivers/gpio/gpiolib-sysfs.o
CC drivers/gpio/gpio-mmio.o
CC drivers/gpio/gpio-davinci.o
CC drivers/gpio/gpio-dwapb.o
CC drivers/gpio/gpio-max732x.o
CC drivers/gpio/gpio-max77620.o
CC drivers/gpio/gpio-mb86s7x.o
CC drivers/gpio/gpio-pca953x.o
CC drivers/gpio/gpio-pcf857x.o
CC drivers/gpio/gpio-pl061.o
CC drivers/gpio/gpio-xgene.o
AR drivers/gpio/built-in.a
CC drivers/pwm/core.o
CC drivers/pwm/sysfs.o
CC drivers/pwm/pwm-omap-dmtimer.o
CC drivers/pwm/pwm-tiecap.o
CC drivers/pwm/pwm-tiehrpwm.o
AR drivers/pwm/built-in.a
CC drivers/pci/pcie/portdrv_core.o
CC drivers/pci/pcie/portdrv_pci.o
CC drivers/pci/pcie/err.o
CC drivers/pci/pcie/aspm.o
CC drivers/pci/pcie/pme.o
AR drivers/pci/pcie/built-in.a
CC drivers/pci/hotplug/pci_hotplug_core.o
AR drivers/pci/hotplug/built-in.a
CC drivers/pci/endpoint/functions/pci-epf-test.o
CC drivers/pci/endpoint/functions/pci-epf-ntb.o
AR drivers/pci/endpoint/functions/built-in.a
CC drivers/pci/endpoint/pci-ep-cfs.o
CC drivers/pci/endpoint/pci-epc-core.o
CC drivers/pci/endpoint/pci-epf-core.o
CC drivers/pci/endpoint/pci-epc-mem.o
AR drivers/pci/endpoint/built-in.a
CC drivers/pci/controller/cadence/pcie-cadence.o
CC drivers/pci/controller/cadence/pcie-cadence-host.o
CC drivers/pci/controller/cadence/pcie-cadence-ep.o
CC drivers/pci/controller/cadence/pci-j721e.o
AR drivers/pci/controller/cadence/built-in.a
CC drivers/pci/controller/dwc/pcie-designware.o
CC drivers/pci/controller/dwc/pcie-designware-host.o
CC drivers/pci/controller/dwc/pcie-designware-ep.o
CC drivers/pci/controller/dwc/pci-keystone.o
CC drivers/pci/controller/dwc/pcie-al.o
CC drivers/pci/controller/dwc/pcie-hisi.o
AR drivers/pci/controller/dwc/built-in.a
CC drivers/pci/controller/mobiveil/pcie-mobiveil.o
CC drivers/pci/controller/mobiveil/pcie-mobiveil-host.o
CC drivers/pci/controller/mobiveil/pcie-layerscape-gen4.o
AR drivers/pci/controller/mobiveil/built-in.a
CC drivers/pci/controller/pci-host-common.o
CC drivers/pci/controller/pci-host-generic.o
CC drivers/pci/controller/pcie-altera.o
CC drivers/pci/controller/pcie-altera-msi.o
CC drivers/pci/controller/pci-thunder-ecam.o
CC drivers/pci/controller/pci-thunder-pem.o
CC drivers/pci/controller/pci-xgene.o
AR drivers/pci/controller/built-in.a
AR drivers/pci/switch/built-in.a
CC drivers/pci/access.o
CC drivers/pci/bus.o
CC drivers/pci/probe.o
CC drivers/pci/host-bridge.o
CC drivers/pci/remove.o
CC drivers/pci/pci.o
CC drivers/pci/pci-driver.o
CC drivers/pci/search.o
CC drivers/pci/pci-sysfs.o
CC drivers/pci/rom.o
CC drivers/pci/setup-res.o
CC drivers/pci/irq.o
CC drivers/pci/vpd.o
CC drivers/pci/setup-bus.o
CC drivers/pci/vc.o
CC drivers/pci/mmap.o
CC drivers/pci/setup-irq.o
CC drivers/pci/proc.o
CC drivers/pci/slot.o
CC drivers/pci/of.o
CC drivers/pci/quirks.o
CC drivers/pci/msi.o
CC drivers/pci/ats.o
CC drivers/pci/iov.o
CC drivers/pci/pci-label.o
CC drivers/pci/syscall.o
CC drivers/pci/ecam.o
AR drivers/pci/built-in.a
CC drivers/video/console/dummycon.o
AR drivers/video/console/built-in.a
CC drivers/video/logo/logo.o
HOSTCC drivers/video/logo/pnmtologo
LOGO drivers/video/logo/logo_linux_clut224.c
CC drivers/video/logo/logo_linux_clut224.o
AR drivers/video/logo/built-in.a
CC drivers/video/backlight/backlight.o
CC drivers/video/backlight/gpio_backlight.o
CC drivers/video/backlight/pwm_bl.o
CC drivers/video/backlight/led_bl.o
AR drivers/video/backlight/built-in.a
CC drivers/video/fbdev/core/fb_cmdline.o
CC drivers/video/fbdev/core/fb_notify.o
CC drivers/video/fbdev/core/fbmem.o
CC drivers/video/fbdev/core/fbmon.o
CC drivers/video/fbdev/core/fbcmap.o
CC drivers/video/fbdev/core/fbsysfs.o
CC drivers/video/fbdev/core/modedb.o
CC drivers/video/fbdev/core/fbcvt.o
CC drivers/video/fbdev/core/fb_defio.o
CC drivers/video/fbdev/core/fbcon.o
CC drivers/video/fbdev/core/bitblit.o
CC drivers/video/fbdev/core/softcursor.o
CC drivers/video/fbdev/core/cfbfillrect.o
CC drivers/video/fbdev/core/cfbcopyarea.o
CC drivers/video/fbdev/core/cfbimgblt.o
CC drivers/video/fbdev/core/sysfillrect.o
CC drivers/video/fbdev/core/syscopyarea.o
CC drivers/video/fbdev/core/sysimgblt.o
CC drivers/video/fbdev/core/fb_sys_fops.o
AR drivers/video/fbdev/core/built-in.a
AR drivers/video/fbdev/omap2/omapfb/dss/built-in.a
AR drivers/video/fbdev/omap2/omapfb/displays/built-in.a
AR drivers/video/fbdev/omap2/omapfb/built-in.a
AR drivers/video/fbdev/omap2/built-in.a
CC drivers/video/fbdev/ssd1307fb.o
AR drivers/video/fbdev/built-in.a
CC drivers/video/hdmi.o
CC drivers/video/display_timing.o
CC drivers/video/videomode.o
CC drivers/video/of_display_timing.o
CC drivers/video/of_videomode.o
AR drivers/video/built-in.a
AR drivers/idle/built-in.a
CC drivers/char/ipmi/ipmi_dmi.o
CC drivers/char/ipmi/ipmi_plat_data.o
AR drivers/char/ipmi/built-in.a
CC drivers/amba/bus.o
AR drivers/amba/built-in.a
AR drivers/clk/actions/built-in.a
AR drivers/clk/analogbits/built-in.a
AR drivers/clk/bcm/built-in.a
AR drivers/clk/imgtec/built-in.a
AR drivers/clk/imx/built-in.a
AR drivers/clk/ingenic/built-in.a
CC drivers/clk/keystone/sci-clk.o
CC drivers/clk/keystone/syscon-clk.o
AR drivers/clk/keystone/built-in.a
AR drivers/clk/mediatek/built-in.a
AR drivers/clk/mvebu/built-in.a
AR drivers/clk/renesas/built-in.a
AR drivers/clk/sprd/built-in.a
AR drivers/clk/ti/built-in.a
AR drivers/clk/versatile/built-in.a
CC drivers/clk/clk-devres.o
CC drivers/clk/clk-bulk.o
CC drivers/clk/clkdev.o
CC drivers/clk/clk.o
CC drivers/clk/clk-divider.o
CC drivers/clk/clk-fixed-factor.o
CC drivers/clk/clk-fixed-rate.o
CC drivers/clk/clk-gate.o
CC drivers/clk/clk-multiplier.o
CC drivers/clk/clk-mux.o
CC drivers/clk/clk-composite.o
CC drivers/clk/clk-fractional-divider.o
CC drivers/clk/clk-gpio.o
CC drivers/clk/clk-conf.o
CC drivers/clk/clk-cs2000-cp.o
CC drivers/clk/clk-pwm.o
CC drivers/clk/clk-rk808.o
CC drivers/clk/clk-s2mps11.o
CC drivers/clk/clk-versaclock5.o
AR drivers/clk/built-in.a
AR drivers/dma/mediatek/built-in.a
CC drivers/dma/qcom/hidma_mgmt.o
CC drivers/dma/qcom/hidma_mgmt_sys.o
CC drivers/dma/qcom/hidma_ll.o
CC drivers/dma/qcom/hidma.o
CC drivers/dma/qcom/hidma_dbg.o
AR drivers/dma/qcom/built-in.a
CC drivers/dma/ti/k3-udma.o
drivers/dma/ti/k3-udma.c:5502:12: warning: ‘udma_pm_resume’ defined but not used [-Wunused-function]
5502 | static int udma_pm_resume(struct device *dev)
drivers/dma/ti/k3-udma.c:5480:12: warning: ‘udma_pm_suspend’ defined but not used [-Wunused-function]
5480 | static int udma_pm_suspend(struct device *dev)
CC drivers/dma/ti/k3-udma-glue.o
CC drivers/dma/ti/k3-psil.o
CC drivers/dma/ti/k3-psil-am654.o
CC drivers/dma/ti/k3-psil-j721e.o
CC drivers/dma/ti/k3-psil-j7200.o
CC drivers/dma/ti/k3-psil-am64.o
CC drivers/dma/ti/k3-psil-j721s2.o
CC drivers/dma/ti/k3-psil-am62.o
CC drivers/dma/ti/k3-psil-j784s4.o
CC drivers/dma/ti/k3-psil-am62a.o
AR drivers/dma/ti/built-in.a
AR drivers/dma/xilinx/built-in.a
CC drivers/dma/dmaengine.o
CC drivers/dma/virt-dma.o
CC drivers/dma/of-dma.o
CC drivers/dma/fsl-edma.o
CC drivers/dma/fsl-edma-common.o
CC drivers/dma/mv_xor_v2.o
CC drivers/dma/pl330.o
AR drivers/dma/built-in.a
AR drivers/soc/bcm/built-in.a
AR drivers/soc/fsl/built-in.a
AR drivers/soc/imx/built-in.a
AR drivers/soc/mediatek/built-in.a
AR drivers/soc/amlogic/built-in.a
AR drivers/soc/qcom/built-in.a
AR drivers/soc/renesas/built-in.a
AR drivers/soc/sunxi/built-in.a
CC drivers/soc/ti/ti_sci_pm_domains.o
CC drivers/soc/ti/ti_sci_inta_msi.o
CC drivers/soc/ti/k3-ringacc.o
CC drivers/soc/ti/k3-socinfo.o
CC drivers/soc/ti/ti-pat.o
AR drivers/soc/ti/built-in.a
AR drivers/soc/xilinx/built-in.a
AR drivers/soc/built-in.a
CC drivers/virtio/virtio.o
CC drivers/virtio/virtio_ring.o
CC drivers/virtio/virtio_mmio.o
CC drivers/virtio/virtio_pci_modern.o
CC drivers/virtio/virtio_pci_common.o
CC drivers/virtio/virtio_pci_legacy.o
CC drivers/virtio/virtio_balloon.o
AR drivers/virtio/built-in.a
CC drivers/regulator/core.o
CC drivers/regulator/dummy.o
CC drivers/regulator/fixed-helper.o
CC drivers/regulator/helpers.o
CC drivers/regulator/devres.o
CC drivers/regulator/of_regulator.o
CC drivers/regulator/fixed.o
CC drivers/regulator/axp20x-regulator.o
CC drivers/regulator/bd718x7-regulator.o
CC drivers/regulator/bd9571mwv-regulator.o
CC drivers/regulator/fan53555.o
CC drivers/regulator/gpio-regulator.o
CC drivers/regulator/hi6421v530-regulator.o
CC drivers/regulator/max77620-regulator.o
CC drivers/regulator/max8973-regulator.o
CC drivers/regulator/qcom_spmi-regulator.o
CC drivers/regulator/palmas-regulator.o
CC drivers/regulator/pca9450-regulator.o
CC drivers/regulator/pfuze100-regulator.o
CC drivers/regulator/pwm-regulator.o
CC drivers/regulator/rk808-regulator.o
CC drivers/regulator/rohm-regulator.o
CC drivers/regulator/s2mps11.o
AR drivers/regulator/built-in.a
AR drivers/reset/hisilicon/built-in.a
CC drivers/reset/core.o
CC drivers/reset/reset-ti-sci.o
CC drivers/reset/reset-ti-syscon.o
AR drivers/reset/built-in.a
CC drivers/tty/vt/vt_ioctl.o
CC drivers/tty/vt/vc_screen.o
CC drivers/tty/vt/selection.o
CC drivers/tty/vt/keyboard.o
CC drivers/tty/vt/consolemap.o
HOSTCC drivers/tty/vt/conmakehash
CONMK drivers/tty/vt/consolemap_deftbl.c
CC drivers/tty/vt/consolemap_deftbl.o
CC drivers/tty/vt/vt.o
SHIPPED drivers/tty/vt/defkeymap.c
CC drivers/tty/vt/defkeymap.o
AR drivers/tty/vt/built-in.a
CC drivers/tty/hvc/hvc_console.o
AR drivers/tty/hvc/built-in.a
CC drivers/tty/serial/8250/8250_core.o
CC drivers/tty/serial/8250/8250_port.o
CC drivers/tty/serial/8250/8250_dma.o
CC drivers/tty/serial/8250/8250_pci.o
CC drivers/tty/serial/8250/8250_exar.o
CC drivers/tty/serial/8250/8250_early.o
CC drivers/tty/serial/8250/8250_fsl.o
CC drivers/tty/serial/8250/8250_omap.o
CC drivers/tty/serial/8250/8250_of.o
AR drivers/tty/serial/8250/built-in.a
CC drivers/tty/serial/serial_core.o
CC drivers/tty/serial/earlycon.o
CC drivers/tty/serial/fsl_lpuart.o
CC drivers/tty/serial/fsl_linflexuart.o
CC drivers/tty/serial/serial_mctrl_gpio.o
AR drivers/tty/serial/built-in.a
CC drivers/tty/serdev/core.o
CC drivers/tty/serdev/serdev-ttyport.o
AR drivers/tty/serdev/built-in.a
AR drivers/tty/ipwireless/built-in.a
CC drivers/tty/tty_io.o
CC drivers/tty/n_tty.o
CC drivers/tty/tty_ioctl.o
CC drivers/tty/tty_ldisc.o
CC drivers/tty/tty_buffer.o
CC drivers/tty/tty_port.o
CC drivers/tty/tty_mutex.o
CC drivers/tty/tty_ldsem.o
CC drivers/tty/tty_baudrate.o
CC drivers/tty/tty_jobctrl.o
CC drivers/tty/n_null.o
CC drivers/tty/pty.o
CC drivers/tty/sysrq.o
AR drivers/tty/built-in.a
AR drivers/char/agp/built-in.a
CC drivers/char/tpm/tpm-chip.o
CC drivers/char/tpm/tpm-dev-common.o
CC drivers/char/tpm/tpm-dev.o
CC drivers/char/tpm/tpm-interface.o
CC drivers/char/tpm/tpm1-cmd.o
CC drivers/char/tpm/tpm2-cmd.o
CC drivers/char/tpm/tpmrm-dev.o
CC drivers/char/tpm/tpm2-space.o
CC drivers/char/tpm/tpm-sysfs.o
CC drivers/char/tpm/eventlog/common.o
CC drivers/char/tpm/eventlog/tpm1.o
CC drivers/char/tpm/eventlog/tpm2.o
CC drivers/char/tpm/eventlog/efi.o
CC drivers/char/tpm/eventlog/of.o
CC drivers/char/tpm/tpm_i2c_infineon.o
AR drivers/char/tpm/built-in.a
CC drivers/char/mem.o
CC drivers/char/random.o
CC drivers/char/misc.o
CC drivers/char/virtio_console.o
AR drivers/char/built-in.a
AR drivers/iommu/amd/built-in.a
AR drivers/iommu/intel/built-in.a
CC drivers/iommu/arm/arm-smmu/arm-smmu.o
CC drivers/iommu/arm/arm-smmu/arm-smmu-impl.o
CC drivers/iommu/arm/arm-smmu/arm-smmu-nvidia.o
CC drivers/iommu/arm/arm-smmu/arm-smmu-qcom.o
AR drivers/iommu/arm/arm-smmu/built-in.a
CC drivers/iommu/arm/arm-smmu-v3/arm-smmu-v3.o
AR drivers/iommu/arm/arm-smmu-v3/built-in.a
AR drivers/iommu/arm/built-in.a
CC drivers/iommu/iommu.o
CC drivers/iommu/iommu-traces.o
CC drivers/iommu/iommu-sysfs.o
CC drivers/iommu/dma-iommu.o
CC drivers/iommu/io-pgtable.o
CC drivers/iommu/io-pgtable-arm.o
CC drivers/iommu/iova.o
CC drivers/iommu/of_iommu.o
AR drivers/iommu/built-in.a
AR drivers/gpu/drm/arm/built-in.a
AR drivers/gpu/drm/rcar-du/built-in.a
AR drivers/gpu/drm/omapdrm/dss/built-in.a
AR drivers/gpu/drm/omapdrm/displays/built-in.a
AR drivers/gpu/drm/omapdrm/built-in.a
AR drivers/gpu/drm/tilcdc/built-in.a
AR drivers/gpu/drm/imx/built-in.a
CC drivers/gpu/drm/i2c/tda998x_drv.o
AR drivers/gpu/drm/i2c/built-in.a
CC drivers/gpu/drm/panel/panel-simple.o
CC drivers/gpu/drm/panel/panel-osd-osd101t2587-53ts.o
AR drivers/gpu/drm/panel/built-in.a
AR drivers/gpu/drm/bridge/analogix/built-in.a
AR drivers/gpu/drm/bridge/cadence/built-in.a
AR drivers/gpu/drm/bridge/synopsys/built-in.a
CC drivers/gpu/drm/bridge/display-connector.o
CC drivers/gpu/drm/bridge/lvds-codec.o
CC drivers/gpu/drm/bridge/sii902x.o
CC drivers/gpu/drm/bridge/tc358767.o
CC drivers/gpu/drm/bridge/tc358768.o
CC drivers/gpu/drm/bridge/ti-tfp410.o
CC drivers/gpu/drm/bridge/ti-tpd12s015.o
AR drivers/gpu/drm/bridge/built-in.a
AR drivers/gpu/drm/hisilicon/built-in.a
AR drivers/gpu/drm/tiny/built-in.a
CC drivers/gpu/drm/tidss/tidss_crtc.o
CC drivers/gpu/drm/tidss/tidss_drv.o
CC drivers/gpu/drm/tidss/tidss_encoder.o
CC drivers/gpu/drm/tidss/tidss_kms.o
CC drivers/gpu/drm/tidss/tidss_irq.o
CC drivers/gpu/drm/tidss/tidss_plane.o
CC drivers/gpu/drm/tidss/tidss_scale_coefs.o
CC drivers/gpu/drm/tidss/tidss_dispc.o
AR drivers/gpu/drm/tidss/built-in.a
AR drivers/gpu/drm/xlnx/built-in.a
CC drivers/gpu/drm/drm_bridge_connector.o
CC drivers/gpu/drm/drm_crtc_helper.o
CC drivers/gpu/drm/drm_dp_helper.o
CC drivers/gpu/drm/drm_dsc.o
CC drivers/gpu/drm/drm_probe_helper.o
CC drivers/gpu/drm/drm_plane_helper.o
CC drivers/gpu/drm/drm_dp_mst_topology.o
CC drivers/gpu/drm/drm_atomic_helper.o
CC drivers/gpu/drm/drm_kms_helper_common.o
CC drivers/gpu/drm/drm_dp_dual_mode_helper.o
CC drivers/gpu/drm/drm_simple_kms_helper.o
CC drivers/gpu/drm/drm_modeset_helper.o
CC drivers/gpu/drm/drm_scdc_helper.o
CC drivers/gpu/drm/drm_gem_framebuffer_helper.o
CC drivers/gpu/drm/drm_atomic_state_helper.o
CC drivers/gpu/drm/drm_damage_helper.o
CC drivers/gpu/drm/drm_format_helper.o
CC drivers/gpu/drm/drm_self_refresh_helper.o
CC drivers/gpu/drm/bridge/panel.o
CC drivers/gpu/drm/drm_fb_helper.o
CC drivers/gpu/drm/drm_fb_cma_helper.o
CC drivers/gpu/drm/drm_auth.o
CC drivers/gpu/drm/drm_cache.o
CC drivers/gpu/drm/drm_file.o
CC drivers/gpu/drm/drm_gem.o
CC drivers/gpu/drm/drm_ioctl.o
CC drivers/gpu/drm/drm_irq.o
CC drivers/gpu/drm/drm_memory.o
CC drivers/gpu/drm/drm_drv.o
CC drivers/gpu/drm/drm_sysfs.o
CC drivers/gpu/drm/drm_hashtab.o
CC drivers/gpu/drm/drm_mm.o
CC drivers/gpu/drm/drm_crtc.o
CC drivers/gpu/drm/drm_fourcc.o
CC drivers/gpu/drm/drm_modes.o
CC drivers/gpu/drm/drm_edid.o
CC drivers/gpu/drm/drm_encoder_slave.o
CC drivers/gpu/drm/drm_trace_points.o
CC drivers/gpu/drm/drm_prime.o
CC drivers/gpu/drm/drm_rect.o
CC drivers/gpu/drm/drm_vma_manager.o
CC drivers/gpu/drm/drm_flip_work.o
CC drivers/gpu/drm/drm_modeset_lock.o
CC drivers/gpu/drm/drm_atomic.o
CC drivers/gpu/drm/drm_bridge.o
CC drivers/gpu/drm/drm_framebuffer.o
CC drivers/gpu/drm/drm_connector.o
CC drivers/gpu/drm/drm_blend.o
CC drivers/gpu/drm/drm_encoder.o
CC drivers/gpu/drm/drm_mode_object.o
CC drivers/gpu/drm/drm_property.o
CC drivers/gpu/drm/drm_plane.o
CC drivers/gpu/drm/drm_color_mgmt.o
CC drivers/gpu/drm/drm_print.o
CC drivers/gpu/drm/drm_dumb_buffers.o
CC drivers/gpu/drm/drm_mode_config.o
CC drivers/gpu/drm/drm_vblank.o
CC drivers/gpu/drm/drm_syncobj.o
CC drivers/gpu/drm/drm_lease.o
CC drivers/gpu/drm/drm_writeback.o
CC drivers/gpu/drm/drm_client.o
CC drivers/gpu/drm/drm_client_modeset.o
CC drivers/gpu/drm/drm_atomic_uapi.o
CC drivers/gpu/drm/drm_hdcp.o
CC drivers/gpu/drm/drm_managed.o
CC drivers/gpu/drm/drm_vblank_work.o
CC drivers/gpu/drm/drm_legacy_misc.o
CC drivers/gpu/drm/drm_bufs.o
CC drivers/gpu/drm/drm_context.o
CC drivers/gpu/drm/drm_dma.o
CC drivers/gpu/drm/drm_scatter.o
CC drivers/gpu/drm/drm_lock.o
CC drivers/gpu/drm/drm_vm.o
CC drivers/gpu/drm/drm_ioc32.o
CC drivers/gpu/drm/drm_gem_cma_helper.o
CC drivers/gpu/drm/drm_panel.o
CC drivers/gpu/drm/drm_of.o
CC drivers/gpu/drm/drm_pci.o
CC drivers/gpu/drm/drm_debugfs.o
CC drivers/gpu/drm/drm_debugfs_crc.o
CC drivers/gpu/drm/drm_mipi_dsi.o
CC drivers/gpu/drm/drm_panel_orientation_quirks.o
AR drivers/gpu/drm/built-in.a
AR drivers/gpu/vga/built-in.a
AR drivers/gpu/built-in.a
CC drivers/base/power/sysfs.o
CC drivers/base/power/generic_ops.o
CC drivers/base/power/common.o
CC drivers/base/power/qos.o
CC drivers/base/power/runtime.o
CC drivers/base/power/wakeirq.o
CC drivers/base/power/domain.o
CC drivers/base/power/domain_governor.o
CC drivers/base/power/clock_ops.o
AR drivers/base/power/built-in.a
AR drivers/base/firmware_loader/builtin/built-in.a
CC drivers/base/firmware_loader/main.o
AR drivers/base/firmware_loader/built-in.a
CC drivers/base/regmap/regmap.o
CC drivers/base/regmap/regcache.o
CC drivers/base/regmap/regcache-rbtree.o
CC drivers/base/regmap/regcache-flat.o
CC drivers/base/regmap/regmap-debugfs.o
CC drivers/base/regmap/regmap-i2c.o
CC drivers/base/regmap/regmap-spi.o
CC drivers/base/regmap/regmap-mmio.o
CC drivers/base/regmap/regmap-irq.o
AR drivers/base/regmap/built-in.a
AR drivers/base/test/built-in.a
CC drivers/base/component.o
CC drivers/base/core.o
CC drivers/base/bus.o
CC drivers/base/dd.o
CC drivers/base/syscore.o
CC drivers/base/driver.o
CC drivers/base/class.o
CC drivers/base/platform.o
CC drivers/base/cpu.o
CC drivers/base/firmware.o
CC drivers/base/init.o
CC drivers/base/map.o
CC drivers/base/devres.o
CC drivers/base/attribute_container.o
CC drivers/base/transport_class.o
CC drivers/base/topology.o
CC drivers/base/container.o
CC drivers/base/property.o
CC drivers/base/cacheinfo.o
CC drivers/base/swnode.o
CC drivers/base/devtmpfs.o
CC drivers/base/module.o
CC drivers/base/soc.o
CC drivers/base/pinctrl.o
CC drivers/base/devcoredump.o
CC drivers/base/platform-msi.o
CC drivers/base/arch_topology.o
AR drivers/base/built-in.a
CC drivers/block/brd.o
CC drivers/block/loop.o
CC drivers/block/virtio_blk.o
AR drivers/block/built-in.a
AR drivers/misc/eeprom/built-in.a
AR drivers/misc/cb710/built-in.a
AR drivers/misc/ti-st/built-in.a
AR drivers/misc/lis3lv02d/built-in.a
AR drivers/misc/cardreader/built-in.a
CC drivers/misc/sram.o
CC drivers/misc/sram-dma-heap.o
CC drivers/misc/dma-buf-phys.o
AR drivers/misc/built-in.a
CC drivers/mfd/bd9571mwv.o
CC drivers/mfd/cros_ec_dev.o
CC drivers/mfd/mfd-core.o
CC drivers/mfd/axp20x.o
CC drivers/mfd/axp20x-i2c.o
CC drivers/mfd/max77620.o
CC drivers/mfd/palmas.o
CC drivers/mfd/rk808.o
CC drivers/mfd/sec-core.o
CC drivers/mfd/sec-irq.o
CC drivers/mfd/syscon.o
CC drivers/mfd/hi6421-pmic-core.o
CC drivers/mfd/rohm-bd718x7.o
AR drivers/mfd/built-in.a
AR drivers/nfc/built-in.a
CC drivers/dma-buf/heaps/heap-helpers.o
CC drivers/dma-buf/heaps/system_heap.o
CC drivers/dma-buf/heaps/cma_heap.o
CC drivers/dma-buf/heaps/carveout-heap.o
AR drivers/dma-buf/heaps/built-in.a
CC drivers/dma-buf/dma-buf.o
CC drivers/dma-buf/dma-fence.o
CC drivers/dma-buf/dma-fence-array.o
CC drivers/dma-buf/dma-fence-chain.o
CC drivers/dma-buf/dma-resv.o
CC drivers/dma-buf/seqno-fence.o
CC drivers/dma-buf/dma-heap.o
CC drivers/dma-buf/sync_file.o
AR drivers/dma-buf/built-in.a
AR drivers/macintosh/built-in.a
CC drivers/scsi/megaraid/megaraid_sas_base.o
CC drivers/scsi/megaraid/megaraid_sas_fusion.o
CC drivers/scsi/megaraid/megaraid_sas_fp.o
CC drivers/scsi/megaraid/megaraid_sas_debugfs.o
AR drivers/scsi/megaraid/built-in.a
CC drivers/scsi/ufs/cdns-pltfrm.o
CC drivers/scsi/ufs/ufshcd.o
CC drivers/scsi/ufs/ufs-sysfs.o
CC drivers/scsi/ufs/ufs_bsg.o
CC drivers/scsi/ufs/ufshcd-pltfrm.o
CC drivers/scsi/ufs/ti-j721e-ufs.o
AR drivers/scsi/ufs/built-in.a
CC drivers/scsi/scsi.o
CC drivers/scsi/hosts.o
CC drivers/scsi/scsi_ioctl.o
CC drivers/scsi/scsicam.o
CC drivers/scsi/scsi_error.o
CC drivers/scsi/scsi_lib.o
CC drivers/scsi/scsi_lib_dma.o
CC drivers/scsi/scsi_scan.o
GEN drivers/scsi/scsi_devinfo_tbl.c
CC drivers/scsi/scsi_sysfs.o
CC drivers/scsi/scsi_devinfo.o
CC drivers/scsi/scsi_sysctl.o
CC drivers/scsi/scsi_debugfs.o
CC drivers/scsi/scsi_trace.o
CC drivers/scsi/scsi_logging.o
CC drivers/scsi/scsi_pm.o
CC drivers/scsi/scsi_common.o
CC drivers/scsi/sd.o
CC drivers/scsi/sd_dif.o
AR drivers/scsi/built-in.a
AR drivers/nvme/host/built-in.a
AR drivers/nvme/target/built-in.a
AR drivers/nvme/built-in.a
CC drivers/mtd/parsers/cmdlinepart.o
CC drivers/mtd/parsers/ofpart.o
AR drivers/mtd/parsers/built-in.a
CC drivers/mtd/chips/chipreg.o
CC drivers/mtd/chips/cfi_probe.o
CC drivers/mtd/chips/cfi_util.o
CC drivers/mtd/chips/cfi_cmdset_0020.o
CC drivers/mtd/chips/cfi_cmdset_0002.o
CC drivers/mtd/chips/cfi_cmdset_0001.o
CC drivers/mtd/chips/gen_probe.o
AR drivers/mtd/chips/built-in.a
AR drivers/mtd/lpddr/built-in.a
CC drivers/mtd/maps/map_funcs.o
CC drivers/mtd/maps/physmap-core.o
AR drivers/mtd/maps/built-in.a
CC drivers/mtd/devices/mtd_dataflash.o
CC drivers/mtd/devices/sst25l.o
AR drivers/mtd/devices/built-in.a
AR drivers/mtd/nand/onenand/built-in.a
AR drivers/mtd/nand/raw/ingenic/built-in.a
CC drivers/mtd/nand/raw/nand_base.o
CC drivers/mtd/nand/raw/nand_legacy.o
CC drivers/mtd/nand/raw/nand_bbt.o
CC drivers/mtd/nand/raw/nand_timings.o
CC drivers/mtd/nand/raw/nand_ids.o
CC drivers/mtd/nand/raw/nand_onfi.o
CC drivers/mtd/nand/raw/nand_jedec.o
CC drivers/mtd/nand/raw/nand_amd.o
CC drivers/mtd/nand/raw/nand_esmt.o
CC drivers/mtd/nand/raw/nand_hynix.o
CC drivers/mtd/nand/raw/nand_macronix.o
CC drivers/mtd/nand/raw/nand_micron.o
CC drivers/mtd/nand/raw/nand_samsung.o
CC drivers/mtd/nand/raw/nand_toshiba.o
CC drivers/mtd/nand/raw/nand_ecc.o
CC drivers/mtd/nand/raw/denali.o
CC drivers/mtd/nand/raw/denali_dt.o
CC drivers/mtd/nand/raw/omap2.o
CC drivers/mtd/nand/raw/omap_elm.o
AR drivers/mtd/nand/raw/built-in.a
CC drivers/mtd/nand/spi/core.o
CC drivers/mtd/nand/spi/gigadevice.o
CC drivers/mtd/nand/spi/macronix.o
CC drivers/mtd/nand/spi/micron.o
CC drivers/mtd/nand/spi/paragon.o
CC drivers/mtd/nand/spi/toshiba.o
CC drivers/mtd/nand/spi/winbond.o
AR drivers/mtd/nand/spi/built-in.a
CC drivers/mtd/nand/core.o
CC drivers/mtd/nand/bbt.o
CC drivers/mtd/nand/ecc.o
AR drivers/mtd/nand/built-in.a
AR drivers/mtd/tests/built-in.a
AR drivers/mtd/spi-nor/controllers/built-in.a
CC drivers/mtd/spi-nor/core.o
CC drivers/mtd/spi-nor/sfdp.o
CC drivers/mtd/spi-nor/atmel.o
CC drivers/mtd/spi-nor/catalyst.o
CC drivers/mtd/spi-nor/eon.o
CC drivers/mtd/spi-nor/esmt.o
CC drivers/mtd/spi-nor/everspin.o
CC drivers/mtd/spi-nor/fujitsu.o
CC drivers/mtd/spi-nor/gigadevice.o
CC drivers/mtd/spi-nor/intel.o
CC drivers/mtd/spi-nor/issi.o
CC drivers/mtd/spi-nor/macronix.o
CC drivers/mtd/spi-nor/micron-st.o
CC drivers/mtd/spi-nor/spansion.o
CC drivers/mtd/spi-nor/sst.o
CC drivers/mtd/spi-nor/winbond.o
CC drivers/mtd/spi-nor/xilinx.o
CC drivers/mtd/spi-nor/xmc.o
AR drivers/mtd/spi-nor/built-in.a
CC drivers/mtd/ubi/vtbl.o
CC drivers/mtd/ubi/vmt.o
CC drivers/mtd/ubi/upd.o
CC drivers/mtd/ubi/build.o
CC drivers/mtd/ubi/cdev.o
CC drivers/mtd/ubi/kapi.o
CC drivers/mtd/ubi/eba.o
CC drivers/mtd/ubi/io.o
CC drivers/mtd/ubi/wl.o
CC drivers/mtd/ubi/attach.o
CC drivers/mtd/ubi/misc.o
CC drivers/mtd/ubi/debug.o
AR drivers/mtd/ubi/built-in.a
CC drivers/mtd/hyperbus/hyperbus-core.o
CC drivers/mtd/hyperbus/hbmc-am654.o
AR drivers/mtd/hyperbus/built-in.a
CC drivers/mtd/mtdcore.o
CC drivers/mtd/mtdsuper.o
CC drivers/mtd/mtdconcat.o
CC drivers/mtd/mtdpart.o
CC drivers/mtd/mtdchar.o
CC drivers/mtd/mtd_blkdevs.o
CC drivers/mtd/mtdblock.o
AR drivers/mtd/built-in.a
CC drivers/spi/spi.o
CC drivers/spi/spi-mem.o
CC drivers/spi/spi-cadence-quadspi.o
CC drivers/spi/spi-nxp-fspi.o
CC drivers/spi/spi-omap2-mcspi.o
CC drivers/spi/spi-pl022.o
AR drivers/spi/built-in.a
CC drivers/spmi/spmi.o
AR drivers/spmi/built-in.a
CC drivers/net/phy/mscc/mscc_main.o
AR drivers/net/phy/mscc/built-in.a
CC drivers/net/phy/mdio-boardinfo.o
CC drivers/net/phy/mdio_devres.o
CC drivers/net/phy/phylink.o
CC drivers/net/phy/phy.o
CC drivers/net/phy/phy-c45.o
CC drivers/net/phy/phy-core.o
CC drivers/net/phy/phy_device.o
CC drivers/net/phy/linkmode.o
CC drivers/net/phy/mdio_bus.o
CC drivers/net/phy/mdio_device.o
CC drivers/net/phy/swphy.o
CC drivers/net/phy/aquantia_main.o
CC drivers/net/phy/aquantia_hwmon.o
CC drivers/net/phy/at803x.o
CC drivers/net/phy/dp83848.o
CC drivers/net/phy/dp83867.o
CC drivers/net/phy/dp83869.o
CC drivers/net/phy/fixed_phy.o
CC drivers/net/phy/marvell.o
CC drivers/net/phy/micrel.o
CC drivers/net/phy/rockchip.o
CC drivers/net/phy/vitesse.o
AR drivers/net/phy/built-in.a
CC drivers/net/mdio/of_mdio.o
CC drivers/net/mdio/mdio-bitbang.o
CC drivers/net/mdio/mdio-gpio.o
CC drivers/net/mdio/mdio-mux.o
CC drivers/net/mdio/mdio-mux-mmioreg.o
CC drivers/net/mdio/mdio-mux-multiplexer.o
AR drivers/net/mdio/built-in.a
AR drivers/net/pcs/built-in.a
AR drivers/net/dsa/b53/built-in.a
AR drivers/net/dsa/microchip/built-in.a
AR drivers/net/dsa/mv88e6xxx/built-in.a
AR drivers/net/dsa/ocelot/built-in.a
AR drivers/net/dsa/qca/built-in.a
AR drivers/net/dsa/sja1105/built-in.a
AR drivers/net/dsa/built-in.a
AR drivers/net/ethernet/alacritech/built-in.a
AR drivers/net/ethernet/aquantia/built-in.a
AR drivers/net/ethernet/aurora/built-in.a
CC drivers/net/ethernet/cadence/macb_main.o
CC drivers/net/ethernet/cadence/macb_ptp.o
AR drivers/net/ethernet/cadence/built-in.a
AR drivers/net/ethernet/broadcom/built-in.a
AR drivers/net/ethernet/cortina/built-in.a
AR drivers/net/ethernet/google/built-in.a
AR drivers/net/ethernet/huawei/built-in.a
CC drivers/net/ethernet/intel/igbvf/vf.o
CC drivers/net/ethernet/intel/igbvf/mbx.o
CC drivers/net/ethernet/intel/igbvf/ethtool.o
CC drivers/net/ethernet/intel/igbvf/netdev.o
AR drivers/net/ethernet/intel/igbvf/built-in.a
AR drivers/net/ethernet/intel/built-in.a
AR drivers/net/ethernet/marvell/octeontx2/built-in.a
AR drivers/net/ethernet/marvell/prestera/built-in.a
CC drivers/net/ethernet/marvell/sky2.o
AR drivers/net/ethernet/marvell/built-in.a
AR drivers/net/ethernet/micrel/built-in.a
AR drivers/net/ethernet/mscc/built-in.a
AR drivers/net/ethernet/neterion/built-in.a
AR drivers/net/ethernet/ni/built-in.a
AR drivers/net/ethernet/packetengines/built-in.a
AR drivers/net/ethernet/qualcomm/emac/built-in.a
AR drivers/net/ethernet/qualcomm/built-in.a
AR drivers/net/ethernet/sfc/built-in.a
CC drivers/net/ethernet/smsc/smc91x.o
CC drivers/net/ethernet/smsc/smsc911x.o
AR drivers/net/ethernet/smsc/built-in.a
AR drivers/net/ethernet/socionext/built-in.a
CC drivers/net/ethernet/ti/davinci_mdio.o
CC drivers/net/ethernet/ti/am65-cpsw-nuss.o
drivers/net/ethernet/ti/am65-cpsw-nuss.c:1926:13: warning: ‘am65_cpsw_nuss_remove_rx_chns’ defined but not used [-Wunused-function]
1926 | static void am65_cpsw_nuss_remove_rx_chns(void *data)
CC drivers/net/ethernet/ti/cpsw_sl.o
CC drivers/net/ethernet/ti/am65-cpsw-ethtool.o
CC drivers/net/ethernet/ti/cpsw_ale.o
CC [M] drivers/net/ethernet/ti/k3-cppi-desc-pool.o
CC drivers/net/ethernet/ti/am65-cpsw-qos.o
CC drivers/net/ethernet/ti/am65-debugfs.o
CC drivers/net/ethernet/ti/am65-cpsw-switchdev.o
CC drivers/net/ethernet/ti/am65-cpts.o
AR drivers/net/ethernet/ti/built-in.a
AR drivers/net/ethernet/xilinx/built-in.a
AR drivers/net/ethernet/pensando/built-in.a
AR drivers/net/ethernet/built-in.a
AR drivers/net/wireless/admtek/built-in.a
AR drivers/net/wireless/ath/built-in.a
AR drivers/net/wireless/atmel/built-in.a
AR drivers/net/wireless/broadcom/built-in.a
AR drivers/net/wireless/cisco/built-in.a
AR drivers/net/wireless/intel/built-in.a
AR drivers/net/wireless/intersil/built-in.a
AR drivers/net/wireless/marvell/built-in.a
AR drivers/net/wireless/mediatek/built-in.a
AR drivers/net/wireless/microchip/built-in.a
AR drivers/net/wireless/ralink/built-in.a
AR drivers/net/wireless/realtek/built-in.a
AR drivers/net/wireless/rsi/built-in.a
AR drivers/net/wireless/st/built-in.a
CC drivers/net/wireless/ti/wilink_platform_data.o
AR drivers/net/wireless/ti/built-in.a
AR drivers/net/wireless/zydas/built-in.a
AR drivers/net/wireless/quantenna/built-in.a
AR drivers/net/wireless/built-in.a
CC drivers/net/mii.o
CC drivers/net/Space.o
CC drivers/net/loopback.o
CC drivers/net/tun.o
CC drivers/net/virtio_net.o
CC drivers/net/net_failover.o
AR drivers/net/built-in.a
AR drivers/firewire/built-in.a
CC drivers/uio/uio.o
AR drivers/uio/built-in.a
CC drivers/vfio/pci/vfio_pci.o
CC drivers/vfio/pci/vfio_pci_intrs.o
CC drivers/vfio/pci/vfio_pci_rdwr.o
CC drivers/vfio/pci/vfio_pci_config.o
AR drivers/vfio/pci/built-in.a
CC drivers/vfio/vfio.o
CC drivers/vfio/virqfd.o
CC drivers/vfio/vfio_iommu_type1.o
AR drivers/vfio/built-in.a
AR drivers/cdrom/built-in.a
AR drivers/auxdisplay/built-in.a
CC drivers/usb/phy/phy.o
CC drivers/usb/phy/of.o
AR drivers/usb/phy/built-in.a
CC drivers/usb/host/pci-quirks.o
AR drivers/usb/host/built-in.a
AR drivers/usb/built-in.a
CC drivers/input/serio/serio.o
CC drivers/input/serio/ambakmi.o
CC drivers/input/serio/libps2.o
AR drivers/input/serio/built-in.a
CC drivers/input/keyboard/atkbd.o
CC drivers/input/keyboard/cros_ec_keyb.o
CC drivers/input/keyboard/gpio_keys.o
AR drivers/input/keyboard/built-in.a
CC drivers/input/mouse/psmouse-base.o
CC drivers/input/mouse/synaptics.o
CC drivers/input/mouse/focaltech.o
CC drivers/input/mouse/alps.o
CC drivers/input/mouse/byd.o
CC drivers/input/mouse/logips2pp.o
CC drivers/input/mouse/trackpoint.o
CC drivers/input/mouse/cypress_ps2.o
CC drivers/input/mouse/psmouse-smbus.o
AR drivers/input/mouse/built-in.a
CC drivers/input/touchscreen/of_touchscreen.o
AR drivers/input/touchscreen/built-in.a
AR drivers/input/misc/built-in.a
CC drivers/input/input.o
CC drivers/input/input-compat.o
CC drivers/input/input-mt.o
CC drivers/input/input-poller.o
CC drivers/input/ff-core.o
CC drivers/input/matrix-keymap.o
CC drivers/input/input-leds.o
CC drivers/input/evdev.o
AR drivers/input/built-in.a
CC drivers/rtc/lib.o
CC drivers/rtc/systohc.o
CC drivers/rtc/class.o
CC drivers/rtc/interface.o
CC drivers/rtc/nvmem.o
CC drivers/rtc/dev.o
CC drivers/rtc/proc.o
CC drivers/rtc/sysfs.o
CC drivers/rtc/rtc-cros-ec.o
CC drivers/rtc/rtc-ds3232.o
CC drivers/rtc/rtc-efi.o
CC drivers/rtc/rtc-max77686.o
CC drivers/rtc/rtc-pl031.o
CC drivers/rtc/rtc-s5m.o
CC drivers/rtc/rtc-ti-k3.o
AR drivers/rtc/built-in.a
CC drivers/i2c/algos/i2c-algo-bit.o
AR drivers/i2c/algos/built-in.a
CC drivers/i2c/busses/i2c-omap.o
CC drivers/i2c/busses/i2c-cros-ec-tunnel.o
AR drivers/i2c/busses/built-in.a
CC drivers/i2c/muxes/i2c-mux-pca954x.o
AR drivers/i2c/muxes/built-in.a
CC drivers/i2c/i2c-boardinfo.o
CC drivers/i2c/i2c-core-base.o
CC drivers/i2c/i2c-core-smbus.o
CC drivers/i2c/i2c-core-of.o
CC drivers/i2c/i2c-dev.o
CC drivers/i2c/i2c-mux.o
AR drivers/i2c/built-in.a
AR drivers/i3c/built-in.a
AR drivers/media/i2c/built-in.a
AR drivers/media/tuners/built-in.a
AR drivers/media/dvb-frontends/built-in.a
CC drivers/media/mc/mc-device.o
CC drivers/media/mc/mc-devnode.o
CC drivers/media/mc/mc-entity.o
CC drivers/media/mc/mc-request.o
CC drivers/media/mc/mc-dev-allocator.o
AR drivers/media/mc/built-in.a
CC drivers/media/v4l2-core/v4l2-dev.o
CC drivers/media/v4l2-core/v4l2-ioctl.o
CC drivers/media/v4l2-core/v4l2-device.o
CC drivers/media/v4l2-core/v4l2-fh.o
CC drivers/media/v4l2-core/v4l2-event.o
CC drivers/media/v4l2-core/v4l2-ctrls.o
CC drivers/media/v4l2-core/v4l2-subdev.o
CC drivers/media/v4l2-core/v4l2-clk.o
CC drivers/media/v4l2-core/v4l2-async.o
CC drivers/media/v4l2-core/v4l2-common.o
CC drivers/media/v4l2-core/v4l2-compat-ioctl32.o
CC drivers/media/v4l2-core/v4l2-mc.o
CC drivers/media/v4l2-core/v4l2-spi.o
CC drivers/media/v4l2-core/v4l2-i2c.o
CC drivers/media/v4l2-core/v4l2-dv-timings.o
AR drivers/media/v4l2-core/built-in.a
CC drivers/media/dvb-core/dvbdev.o
CC drivers/media/dvb-core/dmxdev.o
CC drivers/media/dvb-core/dvb_demux.o
CC drivers/media/dvb-core/dvb_ca_en50221.o
CC drivers/media/dvb-core/dvb_frontend.o
CC drivers/media/dvb-core/dvb_ringbuffer.o
CC drivers/media/dvb-core/dvb_math.o
AR drivers/media/dvb-core/built-in.a
AR drivers/media/rc/keymaps/built-in.a
AR drivers/media/rc/built-in.a
CC drivers/media/cec/core/cec-core.o
CC drivers/media/cec/core/cec-adap.o
CC drivers/media/cec/core/cec-api.o
CC drivers/media/cec/core/cec-notifier.o
AR drivers/media/cec/core/built-in.a
AR drivers/media/cec/i2c/built-in.a
AR drivers/media/cec/platform/built-in.a
AR drivers/media/cec/usb/built-in.a
AR drivers/media/cec/built-in.a
AR drivers/media/common/b2c2/built-in.a
AR drivers/media/common/saa7146/built-in.a
AR drivers/media/common/siano/built-in.a
AR drivers/media/common/v4l2-tpg/built-in.a
AR drivers/media/common/videobuf2/built-in.a
AR drivers/media/common/built-in.a
AR drivers/media/platform/cadence/built-in.a
AR drivers/media/platform/ti/cal/built-in.a
AR drivers/media/platform/ti/vpe/built-in.a
AR drivers/media/platform/ti/j721e-csi2rx/built-in.a
AR drivers/media/platform/ti/built-in.a
AR drivers/media/platform/stm32/built-in.a
AR drivers/media/platform/davinci/built-in.a
AR drivers/media/platform/omap/built-in.a
AR drivers/media/platform/sunxi/sun4i-csi/built-in.a
AR drivers/media/platform/sunxi/sun6i-csi/built-in.a
AR drivers/media/platform/sunxi/sun8i-di/built-in.a
AR drivers/media/platform/sunxi/sun8i-rotate/built-in.a
AR drivers/media/platform/sunxi/built-in.a
AR drivers/media/platform/built-in.a
AR drivers/media/pci/ttpci/built-in.a
AR drivers/media/pci/b2c2/built-in.a
AR drivers/media/pci/pluto2/built-in.a
AR drivers/media/pci/dm1105/built-in.a
AR drivers/media/pci/pt1/built-in.a
AR drivers/media/pci/pt3/built-in.a
AR drivers/media/pci/mantis/built-in.a
AR drivers/media/pci/ngene/built-in.a
AR drivers/media/pci/ddbridge/built-in.a
AR drivers/media/pci/saa7146/built-in.a
AR drivers/media/pci/smipcie/built-in.a
AR drivers/media/pci/netup_unidvb/built-in.a
AR drivers/media/pci/intel/ipu3/built-in.a
AR drivers/media/pci/intel/built-in.a
AR drivers/media/pci/built-in.a
AR drivers/media/usb/ttusb-dec/built-in.a
AR drivers/media/usb/ttusb-budget/built-in.a
AR drivers/media/usb/dvb-usb/built-in.a
AR drivers/media/usb/dvb-usb-v2/built-in.a
AR drivers/media/usb/siano/built-in.a
AR drivers/media/usb/b2c2/built-in.a
AR drivers/media/usb/zr364xx/built-in.a
AR drivers/media/usb/stkwebcam/built-in.a
AR drivers/media/usb/s2255/built-in.a
AR drivers/media/usb/built-in.a
AR drivers/media/mmc/siano/built-in.a
AR drivers/media/mmc/built-in.a
AR drivers/media/firewire/built-in.a
AR drivers/media/spi/built-in.a
AR drivers/media/test-drivers/built-in.a
AR drivers/media/radio/built-in.a
AR drivers/media/built-in.a
AR drivers/pps/clients/built-in.a
AR drivers/pps/generators/built-in.a
CC drivers/pps/pps.o
CC drivers/pps/kapi.o
CC drivers/pps/sysfs.o
AR drivers/pps/built-in.a
CC drivers/ptp/ptp_clock.o
CC drivers/ptp/ptp_chardev.o
CC drivers/ptp/ptp_sysfs.o
AR drivers/ptp/built-in.a
CC drivers/power/reset/xgene-reboot.o
CC drivers/power/reset/syscon-reboot.o
CC drivers/power/reset/reboot-mode.o
CC drivers/power/reset/syscon-reboot-mode.o
AR drivers/power/reset/built-in.a
CC drivers/power/supply/power_supply_core.o
CC drivers/power/supply/power_supply_sysfs.o
CC drivers/power/supply/power_supply_leds.o
CC drivers/power/supply/power_supply_hwmon.o
CC drivers/power/supply/bq27xxx_battery.o
CC drivers/power/supply/bq27xxx_battery_i2c.o
AR drivers/power/supply/built-in.a
AR drivers/power/built-in.a
CC drivers/hwmon/hwmon.o
AR drivers/hwmon/built-in.a
AR drivers/thermal/broadcom/built-in.a
AR drivers/thermal/samsung/built-in.a
AR drivers/thermal/intel/built-in.a
AR drivers/thermal/st/built-in.a
AR drivers/thermal/tegra/built-in.a
CC drivers/thermal/thermal_core.o
CC drivers/thermal/thermal_sysfs.o
CC drivers/thermal/thermal_helpers.o
CC drivers/thermal/thermal_hwmon.o
CC drivers/thermal/thermal_of.o
CC drivers/thermal/gov_step_wise.o
CC drivers/thermal/k3_bandgap.o
CC drivers/thermal/k3_j72xx_bandgap.o
AR drivers/thermal/built-in.a
CC drivers/watchdog/watchdog_core.o
CC drivers/watchdog/watchdog_dev.o
CC drivers/watchdog/sp805_wdt.o
CC drivers/watchdog/sbsa_gwdt.o
CC drivers/watchdog/dw_wdt.o
CC drivers/watchdog/arm_smc_wdt.o
AR drivers/watchdog/built-in.a
CC drivers/md/dm-builtin.o
AR drivers/md/built-in.a
CC drivers/edac/edac_mc.o
CC drivers/edac/edac_device.o
CC drivers/edac/edac_mc_sysfs.o
CC drivers/edac/edac_module.o
CC drivers/edac/edac_device_sysfs.o
CC drivers/edac/wq.o
CC drivers/edac/edac_pci.o
CC drivers/edac/edac_pci_sysfs.o
AR drivers/edac/built-in.a
CC drivers/opp/core.o
CC drivers/opp/cpu.o
CC drivers/opp/of.o
CC drivers/opp/debugfs.o
AR drivers/opp/built-in.a
CC drivers/mmc/core/core.o
CC drivers/mmc/core/bus.o
CC drivers/mmc/core/host.o
CC drivers/mmc/core/mmc.o
CC drivers/mmc/core/mmc_ops.o
CC drivers/mmc/core/sd.o
CC drivers/mmc/core/sd_ops.o
CC drivers/mmc/core/sdio.o
CC drivers/mmc/core/sdio_ops.o
CC drivers/mmc/core/sdio_bus.o
CC drivers/mmc/core/sdio_cis.o
CC drivers/mmc/core/sdio_io.o
CC drivers/mmc/core/sdio_irq.o
CC drivers/mmc/core/slot-gpio.o
CC drivers/mmc/core/regulator.o
CC drivers/mmc/core/pwrseq.o
CC drivers/mmc/core/debugfs.o
CC drivers/mmc/core/pwrseq_simple.o
CC drivers/mmc/core/pwrseq_emmc.o
CC drivers/mmc/core/block.o
CC drivers/mmc/core/queue.o
AR drivers/mmc/core/built-in.a
CC drivers/mmc/host/mmci.o
CC drivers/mmc/host/mmci_stm32_sdmmc.o
CC drivers/mmc/host/sdhci.o
CC drivers/mmc/host/sdhci_f_sdh30.o
CC drivers/mmc/host/sdhci_am654.o
CC drivers/mmc/host/mmc_spi.o
CC drivers/mmc/host/of_mmc_spi.o
CC drivers/mmc/host/sdhci-pltfm.o
CC drivers/mmc/host/sdhci-cadence.o
CC drivers/mmc/host/sdhci-of-arasan.o
CC drivers/mmc/host/sdhci-omap.o
CC drivers/mmc/host/cqhci.o
CC drivers/mmc/host/sdhci-xenon.o
CC drivers/mmc/host/sdhci-xenon-phy.o
AR drivers/mmc/host/built-in.a
AR drivers/mmc/built-in.a
CC drivers/leds/trigger/ledtrig-timer.o
CC drivers/leds/trigger/ledtrig-disk.o
CC drivers/leds/trigger/ledtrig-heartbeat.o
CC drivers/leds/trigger/ledtrig-default-on.o
CC drivers/leds/trigger/ledtrig-panic.o
AR drivers/leds/trigger/built-in.a
CC drivers/leds/led-core.o
CC drivers/leds/led-class.o
CC drivers/leds/led-triggers.o
CC drivers/leds/leds-gpio.o
CC drivers/leds/leds-pwm.o
CC drivers/leds/leds-syscon.o
CC drivers/leds/leds-tlc591xx.o
AR drivers/leds/built-in.a
AR drivers/firmware/arm_scmi/built-in.a
AR drivers/firmware/broadcom/built-in.a
AR drivers/firmware/meson/built-in.a
CC drivers/firmware/efi/libstub/efi-stub-helper.o
CC drivers/firmware/efi/libstub/gop.o
CC drivers/firmware/efi/libstub/secureboot.o
CC drivers/firmware/efi/libstub/tpm.o
CC drivers/firmware/efi/libstub/file.o
CC drivers/firmware/efi/libstub/mem.o
CC drivers/firmware/efi/libstub/random.o
CC drivers/firmware/efi/libstub/randomalloc.o
CC drivers/firmware/efi/libstub/pci.o
CC drivers/firmware/efi/libstub/skip_spaces.o
CC drivers/firmware/efi/libstub/lib-cmdline.o
CC drivers/firmware/efi/libstub/lib-ctype.o
CC drivers/firmware/efi/libstub/alignedmem.o
CC drivers/firmware/efi/libstub/relocate.o
CC drivers/firmware/efi/libstub/vsprintf.o
CC drivers/firmware/efi/libstub/efi-stub.o
CC drivers/firmware/efi/libstub/fdt.o
CC drivers/firmware/efi/libstub/string.o
CC drivers/firmware/efi/libstub/lib-fdt_rw.o
CC drivers/firmware/efi/libstub/lib-fdt_ro.o
CC drivers/firmware/efi/libstub/lib-fdt_wip.o
CC drivers/firmware/efi/libstub/lib-fdt.o
CC drivers/firmware/efi/libstub/lib-fdt_empty_tree.o
CC drivers/firmware/efi/libstub/lib-fdt_sw.o
CC drivers/firmware/efi/libstub/arm64-stub.o
STUBCPY drivers/firmware/efi/libstub/alignedmem.stub.o
STUBCPY drivers/firmware/efi/libstub/arm64-stub.stub.o
STUBCPY drivers/firmware/efi/libstub/efi-stub-helper.stub.o
STUBCPY drivers/firmware/efi/libstub/efi-stub.stub.o
STUBCPY drivers/firmware/efi/libstub/fdt.stub.o
STUBCPY drivers/firmware/efi/libstub/file.stub.o
STUBCPY drivers/firmware/efi/libstub/gop.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-cmdline.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-ctype.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt_empty_tree.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt_ro.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt_rw.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt_sw.stub.o
STUBCPY drivers/firmware/efi/libstub/lib-fdt_wip.stub.o
STUBCPY drivers/firmware/efi/libstub/mem.stub.o
STUBCPY drivers/firmware/efi/libstub/pci.stub.o
STUBCPY drivers/firmware/efi/libstub/random.stub.o
STUBCPY drivers/firmware/efi/libstub/randomalloc.stub.o
STUBCPY drivers/firmware/efi/libstub/relocate.stub.o
STUBCPY drivers/firmware/efi/libstub/secureboot.stub.o
STUBCPY drivers/firmware/efi/libstub/skip_spaces.stub.o
STUBCPY drivers/firmware/efi/libstub/string.stub.o
STUBCPY drivers/firmware/efi/libstub/tpm.stub.o
STUBCPY drivers/firmware/efi/libstub/vsprintf.stub.o
AR drivers/firmware/efi/libstub/lib.a
CC drivers/firmware/efi/efi.o
CC drivers/firmware/efi/vars.o
CC drivers/firmware/efi/reboot.o
CC drivers/firmware/efi/memattr.o
CC drivers/firmware/efi/tpm.o
CC drivers/firmware/efi/capsule.o
CC drivers/firmware/efi/memmap.o
CC drivers/firmware/efi/fdtparams.o
CC drivers/firmware/efi/esrt.o
CC drivers/firmware/efi/runtime-wrappers.o
CC drivers/firmware/efi/efi-init.o
CC drivers/firmware/efi/arm-runtime.o
CC drivers/firmware/efi/capsule-loader.o
CC drivers/firmware/efi/earlycon.o
AR drivers/firmware/efi/built-in.a
AR drivers/firmware/imx/built-in.a
CC drivers/firmware/psci/psci.o
AR drivers/firmware/psci/built-in.a
CC drivers/firmware/smccc/smccc.o
CC drivers/firmware/smccc/soc_id.o
AR drivers/firmware/smccc/built-in.a
AR drivers/firmware/tegra/built-in.a
AR drivers/firmware/xilinx/built-in.a
CC drivers/firmware/dmi_scan.o
CC drivers/firmware/ti_sci.o
AR drivers/firmware/built-in.a
AR drivers/crypto/ti/built-in.a
AR drivers/crypto/hisilicon/built-in.a
AR drivers/crypto/built-in.a
CC drivers/clocksource/timer-of.o
CC drivers/clocksource/timer-probe.o
CC drivers/clocksource/timer-ti-dm.o
CC drivers/clocksource/arm_arch_timer.o
CC drivers/clocksource/dummy_timer.o
AR drivers/clocksource/built-in.a
CC drivers/hid/hid-core.o
CC drivers/hid/hid-input.o
CC drivers/hid/hid-quirks.o
CC drivers/hid/hid-debug.o
CC drivers/hid/hid-generic.o
AR drivers/hid/built-in.a
CC drivers/of/base.o
CC drivers/of/device.o
CC drivers/of/platform.o
CC drivers/of/property.o
CC drivers/of/kobj.o
CC drivers/of/dynamic.o
CC drivers/of/fdt.o
CC drivers/of/fdt_address.o
CC drivers/of/address.o
CC drivers/of/irq.o
CC drivers/of/of_net.o
CC drivers/of/of_reserved_mem.o
CC drivers/of/resolver.o
CC drivers/of/overlay.o
AR drivers/of/built-in.a
AR drivers/staging/media/built-in.a
AR drivers/staging/iio/accel/built-in.a
AR drivers/staging/iio/adc/built-in.a
AR drivers/staging/iio/addac/built-in.a
AR drivers/staging/iio/cdc/built-in.a
AR drivers/staging/iio/frequency/built-in.a
AR drivers/staging/iio/impedance-analyzer/built-in.a
AR drivers/staging/iio/meter/built-in.a
AR drivers/staging/iio/resolver/built-in.a
AR drivers/staging/iio/built-in.a
AR drivers/staging/hikey9xx/built-in.a
AR drivers/staging/built-in.a
CC drivers/platform/chrome/cros_ec.o
CC drivers/platform/chrome/cros_ec_i2c.o
CC drivers/platform/chrome/cros_ec_spi.o
CC drivers/platform/chrome/cros_ec_proto.o
CC drivers/platform/chrome/cros_ec_trace.o
CC drivers/platform/chrome/cros_ec_lightbar.o
CC drivers/platform/chrome/cros_ec_vbc.o
CC drivers/platform/chrome/cros_ec_debugfs.o
CC drivers/platform/chrome/cros_ec_sensorhub.o
CC drivers/platform/chrome/cros_ec_sensorhub_ring.o
CC drivers/platform/chrome/cros_ec_sysfs.o
CC drivers/platform/chrome/cros_usbpd_notify.o
AR drivers/platform/chrome/built-in.a
AR drivers/platform/built-in.a
CC drivers/mailbox/mailbox.o
CC drivers/mailbox/omap-mailbox.o
CC drivers/mailbox/ti-msgmgr.o
AR drivers/mailbox/built-in.a
CC drivers/hwspinlock/hwspinlock_core.o
CC drivers/hwspinlock/omap_hwspinlock.o
AR drivers/hwspinlock/built-in.a
CC drivers/remoteproc/remoteproc_core.o
CC drivers/remoteproc/remoteproc_coredump.o
CC drivers/remoteproc/remoteproc_debugfs.o
CC drivers/remoteproc/remoteproc_sysfs.o
CC drivers/remoteproc/remoteproc_virtio.o
CC drivers/remoteproc/remoteproc_elf_loader.o
AR drivers/remoteproc/built-in.a
CC drivers/rpmsg/rpmsg_core.o
CC drivers/rpmsg/qcom_glink_native.o
CC drivers/rpmsg/qcom_glink_ssr.o
CC drivers/rpmsg/qcom_glink_rpm.o
AR drivers/rpmsg/built-in.a
CC drivers/rpmsg-kdrv/rpmsg_kdrv.o
CC drivers/rpmsg-kdrv/rpmsg_kdrv_display.o
AR drivers/rpmsg-kdrv/built-in.a
CC drivers/devfreq/devfreq.o
CC drivers/devfreq/governor_simpleondemand.o
AR drivers/devfreq/built-in.a
CC drivers/extcon/extcon.o
CC drivers/extcon/devres.o
CC drivers/extcon/extcon-usbc-cros-ec.o
AR drivers/extcon/built-in.a
CC drivers/memory/omap-gpmc.o
AR drivers/memory/built-in.a
AR drivers/iio/accel/built-in.a
AR drivers/iio/adc/built-in.a
AR drivers/iio/afe/built-in.a
AR drivers/iio/amplifiers/built-in.a
AR drivers/iio/buffer/built-in.a
AR drivers/iio/chemical/built-in.a
AR drivers/iio/common/cros_ec_sensors/built-in.a
AR drivers/iio/common/hid-sensors/built-in.a
AR drivers/iio/common/ms_sensors/built-in.a
AR drivers/iio/common/ssp_sensors/built-in.a
AR drivers/iio/common/st_sensors/built-in.a
AR drivers/iio/common/built-in.a
AR drivers/iio/dac/built-in.a
AR drivers/iio/dummy/built-in.a
AR drivers/iio/gyro/built-in.a
AR drivers/iio/frequency/built-in.a
AR drivers/iio/health/built-in.a
AR drivers/iio/humidity/built-in.a
AR drivers/iio/imu/bmi160/built-in.a
AR drivers/iio/imu/inv_icm42600/built-in.a
AR drivers/iio/imu/inv_mpu6050/built-in.a
AR drivers/iio/imu/st_lsm6dsx/built-in.a
AR drivers/iio/imu/built-in.a
AR drivers/iio/light/built-in.a
AR drivers/iio/magnetometer/built-in.a
AR drivers/iio/multiplexer/built-in.a
AR drivers/iio/orientation/built-in.a
AR drivers/iio/position/built-in.a
AR drivers/iio/potentiometer/built-in.a
AR drivers/iio/potentiostat/built-in.a
AR drivers/iio/pressure/built-in.a
AR drivers/iio/proximity/built-in.a
AR drivers/iio/resolver/built-in.a
AR drivers/iio/temperature/built-in.a
AR drivers/iio/trigger/built-in.a
CC drivers/iio/industrialio-core.o
CC drivers/iio/industrialio-event.o
CC drivers/iio/inkern.o
CC drivers/iio/industrialio-buffer.o
CC drivers/iio/industrialio-trigger.o
AR drivers/iio/built-in.a
CC drivers/perf/arm_pmu.o
CC drivers/perf/arm_pmu_platform.o
AR drivers/perf/built-in.a
CC drivers/ras/ras.o
CC drivers/ras/debugfs.o
AR drivers/ras/built-in.a
AR drivers/hwtracing/intel_th/built-in.a
CC drivers/nvmem/core.o
AR drivers/nvmem/built-in.a
CC drivers/fpga/fpga-mgr.o
AR drivers/fpga/built-in.a
CC drivers/tee/optee/core.o
CC drivers/tee/optee/call.o
CC drivers/tee/optee/rpc.o
CC drivers/tee/optee/supp.o
CC drivers/tee/optee/shm_pool.o
CC drivers/tee/optee/device.o
AR drivers/tee/optee/built-in.a
CC drivers/tee/tee_core.o
CC drivers/tee/tee_shm.o
CC drivers/tee/tee_shm_pool.o
AR drivers/tee/built-in.a
CC drivers/mux/core.o
CC drivers/mux/gpio.o
CC drivers/mux/mmio.o
AR drivers/mux/built-in.a
CC drivers/interconnect/core.o
CC drivers/interconnect/bulk.o
AR drivers/interconnect/built-in.a
AR drivers/built-in.a
CC sound/core/sound.o
CC sound/core/init.o
CC sound/core/memory.o
CC sound/core/control.o
CC sound/core/misc.o
CC sound/core/device.o
CC sound/core/info.o
CC sound/core/ctljack.o
CC sound/core/jack.o
CC sound/core/timer.o
CC sound/core/pcm.o
CC sound/core/pcm_native.o
CC sound/core/pcm_lib.o
CC sound/core/pcm_misc.o
CC sound/core/pcm_memory.o
CC sound/core/memalloc.o
CC sound/core/pcm_timer.o
CC sound/core/pcm_drm_eld.o
CC sound/core/pcm_iec958.o
CC sound/core/pcm_dmaengine.o
AR sound/core/built-in.a
AR sound/i2c/other/built-in.a
AR sound/i2c/built-in.a
AR sound/drivers/opl3/built-in.a
AR sound/drivers/opl4/built-in.a
AR sound/drivers/mpu401/built-in.a
AR sound/drivers/vx/built-in.a
AR sound/drivers/pcsp/built-in.a
AR sound/drivers/built-in.a
AR sound/isa/ad1816a/built-in.a
AR sound/isa/ad1848/built-in.a
AR sound/isa/cs423x/built-in.a
AR sound/isa/es1688/built-in.a
AR sound/isa/galaxy/built-in.a
AR sound/isa/gus/built-in.a
AR sound/isa/msnd/built-in.a
AR sound/isa/opti9xx/built-in.a
AR sound/isa/sb/built-in.a
AR sound/isa/wavefront/built-in.a
AR sound/isa/wss/built-in.a
AR sound/isa/built-in.a
AR sound/pci/ac97/built-in.a
AR sound/pci/ali5451/built-in.a
AR sound/pci/asihpi/built-in.a
AR sound/pci/au88x0/built-in.a
AR sound/pci/aw2/built-in.a
AR sound/pci/ctxfi/built-in.a
AR sound/pci/ca0106/built-in.a
AR sound/pci/cs46xx/built-in.a
AR sound/pci/cs5535audio/built-in.a
AR sound/pci/lola/built-in.a
AR sound/pci/lx6464es/built-in.a
AR sound/pci/echoaudio/built-in.a
AR sound/pci/emu10k1/built-in.a
AR sound/pci/hda/built-in.a
AR sound/pci/ice1712/built-in.a
AR sound/pci/korg1212/built-in.a
AR sound/pci/mixart/built-in.a
AR sound/pci/nm256/built-in.a
AR sound/pci/oxygen/built-in.a
AR sound/pci/pcxhr/built-in.a
AR sound/pci/riptide/built-in.a
AR sound/pci/rme9652/built-in.a
AR sound/pci/trident/built-in.a
AR sound/pci/ymfpci/built-in.a
AR sound/pci/vx222/built-in.a
AR sound/pci/built-in.a
AR sound/ppc/built-in.a
AR sound/arm/built-in.a
AR sound/sh/built-in.a
AR sound/synth/built-in.a
AR sound/usb/misc/built-in.a
AR sound/usb/usx2y/built-in.a
AR sound/usb/caiaq/built-in.a
AR sound/usb/6fire/built-in.a
AR sound/usb/hiface/built-in.a
AR sound/usb/bcd2000/built-in.a
AR sound/usb/built-in.a
AR sound/firewire/built-in.a
AR sound/sparc/built-in.a
AR sound/spi/built-in.a
AR sound/parisc/built-in.a
AR sound/pcmcia/vx/built-in.a
AR sound/pcmcia/pdaudiocf/built-in.a
AR sound/pcmcia/built-in.a
AR sound/mips/built-in.a
CC sound/soc/codecs/hdmi-codec.o
AR sound/soc/codecs/built-in.a
AR sound/soc/generic/built-in.a
AR sound/soc/adi/built-in.a
AR sound/soc/amd/built-in.a
AR sound/soc/atmel/built-in.a
AR sound/soc/au1x/built-in.a
AR sound/soc/bcm/built-in.a
AR sound/soc/cirrus/built-in.a
AR sound/soc/dwc/built-in.a
AR sound/soc/fsl/built-in.a
AR sound/soc/hisilicon/built-in.a
AR sound/soc/jz4740/built-in.a
AR sound/soc/img/built-in.a
AR sound/soc/intel/common/built-in.a
AR sound/soc/intel/boards/built-in.a
AR sound/soc/intel/built-in.a
AR sound/soc/mediatek/built-in.a
AR sound/soc/meson/built-in.a
AR sound/soc/mxs/built-in.a
AR sound/soc/kirkwood/built-in.a
AR sound/soc/pxa/built-in.a
AR sound/soc/qcom/built-in.a
AR sound/soc/rockchip/built-in.a
AR sound/soc/samsung/built-in.a
AR sound/soc/sh/built-in.a
AR sound/soc/sirf/built-in.a
AR sound/soc/sof/built-in.a
AR sound/soc/spear/built-in.a
AR sound/soc/sprd/built-in.a
AR sound/soc/sti/built-in.a
AR sound/soc/stm/built-in.a
AR sound/soc/sunxi/built-in.a
AR sound/soc/tegra/built-in.a
CC sound/soc/ti/edma-pcm.o
CC sound/soc/ti/sdma-pcm.o
CC sound/soc/ti/udma-pcm.o
CC sound/soc/ti/davinci-mcasp.o
AR sound/soc/ti/built-in.a
AR sound/soc/txx9/built-in.a
AR sound/soc/uniphier/built-in.a
AR sound/soc/ux500/built-in.a
AR sound/soc/xilinx/built-in.a
AR sound/soc/xtensa/built-in.a
AR sound/soc/zte/built-in.a
CC sound/soc/soc-core.o
CC sound/soc/soc-dapm.o
CC sound/soc/soc-jack.o
CC sound/soc/soc-utils.o
CC sound/soc/soc-dai.o
CC sound/soc/soc-component.o
CC sound/soc/soc-pcm.o
CC sound/soc/soc-devres.o
CC sound/soc/soc-ops.o
CC sound/soc/soc-link.o
CC sound/soc/soc-card.o
CC sound/soc/soc-generic-dmaengine-pcm.o
AR sound/soc/built-in.a
AR sound/atmel/built-in.a
AR sound/hda/built-in.a
AR sound/x86/built-in.a
AR sound/xen/built-in.a
CC sound/sound_core.o
CC sound/last.o
AR sound/built-in.a
AR samples/vfio-mdev/built-in.a
AR samples/built-in.a
CC net/core/sock.o
CC net/core/request_sock.o
CC net/core/skbuff.o
CC net/core/datagram.o
CC net/core/stream.o
CC net/core/scm.o
CC net/core/gen_stats.o
CC net/core/gen_estimator.o
CC net/core/net_namespace.o
CC net/core/secure_seq.o
CC net/core/flow_dissector.o
CC net/core/sysctl_net_core.o
CC net/core/dev.o
CC net/core/dev_addr_lists.o
CC net/core/dst.o
CC net/core/netevent.o
CC net/core/neighbour.o
CC net/core/rtnetlink.o
CC net/core/utils.o
CC net/core/link_watch.o
CC net/core/filter.o
CC net/core/sock_diag.o
CC net/core/dev_ioctl.o
CC net/core/tso.o
CC net/core/sock_reuseport.o
CC net/core/fib_notifier.o
CC net/core/xdp.o
CC net/core/flow_offload.o
CC net/core/net-sysfs.o
CC net/core/page_pool.o
CC net/core/net-procfs.o
CC net/core/ptp_classifier.o
CC net/core/netclassid_cgroup.o
CC net/core/dst_cache.o
CC net/core/devlink.o
CC net/core/gro_cells.o
CC net/core/failover.o
CC net/core/bpf_sk_storage.o
AR net/core/built-in.a
CC net/ethernet/eth.o
AR net/ethernet/built-in.a
AR net/802/built-in.a
CC net/sched/sch_generic.o
CC net/sched/sch_mq.o
CC net/sched/sch_api.o
CC net/sched/sch_blackhole.o
CC net/sched/cls_api.o
CC net/sched/act_api.o
CC net/sched/sch_fifo.o
CC net/sched/ematch.o
AR net/sched/built-in.a
CC net/netlink/af_netlink.o
CC net/netlink/genetlink.o
CC net/netlink/policy.o
AR net/netlink/built-in.a
CC net/bpf/test_run.o
AR net/bpf/built-in.a
CC net/ethtool/ioctl.o
CC net/ethtool/common.o
CC net/ethtool/netlink.o
CC net/ethtool/bitset.o
CC net/ethtool/strset.o
CC net/ethtool/linkinfo.o
CC net/ethtool/linkmodes.o
CC net/ethtool/linkstate.o
CC net/ethtool/debug.o
CC net/ethtool/wol.o
CC net/ethtool/features.o
CC net/ethtool/privflags.o
CC net/ethtool/rings.o
CC net/ethtool/channels.o
CC net/ethtool/coalesce.o
CC net/ethtool/pause.o
CC net/ethtool/eee.o
CC net/ethtool/tsinfo.o
CC net/ethtool/cabletest.o
CC net/ethtool/tunnels.o
AR net/ethtool/built-in.a
CC net/netfilter/core.o
CC net/netfilter/nf_log.o
CC net/netfilter/nf_queue.o
CC net/netfilter/nf_sockopt.o
CC net/netfilter/utils.o
AR net/netfilter/built-in.a
AR net/ipv4/netfilter/built-in.a
CC net/ipv4/route.o
CC net/ipv4/inetpeer.o
CC net/ipv4/protocol.o
CC net/ipv4/ip_input.o
CC net/ipv4/ip_fragment.o
CC net/ipv4/ip_forward.o
CC net/ipv4/ip_options.o
CC net/ipv4/ip_output.o
CC net/ipv4/ip_sockglue.o
CC net/ipv4/inet_hashtables.o
CC net/ipv4/inet_timewait_sock.o
CC net/ipv4/inet_connection_sock.o
CC net/ipv4/tcp.o
CC net/ipv4/tcp_input.o
CC net/ipv4/tcp_output.o
CC net/ipv4/tcp_timer.o
CC net/ipv4/tcp_ipv4.o
CC net/ipv4/tcp_minisocks.o
CC net/ipv4/tcp_cong.o
CC net/ipv4/tcp_metrics.o
CC net/ipv4/tcp_fastopen.o
CC net/ipv4/tcp_rate.o
CC net/ipv4/tcp_recovery.o
CC net/ipv4/tcp_ulp.o
CC net/ipv4/tcp_offload.o
CC net/ipv4/datagram.o
CC net/ipv4/raw.o
CC net/ipv4/udp.o
CC net/ipv4/udplite.o
CC net/ipv4/udp_offload.o
CC net/ipv4/arp.o
CC net/ipv4/icmp.o
CC net/ipv4/devinet.o
CC net/ipv4/af_inet.o
CC net/ipv4/igmp.o
CC net/ipv4/fib_frontend.o
CC net/ipv4/fib_semantics.o
CC net/ipv4/fib_trie.o
CC net/ipv4/fib_notifier.o
CC net/ipv4/inet_fragment.o
CC net/ipv4/ping.o
CC net/ipv4/ip_tunnel_core.o
CC net/ipv4/gre_offload.o
CC net/ipv4/metrics.o
CC net/ipv4/netlink.o
CC net/ipv4/nexthop.o
CC net/ipv4/udp_tunnel_stub.o
CC net/ipv4/sysctl_net_ipv4.o
CC net/ipv4/proc.o
CC net/ipv4/ipconfig.o
CC net/ipv4/netfilter.o
CC net/ipv4/inet_diag.o
CC net/ipv4/tcp_diag.o
CC net/ipv4/tcp_cubic.o
CC net/ipv4/xfrm4_policy.o
CC net/ipv4/xfrm4_state.o
CC net/ipv4/xfrm4_input.o
CC net/ipv4/xfrm4_output.o
CC net/ipv4/xfrm4_protocol.o
CC net/ipv4/bpf_tcp_ca.o
AR net/ipv4/built-in.a
CC net/xfrm/xfrm_policy.o
CC net/xfrm/xfrm_state.o
CC net/xfrm/xfrm_hash.o
CC net/xfrm/xfrm_input.o
CC net/xfrm/xfrm_output.o
CC net/xfrm/xfrm_sysctl.o
CC net/xfrm/xfrm_replay.o
CC net/xfrm/xfrm_device.o
AR net/xfrm/built-in.a
CC net/unix/af_unix.o
CC net/unix/garbage.o
CC net/unix/sysctl_net_unix.o
CC net/unix/scm.o
AR net/unix/built-in.a
AR net/ipv6/netfilter/built-in.a
CC net/ipv6/addrconf_core.o
CC net/ipv6/exthdrs_core.o
CC net/ipv6/ip6_checksum.o
CC net/ipv6/ip6_icmp.o
CC net/ipv6/output_core.o
CC net/ipv6/protocol.o
CC net/ipv6/ip6_offload.o
CC net/ipv6/tcpv6_offload.o
CC net/ipv6/exthdrs_offload.o
CC net/ipv6/inet6_hashtables.o
CC net/ipv6/mcast_snoop.o
AR net/ipv6/built-in.a
CC net/packet/af_packet.o
AR net/packet/built-in.a
CC net/sunrpc/auth_gss/auth_gss.o
CC net/sunrpc/auth_gss/gss_generic_token.o
CC net/sunrpc/auth_gss/gss_mech_switch.o
CC net/sunrpc/auth_gss/svcauth_gss.o
CC net/sunrpc/auth_gss/gss_rpc_upcall.o
CC net/sunrpc/auth_gss/gss_rpc_xdr.o
CC net/sunrpc/auth_gss/trace.o
AR net/sunrpc/auth_gss/built-in.a
CC net/sunrpc/clnt.o
CC net/sunrpc/xprt.o
CC net/sunrpc/socklib.o
CC net/sunrpc/xprtsock.o
CC net/sunrpc/sched.o
CC net/sunrpc/auth.o
CC net/sunrpc/auth_null.o
CC net/sunrpc/auth_unix.o
CC net/sunrpc/svc.o
CC net/sunrpc/svcsock.o
CC net/sunrpc/svcauth.o
CC net/sunrpc/svcauth_unix.o
CC net/sunrpc/addr.o
CC net/sunrpc/rpcb_clnt.o
CC net/sunrpc/timer.o
CC net/sunrpc/xdr.o
CC net/sunrpc/sunrpc_syms.o
CC net/sunrpc/cache.o
CC net/sunrpc/rpc_pipe.o
CC net/sunrpc/svc_xprt.o
CC net/sunrpc/xprtmultipath.o
CC net/sunrpc/backchannel_rqst.o
CC net/sunrpc/stats.o
CC net/sunrpc/sysctl.o
AR net/sunrpc/built-in.a
CC net/8021q/vlan_core.o
AR net/8021q/built-in.a
AR net/wireless/built-in.a
CC net/9p/mod.o
CC net/9p/client.o
CC net/9p/error.o
CC net/9p/protocol.o
CC net/9p/trans_fd.o
CC net/9p/trans_common.o
CC net/9p/trans_virtio.o
AR net/9p/built-in.a
CC net/dns_resolver/dns_key.o
CC net/dns_resolver/dns_query.o
AR net/dns_resolver/built-in.a
CC net/switchdev/switchdev.o
AR net/switchdev/built-in.a
CC net/l3mdev/l3mdev.o
AR net/l3mdev/built-in.a
CC net/xdp/xsk.o
CC net/xdp/xdp_umem.o
CC net/xdp/xsk_queue.o
CC net/xdp/xskmap.o
CC net/xdp/xsk_buff_pool.o
AR net/xdp/built-in.a
CC net/devres.o
CC net/socket.o
CC net/compat.o
CC net/sysctl_net.o
AR net/built-in.a
CC virt/lib/irqbypass.o
AR virt/lib/built-in.a
AR virt/built-in.a
AS arch/arm64/lib/clear_page.o
AS arch/arm64/lib/clear_user.o
AS arch/arm64/lib/copy_from_user.o
AS arch/arm64/lib/copy_in_user.o
AS arch/arm64/lib/copy_page.o
AS arch/arm64/lib/copy_to_user.o
CC arch/arm64/lib/csum.o
CC arch/arm64/lib/delay.o
AS arch/arm64/lib/memchr.o
AS arch/arm64/lib/memcmp.o
AS arch/arm64/lib/memcpy.o
AS arch/arm64/lib/memmove.o
AS arch/arm64/lib/memset.o
AS arch/arm64/lib/strchr.o
AS arch/arm64/lib/strcmp.o
AS arch/arm64/lib/strlen.o
AS arch/arm64/lib/strncmp.o
AS arch/arm64/lib/strnlen.o
AS arch/arm64/lib/strrchr.o
AS arch/arm64/lib/tishift.o
AR arch/arm64/lib/lib.a
AS arch/arm64/lib/crc32.o
AS arch/arm64/lib/mte.o
AR arch/arm64/lib/built-in.a
CC lib/math/div64.o
CC lib/math/gcd.o
CC lib/math/lcm.o
CC lib/math/int_pow.o
CC lib/math/int_sqrt.o
CC lib/math/reciprocal_div.o
CC lib/math/rational.o
AR lib/math/built-in.a
CC lib/crypto/chacha.o
CC lib/crypto/aes.o
CC lib/crypto/blake2s.o
CC lib/crypto/blake2s-generic.o
CC lib/crypto/sha256.o
AR lib/crypto/built-in.a
CC lib/zlib_inflate/inffast.o
CC lib/zlib_inflate/inflate.o
CC lib/zlib_inflate/infutil.o
CC lib/zlib_inflate/inftrees.o
CC lib/zlib_inflate/inflate_syms.o
AR lib/zlib_inflate/built-in.a
CC lib/zlib_deflate/deflate.o
CC lib/zlib_deflate/deftree.o
CC lib/zlib_deflate/deflate_syms.o
AR lib/zlib_deflate/built-in.a
CC lib/lzo/lzo1x_compress.o
CC lib/lzo/lzo1x_decompress_safe.o
AR lib/lzo/built-in.a
CC lib/lz4/lz4_decompress.o
AR lib/lz4/built-in.a
CC lib/zstd/fse_compress.o
CC lib/zstd/huf_compress.o
CC lib/zstd/compress.o
CC lib/zstd/entropy_common.o
CC lib/zstd/fse_decompress.o
CC lib/zstd/zstd_common.o
CC lib/zstd/huf_decompress.o
CC lib/zstd/decompress.o
AR lib/zstd/built-in.a
CC lib/xz/xz_dec_syms.o
CC lib/xz/xz_dec_stream.o
CC lib/xz/xz_dec_lzma2.o
CC lib/xz/xz_dec_bcj.o
AR lib/xz/built-in.a
CC lib/mpi/generic_mpih-lshift.o
CC lib/mpi/generic_mpih-mul1.o
CC lib/mpi/generic_mpih-mul2.o
CC lib/mpi/generic_mpih-mul3.o
CC lib/mpi/generic_mpih-rshift.o
CC lib/mpi/generic_mpih-sub1.o
CC lib/mpi/generic_mpih-add1.o
CC lib/mpi/ec.o
CC lib/mpi/mpicoder.o
CC lib/mpi/mpi-add.o
CC lib/mpi/mpi-bit.o
CC lib/mpi/mpi-cmp.o
CC lib/mpi/mpi-sub-ui.o
CC lib/mpi/mpi-div.o
CC lib/mpi/mpi-inv.o
CC lib/mpi/mpi-mod.o
CC lib/mpi/mpi-mul.o
CC lib/mpi/mpih-cmp.o
CC lib/mpi/mpih-div.o
CC lib/mpi/mpih-mul.o
CC lib/mpi/mpi-pow.o
CC lib/mpi/mpiutil.o
AR lib/mpi/built-in.a
CC lib/fonts/fonts.o
CC lib/fonts/font_8x8.o
CC lib/fonts/font_8x16.o
AR lib/fonts/built-in.a
CC lib/argv_split.o
CC lib/bug.o
CC lib/clz_tab.o
CC lib/cmdline.o
CC lib/cpumask.o
CC lib/ctype.o
CC lib/dec_and_lock.o
CC lib/decompress.o
CC lib/decompress_bunzip2.o
CC lib/decompress_inflate.o
CC lib/decompress_unlz4.o
CC lib/decompress_unlzma.o
CC lib/decompress_unlzo.o
CC lib/decompress_unxz.o
CC lib/decompress_unzstd.o
CC lib/dump_stack.o
CC lib/earlycpio.o
CC lib/extable.o
CC lib/fdt.o
CC lib/fdt_addresses.o
CC lib/fdt_empty_tree.o
CC lib/fdt_ro.o
CC lib/fdt_rw.o
CC lib/fdt_strerror.o
CC lib/fdt_sw.o
CC lib/fdt_wip.o
CC lib/flex_proportions.o
CC lib/idr.o
CC lib/irq_regs.o
CC lib/is_single_threaded.o
CC lib/klist.o
CC lib/kobject.o
CC lib/kobject_uevent.o
CC lib/logic_pio.o
CC lib/memcat_p.o
CC lib/memneq.o
CC lib/nmi_backtrace.o
CC lib/nodemask.o
CC lib/plist.o
CC lib/radix-tree.o
CC lib/ratelimit.o
CC lib/rbtree.o
CC lib/seq_buf.o
CC lib/sha1.o
CC lib/show_mem.o
CC lib/siphash.o
CC lib/string.o
CC lib/timerqueue.o
CC lib/vsprintf.o
CC lib/win_minmax.o
CC lib/xarray.o
AR lib/lib.a
CC lib/lockref.o
CC lib/bcd.o
CC lib/sort.o
CC lib/parser.o
CC lib/debug_locks.o
CC lib/random32.o
CC lib/bust_spinlocks.o
CC lib/kasprintf.o
CC lib/bitmap.o
CC lib/scatterlist.o
CC lib/list_sort.o
CC lib/uuid.o
CC lib/iov_iter.o
CC lib/clz_ctz.o
CC lib/bsearch.o
CC lib/find_bit.o
CC lib/llist.o
CC lib/memweight.o
CC lib/kfifo.o
CC lib/percpu-refcount.o
CC lib/rhashtable.o
CC lib/once.o
CC lib/refcount.o
CC lib/usercopy.o
CC lib/errseq.o
CC lib/bucket_locks.o
CC lib/generic-radix-tree.o
CC lib/string_helpers.o
CC lib/hexdump.o
CC lib/kstrtox.o
CC lib/pci_iomap.o
CC lib/iomap_copy.o
CC lib/devres.o
CC lib/hweight.o
CC lib/assoc_array.o
CC lib/bitrev.o
CC lib/linear_ranges.o
CC lib/crc16.o
CC lib/crc-t10dif.o
CC lib/crc-itu-t.o
HOSTCC lib/gen_crc32table
GEN lib/crc32table.h
CC lib/crc32.o
CC lib/crc7.o
CC lib/xxhash.o
CC lib/genalloc.o
CC lib/bch.o
CC lib/textsearch.o
CC lib/percpu_counter.o
CC lib/syscall.o
CC lib/errname.o
CC lib/nlattr.o
CC lib/checksum.o
CC lib/cpu_rmap.o
CC lib/dynamic_queue_limits.o
CC lib/glob.o
CC lib/strncpy_from_user.o
CC lib/strnlen_user.o
CC lib/net_utils.o
CC lib/sg_split.o
CC lib/sg_pool.o
CC lib/irq_poll.o
CC lib/asn1_decoder.o
GEN lib/oid_registry_data.c
CC lib/oid_registry.o
CC lib/ucs2_string.o
CC lib/sbitmap.o
AR lib/built-in.a
GEN .version
CHK include/generated/compile.h
LD vmlinux.o
MODPOST vmlinux.symvers
MODINFO modules.builtin.modinfo
GEN modules.builtin
LD .tmp_vmlinux.kallsyms1
KSYMS .tmp_vmlinux.kallsyms1.S
AS .tmp_vmlinux.kallsyms1.S
LD .tmp_vmlinux.kallsyms2
KSYMS .tmp_vmlinux.kallsyms2.S
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
SORTTAB vmlinux
SYSMAP System.map
OBJCOPY arch/arm64/boot/Image
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
make: *** No rule to make target 'make'. Stop.
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
CALL scripts/checksyscalls.sh
CALL scripts/atomic/check-atomics.sh
CC [M] arch/arm64/crypto/sha512-ce-glue.o
AS [M] arch/arm64/crypto/sha512-ce-core.o
LD [M] arch/arm64/crypto/sha512-ce.o
CC [M] arch/arm64/crypto/sha3-ce-glue.o
AS [M] arch/arm64/crypto/sha3-ce-core.o
LD [M] arch/arm64/crypto/sha3-ce.o
CC [M] arch/arm64/crypto/sm3-ce-glue.o
AS [M] arch/arm64/crypto/sm3-ce-core.o
LD [M] arch/arm64/crypto/sm3-ce.o
AS [M] arch/arm64/crypto/crct10dif-ce-core.o
CC [M] arch/arm64/crypto/crct10dif-ce-glue.o
LD [M] arch/arm64/crypto/crct10dif-ce.o
CC [M] arch/arm64/crypto/aes-glue-neon.o
AS [M] arch/arm64/crypto/aes-neon.o
LD [M] arch/arm64/crypto/aes-neon-blk.o
CC [M] arch/arm64/crypto/sha512-glue.o
SHIPPED arch/arm64/crypto/sha512-core.S
AS [M] arch/arm64/crypto/sha512-core.o
LD [M] arch/arm64/crypto/sha512-arm64.o
AS [M] arch/arm64/crypto/chacha-neon-core.o
CC [M] arch/arm64/crypto/chacha-neon-glue.o
LD [M] arch/arm64/crypto/chacha-neon.o
AS [M] arch/arm64/crypto/aes-neonbs-core.o
CC [M] arch/arm64/crypto/aes-neonbs-glue.o
LD [M] arch/arm64/crypto/aes-neon-bs.o
CC [M] fs/nfs/blocklayout/blocklayout.o
CC [M] fs/nfs/blocklayout/dev.o
CC [M] fs/nfs/blocklayout/extent_tree.o
CC [M] fs/nfs/blocklayout/rpc_pipefs.o
LD [M] fs/nfs/blocklayout/blocklayoutdriver.o
CC [M] fs/cifs/trace.o
CC [M] fs/cifs/cifsfs.o
CC [M] fs/cifs/cifssmb.o
CC [M] fs/cifs/cifs_debug.o
CC [M] fs/cifs/connect.o
CC [M] fs/cifs/dir.o
CC [M] fs/cifs/file.o
CC [M] fs/cifs/inode.o
CC [M] fs/cifs/link.o
CC [M] fs/cifs/misc.o
CC [M] fs/cifs/netmisc.o
CC [M] fs/cifs/smbencrypt.o
CC [M] fs/cifs/transport.o
CC [M] fs/cifs/asn1.o
CC [M] fs/cifs/cifs_unicode.o
CC [M] fs/cifs/nterr.o
CC [M] fs/cifs/cifsencrypt.o
CC [M] fs/cifs/readdir.o
CC [M] fs/cifs/ioctl.o
CC [M] fs/cifs/sess.o
CC [M] fs/cifs/export.o
CC [M] fs/cifs/smb1ops.o
CC [M] fs/cifs/winucase.o
CC [M] fs/cifs/smb2ops.o
CC [M] fs/cifs/smb2maperror.o
CC [M] fs/cifs/smb2transport.o
CC [M] fs/cifs/smb2misc.o
CC [M] fs/cifs/smb2pdu.o
CC [M] fs/cifs/smb2inode.o
CC [M] fs/cifs/smb2file.o
CC [M] fs/cifs/cifsacl.o
CC [M] fs/cifs/fs_context.o
CC [M] fs/cifs/xattr.o
LD [M] fs/cifs/cifs.o
CC [M] fs/fuse/dev.o
CC [M] fs/fuse/dir.o
CC [M] fs/fuse/file.o
CC [M] fs/fuse/inode.o
CC [M] fs/fuse/control.o
CC [M] fs/fuse/xattr.o
CC [M] fs/fuse/acl.o
CC [M] fs/fuse/readdir.o
LD [M] fs/fuse/fuse.o
CC [M] fs/fuse/cuse.o
CC [M] fs/overlayfs/super.o
CC [M] fs/overlayfs/namei.o
CC [M] fs/overlayfs/util.o
CC [M] fs/overlayfs/inode.o
CC [M] fs/overlayfs/file.o
CC [M] fs/overlayfs/dir.o
CC [M] fs/overlayfs/readdir.o
CC [M] fs/overlayfs/copy_up.o
CC [M] fs/overlayfs/export.o
LD [M] fs/overlayfs/overlay.o
CC [M] fs/btrfs/super.o
CC [M] fs/btrfs/ctree.o
CC [M] fs/btrfs/extent-tree.o
CC [M] fs/btrfs/print-tree.o
CC [M] fs/btrfs/root-tree.o
CC [M] fs/btrfs/dir-item.o
CC [M] fs/btrfs/file-item.o
CC [M] fs/btrfs/inode-item.o
CC [M] fs/btrfs/inode-map.o
CC [M] fs/btrfs/disk-io.o
CC [M] fs/btrfs/transaction.o
CC [M] fs/btrfs/inode.o
CC [M] fs/btrfs/file.o
CC [M] fs/btrfs/tree-defrag.o
CC [M] fs/btrfs/extent_map.o
CC [M] fs/btrfs/sysfs.o
CC [M] fs/btrfs/struct-funcs.o
CC [M] fs/btrfs/xattr.o
CC [M] fs/btrfs/ordered-data.o
CC [M] fs/btrfs/extent_io.o
CC [M] fs/btrfs/volumes.o
CC [M] fs/btrfs/async-thread.o
CC [M] fs/btrfs/ioctl.o
CC [M] fs/btrfs/locking.o
CC [M] fs/btrfs/orphan.o
CC [M] fs/btrfs/export.o
CC [M] fs/btrfs/tree-log.o
CC [M] fs/btrfs/free-space-cache.o
CC [M] fs/btrfs/zlib.o
CC [M] fs/btrfs/lzo.o
CC [M] fs/btrfs/zstd.o
CC [M] fs/btrfs/compression.o
CC [M] fs/btrfs/delayed-ref.o
CC [M] fs/btrfs/relocation.o
CC [M] fs/btrfs/delayed-inode.o
CC [M] fs/btrfs/scrub.o
CC [M] fs/btrfs/reada.o
CC [M] fs/btrfs/backref.o
CC [M] fs/btrfs/ulist.o
CC [M] fs/btrfs/qgroup.o
CC [M] fs/btrfs/send.o
CC [M] fs/btrfs/dev-replace.o
CC [M] fs/btrfs/raid56.o
CC [M] fs/btrfs/uuid-tree.o
CC [M] fs/btrfs/props.o
CC [M] fs/btrfs/free-space-tree.o
CC [M] fs/btrfs/tree-checker.o
CC [M] fs/btrfs/space-info.o
CC [M] fs/btrfs/block-rsv.o
CC [M] fs/btrfs/delalloc-space.o
CC [M] fs/btrfs/block-group.o
CC [M] fs/btrfs/discard.o
CC [M] fs/btrfs/reflink.o
CC [M] fs/btrfs/acl.o
LD [M] fs/btrfs/btrfs.o
CC [M] crypto/seqiv.o
CC [M] crypto/cmac.o
CC [M] crypto/md4.o
CC [M] crypto/md5.o
CC [M] crypto/sha512_generic.o
CC [M] crypto/sha3_generic.o
CC [M] crypto/sm3_generic.o
CC [M] crypto/blake2b_generic.o
CC [M] crypto/ecb.o
CC [M] crypto/cbc.o
CC [M] crypto/xts.o
CC [M] crypto/ctr.o
CC [M] crypto/gcm.o
CC [M] crypto/ccm.o
CC [M] crypto/des_generic.o
CC [M] crypto/sm4_generic.o
CC [M] crypto/authenc.o
CC [M] crypto/authencesn.o
CC [M] crypto/xxhash_generic.o
CC [M] crypto/tcrypt.o
CC [M] crypto/ghash-generic.o
CC [M] crypto/af_alg.o
CC [M] crypto/algif_hash.o
CC [M] crypto/algif_rng.o
CC [M] crypto/ecc.o
CC [M] crypto/ecdh.o
CC [M] crypto/ecdh_helper.o
LD [M] crypto/ecdh_generic.o
CC [M] crypto/xor.o
CC [M] drivers/irqchip/irq-pruss-intc.o
CC [M] drivers/phy/cadence/cdns-dphy.o
CC [M] drivers/phy/freescale/phy-fsl-imx8-mipi-dphy.o
CC [M] drivers/phy/ti/phy-omap-usb2.o
CC [M] drivers/phy/phy-can-transceiver.o
CC [M] drivers/gpio/gpio-altera.o
CC [M] drivers/gpio/gpio-bd9571mwv.o
CC [M] drivers/gpio/gpio-pisosr.o
CC [M] drivers/gpio/gpio-tpic2810.o
CC [M] drivers/gpio/gpio-wcd934x.o
CC [M] drivers/pwm/pwm-cros-ec.o
CC [M] drivers/video/backlight/lp855x_bl.o
CC [M] drivers/char/ipmi/ipmi_msghandler.o
CC [M] drivers/char/ipmi/ipmi_devintf.o
CC [M] drivers/char/ipmi/ipmi_si_intf.o
CC [M] drivers/char/ipmi/ipmi_kcs_sm.o
CC [M] drivers/char/ipmi/ipmi_smic_sm.o
CC [M] drivers/char/ipmi/ipmi_bt_sm.o
CC [M] drivers/char/ipmi/ipmi_si_hotmod.o
CC [M] drivers/char/ipmi/ipmi_si_hardcode.o
CC [M] drivers/char/ipmi/ipmi_si_platform.o
CC [M] drivers/char/ipmi/ipmi_si_port_io.o
CC [M] drivers/char/ipmi/ipmi_si_mem_io.o
CC [M] drivers/char/ipmi/ipmi_si_pci.o
LD [M] drivers/char/ipmi/ipmi_si.o
CC [M] drivers/clk/clk-bd718x7.o
CC [M] drivers/soc/ti/pruss.o
CC [M] drivers/regulator/vctrl-regulator.o
CC [M] drivers/tty/serial/8250/8250_pruss.o
CC [M] drivers/char/hw_random/core.o
LD [M] drivers/char/hw_random/rng-core.o
CC [M] drivers/char/hw_random/omap-rng.o
CC [M] drivers/char/hw_random/optee-rng.o
CC [M] drivers/gpu/drm/arm/malidp_drv.o
CC [M] drivers/gpu/drm/arm/malidp_hw.o
CC [M] drivers/gpu/drm/arm/malidp_planes.o
CC [M] drivers/gpu/drm/arm/malidp_crtc.o
CC [M] drivers/gpu/drm/arm/malidp_mw.o
LD [M] drivers/gpu/drm/arm/mali-dp.o
CC [M] drivers/gpu/drm/rcar-du/rcar_dw_hdmi.o
CC [M] drivers/gpu/drm/panel/panel-lvds.o
CC [M] drivers/gpu/drm/panel/panel-raydium-rm67191.o
CC [M] drivers/gpu/drm/panel/panel-sitronix-st7703.o
CC [M] drivers/gpu/drm/panel/panel-truly-nt35597.o
CC [M] drivers/gpu/drm/bridge/cadence/cdns-mhdp8546-core.o
CC [M] drivers/gpu/drm/bridge/cadence/cdns-mhdp8546-j721e.o
LD [M] drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.o
CC [M] drivers/gpu/drm/bridge/cadence/cdns-dsi-core.o
CC [M] drivers/gpu/drm/bridge/cadence/cdns-dsi-j721e.o
LD [M] drivers/gpu/drm/bridge/cadence/cdns-dsi.o
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi.o
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-ahb-audio.o
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-cec.o
CC [M] drivers/gpu/drm/bridge/lontium-lt9611.o
CC [M] drivers/gpu/drm/bridge/simple-bridge.o
CC [M] drivers/gpu/drm/bridge/thc63lvd1024.o
CC [M] drivers/gpu/drm/bridge/ti-sn65dsi86.o
CC [M] drivers/gpu/drm/bridge/nwl-dsi.o
CC [M] drivers/gpu/drm/tiny/ili9225.o
CC [M] drivers/gpu/drm/drm_mipi_dbi.o
CC [M] drivers/base/regmap/regmap-slimbus.o
CC [M] drivers/base/regmap/regmap-spmi.o
CC [M] drivers/base/regmap/regmap-sdw.o
CC [M] drivers/block/nbd.o
CC [M] drivers/misc/eeprom/at24.o
CC [M] drivers/misc/eeprom/at25.o
CC [M] drivers/misc/eeprom/eeprom_93xx46.o
CC [M] drivers/misc/uacce/uacce.o
CC [M] drivers/misc/pci_endpoint_test.o
CC [M] drivers/misc/mytest.o
CC [M] drivers/mfd/ti_am335x_tscadc.o
CC [M] drivers/mfd/wcd934x.o
CC [M] drivers/nfc/s3fwrn5/core.o
CC [M] drivers/nfc/s3fwrn5/firmware.o
CC [M] drivers/nfc/s3fwrn5/nci.o
LD [M] drivers/nfc/s3fwrn5/s3fwrn5.o
CC [M] drivers/nfc/s3fwrn5/i2c.o
LD [M] drivers/nfc/s3fwrn5/s3fwrn5_i2c.o
CC [M] drivers/scsi/libsas/sas_init.o
CC [M] drivers/scsi/libsas/sas_phy.o
CC [M] drivers/scsi/libsas/sas_port.o
CC [M] drivers/scsi/libsas/sas_event.o
CC [M] drivers/scsi/libsas/sas_discover.o
CC [M] drivers/scsi/libsas/sas_expander.o
CC [M] drivers/scsi/libsas/sas_scsi_host.o
CC [M] drivers/scsi/libsas/sas_task.o
CC [M] drivers/scsi/libsas/sas_ata.o
CC [M] drivers/scsi/libsas/sas_host_smp.o
LD [M] drivers/scsi/libsas/libsas.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_base.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_config.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_scsih.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_transport.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_ctl.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_trigger_diag.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_warpdrive.o
CC [M] drivers/scsi/mpt3sas/mpt3sas_debugfs.o
LD [M] drivers/scsi/mpt3sas/mpt3sas.o
CC [M] drivers/scsi/hisi_sas/hisi_sas_main.o
CC [M] drivers/scsi/hisi_sas/hisi_sas_v1_hw.o
CC [M] drivers/scsi/hisi_sas/hisi_sas_v2_hw.o
CC [M] drivers/scsi/raid_class.o
CC [M] drivers/scsi/scsi_transport_sas.o
CC [M] drivers/nvme/host/core.o
LD [M] drivers/nvme/host/nvme-core.o
CC [M] drivers/nvme/host/pci.o
LD [M] drivers/nvme/host/nvme.o
CC [M] drivers/mtd/tests/oobtest.o
CC [M] drivers/mtd/tests/mtd_test.o
LD [M] drivers/mtd/tests/mtd_oobtest.o
CC [M] drivers/mtd/tests/pagetest.o
LD [M] drivers/mtd/tests/mtd_pagetest.o
CC [M] drivers/mtd/tests/readtest.o
LD [M] drivers/mtd/tests/mtd_readtest.o
CC [M] drivers/mtd/tests/speedtest.o
LD [M] drivers/mtd/tests/mtd_speedtest.o
CC [M] drivers/mtd/tests/stresstest.o
LD [M] drivers/mtd/tests/mtd_stresstest.o
CC [M] drivers/mtd/tests/subpagetest.o
LD [M] drivers/mtd/tests/mtd_subpagetest.o
CC [M] drivers/mtd/tests/torturetest.o
LD [M] drivers/mtd/tests/mtd_torturetest.o
CC [M] drivers/mtd/tests/mtd_nandecctest.o
CC [M] drivers/mtd/tests/nandbiterrs.o
LD [M] drivers/mtd/tests/mtd_nandbiterrs.o
CC [M] drivers/spi/spidev.o
CC [M] drivers/net/phy/marvell10g.o
CC [M] drivers/net/phy/microchip.o
CC [M] drivers/net/phy/realtek.o
CC [M] drivers/net/phy/smsc.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_stats.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_dcb.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_sp.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_self_test.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_vfpf.o
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x_sriov.o
LD [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x.o
CC [M] drivers/net/ethernet/broadcom/tg3.o
CC [M] drivers/net/ethernet/intel/e1000/e1000_main.o
CC [M] drivers/net/ethernet/intel/e1000/e1000_hw.o
CC [M] drivers/net/ethernet/intel/e1000/e1000_ethtool.o
CC [M] drivers/net/ethernet/intel/e1000/e1000_param.o
LD [M] drivers/net/ethernet/intel/e1000/e1000.o
CC [M] drivers/net/ethernet/intel/e1000e/82571.o
CC [M] drivers/net/ethernet/intel/e1000e/ich8lan.o
CC [M] drivers/net/ethernet/intel/e1000e/80003es2lan.o
CC [M] drivers/net/ethernet/intel/e1000e/mac.o
CC [M] drivers/net/ethernet/intel/e1000e/manage.o
CC [M] drivers/net/ethernet/intel/e1000e/nvm.o
CC [M] drivers/net/ethernet/intel/e1000e/phy.o
CC [M] drivers/net/ethernet/intel/e1000e/param.o
CC [M] drivers/net/ethernet/intel/e1000e/ethtool.o
CC [M] drivers/net/ethernet/intel/e1000e/netdev.o
CC [M] drivers/net/ethernet/intel/e1000e/ptp.o
LD [M] drivers/net/ethernet/intel/e1000e/e1000e.o
CC [M] drivers/net/ethernet/marvell/skge.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-mac.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-phy.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-sgmii.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-ethtool.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-sgmii-fsm9900.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-sgmii-qdf2432.o
CC [M] drivers/net/ethernet/qualcomm/emac/emac-sgmii-qdf2400.o
LD [M] drivers/net/ethernet/qualcomm/emac/qcom-emac.o
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet_config.o
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet_vnd.o
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet_handlers.o
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet_map_data.o
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet_map_command.o
LD [M] drivers/net/ethernet/qualcomm/rmnet/rmnet.o
CC [M] drivers/net/ethernet/qualcomm/qca_7k_common.o
CC [M] drivers/net/ethernet/qualcomm/qca_7k.o
CC [M] drivers/net/ethernet/qualcomm/qca_debug.o
CC [M] drivers/net/ethernet/qualcomm/qca_spi.o
LD [M] drivers/net/ethernet/qualcomm/qcaspi.o
CC [M] drivers/net/ethernet/qualcomm/qca_uart.o
LD [M] drivers/net/ethernet/qualcomm/qcauart.o
CC [M] drivers/net/ethernet/ti/j721e-cpsw-virt-mac.o
LD [M] drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.o
CC [M] drivers/net/ethernet/ti/prueth_core.o
CC [M] drivers/net/ethernet/ti/prueth_qos.o
CC [M] drivers/net/ethernet/ti/prueth_switch.o
CC [M] drivers/net/ethernet/ti/prueth_lre.o
LD [M] drivers/net/ethernet/ti/prueth.o
CC [M] drivers/net/ethernet/ti/icss_iep.o
CC [M] drivers/net/ethernet/ti/icssg_prueth.o
CC [M] drivers/net/ethernet/ti/icssg_classifier.o
CC [M] drivers/net/ethernet/ti/icssg_ethtool.o
CC [M] drivers/net/ethernet/ti/icssg_queues.o
CC [M] drivers/net/ethernet/ti/icssg_config.o
CC [M] drivers/net/ethernet/ti/icssg_mii_cfg.o
CC [M] drivers/net/ethernet/ti/icssg_switchdev.o
CC [M] drivers/net/ethernet/ti/icssg_qos.o
LD [M] drivers/net/ethernet/ti/icssg-prueth.o
CC [M] drivers/net/wireless/ath/ath10k/mac.o
CC [M] drivers/net/wireless/ath/ath10k/debug.o
CC [M] drivers/net/wireless/ath/ath10k/core.o
CC [M] drivers/net/wireless/ath/ath10k/htc.o
CC [M] drivers/net/wireless/ath/ath10k/htt.o
CC [M] drivers/net/wireless/ath/ath10k/htt_rx.o
CC [M] drivers/net/wireless/ath/ath10k/htt_tx.o
CC [M] drivers/net/wireless/ath/ath10k/txrx.o
CC [M] drivers/net/wireless/ath/ath10k/wmi.o
CC [M] drivers/net/wireless/ath/ath10k/wmi-tlv.o
CC [M] drivers/net/wireless/ath/ath10k/bmi.o
CC [M] drivers/net/wireless/ath/ath10k/hw.o
CC [M] drivers/net/wireless/ath/ath10k/p2p.o
CC [M] drivers/net/wireless/ath/ath10k/swap.o
CC [M] drivers/net/wireless/ath/ath10k/testmode.o
CC [M] drivers/net/wireless/ath/ath10k/thermal.o
CC [M] drivers/net/wireless/ath/ath10k/wow.o
CC [M] drivers/net/wireless/ath/ath10k/coredump.o
CC [M] drivers/net/wireless/ath/ath10k/ce.o
LD [M] drivers/net/wireless/ath/ath10k/ath10k_core.o
CC [M] drivers/net/wireless/ath/ath10k/pci.o
LD [M] drivers/net/wireless/ath/ath10k/ath10k_pci.o
CC [M] drivers/net/wireless/ath/main.o
CC [M] drivers/net/wireless/ath/regd.o
CC [M] drivers/net/wireless/ath/hw.o
CC [M] drivers/net/wireless/ath/key.o
CC [M] drivers/net/wireless/ath/dfs_pattern_detector.o
CC [M] drivers/net/wireless/ath/dfs_pri_detector.o
LD [M] drivers/net/wireless/ath/ath.o
CC [M] drivers/net/wireless/broadcom/b43/main.o
CC [M] drivers/net/wireless/broadcom/b43/bus.o
CC [M] drivers/net/wireless/broadcom/b43/phy_g.o
CC [M] drivers/net/wireless/broadcom/b43/tables.o
CC [M] drivers/net/wireless/broadcom/b43/lo.o
CC [M] drivers/net/wireless/broadcom/b43/wa.o
CC [M] drivers/net/wireless/broadcom/b43/tables_nphy.o
CC [M] drivers/net/wireless/broadcom/b43/radio_2055.o
CC [M] drivers/net/wireless/broadcom/b43/radio_2056.o
CC [M] drivers/net/wireless/broadcom/b43/radio_2057.o
CC [M] drivers/net/wireless/broadcom/b43/phy_common.o
CC [M] drivers/net/wireless/broadcom/b43/phy_n.o
CC [M] drivers/net/wireless/broadcom/b43/phy_lp.o
CC [M] drivers/net/wireless/broadcom/b43/tables_lpphy.o
CC [M] drivers/net/wireless/broadcom/b43/phy_ht.o
CC [M] drivers/net/wireless/broadcom/b43/tables_phy_ht.o
CC [M] drivers/net/wireless/broadcom/b43/radio_2059.o
CC [M] drivers/net/wireless/broadcom/b43/sysfs.o
CC [M] drivers/net/wireless/broadcom/b43/xmit.o
CC [M] drivers/net/wireless/broadcom/b43/dma.o
CC [M] drivers/net/wireless/broadcom/b43/pio.o
CC [M] drivers/net/wireless/broadcom/b43/rfkill.o
CC [M] drivers/net/wireless/broadcom/b43/ppr.o
CC [M] drivers/net/wireless/broadcom/b43/leds.o
LD [M] drivers/net/wireless/broadcom/b43/b43.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmutil/utils.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmutil/d11.o
LD [M] drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/chip.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/fwil.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/fweh.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/p2p.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/proto.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/common.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/core.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/firmware.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/feature.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/btcoex.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/vendor.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/pno.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/bcdc.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/fwsignal.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/bcmsdh.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/of.o
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/dmi.o
LD [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/main.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/rs.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/mac80211.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/ucode.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/tx.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/lib.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/calib.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/tt.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/sta.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/rx.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/power.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/scan.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/rxon.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/devices.o
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/led.o
LD [M] drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/fw.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/mac80211.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/nvm.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/ops.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/phy-ctxt.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/mac-ctxt.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/utils.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/rx.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/rxmq.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/tx.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/binding.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/quota.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/sta.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/sf.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/scan.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/time-event.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/rs.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/rs-fw.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/power.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/coex.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/tt.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/offloading.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/tdls.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/ftm-responder.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/ftm-initiator.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/led.o
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/d3.o
LD [M] drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-io.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-drv.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-debug.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-eeprom-read.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-eeprom-parse.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-phy-db.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-nvm-parse.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/drv.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/rx.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/tx.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/trans.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/ctxt-info.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/ctxt-info-gen3.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/trans-gen2.o
CC [M] drivers/net/wireless/intel/iwlwifi/pcie/tx-gen2.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-dbg-tlv.o
CC [M] drivers/net/wireless/intel/iwlwifi/iwl-trans.o
CC [M] drivers/net/wireless/intel/iwlwifi/queue/tx.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/img.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/notif-wait.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/dbg.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/pnvm.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/1000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/2000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/5000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/6000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/7000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/8000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/9000.o
CC [M] drivers/net/wireless/intel/iwlwifi/cfg/22000.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/paging.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/smem.o
CC [M] drivers/net/wireless/intel/iwlwifi/fw/init.o
LD [M] drivers/net/wireless/intel/iwlwifi/iwlwifi.o
CC [M] drivers/net/wireless/marvell/mwifiex/main.o
CC [M] drivers/net/wireless/marvell/mwifiex/init.o
CC [M] drivers/net/wireless/marvell/mwifiex/cfp.o
CC [M] drivers/net/wireless/marvell/mwifiex/cmdevt.o
CC [M] drivers/net/wireless/marvell/mwifiex/util.o
CC [M] drivers/net/wireless/marvell/mwifiex/txrx.o
CC [M] drivers/net/wireless/marvell/mwifiex/wmm.o
CC [M] drivers/net/wireless/marvell/mwifiex/11n.o
CC [M] drivers/net/wireless/marvell/mwifiex/11ac.o
CC [M] drivers/net/wireless/marvell/mwifiex/11n_aggr.o
CC [M] drivers/net/wireless/marvell/mwifiex/11n_rxreorder.o
CC [M] drivers/net/wireless/marvell/mwifiex/scan.o
CC [M] drivers/net/wireless/marvell/mwifiex/join.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_ioctl.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_cmd.o
CC [M] drivers/net/wireless/marvell/mwifiex/uap_cmd.o
CC [M] drivers/net/wireless/marvell/mwifiex/ie.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_cmdresp.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_event.o
CC [M] drivers/net/wireless/marvell/mwifiex/uap_event.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_tx.o
CC [M] drivers/net/wireless/marvell/mwifiex/sta_rx.o
CC [M] drivers/net/wireless/marvell/mwifiex/uap_txrx.o
CC [M] drivers/net/wireless/marvell/mwifiex/cfg80211.o
CC [M] drivers/net/wireless/marvell/mwifiex/ethtool.o
CC [M] drivers/net/wireless/marvell/mwifiex/11h.o
CC [M] drivers/net/wireless/marvell/mwifiex/tdls.o
CC [M] drivers/net/wireless/marvell/mwifiex/debugfs.o
LD [M] drivers/net/wireless/marvell/mwifiex/mwifiex.o
CC [M] drivers/net/wireless/marvell/mwifiex/pcie.o
LD [M] drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.o
CC [M] drivers/net/wireless/ti/wlcore/main.o
CC [M] drivers/net/wireless/ti/wlcore/cmd.o
CC [M] drivers/net/wireless/ti/wlcore/io.o
CC [M] drivers/net/wireless/ti/wlcore/event.o
CC [M] drivers/net/wireless/ti/wlcore/tx.o
CC [M] drivers/net/wireless/ti/wlcore/rx.o
CC [M] drivers/net/wireless/ti/wlcore/ps.o
CC [M] drivers/net/wireless/ti/wlcore/acx.o
CC [M] drivers/net/wireless/ti/wlcore/boot.o
CC [M] drivers/net/wireless/ti/wlcore/init.o
CC [M] drivers/net/wireless/ti/wlcore/debugfs.o
CC [M] drivers/net/wireless/ti/wlcore/scan.o
CC [M] drivers/net/wireless/ti/wlcore/sysfs.o
CC [M] drivers/net/wireless/ti/wlcore/vendor_cmd.o
CC [M] drivers/net/wireless/ti/wlcore/testmode.o
LD [M] drivers/net/wireless/ti/wlcore/wlcore.o
CC [M] drivers/net/wireless/ti/wlcore/sdio.o
LD [M] drivers/net/wireless/ti/wlcore/wlcore_sdio.o
CC [M] drivers/net/wireless/ti/wl18xx/main.o
CC [M] drivers/net/wireless/ti/wl18xx/acx.o
CC [M] drivers/net/wireless/ti/wl18xx/tx.o
CC [M] drivers/net/wireless/ti/wl18xx/io.o
CC [M] drivers/net/wireless/ti/wl18xx/debugfs.o
CC [M] drivers/net/wireless/ti/wl18xx/scan.o
CC [M] drivers/net/wireless/ti/wl18xx/cmd.o
CC [M] drivers/net/wireless/ti/wl18xx/event.o
LD [M] drivers/net/wireless/ti/wl18xx/wl18xx.o
CC [M] drivers/net/ipvlan/ipvlan_core.o
CC [M] drivers/net/ipvlan/ipvlan_main.o
CC [M] drivers/net/ipvlan/ipvlan_l3s.o
LD [M] drivers/net/ipvlan/ipvlan.o
CC [M] drivers/net/can/dev/dev.o
CC [M] drivers/net/can/dev/rx-offload.o
LD [M] drivers/net/can/dev/can-dev.o
CC [M] drivers/net/can/c_can/c_can.o
CC [M] drivers/net/can/c_can/c_can_platform.o
CC [M] drivers/net/can/m_can/m_can.o
CC [M] drivers/net/can/m_can/m_can_platform.o
CC [M] drivers/net/can/flexcan.o
CC [M] drivers/net/usb/pegasus.o
CC [M] drivers/net/usb/rtl8150.o
CC [M] drivers/net/usb/r8152.o
CC [M] drivers/net/usb/lan78xx.o
CC [M] drivers/net/usb/asix_devices.o
CC [M] drivers/net/usb/asix_common.o
CC [M] drivers/net/usb/ax88172a.o
LD [M] drivers/net/usb/asix.o
CC [M] drivers/net/usb/ax88179_178a.o
CC [M] drivers/net/usb/cdc_ether.o
CC [M] drivers/net/usb/cdc_eem.o
CC [M] drivers/net/usb/dm9601.o
CC [M] drivers/net/usb/sr9800.o
CC [M] drivers/net/usb/smsc75xx.o
CC [M] drivers/net/usb/smsc95xx.o
CC [M] drivers/net/usb/net1080.o
CC [M] drivers/net/usb/plusb.o
CC [M] drivers/net/usb/cdc_subset.o
CC [M] drivers/net/usb/zaurus.o
CC [M] drivers/net/usb/mcs7830.o
CC [M] drivers/net/usb/usbnet.o
CC [M] drivers/net/usb/cdc_ncm.o
CC [M] drivers/net/dummy.o
CC [M] drivers/net/macvlan.o
CC [M] drivers/net/macvtap.o
CC [M] drivers/net/mdio.o
CC [M] drivers/net/tap.o
CC [M] drivers/net/veth.o
CC [M] drivers/net/vxlan.o
CC [M] drivers/net/ntb_netdev.o
CC [M] drivers/usb/phy/phy-generic.o
CC [M] drivers/usb/host/ehci-hcd.o
CC [M] drivers/usb/host/ehci-pci.o
CC [M] drivers/usb/host/ehci-platform.o
CC [M] drivers/usb/host/ohci-hcd.o
CC [M] drivers/usb/host/ohci-pci.o
CC [M] drivers/usb/host/ohci-platform.o
CC [M] drivers/usb/host/xhci.o
CC [M] drivers/usb/host/xhci-mem.o
CC [M] drivers/usb/host/xhci-ext-caps.o
CC [M] drivers/usb/host/xhci-ring.o
CC [M] drivers/usb/host/xhci-hub.o
CC [M] drivers/usb/host/xhci-dbg.o
CC [M] drivers/usb/host/xhci-trace.o
CC [M] drivers/usb/host/xhci-debugfs.o
LD [M] drivers/usb/host/xhci-hcd.o
CC [M] drivers/usb/host/xhci-pci.o
CC [M] drivers/usb/host/xhci-plat.o
LD [M] drivers/usb/host/xhci-plat-hcd.o
CC [M] drivers/usb/common/common.o
LD [M] drivers/usb/common/usb-common.o
CC [M] drivers/usb/common/usb-conn-gpio.o
CC [M] drivers/usb/core/usb.o
CC [M] drivers/usb/core/hub.o
CC [M] drivers/usb/core/hcd.o
CC [M] drivers/usb/core/urb.o
CC [M] drivers/usb/core/message.o
CC [M] drivers/usb/core/driver.o
CC [M] drivers/usb/core/config.o
CC [M] drivers/usb/core/file.o
CC [M] drivers/usb/core/buffer.o
CC [M] drivers/usb/core/sysfs.o
CC [M] drivers/usb/core/endpoint.o
CC [M] drivers/usb/core/devio.o
CC [M] drivers/usb/core/notify.o
CC [M] drivers/usb/core/generic.o
CC [M] drivers/usb/core/quirks.o
CC [M] drivers/usb/core/devices.o
CC [M] drivers/usb/core/phy.o
CC [M] drivers/usb/core/port.o
CC [M] drivers/usb/core/of.o
CC [M] drivers/usb/core/hcd-pci.o
LD [M] drivers/usb/core/usbcore.o
CC [M] drivers/usb/dwc3/core.o
CC [M] drivers/usb/dwc3/host.o
CC [M] drivers/usb/dwc3/gadget.o
CC [M] drivers/usb/dwc3/ep0.o
CC [M] drivers/usb/dwc3/drd.o
CC [M] drivers/usb/dwc3/debugfs.o
LD [M] drivers/usb/dwc3/dwc3.o
CC [M] drivers/usb/dwc3/dwc3-am62.o
CC [M] drivers/usb/dwc3/dwc3-haps.o
CC [M] drivers/usb/dwc3/dwc3-keystone.o
CC [M] drivers/usb/dwc3/dwc3-of-simple.o
CC [M] drivers/usb/isp1760/isp1760-core.o
CC [M] drivers/usb/isp1760/isp1760-if.o
CC [M] drivers/usb/isp1760/isp1760-hcd.o
CC [M] drivers/usb/isp1760/isp1760-udc.o
LD [M] drivers/usb/isp1760/isp1760.o
CC [M] drivers/usb/cdns3/core.o
CC [M] drivers/usb/cdns3/drd.o
CC [M] drivers/usb/cdns3/gadget.o
CC [M] drivers/usb/cdns3/ep0.o
CC [M] drivers/usb/cdns3/host.o
LD [M] drivers/usb/cdns3/cdns3.o
CC [M] drivers/usb/cdns3/cdns3-ti.o
CC [M] drivers/usb/class/cdc-acm.o
CC [M] drivers/usb/storage/scsiglue.o
CC [M] drivers/usb/storage/protocol.o
CC [M] drivers/usb/storage/transport.o
CC [M] drivers/usb/storage/usb.o
CC [M] drivers/usb/storage/initializers.o
CC [M] drivers/usb/storage/sierra_ms.o
CC [M] drivers/usb/storage/option_ms.o
CC [M] drivers/usb/storage/usual-tables.o
LD [M] drivers/usb/storage/usb-storage.o
CC [M] drivers/usb/serial/usb-serial.o
CC [M] drivers/usb/serial/generic.o
CC [M] drivers/usb/serial/bus.o
LD [M] drivers/usb/serial/usbserial.o
CC [M] drivers/usb/serial/cp210x.o
CC [M] drivers/usb/serial/ftdi_sio.o
CC [M] drivers/usb/serial/option.o
CC [M] drivers/usb/serial/pl2303.o
CC [M] drivers/usb/serial/usb_wwan.o
CC [M] drivers/usb/misc/usbtest.o
CC [M] drivers/usb/misc/usb3503.o
CC [M] drivers/usb/musb/musb_core.o
CC [M] drivers/usb/musb/musb_trace.o
CC [M] drivers/usb/musb/musb_virthub.o
CC [M] drivers/usb/musb/musb_host.o
CC [M] drivers/usb/musb/musb_gadget_ep0.o
CC [M] drivers/usb/musb/musb_gadget.o
CC [M] drivers/usb/musb/musb_debugfs.o
LD [M] drivers/usb/musb/musb_hdrc.o
CC [M] drivers/usb/gadget/udc/core.o
CC [M] drivers/usb/gadget/udc/trace.o
LD [M] drivers/usb/gadget/udc/udc-core.o
CC [M] drivers/usb/gadget/function/f_acm.o
LD [M] drivers/usb/gadget/function/usb_f_acm.o
CC [M] drivers/usb/gadget/function/f_loopback.o
CC [M] drivers/usb/gadget/function/f_sourcesink.o
LD [M] drivers/usb/gadget/function/usb_f_ss_lb.o
CC [M] drivers/usb/gadget/function/u_serial.o
CC [M] drivers/usb/gadget/function/f_serial.o
LD [M] drivers/usb/gadget/function/usb_f_serial.o
CC [M] drivers/usb/gadget/function/f_obex.o
LD [M] drivers/usb/gadget/function/usb_f_obex.o
CC [M] drivers/usb/gadget/function/u_ether.o
CC [M] drivers/usb/gadget/function/f_ncm.o
LD [M] drivers/usb/gadget/function/usb_f_ncm.o
CC [M] drivers/usb/gadget/function/f_ecm.o
LD [M] drivers/usb/gadget/function/usb_f_ecm.o
CC [M] drivers/usb/gadget/function/f_eem.o
LD [M] drivers/usb/gadget/function/usb_f_eem.o
CC [M] drivers/usb/gadget/function/f_subset.o
LD [M] drivers/usb/gadget/function/usb_f_ecm_subset.o
CC [M] drivers/usb/gadget/function/f_rndis.o
CC [M] drivers/usb/gadget/function/rndis.o
LD [M] drivers/usb/gadget/function/usb_f_rndis.o
CC [M] drivers/usb/gadget/function/f_mass_storage.o
CC [M] drivers/usb/gadget/function/storage_common.o
LD [M] drivers/usb/gadget/function/usb_f_mass_storage.o
CC [M] drivers/usb/gadget/function/f_fs.o
LD [M] drivers/usb/gadget/function/usb_f_fs.o
CC [M] drivers/usb/gadget/function/u_audio.o
CC [M] drivers/usb/gadget/function/f_uac1.o
LD [M] drivers/usb/gadget/function/usb_f_uac1.o
CC [M] drivers/usb/gadget/function/f_uac2.o
LD [M] drivers/usb/gadget/function/usb_f_uac2.o
CC [M] drivers/usb/gadget/function/f_uvc.o
CC [M] drivers/usb/gadget/function/uvc_queue.o
CC [M] drivers/usb/gadget/function/uvc_v4l2.o
CC [M] drivers/usb/gadget/function/uvc_video.o
CC [M] drivers/usb/gadget/function/uvc_configfs.o
LD [M] drivers/usb/gadget/function/usb_f_uvc.o
CC [M] drivers/usb/gadget/function/f_midi.o
LD [M] drivers/usb/gadget/function/usb_f_midi.o
CC [M] drivers/usb/gadget/function/f_hid.o
LD [M] drivers/usb/gadget/function/usb_f_hid.o
CC [M] drivers/usb/gadget/function/f_printer.o
LD [M] drivers/usb/gadget/function/usb_f_printer.o
CC [M] drivers/usb/gadget/legacy/zero.o
LD [M] drivers/usb/gadget/legacy/g_zero.o
CC [M] drivers/usb/gadget/legacy/audio.o
LD [M] drivers/usb/gadget/legacy/g_audio.o
CC [M] drivers/usb/gadget/legacy/ether.o
LD [M] drivers/usb/gadget/legacy/g_ether.o
CC [M] drivers/usb/gadget/legacy/inode.o
LD [M] drivers/usb/gadget/legacy/gadgetfs.o
CC [M] drivers/usb/gadget/legacy/g_ffs.o
CC [M] drivers/usb/gadget/legacy/mass_storage.o
LD [M] drivers/usb/gadget/legacy/g_mass_storage.o
CC [M] drivers/usb/gadget/legacy/serial.o
LD [M] drivers/usb/gadget/legacy/g_serial.o
CC [M] drivers/usb/gadget/legacy/printer.o
LD [M] drivers/usb/gadget/legacy/g_printer.o
CC [M] drivers/usb/gadget/legacy/gmidi.o
LD [M] drivers/usb/gadget/legacy/g_midi.o
CC [M] drivers/usb/gadget/legacy/cdc2.o
LD [M] drivers/usb/gadget/legacy/g_cdc.o
CC [M] drivers/usb/gadget/legacy/hid.o
LD [M] drivers/usb/gadget/legacy/g_hid.o
CC [M] drivers/usb/gadget/legacy/dbgp.o
LD [M] drivers/usb/gadget/legacy/g_dbgp.o
CC [M] drivers/usb/gadget/legacy/multi.o
LD [M] drivers/usb/gadget/legacy/g_multi.o
CC [M] drivers/usb/gadget/legacy/webcam.o
LD [M] drivers/usb/gadget/legacy/g_webcam.o
CC [M] drivers/usb/gadget/legacy/ncm.o
LD [M] drivers/usb/gadget/legacy/g_ncm.o
CC [M] drivers/usb/gadget/legacy/acm_ms.o
LD [M] drivers/usb/gadget/legacy/g_acm_ms.o
CC [M] drivers/usb/gadget/usbstring.o
CC [M] drivers/usb/gadget/config.o
CC [M] drivers/usb/gadget/epautoconf.o
CC [M] drivers/usb/gadget/composite.o
CC [M] drivers/usb/gadget/functions.o
CC [M] drivers/usb/gadget/configfs.o
CC [M] drivers/usb/gadget/u_f.o
LD [M] drivers/usb/gadget/libcomposite.o
CC [M] drivers/usb/typec/tcpm/tcpm.o
CC [M] drivers/usb/typec/tcpm/fusb302.o
CC [M] drivers/usb/typec/class.o
CC [M] drivers/usb/typec/mux.o
CC [M] drivers/usb/typec/bus.o
LD [M] drivers/usb/typec/typec.o
CC [M] drivers/usb/typec/hd3ss3220.o
CC [M] drivers/usb/typec/tps6598x.o
drivers/usb/typec/tps6598x.c:654:12: warning: ‘tps6589x_resume’ defined but not used [-Wunused-function]
654 | static int tps6589x_resume(struct device *dev)
drivers/usb/typec/tps6598x.c:639:12: warning: ‘tps6589x_suspend’ defined but not used [-Wunused-function]
639 | static int tps6589x_suspend(struct device *dev)
CC [M] drivers/usb/roles/class.o
LD [M] drivers/usb/roles/roles.o
CC [M] drivers/input/keyboard/adc-keys.o
CC [M] drivers/input/keyboard/matrix_keypad.o
CC [M] drivers/input/touchscreen/atmel_mxt_ts.o
CC [M] drivers/input/touchscreen/edt-ft5x06.o
CC [M] drivers/input/touchscreen/goodix.o
CC [M] drivers/input/touchscreen/ili210x.o
CC [M] drivers/input/touchscreen/pixcir_i2c_ts.o
CC [M] drivers/input/touchscreen/ti_am335x_tsc.o
CC [M] drivers/input/misc/gpio_decoder.o
CC [M] drivers/rtc/rtc-ds1307.o
CC [M] drivers/rtc/rtc-pcf2127.o
CC [M] drivers/rtc/rtc-pcf85363.o
CC [M] drivers/rtc/rtc-rk808.o
CC [M] drivers/rtc/rtc-rv8803.o
CC [M] drivers/rtc/rtc-rx8581.o
CC [M] drivers/i2c/i2c-atr.o
CC [M] drivers/media/i2c/ov2312.o
CC [M] drivers/media/i2c/ov5640.o
CC [M] drivers/media/i2c/ov5645.o
CC [M] drivers/media/i2c/ov1063x.o
CC [M] drivers/media/i2c/ov2659.o
CC [M] drivers/media/i2c/imx219.o
CC [M] drivers/media/i2c/imx390.o
CC [M] drivers/media/i2c/ds90ub953.o
CC [M] drivers/media/i2c/ds90ub960.o
CC [M] drivers/media/tuners/tuner-xc2028.o
CC [M] drivers/media/tuners/tuner-simple.o
CC [M] drivers/media/tuners/tuner-types.o
CC [M] drivers/media/tuners/mt20xx.o
CC [M] drivers/media/tuners/tda8290.o
CC [M] drivers/media/tuners/tea5767.o
CC [M] drivers/media/tuners/tea5761.o
CC [M] drivers/media/tuners/tda9887.o
CC [M] drivers/media/tuners/tda827x.o
CC [M] drivers/media/tuners/tda18271-maps.o
CC [M] drivers/media/tuners/tda18271-common.o
CC [M] drivers/media/tuners/tda18271-fe.o
LD [M] drivers/media/tuners/tda18271.o
CC [M] drivers/media/tuners/xc5000.o
CC [M] drivers/media/tuners/xc4000.o
CC [M] drivers/media/tuners/msi001.o
CC [M] drivers/media/tuners/mt2060.o
CC [M] drivers/media/tuners/mt2063.o
CC [M] drivers/media/tuners/mt2266.o
CC [M] drivers/media/tuners/qt1010.o
CC [M] drivers/media/tuners/mt2131.o
CC [M] drivers/media/tuners/mxl5005s.o
CC [M] drivers/media/tuners/mxl5007t.o
CC [M] drivers/media/tuners/mc44s803.o
CC [M] drivers/media/tuners/max2165.o
CC [M] drivers/media/tuners/tda18218.o
CC [M] drivers/media/tuners/tda18212.o
CC [M] drivers/media/tuners/e4000.o
CC [M] drivers/media/tuners/fc2580.o
CC [M] drivers/media/tuners/tua9001.o
CC [M] drivers/media/tuners/si2157.o
CC [M] drivers/media/tuners/fc0011.o
CC [M] drivers/media/tuners/fc0012.o
CC [M] drivers/media/tuners/fc0013.o
CC [M] drivers/media/tuners/it913x.o
CC [M] drivers/media/tuners/r820t.o
CC [M] drivers/media/tuners/mxl301rf.o
CC [M] drivers/media/tuners/qm1d1c0042.o
CC [M] drivers/media/tuners/qm1d1b0004.o
CC [M] drivers/media/tuners/m88rs6000t.o
CC [M] drivers/media/tuners/tda18250.o
CC [M] drivers/media/dvb-frontends/drx39xyj/drxj.o
LD [M] drivers/media/dvb-frontends/drx39xyj/drx39xyj.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_common.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_devio_spi.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_integ.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_io.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_spi_device.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd_dvbt2.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd_dvbt2_mon.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd_dvbt.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd_dvbt_mon.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_tnrdmd_mon.o
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880_top.o
LD [M] drivers/media/dvb-frontends/cxd2880/cxd2880.o
CC [M] drivers/media/dvb-frontends/dvb-pll.o
CC [M] drivers/media/dvb-frontends/stv0299.o
CC [M] drivers/media/dvb-frontends/stb0899_drv.o
CC [M] drivers/media/dvb-frontends/stb0899_algo.o
LD [M] drivers/media/dvb-frontends/stb0899.o
CC [M] drivers/media/dvb-frontends/stb6100.o
CC [M] drivers/media/dvb-frontends/sp8870.o
CC [M] drivers/media/dvb-frontends/cx22700.o
CC [M] drivers/media/dvb-frontends/s5h1432.o
CC [M] drivers/media/dvb-frontends/cx24110.o
CC [M] drivers/media/dvb-frontends/tda8083.o
CC [M] drivers/media/dvb-frontends/l64781.o
CC [M] drivers/media/dvb-frontends/dib3000mb.o
CC [M] drivers/media/dvb-frontends/dib3000mc.o
CC [M] drivers/media/dvb-frontends/dibx000_common.o
CC [M] drivers/media/dvb-frontends/dib7000m.o
CC [M] drivers/media/dvb-frontends/dib7000p.o
CC [M] drivers/media/dvb-frontends/dib8000.o
CC [M] drivers/media/dvb-frontends/dib9000.o
CC [M] drivers/media/dvb-frontends/mt312.o
CC [M] drivers/media/dvb-frontends/ves1820.o
CC [M] drivers/media/dvb-frontends/ves1x93.o
CC [M] drivers/media/dvb-frontends/tda1004x.o
CC [M] drivers/media/dvb-frontends/sp887x.o
CC [M] drivers/media/dvb-frontends/nxt6000.o
CC [M] drivers/media/dvb-frontends/mt352.o
CC [M] drivers/media/dvb-frontends/zl10036.o
CC [M] drivers/media/dvb-frontends/zl10039.o
CC [M] drivers/media/dvb-frontends/zl10353.o
CC [M] drivers/media/dvb-frontends/cx22702.o
CC [M] drivers/media/dvb-frontends/drxd_firm.o
CC [M] drivers/media/dvb-frontends/drxd_hard.o
LD [M] drivers/media/dvb-frontends/drxd.o
CC [M] drivers/media/dvb-frontends/tda10021.o
CC [M] drivers/media/dvb-frontends/tda10023.o
CC [M] drivers/media/dvb-frontends/stv0297.o
CC [M] drivers/media/dvb-frontends/nxt200x.o
CC [M] drivers/media/dvb-frontends/or51211.o
CC [M] drivers/media/dvb-frontends/or51132.o
CC [M] drivers/media/dvb-frontends/bcm3510.o
CC [M] drivers/media/dvb-frontends/s5h1420.o
CC [M] drivers/media/dvb-frontends/lgdt330x.o
CC [M] drivers/media/dvb-frontends/lgdt3305.o
CC [M] drivers/media/dvb-frontends/lgdt3306a.o
CC [M] drivers/media/dvb-frontends/lg2160.o
CC [M] drivers/media/dvb-frontends/cx24123.o
CC [M] drivers/media/dvb-frontends/lnbh25.o
CC [M] drivers/media/dvb-frontends/lnbh29.o
CC [M] drivers/media/dvb-frontends/lnbp21.o
CC [M] drivers/media/dvb-frontends/lnbp22.o
CC [M] drivers/media/dvb-frontends/isl6405.o
CC [M] drivers/media/dvb-frontends/isl6421.o
CC [M] drivers/media/dvb-frontends/tda10086.o
CC [M] drivers/media/dvb-frontends/tda826x.o
CC [M] drivers/media/dvb-frontends/tda8261.o
CC [M] drivers/media/dvb-frontends/dib0070.o
CC [M] drivers/media/dvb-frontends/dib0090.o
CC [M] drivers/media/dvb-frontends/tua6100.o
CC [M] drivers/media/dvb-frontends/s5h1409.o
CC [M] drivers/media/dvb-frontends/itd1000.o
CC [M] drivers/media/dvb-frontends/au8522_common.o
CC [M] drivers/media/dvb-frontends/au8522_dig.o
CC [M] drivers/media/dvb-frontends/au8522_decoder.o
CC [M] drivers/media/dvb-frontends/tda10048.o
CC [M] drivers/media/dvb-frontends/cx24113.o
CC [M] drivers/media/dvb-frontends/s5h1411.o
CC [M] drivers/media/dvb-frontends/lgs8gl5.o
CC [M] drivers/media/dvb-frontends/tda665x.o
CC [M] drivers/media/dvb-frontends/lgs8gxx.o
CC [M] drivers/media/dvb-frontends/atbm8830.o
CC [M] drivers/media/dvb-frontends/af9013.o
CC [M] drivers/media/dvb-frontends/cx24116.o
CC [M] drivers/media/dvb-frontends/cx24117.o
CC [M] drivers/media/dvb-frontends/cx24120.o
CC [M] drivers/media/dvb-frontends/si21xx.o
CC [M] drivers/media/dvb-frontends/si2168.o
CC [M] drivers/media/dvb-frontends/stv0288.o
CC [M] drivers/media/dvb-frontends/stb6000.o
CC [M] drivers/media/dvb-frontends/s921.o
CC [M] drivers/media/dvb-frontends/stv6110.o
CC [M] drivers/media/dvb-frontends/stv0900_core.o
CC [M] drivers/media/dvb-frontends/stv0900_sw.o
LD [M] drivers/media/dvb-frontends/stv0900.o
CC [M] drivers/media/dvb-frontends/stv090x.o
CC [M] drivers/media/dvb-frontends/stv6110x.o
CC [M] drivers/media/dvb-frontends/m88ds3103.o
CC [M] drivers/media/dvb-frontends/mn88472.o
CC [M] drivers/media/dvb-frontends/mn88473.o
CC [M] drivers/media/dvb-frontends/isl6423.o
CC [M] drivers/media/dvb-frontends/ec100.o
CC [M] drivers/media/dvb-frontends/ds3000.o
CC [M] drivers/media/dvb-frontends/ts2020.o
CC [M] drivers/media/dvb-frontends/mb86a16.o
CC [M] drivers/media/dvb-frontends/mb86a20s.o
CC [M] drivers/media/dvb-frontends/ix2505v.o
CC [M] drivers/media/dvb-frontends/stv0367.o
CC [M] drivers/media/dvb-frontends/cxd2820r_core.o
CC [M] drivers/media/dvb-frontends/cxd2820r_c.o
CC [M] drivers/media/dvb-frontends/cxd2820r_t.o
CC [M] drivers/media/dvb-frontends/cxd2820r_t2.o
LD [M] drivers/media/dvb-frontends/cxd2820r.o
CC [M] drivers/media/dvb-frontends/cxd2841er.o
CC [M] drivers/media/dvb-frontends/drxk_hard.o
LD [M] drivers/media/dvb-frontends/drxk.o
CC [M] drivers/media/dvb-frontends/tda18271c2dd.o
CC [M] drivers/media/dvb-frontends/stv0910.o
CC [M] drivers/media/dvb-frontends/stv6111.o
CC [M] drivers/media/dvb-frontends/mxl5xx.o
CC [M] drivers/media/dvb-frontends/si2165.o
CC [M] drivers/media/dvb-frontends/a8293.o
CC [M] drivers/media/dvb-frontends/sp2.o
CC [M] drivers/media/dvb-frontends/tda10071.o
CC [M] drivers/media/dvb-frontends/rtl2830.o
CC [M] drivers/media/dvb-frontends/rtl2832.o
CC [M] drivers/media/dvb-frontends/rtl2832_sdr.o
CC [M] drivers/media/dvb-frontends/m88rs2000.o
CC [M] drivers/media/dvb-frontends/af9033.o
CC [M] drivers/media/dvb-frontends/tc90522.o
CC [M] drivers/media/dvb-frontends/mn88443x.o
CC [M] drivers/media/dvb-frontends/horus3a.o
CC [M] drivers/media/dvb-frontends/ascot2e.o
CC [M] drivers/media/dvb-frontends/helene.o
CC [M] drivers/media/dvb-frontends/zd1301_demod.o
CC [M] drivers/media/dvb-frontends/cxd2099.o
CC [M] drivers/media/v4l2-core/v4l2-fwnode.o
CC [M] drivers/media/v4l2-core/v4l2-mem2mem.o
CC [M] drivers/media/common/videobuf2/videobuf2-core.o
LD [M] drivers/media/common/videobuf2/videobuf2-common.o
CC [M] drivers/media/common/videobuf2/videobuf2-v4l2.o
CC [M] drivers/media/common/videobuf2/videobuf2-memops.o
CC [M] drivers/media/common/videobuf2/videobuf2-vmalloc.o
CC [M] drivers/media/common/videobuf2/videobuf2-dma-contig.o
CC [M] drivers/media/common/videobuf2/videobuf2-dma-sg.o
CC [M] drivers/media/platform/cadence/cdns-csi2rx.o
CC [M] drivers/media/platform/ti/cal/cal.o
CC [M] drivers/media/platform/ti/cal/cal-camerarx.o
CC [M] drivers/media/platform/ti/cal/cal-video.o
LD [M] drivers/media/platform/ti/cal/ti-cal.o
CC [M] drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.o
drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.c:1457:12: warning: ‘ti_csi2rx_resume’ defined but not used [-Wunused-function]
1457 | static int ti_csi2rx_resume(struct device *dev)
drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.c:1421:12: warning: ‘ti_csi2rx_suspend’ defined but not used [-Wunused-function]
1421 | static int ti_csi2rx_suspend(struct device *dev)
CC [M] drivers/media/platform/vxe-vxd/common/img_mem_man.o
CC [M] drivers/media/platform/vxe-vxd/common/img_mem_unified.o
CC [M] drivers/media/platform/vxe-vxd/common/imgmmu.o
CC [M] drivers/media/platform/vxe-vxd/common/pool_api.o
CC [M] drivers/media/platform/vxe-vxd/common/idgen_api.o
CC [M] drivers/media/platform/vxe-vxd/common/talmmu_api.o
CC [M] drivers/media/platform/vxe-vxd/common/pool.o
CC [M] drivers/media/platform/vxe-vxd/common/hash.o
CC [M] drivers/media/platform/vxe-vxd/common/ra.o
CC [M] drivers/media/platform/vxe-vxd/common/addr_alloc.o
CC [M] drivers/media/platform/vxe-vxd/common/work_queue.o
CC [M] drivers/media/platform/vxe-vxd/common/lst.o
CC [M] drivers/media/platform/vxe-vxd/common/dq.o
CC [M] drivers/media/platform/vxe-vxd/common/resource.o
CC [M] drivers/media/platform/vxe-vxd/common/rman_api.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vxd_core.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vxd_pvdec.o
CC [M] drivers/media/platform/vxe-vxd/decoder/dec_resources.o
CC [M] drivers/media/platform/vxe-vxd/decoder/pixel_api.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vdecdd_utils_buf.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vdecdd_utils.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vdec_mmu_wrapper.o
CC [M] drivers/media/platform/vxe-vxd/decoder/hw_control.o
drivers/media/platform/vxe-vxd/decoder/hw_control.c:782:13: warning: ‘hwctrl_dump_state’ defined but not used [-Wunused-function]
782 | static void hwctrl_dump_state(struct vxd_states *prev_state,
CC [M] drivers/media/platform/vxe-vxd/decoder/vxd_int.o
CC [M] drivers/media/platform/vxe-vxd/decoder/translation_api.o
CC [M] drivers/media/platform/vxe-vxd/decoder/decoder.o
CC [M] drivers/media/platform/vxe-vxd/decoder/core.o
CC [M] drivers/media/platform/vxe-vxd/decoder/swsr.o
CC [M] drivers/media/platform/vxe-vxd/decoder/h264_secure_parser.o
CC [M] drivers/media/platform/vxe-vxd/decoder/bspp.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vxd_dec.o
CC [M] drivers/media/platform/vxe-vxd/decoder/vxd_v4l2.o
drivers/media/platform/vxe-vxd/decoder/vxd_v4l2.c:379:13: warning: ‘vxd_error_recovery’ defined but not used [-Wunused-function]
379 | static void vxd_error_recovery(struct vxd_dec_ctx *ctx)
CC [M] drivers/media/platform/vxe-vxd/decoder/hevc_secure_parser.o
CC [M] drivers/media/platform/vxe-vxd/decoder/jpeg_secure_parser.o
LD [M] drivers/media/platform/vxe-vxd/vxd-dec.o
CC [M] drivers/media/platform/vxe-vxd/encoder/vxe_v4l2.o
CC [M] drivers/media/platform/vxe-vxd/encoder/vxe_enc.o
CC [M] drivers/media/platform/vxe-vxd/encoder/topaz_device.o
CC [M] drivers/media/platform/vxe-vxd/encoder/topazmmu.o
CC [M] drivers/media/platform/vxe-vxd/encoder/topaz_api.o
CC [M] drivers/media/platform/vxe-vxd/encoder/topaz_api_utils.o
CC [M] drivers/media/platform/vxe-vxd/encoder/header_gen.o
CC [M] drivers/media/platform/vxe-vxd/encoder/mtx_fwif.o
LD [M] drivers/media/platform/vxe-vxd/vxe-enc.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-hw.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-vpuapi.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-vdi.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-vpu-dec.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-vpu.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-vpu-enc.o
CC [M] drivers/media/platform/chips-media/wave5/wave5-helper.o
LD [M] drivers/media/platform/chips-media/wave5/wave5.o
CC [M] drivers/media/usb/uvc/uvc_driver.o
CC [M] drivers/media/usb/uvc/uvc_queue.o
CC [M] drivers/media/usb/uvc/uvc_v4l2.o
CC [M] drivers/media/usb/uvc/uvc_video.o
CC [M] drivers/media/usb/uvc/uvc_ctrl.o
CC [M] drivers/media/usb/uvc/uvc_status.o
CC [M] drivers/media/usb/uvc/uvc_isight.o
CC [M] drivers/media/usb/uvc/uvc_debugfs.o
CC [M] drivers/media/usb/uvc/uvc_metadata.o
CC [M] drivers/media/usb/uvc/uvc_entity.o
LD [M] drivers/media/usb/uvc/uvcvideo.o
CC [M] drivers/media/usb/gspca/gspca.o
CC [M] drivers/media/usb/gspca/autogain_functions.o
LD [M] drivers/media/usb/gspca/gspca_main.o
CC [M] drivers/media/spi/cxd2880-spi.o
CC [M] drivers/power/supply/sbs-battery.o
CC [M] drivers/power/supply/bq27xxx_battery_hdq.o
CC [M] drivers/hwmon/ina2xx.o
CC [M] drivers/hwmon/ina3221.o
CC [M] drivers/hwmon/lm90.o
CC [M] drivers/hwmon/pwm-fan.o
CC [M] drivers/watchdog/rti_wdt.o
CC [M] drivers/md/persistent-data/dm-array.o
CC [M] drivers/md/persistent-data/dm-bitset.o
CC [M] drivers/md/persistent-data/dm-block-manager.o
CC [M] drivers/md/persistent-data/dm-space-map-common.o
CC [M] drivers/md/persistent-data/dm-space-map-disk.o
CC [M] drivers/md/persistent-data/dm-space-map-metadata.o
CC [M] drivers/md/persistent-data/dm-transaction-manager.o
CC [M] drivers/md/persistent-data/dm-btree.o
CC [M] drivers/md/persistent-data/dm-btree-remove.o
CC [M] drivers/md/persistent-data/dm-btree-spine.o
LD [M] drivers/md/persistent-data/dm-persistent-data.o
CC [M] drivers/md/md.o
CC [M] drivers/md/md-bitmap.o
LD [M] drivers/md/md-mod.o
CC [M] drivers/md/dm.o
CC [M] drivers/md/dm-table.o
CC [M] drivers/md/dm-target.o
CC [M] drivers/md/dm-linear.o
CC [M] drivers/md/dm-stripe.o
CC [M] drivers/md/dm-ioctl.o
CC [M] drivers/md/dm-io.o
CC [M] drivers/md/dm-kcopyd.o
CC [M] drivers/md/dm-sysfs.o
CC [M] drivers/md/dm-stats.o
CC [M] drivers/md/dm-rq.o
LD [M] drivers/md/dm-mod.o
CC [M] drivers/md/dm-bufio.o
CC [M] drivers/md/dm-bio-prison-v1.o
CC [M] drivers/md/dm-bio-prison-v2.o
LD [M] drivers/md/dm-bio-prison.o
CC [M] drivers/md/dm-raid1.o
LD [M] drivers/md/dm-mirror.o
CC [M] drivers/md/dm-log.o
CC [M] drivers/md/dm-region-hash.o
CC [M] drivers/md/dm-zero.o
CC [M] drivers/md/dm-thin.o
CC [M] drivers/md/dm-thin-metadata.o
LD [M] drivers/md/dm-thin-pool.o
CC [M] drivers/crypto/ti/mcrc.o
CC [M] drivers/crypto/ccree/cc_driver.o
CC [M] drivers/crypto/ccree/cc_buffer_mgr.o
CC [M] drivers/crypto/ccree/cc_request_mgr.o
CC [M] drivers/crypto/ccree/cc_cipher.o
CC [M] drivers/crypto/ccree/cc_hash.o
CC [M] drivers/crypto/ccree/cc_aead.o
CC [M] drivers/crypto/ccree/cc_sram_mgr.o
CC [M] drivers/crypto/ccree/cc_debugfs.o
CC [M] drivers/crypto/ccree/cc_pm.o
LD [M] drivers/crypto/ccree/ccree.o
CC [M] drivers/crypto/sa2ul.o
CC [M] drivers/hid/usbhid/hid-core.o
LD [M] drivers/hid/usbhid/usbhid.o
CC [M] drivers/hid/i2c-hid/i2c-hid-core.o
CC [M] drivers/hid/i2c-hid/i2c-hid-dmi-quirks.o
LD [M] drivers/hid/i2c-hid/i2c-hid.o
CC [M] drivers/hid/hid-multitouch.o
CC [M] drivers/platform/chrome/cros_ec_typec.o
CC [M] drivers/platform/chrome/cros_ec_chardev.o
CC [M] drivers/remoteproc/pru_rproc.o
CC [M] drivers/remoteproc/ti_k3_dsp_remoteproc.o
CC [M] drivers/remoteproc/ti_k3_r5_remoteproc.o
CC [M] drivers/remoteproc/ti_k3_m4_remoteproc.o
CC [M] drivers/rpmsg/rpmsg_char.o
CC [M] drivers/rpmsg/virtio_rpmsg_bus.o
CC [M] drivers/rpmsg/rpmsg_pru.o
CC [M] drivers/rpmsg-kdrv/rpmsg_kdrv_switch.o
CC [M] drivers/extcon/extcon-palmas.o
CC [M] drivers/extcon/extcon-ptn5150.o
CC [M] drivers/extcon/extcon-usb-gpio.o
CC [M] drivers/iio/adc/max9611.o
CC [M] drivers/iio/adc/qcom-spmi-adc5.o
CC [M] drivers/iio/adc/qcom-vadc-common.o
CC [M] drivers/iio/adc/ti_am335x_adc.o
CC [M] drivers/iio/buffer/industrialio-triggered-buffer.o
CC [M] drivers/iio/buffer/kfifo_buf.o
CC [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors_core.o
CC [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors.o
CC [M] drivers/iio/light/cros_ec_light_prox.o
CC [M] drivers/iio/light/isl29018.o
CC [M] drivers/iio/pressure/cros_ec_baro.o
CC [M] drivers/iio/pressure/mpl3115.o
CC [M] drivers/fpga/fpga-bridge.o
CC [M] drivers/fpga/altera-freeze-bridge.o
CC [M] drivers/fpga/fpga-region.o
CC [M] drivers/fpga/of-fpga-region.o
CC [M] drivers/ata/libata-core.o
CC [M] drivers/ata/libata-scsi.o
CC [M] drivers/ata/libata-eh.o
CC [M] drivers/ata/libata-transport.o
CC [M] drivers/ata/libata-trace.o
CC [M] drivers/ata/libata-sata.o
CC [M] drivers/ata/libata-sff.o
CC [M] drivers/ata/libata-pmp.o
LD [M] drivers/ata/libata.o
CC [M] drivers/ata/ahci.o
CC [M] drivers/ata/libahci.o
CC [M] drivers/ata/ahci_platform.o
CC [M] drivers/ata/libahci_platform.o
CC [M] drivers/ata/sata_sil24.o
CC [M] drivers/ata/ahci_ceva.o
CC [M] drivers/ata/ahci_xgene.o
CC [M] drivers/ata/ahci_qoriq.o
CC [M] drivers/ata/pata_platform.o
CC [M] drivers/ata/pata_of_platform.o
CC [M] drivers/slimbus/core.o
CC [M] drivers/slimbus/messaging.o
CC [M] drivers/slimbus/sched.o
CC [M] drivers/slimbus/stream.o
LD [M] drivers/slimbus/slimbus.o
CC [M] drivers/slimbus/qcom-ctrl.o
LD [M] drivers/slimbus/slim-qcom-ctrl.o
CC [M] drivers/w1/w1.o
CC [M] drivers/w1/w1_int.o
CC [M] drivers/w1/w1_family.o
CC [M] drivers/w1/w1_netlink.o
CC [M] drivers/w1/w1_io.o
LD [M] drivers/w1/wire.o
CC [M] drivers/bluetooth/hci_ldisc.o
CC [M] drivers/bluetooth/hci_serdev.o
CC [M] drivers/bluetooth/hci_h4.o
CC [M] drivers/bluetooth/hci_ll.o
CC [M] drivers/bluetooth/hci_bcm.o
CC [M] drivers/bluetooth/hci_qca.o
LD [M] drivers/bluetooth/hci_uart.o
CC [M] drivers/bluetooth/btusb.o
CC [M] drivers/bluetooth/btintel.o
CC [M] drivers/bluetooth/btbcm.o
CC [M] drivers/bluetooth/btrtl.o
CC [M] drivers/bluetooth/btqca.o
CC [M] drivers/ssb/main.o
CC [M] drivers/ssb/scan.o
CC [M] drivers/ssb/sprom.o
CC [M] drivers/ssb/pci.o
CC [M] drivers/ssb/pcihost_wrapper.o
CC [M] drivers/ssb/driver_chipcommon.o
CC [M] drivers/ssb/driver_chipcommon_pmu.o
CC [M] drivers/ssb/driver_pcicore.o
CC [M] drivers/ssb/b43_pci_bridge.o
LD [M] drivers/ssb/ssb.o
CC [M] drivers/bcma/main.o
CC [M] drivers/bcma/scan.o
CC [M] drivers/bcma/core.o
CC [M] drivers/bcma/sprom.o
CC [M] drivers/bcma/driver_chipcommon.o
CC [M] drivers/bcma/driver_chipcommon_pmu.o
CC [M] drivers/bcma/driver_chipcommon_b.o
CC [M] drivers/bcma/driver_pci.o
CC [M] drivers/bcma/driver_pcie2.o
CC [M] drivers/bcma/host_pci.o
LD [M] drivers/bcma/bcma.o
CC [M] drivers/soundwire/bus_type.o
CC [M] drivers/soundwire/bus.o
CC [M] drivers/soundwire/master.o
CC [M] drivers/soundwire/slave.o
CC [M] drivers/soundwire/mipi_disco.o
CC [M] drivers/soundwire/stream.o
CC [M] drivers/soundwire/sysfs_slave.o
CC [M] drivers/soundwire/sysfs_slave_dpn.o
CC [M] drivers/soundwire/debugfs.o
LD [M] drivers/soundwire/soundwire-bus.o
CC [M] drivers/soundwire/qcom.o
LD [M] drivers/soundwire/soundwire-qcom.o
CC [M] drivers/ntb/hw/epf/ntb_hw_epf.o
CC [M] drivers/ntb/core.o
LD [M] drivers/ntb/ntb.o
CC [M] drivers/ntb/ntb_transport.o
CC [M] drivers/counter/counter-core.o
CC [M] drivers/counter/counter-sysfs.o
CC [M] drivers/counter/counter-chrdev.o
LD [M] drivers/counter/counter.o
CC [M] drivers/counter/ti-ecap-capture.o
CC [M] sound/core/hwdep.o
LD [M] sound/core/snd-hwdep.o
CC [M] sound/core/rawmidi.o
LD [M] sound/core/snd-rawmidi.o
CC [M] sound/usb/card.o
CC [M] sound/usb/clock.o
CC [M] sound/usb/endpoint.o
CC [M] sound/usb/format.o
CC [M] sound/usb/helper.o
CC [M] sound/usb/mixer.o
CC [M] sound/usb/mixer_quirks.o
CC [M] sound/usb/mixer_scarlett.o
CC [M] sound/usb/mixer_scarlett_gen2.o
CC [M] sound/usb/mixer_us16x08.o
CC [M] sound/usb/mixer_s1810c.o
CC [M] sound/usb/pcm.o
CC [M] sound/usb/power.o
CC [M] sound/usb/proc.o
CC [M] sound/usb/quirks.o
CC [M] sound/usb/stream.o
CC [M] sound/usb/validate.o
CC [M] sound/usb/media.o
LD [M] sound/usb/snd-usb-audio.o
CC [M] sound/usb/midi.o
LD [M] sound/usb/snd-usbmidi-lib.o
CC [M] sound/soc/codecs/pcm3168a.o
LD [M] sound/soc/codecs/snd-soc-pcm3168a.o
CC [M] sound/soc/codecs/pcm3168a-i2c.o
LD [M] sound/soc/codecs/snd-soc-pcm3168a-i2c.o
CC [M] sound/soc/codecs/tlv320aic31xx.o
LD [M] sound/soc/codecs/snd-soc-tlv320aic31xx.o
CC [M] sound/soc/codecs/tlv320aic3x.o
LD [M] sound/soc/codecs/snd-soc-tlv320aic3x.o
CC [M] sound/soc/codecs/wcd-clsh-v2.o
CC [M] sound/soc/codecs/wcd934x.o
LD [M] sound/soc/codecs/snd-soc-wcd934x.o
CC [M] sound/soc/codecs/wm8904.o
LD [M] sound/soc/codecs/snd-soc-wm8904.o
CC [M] sound/soc/codecs/wsa881x.o
LD [M] sound/soc/codecs/snd-soc-wsa881x.o
CC [M] sound/soc/codecs/simple-amplifier.o
LD [M] sound/soc/codecs/snd-soc-simple-amplifier.o
CC [M] sound/soc/generic/simple-card-utils.o
LD [M] sound/soc/generic/snd-soc-simple-card-utils.o
CC [M] sound/soc/generic/simple-card.o
LD [M] sound/soc/generic/snd-soc-simple-card.o
CC [M] sound/soc/generic/audio-graph-card.o
LD [M] sound/soc/generic/snd-soc-audio-graph-card.o
CC [M] sound/soc/ti/j721e-evm.o
LD [M] sound/soc/ti/snd-soc-j721e-evm.o
CC [M] samples/rpmsg/rpmsg_client_sample.o
CC [M] net/802/p8022.o
CC [M] net/802/psnap.o
CC [M] net/802/stp.o
CC [M] net/802/garp.o
CC [M] net/802/mrp.o
CC [M] net/sched/act_police.o
CC [M] net/sched/act_gact.o
CC [M] net/sched/act_mirred.o
CC [M] net/sched/act_ipt.o
CC [M] net/sched/act_nat.o
CC [M] net/sched/act_pedit.o
CC [M] net/sched/act_simple.o
CC [M] net/sched/act_skbedit.o
CC [M] net/sched/act_csum.o
CC [M] net/sched/act_gate.o
CC [M] net/sched/sch_cbq.o
CC [M] net/sched/sch_htb.o
CC [M] net/sched/sch_hfsc.o
CC [M] net/sched/sch_red.o
CC [M] net/sched/sch_gred.o
CC [M] net/sched/sch_ingress.o
CC [M] net/sched/sch_dsmark.o
CC [M] net/sched/sch_sfb.o
CC [M] net/sched/sch_sfq.o
CC [M] net/sched/sch_tbf.o
CC [M] net/sched/sch_teql.o
CC [M] net/sched/sch_prio.o
CC [M] net/sched/sch_multiq.o
CC [M] net/sched/sch_netem.o
CC [M] net/sched/sch_drr.o
CC [M] net/sched/sch_mqprio.o
CC [M] net/sched/sch_choke.o
CC [M] net/sched/sch_qfq.o
CC [M] net/sched/sch_codel.o
CC [M] net/sched/sch_fq_codel.o
CC [M] net/sched/sch_cbs.o
CC [M] net/sched/sch_etf.o
CC [M] net/sched/sch_taprio.o
CC [M] net/sched/cls_u32.o
CC [M] net/sched/cls_route.o
CC [M] net/sched/cls_fw.o
CC [M] net/sched/cls_rsvp.o
CC [M] net/sched/cls_tcindex.o
CC [M] net/sched/cls_rsvp6.o
CC [M] net/sched/cls_basic.o
CC [M] net/sched/cls_flow.o
CC [M] net/sched/cls_cgroup.o
CC [M] net/sched/cls_flower.o
CC [M] net/sched/em_cmp.o
CC [M] net/sched/em_nbyte.o
CC [M] net/sched/em_u32.o
CC [M] net/sched/em_meta.o
CC [M] net/sched/em_text.o
CC [M] net/netfilter/ipvs/ip_vs_conn.o
CC [M] net/netfilter/ipvs/ip_vs_core.o
CC [M] net/netfilter/ipvs/ip_vs_ctl.o
CC [M] net/netfilter/ipvs/ip_vs_sched.o
CC [M] net/netfilter/ipvs/ip_vs_xmit.o
CC [M] net/netfilter/ipvs/ip_vs_app.o
CC [M] net/netfilter/ipvs/ip_vs_sync.o
CC [M] net/netfilter/ipvs/ip_vs_est.o
CC [M] net/netfilter/ipvs/ip_vs_proto.o
CC [M] net/netfilter/ipvs/ip_vs_pe.o
LD [M] net/netfilter/ipvs/ip_vs.o
CC [M] net/netfilter/ipvs/ip_vs_rr.o
CC [M] net/netfilter/nf_conntrack_core.o
CC [M] net/netfilter/nf_conntrack_standalone.o
CC [M] net/netfilter/nf_conntrack_expect.o
CC [M] net/netfilter/nf_conntrack_helper.o
CC [M] net/netfilter/nf_conntrack_proto.o
CC [M] net/netfilter/nf_conntrack_proto_generic.o
CC [M] net/netfilter/nf_conntrack_proto_tcp.o
CC [M] net/netfilter/nf_conntrack_proto_udp.o
CC [M] net/netfilter/nf_conntrack_proto_icmp.o
CC [M] net/netfilter/nf_conntrack_extend.o
CC [M] net/netfilter/nf_conntrack_acct.o
CC [M] net/netfilter/nf_conntrack_seqadj.o
CC [M] net/netfilter/nf_conntrack_proto_icmpv6.o
CC [M] net/netfilter/nf_conntrack_ecache.o
CC [M] net/netfilter/nf_conntrack_proto_dccp.o
CC [M] net/netfilter/nf_conntrack_proto_sctp.o
LD [M] net/netfilter/nf_conntrack.o
CC [M] net/netfilter/nf_conntrack_ftp.o
CC [M] net/netfilter/nf_conntrack_tftp.o
CC [M] net/netfilter/nf_log_common.o
CC [M] net/netfilter/nf_nat_core.o
CC [M] net/netfilter/nf_nat_proto.o
CC [M] net/netfilter/nf_nat_helper.o
CC [M] net/netfilter/nf_nat_masquerade.o
LD [M] net/netfilter/nf_nat.o
CC [M] net/netfilter/nf_nat_ftp.o
CC [M] net/netfilter/nf_nat_tftp.o
CC [M] net/netfilter/x_tables.o
CC [M] net/netfilter/xt_tcpudp.o
CC [M] net/netfilter/xt_mark.o
CC [M] net/netfilter/xt_nat.o
CC [M] net/netfilter/xt_CHECKSUM.o
CC [M] net/netfilter/xt_CLASSIFY.o
CC [M] net/netfilter/xt_LOG.o
CC [M] net/netfilter/xt_MASQUERADE.o
CC [M] net/netfilter/xt_IDLETIMER.o
CC [M] net/netfilter/xt_addrtype.o
CC [M] net/netfilter/xt_comment.o
CC [M] net/netfilter/xt_conntrack.o
CC [M] net/netfilter/xt_cpu.o
CC [M] net/netfilter/xt_iprange.o
CC [M] net/netfilter/xt_ipvs.o
CC [M] net/netfilter/xt_length.o
CC [M] net/netfilter/xt_limit.o
CC [M] net/netfilter/xt_mac.o
CC [M] net/netfilter/xt_multiport.o
CC [M] net/netfilter/xt_pkttype.o
CC [M] net/netfilter/xt_policy.o
CC [M] net/netfilter/xt_sctp.o
CC [M] net/ipv4/netfilter/nf_defrag_ipv4.o
CC [M] net/ipv4/netfilter/nf_log_ipv4.o
CC [M] net/ipv4/netfilter/nf_reject_ipv4.o
CC [M] net/ipv4/netfilter/ip_tables.o
CC [M] net/ipv4/netfilter/iptable_filter.o
CC [M] net/ipv4/netfilter/iptable_mangle.o
CC [M] net/ipv4/netfilter/iptable_nat.o
CC [M] net/ipv4/netfilter/ipt_REJECT.o
CC [M] net/ipv4/netfilter/arp_tables.o
CC [M] net/ipv4/netfilter/arpt_mangle.o
CC [M] net/ipv4/netfilter/arptable_filter.o
CC [M] net/ipv4/ip_tunnel.o
CC [M] net/ipv4/udp_tunnel_core.o
CC [M] net/ipv4/udp_tunnel_nic.o
LD [M] net/ipv4/udp_tunnel.o
CC [M] net/ipv4/ah4.o
CC [M] net/ipv4/esp4.o
CC [M] net/ipv4/ipcomp.o
CC [M] net/ipv4/xfrm4_tunnel.o
CC [M] net/ipv4/tunnel4.o
CC [M] net/xfrm/xfrm_algo.o
CC [M] net/xfrm/xfrm_user.o
CC [M] net/xfrm/xfrm_ipcomp.o
CC [M] net/ipv6/netfilter/ip6_tables.o
CC [M] net/ipv6/netfilter/ip6table_filter.o
CC [M] net/ipv6/netfilter/ip6table_mangle.o
CC [M] net/ipv6/netfilter/ip6table_nat.o
CC [M] net/ipv6/netfilter/nf_defrag_ipv6_hooks.o
CC [M] net/ipv6/netfilter/nf_conntrack_reasm.o
LD [M] net/ipv6/netfilter/nf_defrag_ipv6.o
CC [M] net/ipv6/netfilter/nf_log_ipv6.o
CC [M] net/ipv6/netfilter/nf_reject_ipv6.o
CC [M] net/ipv6/netfilter/ip6t_REJECT.o
CC [M] net/ipv6/af_inet6.o
CC [M] net/ipv6/anycast.o
CC [M] net/ipv6/ip6_output.o
CC [M] net/ipv6/ip6_input.o
CC [M] net/ipv6/addrconf.o
CC [M] net/ipv6/addrlabel.o
CC [M] net/ipv6/route.o
CC [M] net/ipv6/ip6_fib.o
CC [M] net/ipv6/ipv6_sockglue.o
CC [M] net/ipv6/ndisc.o
CC [M] net/ipv6/udp.o
CC [M] net/ipv6/udplite.o
CC [M] net/ipv6/raw.o
CC [M] net/ipv6/icmp.o
CC [M] net/ipv6/mcast.o
CC [M] net/ipv6/reassembly.o
CC [M] net/ipv6/tcp_ipv6.o
CC [M] net/ipv6/ping.o
CC [M] net/ipv6/exthdrs.o
CC [M] net/ipv6/datagram.o
CC [M] net/ipv6/ip6_flowlabel.o
CC [M] net/ipv6/inet6_connection_sock.o
CC [M] net/ipv6/udp_offload.o
CC [M] net/ipv6/seg6.o
CC [M] net/ipv6/fib6_notifier.o
CC [M] net/ipv6/rpl.o
CC [M] net/ipv6/sysctl_net_ipv6.o
CC [M] net/ipv6/xfrm6_policy.o
CC [M] net/ipv6/xfrm6_state.o
CC [M] net/ipv6/xfrm6_input.o
CC [M] net/ipv6/xfrm6_output.o
CC [M] net/ipv6/xfrm6_protocol.o
CC [M] net/ipv6/netfilter.o
CC [M] net/ipv6/proc.o
LD [M] net/ipv6/ipv6.o
CC [M] net/ipv6/ah6.o
CC [M] net/ipv6/ipcomp6.o
CC [M] net/ipv6/xfrm6_tunnel.o
CC [M] net/ipv6/tunnel6.o
CC [M] net/ipv6/sit.o
CC [M] net/ipv6/ip6_tunnel.o
CC [M] net/ipv6/ip6_udp_tunnel.o
CC [M] net/8021q/vlan.o
CC [M] net/8021q/vlan_dev.o
CC [M] net/8021q/vlan_netlink.o
CC [M] net/8021q/vlan_gvrp.o
CC [M] net/8021q/vlan_mvrp.o
CC [M] net/8021q/vlanproc.o
LD [M] net/8021q/8021q.o
CC [M] net/wireless/core.o
CC [M] net/wireless/sysfs.o
CC [M] net/wireless/radiotap.o
CC [M] net/wireless/util.o
CC [M] net/wireless/reg.o
CC [M] net/wireless/scan.o
CC [M] net/wireless/nl80211.o
CC [M] net/wireless/mlme.o
CC [M] net/wireless/ibss.o
CC [M] net/wireless/sme.o
CC [M] net/wireless/chan.o
CC [M] net/wireless/ethtool.o
CC [M] net/wireless/mesh.o
CC [M] net/wireless/ap.o
CC [M] net/wireless/trace.o
CC [M] net/wireless/ocb.o
CC [M] net/wireless/pmsr.o
CC [M] net/wireless/of.o
GEN net/wireless/shipped-certs.c
CC [M] net/wireless/shipped-certs.o
LD [M] net/wireless/cfg80211.o
CC [M] net/llc/llc_core.o
CC [M] net/llc/llc_input.o
CC [M] net/llc/llc_output.o
LD [M] net/llc/llc.o
CC [M] net/key/af_key.o
CC [M] net/bridge/netfilter/ebtables.o
CC [M] net/bridge/netfilter/ebtable_broute.o
CC [M] net/bridge/netfilter/ebtable_filter.o
CC [M] net/bridge/netfilter/ebtable_nat.o
CC [M] net/bridge/netfilter/ebt_802_3.o
CC [M] net/bridge/netfilter/ebt_among.o
CC [M] net/bridge/netfilter/ebt_arp.o
CC [M] net/bridge/netfilter/ebt_ip.o
CC [M] net/bridge/netfilter/ebt_ip6.o
CC [M] net/bridge/netfilter/ebt_limit.o
CC [M] net/bridge/netfilter/ebt_mark_m.o
CC [M] net/bridge/netfilter/ebt_pkttype.o
CC [M] net/bridge/netfilter/ebt_stp.o
CC [M] net/bridge/netfilter/ebt_vlan.o
CC [M] net/bridge/netfilter/ebt_arpreply.o
CC [M] net/bridge/netfilter/ebt_mark.o
CC [M] net/bridge/netfilter/ebt_dnat.o
CC [M] net/bridge/netfilter/ebt_redirect.o
CC [M] net/bridge/netfilter/ebt_snat.o
CC [M] net/bridge/netfilter/ebt_log.o
CC [M] net/bridge/netfilter/ebt_nflog.o
CC [M] net/bridge/br.o
CC [M] net/bridge/br_device.o
CC [M] net/bridge/br_fdb.o
CC [M] net/bridge/br_forward.o
CC [M] net/bridge/br_if.o
CC [M] net/bridge/br_input.o
CC [M] net/bridge/br_ioctl.o
CC [M] net/bridge/br_stp.o
CC [M] net/bridge/br_stp_bpdu.o
CC [M] net/bridge/br_stp_if.o
CC [M] net/bridge/br_stp_timer.o
CC [M] net/bridge/br_netlink.o
CC [M] net/bridge/br_netlink_tunnel.o
CC [M] net/bridge/br_arp_nd_proxy.o
CC [M] net/bridge/br_sysfs_if.o
CC [M] net/bridge/br_sysfs_br.o
CC [M] net/bridge/br_nf_core.o
CC [M] net/bridge/br_multicast.o
CC [M] net/bridge/br_mdb.o
CC [M] net/bridge/br_vlan.o
CC [M] net/bridge/br_vlan_tunnel.o
CC [M] net/bridge/br_vlan_options.o
CC [M] net/bridge/br_switchdev.o
LD [M] net/bridge/bridge.o
CC [M] net/bridge/br_netfilter_hooks.o
CC [M] net/bridge/br_netfilter_ipv6.o
LD [M] net/bridge/br_netfilter.o
CC [M] net/dsa/dsa.o
CC [M] net/dsa/dsa2.o
CC [M] net/dsa/master.o
CC [M] net/dsa/port.o
CC [M] net/dsa/slave.o
CC [M] net/dsa/switch.o
LD [M] net/dsa/dsa_core.o
CC [M] net/can/af_can.o
CC [M] net/can/proc.o
LD [M] net/can/can.o
CC [M] net/can/raw.o
LD [M] net/can/can-raw.o
CC [M] net/can/bcm.o
LD [M] net/can/can-bcm.o
CC [M] net/can/gw.o
LD [M] net/can/can-gw.o
CC [M] net/bluetooth/hidp/core.o
CC [M] net/bluetooth/hidp/sock.o
LD [M] net/bluetooth/hidp/hidp.o
CC [M] net/bluetooth/af_bluetooth.o
CC [M] net/bluetooth/hci_core.o
CC [M] net/bluetooth/hci_conn.o
CC [M] net/bluetooth/hci_event.o
CC [M] net/bluetooth/mgmt.o
CC [M] net/bluetooth/hci_sock.o
CC [M] net/bluetooth/hci_sysfs.o
CC [M] net/bluetooth/l2cap_core.o
CC [M] net/bluetooth/l2cap_sock.o
CC [M] net/bluetooth/smp.o
CC [M] net/bluetooth/lib.o
CC [M] net/bluetooth/ecdh_helper.o
CC [M] net/bluetooth/hci_request.o
CC [M] net/bluetooth/mgmt_util.o
CC [M] net/bluetooth/mgmt_config.o
CC [M] net/bluetooth/sco.o
CC [M] net/bluetooth/leds.o
LD [M] net/bluetooth/bluetooth.o
CC [M] net/sctp/sm_statetable.o
CC [M] net/sctp/sm_statefuns.o
CC [M] net/sctp/sm_sideeffect.o
CC [M] net/sctp/protocol.o
CC [M] net/sctp/endpointola.o
CC [M] net/sctp/associola.o
CC [M] net/sctp/transport.o
CC [M] net/sctp/chunk.o
CC [M] net/sctp/sm_make_chunk.o
CC [M] net/sctp/ulpevent.o
CC [M] net/sctp/inqueue.o
CC [M] net/sctp/outqueue.o
CC [M] net/sctp/ulpqueue.o
CC [M] net/sctp/tsnmap.o
CC [M] net/sctp/bind_addr.o
CC [M] net/sctp/socket.o
CC [M] net/sctp/primitive.o
CC [M] net/sctp/output.o
CC [M] net/sctp/input.o
CC [M] net/sctp/debug.o
CC [M] net/sctp/stream.o
CC [M] net/sctp/auth.o
CC [M] net/sctp/offload.o
CC [M] net/sctp/stream_sched.o
CC [M] net/sctp/stream_sched_prio.o
CC [M] net/sctp/stream_sched_rr.o
CC [M] net/sctp/stream_interleave.o
CC [M] net/sctp/proc.o
CC [M] net/sctp/sysctl.o
CC [M] net/sctp/ipv6.o
LD [M] net/sctp/sctp.o
CC [M] net/sctp/diag.o
LD [M] net/sctp/sctp_diag.o
CC [M] net/mac80211/main.o
CC [M] net/mac80211/status.o
CC [M] net/mac80211/driver-ops.o
CC [M] net/mac80211/sta_info.o
CC [M] net/mac80211/wep.o
CC [M] net/mac80211/aead_api.o
CC [M] net/mac80211/wpa.o
CC [M] net/mac80211/scan.o
CC [M] net/mac80211/offchannel.o
CC [M] net/mac80211/ht.o
CC [M] net/mac80211/agg-tx.o
CC [M] net/mac80211/agg-rx.o
CC [M] net/mac80211/vht.o
CC [M] net/mac80211/he.o
CC [M] net/mac80211/s1g.o
CC [M] net/mac80211/ibss.o
CC [M] net/mac80211/iface.o
CC [M] net/mac80211/rate.o
CC [M] net/mac80211/michael.o
CC [M] net/mac80211/tkip.o
CC [M] net/mac80211/aes_cmac.o
CC [M] net/mac80211/aes_gmac.o
CC [M] net/mac80211/fils_aead.o
CC [M] net/mac80211/cfg.o
CC [M] net/mac80211/ethtool.o
CC [M] net/mac80211/rx.o
CC [M] net/mac80211/spectmgmt.o
CC [M] net/mac80211/tx.o
CC [M] net/mac80211/key.o
CC [M] net/mac80211/util.o
CC [M] net/mac80211/wme.o
CC [M] net/mac80211/chan.o
CC [M] net/mac80211/trace.o
CC [M] net/mac80211/mlme.o
CC [M] net/mac80211/tdls.o
CC [M] net/mac80211/ocb.o
CC [M] net/mac80211/airtime.o
CC [M] net/mac80211/led.o
CC [M] net/mac80211/mesh.o
CC [M] net/mac80211/mesh_pathtbl.o
CC [M] net/mac80211/mesh_plink.o
CC [M] net/mac80211/mesh_hwmp.o
CC [M] net/mac80211/mesh_sync.o
CC [M] net/mac80211/mesh_ps.o
CC [M] net/mac80211/pm.o
CC [M] net/mac80211/rc80211_minstrel.o
CC [M] net/mac80211/rc80211_minstrel_ht.o
LD [M] net/mac80211/mac80211.o
CC [M] net/rfkill/core.o
LD [M] net/rfkill/rfkill.o
CC [M] net/nfc/nci/core.o
CC [M] net/nfc/nci/data.o
CC [M] net/nfc/nci/lib.o
CC [M] net/nfc/nci/ntf.o
CC [M] net/nfc/nci/rsp.o
CC [M] net/nfc/nci/hci.o
LD [M] net/nfc/nci/nci.o
CC [M] net/nfc/core.o
CC [M] net/nfc/netlink.o
CC [M] net/nfc/af_nfc.o
CC [M] net/nfc/rawsock.o
CC [M] net/nfc/llcp_core.o
CC [M] net/nfc/llcp_commands.o
CC [M] net/nfc/llcp_sock.o
LD [M] net/nfc/nfc.o
CC [M] net/hsr/hsr_main.o
CC [M] net/hsr/hsr_framereg.o
CC [M] net/hsr/hsr_device.o
CC [M] net/hsr/hsr_netlink.o
CC [M] net/hsr/hsr_slave.o
CC [M] net/hsr/hsr_forward.o
CC [M] net/hsr/hsr_debugfs.o
CC [M] net/hsr/hsr_proc.o
LD [M] net/hsr/hsr.o
CC [M] net/qrtr/qrtr.o
CC [M] net/qrtr/ns.o
CC [M] net/qrtr/smd.o
LD [M] net/qrtr/qrtr-smd.o
CC [M] net/qrtr/tun.o
LD [M] net/qrtr/qrtr-tun.o
CC [M] arch/arm64/lib/xor-neon.o
CC [M] lib/math/cordic.o
CC [M] lib/crypto/libchacha.o
CC [M] lib/crypto/arc4.o
LD [M] lib/crypto/libarc4.o
CC [M] lib/crypto/des.o
LD [M] lib/crypto/libdes.o
CC [M] lib/raid6/algos.o
CC [M] lib/raid6/recov.o
HOSTCC lib/raid6/mktables
TABLE lib/raid6/tables.c
CC [M] lib/raid6/tables.o
UNROLL lib/raid6/int1.c
CC [M] lib/raid6/int1.o
UNROLL lib/raid6/int2.c
CC [M] lib/raid6/int2.o
UNROLL lib/raid6/int4.c
CC [M] lib/raid6/int4.o
UNROLL lib/raid6/int8.c
CC [M] lib/raid6/int8.o
UNROLL lib/raid6/int16.c
CC [M] lib/raid6/int16.o
UNROLL lib/raid6/int32.c
CC [M] lib/raid6/int32.o
CC [M] lib/raid6/neon.o
UNROLL lib/raid6/neon1.c
CC [M] lib/raid6/neon1.o
UNROLL lib/raid6/neon2.c
CC [M] lib/raid6/neon2.o
UNROLL lib/raid6/neon4.c
CC [M] lib/raid6/neon4.o
UNROLL lib/raid6/neon8.c
CC [M] lib/raid6/neon8.o
CC [M] lib/raid6/recov_neon.o
CC [M] lib/raid6/recov_neon_inner.o
LD [M] lib/raid6/raid6_pq.o
CC [M] lib/crc-ccitt.o
CC [M] lib/libcrc32c.o
CC [M] lib/ts_kmp.o
CC [M] lib/ts_bm.o
CC [M] lib/ts_fsm.o
LDS scripts/module.lds
MODPOST modules-only.symvers
GEN Module.symvers
CC [M] arch/arm64/crypto/aes-neon-blk.mod.o
LD [M] arch/arm64/crypto/aes-neon-blk.ko
CC [M] arch/arm64/crypto/aes-neon-bs.mod.o
LD [M] arch/arm64/crypto/aes-neon-bs.ko
CC [M] arch/arm64/crypto/chacha-neon.mod.o
LD [M] arch/arm64/crypto/chacha-neon.ko
CC [M] arch/arm64/crypto/crct10dif-ce.mod.o
LD [M] arch/arm64/crypto/crct10dif-ce.ko
CC [M] arch/arm64/crypto/sha3-ce.mod.o
LD [M] arch/arm64/crypto/sha3-ce.ko
CC [M] arch/arm64/crypto/sha512-arm64.mod.o
LD [M] arch/arm64/crypto/sha512-arm64.ko
CC [M] arch/arm64/crypto/sha512-ce.mod.o
LD [M] arch/arm64/crypto/sha512-ce.ko
CC [M] arch/arm64/crypto/sm3-ce.mod.o
LD [M] arch/arm64/crypto/sm3-ce.ko
CC [M] arch/arm64/lib/xor-neon.mod.o
LD [M] arch/arm64/lib/xor-neon.ko
CC [M] crypto/af_alg.mod.o
LD [M] crypto/af_alg.ko
CC [M] crypto/algif_hash.mod.o
LD [M] crypto/algif_hash.ko
CC [M] crypto/algif_rng.mod.o
LD [M] crypto/algif_rng.ko
CC [M] crypto/authenc.mod.o
LD [M] crypto/authenc.ko
CC [M] crypto/authencesn.mod.o
LD [M] crypto/authencesn.ko
CC [M] crypto/blake2b_generic.mod.o
LD [M] crypto/blake2b_generic.ko
CC [M] crypto/cbc.mod.o
LD [M] crypto/cbc.ko
CC [M] crypto/ccm.mod.o
LD [M] crypto/ccm.ko
CC [M] crypto/cmac.mod.o
LD [M] crypto/cmac.ko
CC [M] crypto/ctr.mod.o
LD [M] crypto/ctr.ko
CC [M] crypto/des_generic.mod.o
LD [M] crypto/des_generic.ko
CC [M] crypto/ecb.mod.o
LD [M] crypto/ecb.ko
CC [M] crypto/ecc.mod.o
LD [M] crypto/ecc.ko
CC [M] crypto/ecdh_generic.mod.o
LD [M] crypto/ecdh_generic.ko
CC [M] crypto/gcm.mod.o
LD [M] crypto/gcm.ko
CC [M] crypto/ghash-generic.mod.o
LD [M] crypto/ghash-generic.ko
CC [M] crypto/md4.mod.o
LD [M] crypto/md4.ko
CC [M] crypto/md5.mod.o
LD [M] crypto/md5.ko
CC [M] crypto/seqiv.mod.o
LD [M] crypto/seqiv.ko
CC [M] crypto/sha3_generic.mod.o
LD [M] crypto/sha3_generic.ko
CC [M] crypto/sha512_generic.mod.o
LD [M] crypto/sha512_generic.ko
CC [M] crypto/sm3_generic.mod.o
LD [M] crypto/sm3_generic.ko
CC [M] crypto/sm4_generic.mod.o
LD [M] crypto/sm4_generic.ko
CC [M] crypto/tcrypt.mod.o
LD [M] crypto/tcrypt.ko
CC [M] crypto/xor.mod.o
LD [M] crypto/xor.ko
CC [M] crypto/xts.mod.o
LD [M] crypto/xts.ko
CC [M] crypto/xxhash_generic.mod.o
LD [M] crypto/xxhash_generic.ko
CC [M] drivers/ata/ahci.mod.o
LD [M] drivers/ata/ahci.ko
CC [M] drivers/ata/ahci_ceva.mod.o
LD [M] drivers/ata/ahci_ceva.ko
CC [M] drivers/ata/ahci_platform.mod.o
LD [M] drivers/ata/ahci_platform.ko
CC [M] drivers/ata/ahci_qoriq.mod.o
LD [M] drivers/ata/ahci_qoriq.ko
CC [M] drivers/ata/ahci_xgene.mod.o
LD [M] drivers/ata/ahci_xgene.ko
CC [M] drivers/ata/libahci.mod.o
LD [M] drivers/ata/libahci.ko
CC [M] drivers/ata/libahci_platform.mod.o
LD [M] drivers/ata/libahci_platform.ko
CC [M] drivers/ata/libata.mod.o
LD [M] drivers/ata/libata.ko
CC [M] drivers/ata/pata_of_platform.mod.o
LD [M] drivers/ata/pata_of_platform.ko
CC [M] drivers/ata/pata_platform.mod.o
LD [M] drivers/ata/pata_platform.ko
CC [M] drivers/ata/sata_sil24.mod.o
LD [M] drivers/ata/sata_sil24.ko
CC [M] drivers/base/regmap/regmap-sdw.mod.o
LD [M] drivers/base/regmap/regmap-sdw.ko
CC [M] drivers/base/regmap/regmap-slimbus.mod.o
LD [M] drivers/base/regmap/regmap-slimbus.ko
CC [M] drivers/base/regmap/regmap-spmi.mod.o
LD [M] drivers/base/regmap/regmap-spmi.ko
CC [M] drivers/bcma/bcma.mod.o
LD [M] drivers/bcma/bcma.ko
CC [M] drivers/block/nbd.mod.o
LD [M] drivers/block/nbd.ko
CC [M] drivers/bluetooth/btbcm.mod.o
LD [M] drivers/bluetooth/btbcm.ko
CC [M] drivers/bluetooth/btintel.mod.o
LD [M] drivers/bluetooth/btintel.ko
CC [M] drivers/bluetooth/btqca.mod.o
LD [M] drivers/bluetooth/btqca.ko
CC [M] drivers/bluetooth/btrtl.mod.o
LD [M] drivers/bluetooth/btrtl.ko
CC [M] drivers/bluetooth/btusb.mod.o
LD [M] drivers/bluetooth/btusb.ko
CC [M] drivers/bluetooth/hci_uart.mod.o
LD [M] drivers/bluetooth/hci_uart.ko
CC [M] drivers/char/hw_random/omap-rng.mod.o
LD [M] drivers/char/hw_random/omap-rng.ko
CC [M] drivers/char/hw_random/optee-rng.mod.o
LD [M] drivers/char/hw_random/optee-rng.ko
CC [M] drivers/char/hw_random/rng-core.mod.o
LD [M] drivers/char/hw_random/rng-core.ko
CC [M] drivers/char/ipmi/ipmi_devintf.mod.o
LD [M] drivers/char/ipmi/ipmi_devintf.ko
CC [M] drivers/char/ipmi/ipmi_msghandler.mod.o
LD [M] drivers/char/ipmi/ipmi_msghandler.ko
CC [M] drivers/char/ipmi/ipmi_si.mod.o
LD [M] drivers/char/ipmi/ipmi_si.ko
CC [M] drivers/clk/clk-bd718x7.mod.o
LD [M] drivers/clk/clk-bd718x7.ko
CC [M] drivers/counter/counter.mod.o
LD [M] drivers/counter/counter.ko
CC [M] drivers/counter/ti-ecap-capture.mod.o
LD [M] drivers/counter/ti-ecap-capture.ko
CC [M] drivers/crypto/ccree/ccree.mod.o
LD [M] drivers/crypto/ccree/ccree.ko
CC [M] drivers/crypto/sa2ul.mod.o
LD [M] drivers/crypto/sa2ul.ko
CC [M] drivers/crypto/ti/mcrc.mod.o
LD [M] drivers/crypto/ti/mcrc.ko
CC [M] drivers/extcon/extcon-palmas.mod.o
LD [M] drivers/extcon/extcon-palmas.ko
CC [M] drivers/extcon/extcon-ptn5150.mod.o
LD [M] drivers/extcon/extcon-ptn5150.ko
CC [M] drivers/extcon/extcon-usb-gpio.mod.o
LD [M] drivers/extcon/extcon-usb-gpio.ko
CC [M] drivers/fpga/altera-freeze-bridge.mod.o
LD [M] drivers/fpga/altera-freeze-bridge.ko
CC [M] drivers/fpga/fpga-bridge.mod.o
LD [M] drivers/fpga/fpga-bridge.ko
CC [M] drivers/fpga/fpga-region.mod.o
LD [M] drivers/fpga/fpga-region.ko
CC [M] drivers/fpga/of-fpga-region.mod.o
LD [M] drivers/fpga/of-fpga-region.ko
CC [M] drivers/gpio/gpio-altera.mod.o
LD [M] drivers/gpio/gpio-altera.ko
CC [M] drivers/gpio/gpio-bd9571mwv.mod.o
LD [M] drivers/gpio/gpio-bd9571mwv.ko
CC [M] drivers/gpio/gpio-pisosr.mod.o
LD [M] drivers/gpio/gpio-pisosr.ko
CC [M] drivers/gpio/gpio-tpic2810.mod.o
LD [M] drivers/gpio/gpio-tpic2810.ko
CC [M] drivers/gpio/gpio-wcd934x.mod.o
LD [M] drivers/gpio/gpio-wcd934x.ko
CC [M] drivers/gpu/drm/arm/mali-dp.mod.o
LD [M] drivers/gpu/drm/arm/mali-dp.ko
CC [M] drivers/gpu/drm/bridge/cadence/cdns-dsi.mod.o
LD [M] drivers/gpu/drm/bridge/cadence/cdns-dsi.ko
CC [M] drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.mod.o
LD [M] drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.ko
CC [M] drivers/gpu/drm/bridge/lontium-lt9611.mod.o
LD [M] drivers/gpu/drm/bridge/lontium-lt9611.ko
CC [M] drivers/gpu/drm/bridge/nwl-dsi.mod.o
LD [M] drivers/gpu/drm/bridge/nwl-dsi.ko
CC [M] drivers/gpu/drm/bridge/simple-bridge.mod.o
LD [M] drivers/gpu/drm/bridge/simple-bridge.ko
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-ahb-audio.mod.o
LD [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-ahb-audio.ko
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-cec.mod.o
LD [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi-cec.ko
CC [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi.mod.o
LD [M] drivers/gpu/drm/bridge/synopsys/dw-hdmi.ko
CC [M] drivers/gpu/drm/bridge/thc63lvd1024.mod.o
LD [M] drivers/gpu/drm/bridge/thc63lvd1024.ko
CC [M] drivers/gpu/drm/bridge/ti-sn65dsi86.mod.o
LD [M] drivers/gpu/drm/bridge/ti-sn65dsi86.ko
CC [M] drivers/gpu/drm/drm_mipi_dbi.mod.o
LD [M] drivers/gpu/drm/drm_mipi_dbi.ko
CC [M] drivers/gpu/drm/panel/panel-lvds.mod.o
LD [M] drivers/gpu/drm/panel/panel-lvds.ko
CC [M] drivers/gpu/drm/panel/panel-raydium-rm67191.mod.o
LD [M] drivers/gpu/drm/panel/panel-raydium-rm67191.ko
CC [M] drivers/gpu/drm/panel/panel-sitronix-st7703.mod.o
LD [M] drivers/gpu/drm/panel/panel-sitronix-st7703.ko
CC [M] drivers/gpu/drm/panel/panel-truly-nt35597.mod.o
LD [M] drivers/gpu/drm/panel/panel-truly-nt35597.ko
CC [M] drivers/gpu/drm/rcar-du/rcar_dw_hdmi.mod.o
LD [M] drivers/gpu/drm/rcar-du/rcar_dw_hdmi.ko
CC [M] drivers/gpu/drm/tiny/ili9225.mod.o
LD [M] drivers/gpu/drm/tiny/ili9225.ko
CC [M] drivers/hid/hid-multitouch.mod.o
LD [M] drivers/hid/hid-multitouch.ko
CC [M] drivers/hid/i2c-hid/i2c-hid.mod.o
LD [M] drivers/hid/i2c-hid/i2c-hid.ko
CC [M] drivers/hid/usbhid/usbhid.mod.o
LD [M] drivers/hid/usbhid/usbhid.ko
CC [M] drivers/hwmon/ina2xx.mod.o
LD [M] drivers/hwmon/ina2xx.ko
CC [M] drivers/hwmon/ina3221.mod.o
LD [M] drivers/hwmon/ina3221.ko
CC [M] drivers/hwmon/lm90.mod.o
LD [M] drivers/hwmon/lm90.ko
CC [M] drivers/hwmon/pwm-fan.mod.o
LD [M] drivers/hwmon/pwm-fan.ko
CC [M] drivers/i2c/i2c-atr.mod.o
LD [M] drivers/i2c/i2c-atr.ko
CC [M] drivers/iio/adc/max9611.mod.o
LD [M] drivers/iio/adc/max9611.ko
CC [M] drivers/iio/adc/qcom-spmi-adc5.mod.o
LD [M] drivers/iio/adc/qcom-spmi-adc5.ko
CC [M] drivers/iio/adc/qcom-vadc-common.mod.o
LD [M] drivers/iio/adc/qcom-vadc-common.ko
CC [M] drivers/iio/adc/ti_am335x_adc.mod.o
LD [M] drivers/iio/adc/ti_am335x_adc.ko
CC [M] drivers/iio/buffer/industrialio-triggered-buffer.mod.o
LD [M] drivers/iio/buffer/industrialio-triggered-buffer.ko
CC [M] drivers/iio/buffer/kfifo_buf.mod.o
LD [M] drivers/iio/buffer/kfifo_buf.ko
CC [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors.mod.o
LD [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors.ko
CC [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors_core.mod.o
LD [M] drivers/iio/common/cros_ec_sensors/cros_ec_sensors_core.ko
CC [M] drivers/iio/light/cros_ec_light_prox.mod.o
LD [M] drivers/iio/light/cros_ec_light_prox.ko
CC [M] drivers/iio/light/isl29018.mod.o
LD [M] drivers/iio/light/isl29018.ko
CC [M] drivers/iio/pressure/cros_ec_baro.mod.o
LD [M] drivers/iio/pressure/cros_ec_baro.ko
CC [M] drivers/iio/pressure/mpl3115.mod.o
LD [M] drivers/iio/pressure/mpl3115.ko
CC [M] drivers/input/keyboard/adc-keys.mod.o
LD [M] drivers/input/keyboard/adc-keys.ko
CC [M] drivers/input/keyboard/matrix_keypad.mod.o
LD [M] drivers/input/keyboard/matrix_keypad.ko
CC [M] drivers/input/misc/gpio_decoder.mod.o
LD [M] drivers/input/misc/gpio_decoder.ko
CC [M] drivers/input/touchscreen/atmel_mxt_ts.mod.o
LD [M] drivers/input/touchscreen/atmel_mxt_ts.ko
CC [M] drivers/input/touchscreen/edt-ft5x06.mod.o
LD [M] drivers/input/touchscreen/edt-ft5x06.ko
CC [M] drivers/input/touchscreen/goodix.mod.o
LD [M] drivers/input/touchscreen/goodix.ko
CC [M] drivers/input/touchscreen/ili210x.mod.o
LD [M] drivers/input/touchscreen/ili210x.ko
CC [M] drivers/input/touchscreen/pixcir_i2c_ts.mod.o
LD [M] drivers/input/touchscreen/pixcir_i2c_ts.ko
CC [M] drivers/input/touchscreen/ti_am335x_tsc.mod.o
LD [M] drivers/input/touchscreen/ti_am335x_tsc.ko
CC [M] drivers/irqchip/irq-pruss-intc.mod.o
LD [M] drivers/irqchip/irq-pruss-intc.ko
CC [M] drivers/md/dm-bio-prison.mod.o
LD [M] drivers/md/dm-bio-prison.ko
CC [M] drivers/md/dm-bufio.mod.o
LD [M] drivers/md/dm-bufio.ko
CC [M] drivers/md/dm-log.mod.o
LD [M] drivers/md/dm-log.ko
CC [M] drivers/md/dm-mirror.mod.o
LD [M] drivers/md/dm-mirror.ko
CC [M] drivers/md/dm-mod.mod.o
LD [M] drivers/md/dm-mod.ko
CC [M] drivers/md/dm-region-hash.mod.o
LD [M] drivers/md/dm-region-hash.ko
CC [M] drivers/md/dm-thin-pool.mod.o
LD [M] drivers/md/dm-thin-pool.ko
CC [M] drivers/md/dm-zero.mod.o
LD [M] drivers/md/dm-zero.ko
CC [M] drivers/md/md-mod.mod.o
LD [M] drivers/md/md-mod.ko
CC [M] drivers/md/persistent-data/dm-persistent-data.mod.o
LD [M] drivers/md/persistent-data/dm-persistent-data.ko
CC [M] drivers/media/common/videobuf2/videobuf2-common.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-common.ko
CC [M] drivers/media/common/videobuf2/videobuf2-dma-contig.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-dma-contig.ko
CC [M] drivers/media/common/videobuf2/videobuf2-dma-sg.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-dma-sg.ko
CC [M] drivers/media/common/videobuf2/videobuf2-memops.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-memops.ko
CC [M] drivers/media/common/videobuf2/videobuf2-v4l2.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-v4l2.ko
CC [M] drivers/media/common/videobuf2/videobuf2-vmalloc.mod.o
LD [M] drivers/media/common/videobuf2/videobuf2-vmalloc.ko
CC [M] drivers/media/dvb-frontends/a8293.mod.o
LD [M] drivers/media/dvb-frontends/a8293.ko
CC [M] drivers/media/dvb-frontends/af9013.mod.o
LD [M] drivers/media/dvb-frontends/af9013.ko
CC [M] drivers/media/dvb-frontends/af9033.mod.o
LD [M] drivers/media/dvb-frontends/af9033.ko
CC [M] drivers/media/dvb-frontends/ascot2e.mod.o
LD [M] drivers/media/dvb-frontends/ascot2e.ko
CC [M] drivers/media/dvb-frontends/atbm8830.mod.o
LD [M] drivers/media/dvb-frontends/atbm8830.ko
CC [M] drivers/media/dvb-frontends/au8522_common.mod.o
LD [M] drivers/media/dvb-frontends/au8522_common.ko
CC [M] drivers/media/dvb-frontends/au8522_decoder.mod.o
LD [M] drivers/media/dvb-frontends/au8522_decoder.ko
CC [M] drivers/media/dvb-frontends/au8522_dig.mod.o
LD [M] drivers/media/dvb-frontends/au8522_dig.ko
CC [M] drivers/media/dvb-frontends/bcm3510.mod.o
LD [M] drivers/media/dvb-frontends/bcm3510.ko
CC [M] drivers/media/dvb-frontends/cx22700.mod.o
LD [M] drivers/media/dvb-frontends/cx22700.ko
CC [M] drivers/media/dvb-frontends/cx22702.mod.o
LD [M] drivers/media/dvb-frontends/cx22702.ko
CC [M] drivers/media/dvb-frontends/cx24110.mod.o
LD [M] drivers/media/dvb-frontends/cx24110.ko
CC [M] drivers/media/dvb-frontends/cx24113.mod.o
LD [M] drivers/media/dvb-frontends/cx24113.ko
CC [M] drivers/media/dvb-frontends/cx24116.mod.o
LD [M] drivers/media/dvb-frontends/cx24116.ko
CC [M] drivers/media/dvb-frontends/cx24117.mod.o
LD [M] drivers/media/dvb-frontends/cx24117.ko
CC [M] drivers/media/dvb-frontends/cx24120.mod.o
LD [M] drivers/media/dvb-frontends/cx24120.ko
CC [M] drivers/media/dvb-frontends/cx24123.mod.o
LD [M] drivers/media/dvb-frontends/cx24123.ko
CC [M] drivers/media/dvb-frontends/cxd2099.mod.o
LD [M] drivers/media/dvb-frontends/cxd2099.ko
CC [M] drivers/media/dvb-frontends/cxd2820r.mod.o
LD [M] drivers/media/dvb-frontends/cxd2820r.ko
CC [M] drivers/media/dvb-frontends/cxd2841er.mod.o
LD [M] drivers/media/dvb-frontends/cxd2841er.ko
CC [M] drivers/media/dvb-frontends/cxd2880/cxd2880.mod.o
LD [M] drivers/media/dvb-frontends/cxd2880/cxd2880.ko
CC [M] drivers/media/dvb-frontends/dib0070.mod.o
LD [M] drivers/media/dvb-frontends/dib0070.ko
CC [M] drivers/media/dvb-frontends/dib0090.mod.o
LD [M] drivers/media/dvb-frontends/dib0090.ko
CC [M] drivers/media/dvb-frontends/dib3000mb.mod.o
LD [M] drivers/media/dvb-frontends/dib3000mb.ko
CC [M] drivers/media/dvb-frontends/dib3000mc.mod.o
LD [M] drivers/media/dvb-frontends/dib3000mc.ko
CC [M] drivers/media/dvb-frontends/dib7000m.mod.o
LD [M] drivers/media/dvb-frontends/dib7000m.ko
CC [M] drivers/media/dvb-frontends/dib7000p.mod.o
LD [M] drivers/media/dvb-frontends/dib7000p.ko
CC [M] drivers/media/dvb-frontends/dib8000.mod.o
LD [M] drivers/media/dvb-frontends/dib8000.ko
CC [M] drivers/media/dvb-frontends/dib9000.mod.o
LD [M] drivers/media/dvb-frontends/dib9000.ko
CC [M] drivers/media/dvb-frontends/dibx000_common.mod.o
LD [M] drivers/media/dvb-frontends/dibx000_common.ko
CC [M] drivers/media/dvb-frontends/drx39xyj/drx39xyj.mod.o
LD [M] drivers/media/dvb-frontends/drx39xyj/drx39xyj.ko
CC [M] drivers/media/dvb-frontends/drxd.mod.o
LD [M] drivers/media/dvb-frontends/drxd.ko
CC [M] drivers/media/dvb-frontends/drxk.mod.o
LD [M] drivers/media/dvb-frontends/drxk.ko
CC [M] drivers/media/dvb-frontends/ds3000.mod.o
LD [M] drivers/media/dvb-frontends/ds3000.ko
CC [M] drivers/media/dvb-frontends/dvb-pll.mod.o
LD [M] drivers/media/dvb-frontends/dvb-pll.ko
CC [M] drivers/media/dvb-frontends/ec100.mod.o
LD [M] drivers/media/dvb-frontends/ec100.ko
CC [M] drivers/media/dvb-frontends/helene.mod.o
LD [M] drivers/media/dvb-frontends/helene.ko
CC [M] drivers/media/dvb-frontends/horus3a.mod.o
LD [M] drivers/media/dvb-frontends/horus3a.ko
CC [M] drivers/media/dvb-frontends/isl6405.mod.o
LD [M] drivers/media/dvb-frontends/isl6405.ko
CC [M] drivers/media/dvb-frontends/isl6421.mod.o
LD [M] drivers/media/dvb-frontends/isl6421.ko
CC [M] drivers/media/dvb-frontends/isl6423.mod.o
LD [M] drivers/media/dvb-frontends/isl6423.ko
CC [M] drivers/media/dvb-frontends/itd1000.mod.o
LD [M] drivers/media/dvb-frontends/itd1000.ko
CC [M] drivers/media/dvb-frontends/ix2505v.mod.o
LD [M] drivers/media/dvb-frontends/ix2505v.ko
CC [M] drivers/media/dvb-frontends/l64781.mod.o
LD [M] drivers/media/dvb-frontends/l64781.ko
CC [M] drivers/media/dvb-frontends/lg2160.mod.o
LD [M] drivers/media/dvb-frontends/lg2160.ko
CC [M] drivers/media/dvb-frontends/lgdt3305.mod.o
LD [M] drivers/media/dvb-frontends/lgdt3305.ko
CC [M] drivers/media/dvb-frontends/lgdt3306a.mod.o
LD [M] drivers/media/dvb-frontends/lgdt3306a.ko
CC [M] drivers/media/dvb-frontends/lgdt330x.mod.o
LD [M] drivers/media/dvb-frontends/lgdt330x.ko
CC [M] drivers/media/dvb-frontends/lgs8gl5.mod.o
LD [M] drivers/media/dvb-frontends/lgs8gl5.ko
CC [M] drivers/media/dvb-frontends/lgs8gxx.mod.o
LD [M] drivers/media/dvb-frontends/lgs8gxx.ko
CC [M] drivers/media/dvb-frontends/lnbh25.mod.o
LD [M] drivers/media/dvb-frontends/lnbh25.ko
CC [M] drivers/media/dvb-frontends/lnbh29.mod.o
LD [M] drivers/media/dvb-frontends/lnbh29.ko
CC [M] drivers/media/dvb-frontends/lnbp21.mod.o
LD [M] drivers/media/dvb-frontends/lnbp21.ko
CC [M] drivers/media/dvb-frontends/lnbp22.mod.o
LD [M] drivers/media/dvb-frontends/lnbp22.ko
CC [M] drivers/media/dvb-frontends/m88ds3103.mod.o
LD [M] drivers/media/dvb-frontends/m88ds3103.ko
CC [M] drivers/media/dvb-frontends/m88rs2000.mod.o
LD [M] drivers/media/dvb-frontends/m88rs2000.ko
CC [M] drivers/media/dvb-frontends/mb86a16.mod.o
LD [M] drivers/media/dvb-frontends/mb86a16.ko
CC [M] drivers/media/dvb-frontends/mb86a20s.mod.o
LD [M] drivers/media/dvb-frontends/mb86a20s.ko
CC [M] drivers/media/dvb-frontends/mn88443x.mod.o
LD [M] drivers/media/dvb-frontends/mn88443x.ko
CC [M] drivers/media/dvb-frontends/mn88472.mod.o
LD [M] drivers/media/dvb-frontends/mn88472.ko
CC [M] drivers/media/dvb-frontends/mn88473.mod.o
LD [M] drivers/media/dvb-frontends/mn88473.ko
CC [M] drivers/media/dvb-frontends/mt312.mod.o
LD [M] drivers/media/dvb-frontends/mt312.ko
CC [M] drivers/media/dvb-frontends/mt352.mod.o
LD [M] drivers/media/dvb-frontends/mt352.ko
CC [M] drivers/media/dvb-frontends/mxl5xx.mod.o
LD [M] drivers/media/dvb-frontends/mxl5xx.ko
CC [M] drivers/media/dvb-frontends/nxt200x.mod.o
LD [M] drivers/media/dvb-frontends/nxt200x.ko
CC [M] drivers/media/dvb-frontends/nxt6000.mod.o
LD [M] drivers/media/dvb-frontends/nxt6000.ko
CC [M] drivers/media/dvb-frontends/or51132.mod.o
LD [M] drivers/media/dvb-frontends/or51132.ko
CC [M] drivers/media/dvb-frontends/or51211.mod.o
LD [M] drivers/media/dvb-frontends/or51211.ko
CC [M] drivers/media/dvb-frontends/rtl2830.mod.o
LD [M] drivers/media/dvb-frontends/rtl2830.ko
CC [M] drivers/media/dvb-frontends/rtl2832.mod.o
LD [M] drivers/media/dvb-frontends/rtl2832.ko
CC [M] drivers/media/dvb-frontends/rtl2832_sdr.mod.o
LD [M] drivers/media/dvb-frontends/rtl2832_sdr.ko
CC [M] drivers/media/dvb-frontends/s5h1409.mod.o
LD [M] drivers/media/dvb-frontends/s5h1409.ko
CC [M] drivers/media/dvb-frontends/s5h1411.mod.o
LD [M] drivers/media/dvb-frontends/s5h1411.ko
CC [M] drivers/media/dvb-frontends/s5h1420.mod.o
LD [M] drivers/media/dvb-frontends/s5h1420.ko
CC [M] drivers/media/dvb-frontends/s5h1432.mod.o
LD [M] drivers/media/dvb-frontends/s5h1432.ko
CC [M] drivers/media/dvb-frontends/s921.mod.o
LD [M] drivers/media/dvb-frontends/s921.ko
CC [M] drivers/media/dvb-frontends/si2165.mod.o
LD [M] drivers/media/dvb-frontends/si2165.ko
CC [M] drivers/media/dvb-frontends/si2168.mod.o
LD [M] drivers/media/dvb-frontends/si2168.ko
CC [M] drivers/media/dvb-frontends/si21xx.mod.o
LD [M] drivers/media/dvb-frontends/si21xx.ko
CC [M] drivers/media/dvb-frontends/sp2.mod.o
LD [M] drivers/media/dvb-frontends/sp2.ko
CC [M] drivers/media/dvb-frontends/sp8870.mod.o
LD [M] drivers/media/dvb-frontends/sp8870.ko
CC [M] drivers/media/dvb-frontends/sp887x.mod.o
LD [M] drivers/media/dvb-frontends/sp887x.ko
CC [M] drivers/media/dvb-frontends/stb0899.mod.o
LD [M] drivers/media/dvb-frontends/stb0899.ko
CC [M] drivers/media/dvb-frontends/stb6000.mod.o
LD [M] drivers/media/dvb-frontends/stb6000.ko
CC [M] drivers/media/dvb-frontends/stb6100.mod.o
LD [M] drivers/media/dvb-frontends/stb6100.ko
CC [M] drivers/media/dvb-frontends/stv0288.mod.o
LD [M] drivers/media/dvb-frontends/stv0288.ko
CC [M] drivers/media/dvb-frontends/stv0297.mod.o
LD [M] drivers/media/dvb-frontends/stv0297.ko
CC [M] drivers/media/dvb-frontends/stv0299.mod.o
LD [M] drivers/media/dvb-frontends/stv0299.ko
CC [M] drivers/media/dvb-frontends/stv0367.mod.o
LD [M] drivers/media/dvb-frontends/stv0367.ko
CC [M] drivers/media/dvb-frontends/stv0900.mod.o
LD [M] drivers/media/dvb-frontends/stv0900.ko
CC [M] drivers/media/dvb-frontends/stv090x.mod.o
LD [M] drivers/media/dvb-frontends/stv090x.ko
CC [M] drivers/media/dvb-frontends/stv0910.mod.o
LD [M] drivers/media/dvb-frontends/stv0910.ko
CC [M] drivers/media/dvb-frontends/stv6110.mod.o
LD [M] drivers/media/dvb-frontends/stv6110.ko
CC [M] drivers/media/dvb-frontends/stv6110x.mod.o
LD [M] drivers/media/dvb-frontends/stv6110x.ko
CC [M] drivers/media/dvb-frontends/stv6111.mod.o
LD [M] drivers/media/dvb-frontends/stv6111.ko
CC [M] drivers/media/dvb-frontends/tc90522.mod.o
LD [M] drivers/media/dvb-frontends/tc90522.ko
CC [M] drivers/media/dvb-frontends/tda10021.mod.o
LD [M] drivers/media/dvb-frontends/tda10021.ko
CC [M] drivers/media/dvb-frontends/tda10023.mod.o
LD [M] drivers/media/dvb-frontends/tda10023.ko
CC [M] drivers/media/dvb-frontends/tda10048.mod.o
LD [M] drivers/media/dvb-frontends/tda10048.ko
CC [M] drivers/media/dvb-frontends/tda1004x.mod.o
LD [M] drivers/media/dvb-frontends/tda1004x.ko
CC [M] drivers/media/dvb-frontends/tda10071.mod.o
LD [M] drivers/media/dvb-frontends/tda10071.ko
CC [M] drivers/media/dvb-frontends/tda10086.mod.o
LD [M] drivers/media/dvb-frontends/tda10086.ko
CC [M] drivers/media/dvb-frontends/tda18271c2dd.mod.o
LD [M] drivers/media/dvb-frontends/tda18271c2dd.ko
CC [M] drivers/media/dvb-frontends/tda665x.mod.o
LD [M] drivers/media/dvb-frontends/tda665x.ko
CC [M] drivers/media/dvb-frontends/tda8083.mod.o
LD [M] drivers/media/dvb-frontends/tda8083.ko
CC [M] drivers/media/dvb-frontends/tda8261.mod.o
LD [M] drivers/media/dvb-frontends/tda8261.ko
CC [M] drivers/media/dvb-frontends/tda826x.mod.o
LD [M] drivers/media/dvb-frontends/tda826x.ko
CC [M] drivers/media/dvb-frontends/ts2020.mod.o
LD [M] drivers/media/dvb-frontends/ts2020.ko
CC [M] drivers/media/dvb-frontends/tua6100.mod.o
LD [M] drivers/media/dvb-frontends/tua6100.ko
CC [M] drivers/media/dvb-frontends/ves1820.mod.o
LD [M] drivers/media/dvb-frontends/ves1820.ko
CC [M] drivers/media/dvb-frontends/ves1x93.mod.o
LD [M] drivers/media/dvb-frontends/ves1x93.ko
CC [M] drivers/media/dvb-frontends/zd1301_demod.mod.o
LD [M] drivers/media/dvb-frontends/zd1301_demod.ko
CC [M] drivers/media/dvb-frontends/zl10036.mod.o
LD [M] drivers/media/dvb-frontends/zl10036.ko
CC [M] drivers/media/dvb-frontends/zl10039.mod.o
LD [M] drivers/media/dvb-frontends/zl10039.ko
CC [M] drivers/media/dvb-frontends/zl10353.mod.o
LD [M] drivers/media/dvb-frontends/zl10353.ko
CC [M] drivers/media/i2c/ds90ub953.mod.o
LD [M] drivers/media/i2c/ds90ub953.ko
CC [M] drivers/media/i2c/ds90ub960.mod.o
LD [M] drivers/media/i2c/ds90ub960.ko
CC [M] drivers/media/i2c/imx219.mod.o
LD [M] drivers/media/i2c/imx219.ko
CC [M] drivers/media/i2c/imx390.mod.o
LD [M] drivers/media/i2c/imx390.ko
CC [M] drivers/media/i2c/ov1063x.mod.o
LD [M] drivers/media/i2c/ov1063x.ko
CC [M] drivers/media/i2c/ov2312.mod.o
LD [M] drivers/media/i2c/ov2312.ko
CC [M] drivers/media/i2c/ov2659.mod.o
LD [M] drivers/media/i2c/ov2659.ko
CC [M] drivers/media/i2c/ov5640.mod.o
LD [M] drivers/media/i2c/ov5640.ko
CC [M] drivers/media/i2c/ov5645.mod.o
LD [M] drivers/media/i2c/ov5645.ko
CC [M] drivers/media/platform/cadence/cdns-csi2rx.mod.o
LD [M] drivers/media/platform/cadence/cdns-csi2rx.ko
CC [M] drivers/media/platform/chips-media/wave5/wave5.mod.o
LD [M] drivers/media/platform/chips-media/wave5/wave5.ko
CC [M] drivers/media/platform/ti/cal/ti-cal.mod.o
LD [M] drivers/media/platform/ti/cal/ti-cal.ko
CC [M] drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.mod.o
LD [M] drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.ko
CC [M] drivers/media/platform/vxe-vxd/vxd-dec.mod.o
LD [M] drivers/media/platform/vxe-vxd/vxd-dec.ko
CC [M] drivers/media/platform/vxe-vxd/vxe-enc.mod.o
LD [M] drivers/media/platform/vxe-vxd/vxe-enc.ko
CC [M] drivers/media/spi/cxd2880-spi.mod.o
LD [M] drivers/media/spi/cxd2880-spi.ko
CC [M] drivers/media/tuners/e4000.mod.o
LD [M] drivers/media/tuners/e4000.ko
CC [M] drivers/media/tuners/fc0011.mod.o
LD [M] drivers/media/tuners/fc0011.ko
CC [M] drivers/media/tuners/fc0012.mod.o
LD [M] drivers/media/tuners/fc0012.ko
CC [M] drivers/media/tuners/fc0013.mod.o
LD [M] drivers/media/tuners/fc0013.ko
CC [M] drivers/media/tuners/fc2580.mod.o
LD [M] drivers/media/tuners/fc2580.ko
CC [M] drivers/media/tuners/it913x.mod.o
LD [M] drivers/media/tuners/it913x.ko
CC [M] drivers/media/tuners/m88rs6000t.mod.o
LD [M] drivers/media/tuners/m88rs6000t.ko
CC [M] drivers/media/tuners/max2165.mod.o
LD [M] drivers/media/tuners/max2165.ko
CC [M] drivers/media/tuners/mc44s803.mod.o
LD [M] drivers/media/tuners/mc44s803.ko
CC [M] drivers/media/tuners/msi001.mod.o
LD [M] drivers/media/tuners/msi001.ko
CC [M] drivers/media/tuners/mt2060.mod.o
LD [M] drivers/media/tuners/mt2060.ko
CC [M] drivers/media/tuners/mt2063.mod.o
LD [M] drivers/media/tuners/mt2063.ko
CC [M] drivers/media/tuners/mt20xx.mod.o
LD [M] drivers/media/tuners/mt20xx.ko
CC [M] drivers/media/tuners/mt2131.mod.o
LD [M] drivers/media/tuners/mt2131.ko
CC [M] drivers/media/tuners/mt2266.mod.o
LD [M] drivers/media/tuners/mt2266.ko
CC [M] drivers/media/tuners/mxl301rf.mod.o
LD [M] drivers/media/tuners/mxl301rf.ko
CC [M] drivers/media/tuners/mxl5005s.mod.o
LD [M] drivers/media/tuners/mxl5005s.ko
CC [M] drivers/media/tuners/mxl5007t.mod.o
LD [M] drivers/media/tuners/mxl5007t.ko
CC [M] drivers/media/tuners/qm1d1b0004.mod.o
LD [M] drivers/media/tuners/qm1d1b0004.ko
CC [M] drivers/media/tuners/qm1d1c0042.mod.o
LD [M] drivers/media/tuners/qm1d1c0042.ko
CC [M] drivers/media/tuners/qt1010.mod.o
LD [M] drivers/media/tuners/qt1010.ko
CC [M] drivers/media/tuners/r820t.mod.o
LD [M] drivers/media/tuners/r820t.ko
CC [M] drivers/media/tuners/si2157.mod.o
LD [M] drivers/media/tuners/si2157.ko
CC [M] drivers/media/tuners/tda18212.mod.o
LD [M] drivers/media/tuners/tda18212.ko
CC [M] drivers/media/tuners/tda18218.mod.o
LD [M] drivers/media/tuners/tda18218.ko
CC [M] drivers/media/tuners/tda18250.mod.o
LD [M] drivers/media/tuners/tda18250.ko
CC [M] drivers/media/tuners/tda18271.mod.o
LD [M] drivers/media/tuners/tda18271.ko
CC [M] drivers/media/tuners/tda827x.mod.o
LD [M] drivers/media/tuners/tda827x.ko
CC [M] drivers/media/tuners/tda8290.mod.o
LD [M] drivers/media/tuners/tda8290.ko
CC [M] drivers/media/tuners/tda9887.mod.o
LD [M] drivers/media/tuners/tda9887.ko
CC [M] drivers/media/tuners/tea5761.mod.o
LD [M] drivers/media/tuners/tea5761.ko
CC [M] drivers/media/tuners/tea5767.mod.o
LD [M] drivers/media/tuners/tea5767.ko
CC [M] drivers/media/tuners/tua9001.mod.o
LD [M] drivers/media/tuners/tua9001.ko
CC [M] drivers/media/tuners/tuner-simple.mod.o
LD [M] drivers/media/tuners/tuner-simple.ko
CC [M] drivers/media/tuners/tuner-types.mod.o
LD [M] drivers/media/tuners/tuner-types.ko
CC [M] drivers/media/tuners/tuner-xc2028.mod.o
LD [M] drivers/media/tuners/tuner-xc2028.ko
CC [M] drivers/media/tuners/xc4000.mod.o
LD [M] drivers/media/tuners/xc4000.ko
CC [M] drivers/media/tuners/xc5000.mod.o
LD [M] drivers/media/tuners/xc5000.ko
CC [M] drivers/media/usb/gspca/gspca_main.mod.o
LD [M] drivers/media/usb/gspca/gspca_main.ko
CC [M] drivers/media/usb/uvc/uvcvideo.mod.o
LD [M] drivers/media/usb/uvc/uvcvideo.ko
CC [M] drivers/media/v4l2-core/v4l2-fwnode.mod.o
LD [M] drivers/media/v4l2-core/v4l2-fwnode.ko
CC [M] drivers/media/v4l2-core/v4l2-mem2mem.mod.o
LD [M] drivers/media/v4l2-core/v4l2-mem2mem.ko
CC [M] drivers/mfd/ti_am335x_tscadc.mod.o
LD [M] drivers/mfd/ti_am335x_tscadc.ko
CC [M] drivers/mfd/wcd934x.mod.o
LD [M] drivers/mfd/wcd934x.ko
CC [M] drivers/misc/eeprom/at24.mod.o
LD [M] drivers/misc/eeprom/at24.ko
CC [M] drivers/misc/eeprom/at25.mod.o
LD [M] drivers/misc/eeprom/at25.ko
CC [M] drivers/misc/eeprom/eeprom_93xx46.mod.o
LD [M] drivers/misc/eeprom/eeprom_93xx46.ko
CC [M] drivers/misc/mytest.mod.o
LD [M] drivers/misc/mytest.ko
CC [M] drivers/misc/pci_endpoint_test.mod.o
LD [M] drivers/misc/pci_endpoint_test.ko
CC [M] drivers/misc/uacce/uacce.mod.o
LD [M] drivers/misc/uacce/uacce.ko
CC [M] drivers/mtd/tests/mtd_nandbiterrs.mod.o
LD [M] drivers/mtd/tests/mtd_nandbiterrs.ko
CC [M] drivers/mtd/tests/mtd_nandecctest.mod.o
LD [M] drivers/mtd/tests/mtd_nandecctest.ko
CC [M] drivers/mtd/tests/mtd_oobtest.mod.o
LD [M] drivers/mtd/tests/mtd_oobtest.ko
CC [M] drivers/mtd/tests/mtd_pagetest.mod.o
LD [M] drivers/mtd/tests/mtd_pagetest.ko
CC [M] drivers/mtd/tests/mtd_readtest.mod.o
LD [M] drivers/mtd/tests/mtd_readtest.ko
CC [M] drivers/mtd/tests/mtd_speedtest.mod.o
LD [M] drivers/mtd/tests/mtd_speedtest.ko
CC [M] drivers/mtd/tests/mtd_stresstest.mod.o
LD [M] drivers/mtd/tests/mtd_stresstest.ko
CC [M] drivers/mtd/tests/mtd_subpagetest.mod.o
LD [M] drivers/mtd/tests/mtd_subpagetest.ko
CC [M] drivers/mtd/tests/mtd_torturetest.mod.o
LD [M] drivers/mtd/tests/mtd_torturetest.ko
CC [M] drivers/net/can/c_can/c_can.mod.o
LD [M] drivers/net/can/c_can/c_can.ko
CC [M] drivers/net/can/c_can/c_can_platform.mod.o
LD [M] drivers/net/can/c_can/c_can_platform.ko
CC [M] drivers/net/can/dev/can-dev.mod.o
LD [M] drivers/net/can/dev/can-dev.ko
CC [M] drivers/net/can/flexcan.mod.o
LD [M] drivers/net/can/flexcan.ko
CC [M] drivers/net/can/m_can/m_can.mod.o
LD [M] drivers/net/can/m_can/m_can.ko
CC [M] drivers/net/can/m_can/m_can_platform.mod.o
LD [M] drivers/net/can/m_can/m_can_platform.ko
CC [M] drivers/net/dummy.mod.o
LD [M] drivers/net/dummy.ko
CC [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x.mod.o
LD [M] drivers/net/ethernet/broadcom/bnx2x/bnx2x.ko
CC [M] drivers/net/ethernet/broadcom/tg3.mod.o
LD [M] drivers/net/ethernet/broadcom/tg3.ko
CC [M] drivers/net/ethernet/intel/e1000/e1000.mod.o
LD [M] drivers/net/ethernet/intel/e1000/e1000.ko
CC [M] drivers/net/ethernet/intel/e1000e/e1000e.mod.o
LD [M] drivers/net/ethernet/intel/e1000e/e1000e.ko
CC [M] drivers/net/ethernet/marvell/skge.mod.o
LD [M] drivers/net/ethernet/marvell/skge.ko
CC [M] drivers/net/ethernet/qualcomm/emac/qcom-emac.mod.o
LD [M] drivers/net/ethernet/qualcomm/emac/qcom-emac.ko
CC [M] drivers/net/ethernet/qualcomm/qca_7k_common.mod.o
LD [M] drivers/net/ethernet/qualcomm/qca_7k_common.ko
CC [M] drivers/net/ethernet/qualcomm/qcaspi.mod.o
LD [M] drivers/net/ethernet/qualcomm/qcaspi.ko
CC [M] drivers/net/ethernet/qualcomm/qcauart.mod.o
LD [M] drivers/net/ethernet/qualcomm/qcauart.ko
CC [M] drivers/net/ethernet/qualcomm/rmnet/rmnet.mod.o
LD [M] drivers/net/ethernet/qualcomm/rmnet/rmnet.ko
CC [M] drivers/net/ethernet/ti/icss_iep.mod.o
LD [M] drivers/net/ethernet/ti/icss_iep.ko
CC [M] drivers/net/ethernet/ti/icssg-prueth.mod.o
LD [M] drivers/net/ethernet/ti/icssg-prueth.ko
CC [M] drivers/net/ethernet/ti/prueth.mod.o
LD [M] drivers/net/ethernet/ti/prueth.ko
CC [M] drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.mod.o
LD [M] drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.ko
CC [M] drivers/net/ipvlan/ipvlan.mod.o
LD [M] drivers/net/ipvlan/ipvlan.ko
CC [M] drivers/net/macvlan.mod.o
LD [M] drivers/net/macvlan.ko
CC [M] drivers/net/macvtap.mod.o
LD [M] drivers/net/macvtap.ko
CC [M] drivers/net/mdio.mod.o
LD [M] drivers/net/mdio.ko
CC [M] drivers/net/ntb_netdev.mod.o
LD [M] drivers/net/ntb_netdev.ko
CC [M] drivers/net/phy/marvell10g.mod.o
LD [M] drivers/net/phy/marvell10g.ko
CC [M] drivers/net/phy/microchip.mod.o
LD [M] drivers/net/phy/microchip.ko
CC [M] drivers/net/phy/realtek.mod.o
LD [M] drivers/net/phy/realtek.ko
CC [M] drivers/net/phy/smsc.mod.o
LD [M] drivers/net/phy/smsc.ko
CC [M] drivers/net/tap.mod.o
LD [M] drivers/net/tap.ko
CC [M] drivers/net/usb/asix.mod.o
LD [M] drivers/net/usb/asix.ko
CC [M] drivers/net/usb/ax88179_178a.mod.o
LD [M] drivers/net/usb/ax88179_178a.ko
CC [M] drivers/net/usb/cdc_eem.mod.o
LD [M] drivers/net/usb/cdc_eem.ko
CC [M] drivers/net/usb/cdc_ether.mod.o
LD [M] drivers/net/usb/cdc_ether.ko
CC [M] drivers/net/usb/cdc_ncm.mod.o
LD [M] drivers/net/usb/cdc_ncm.ko
CC [M] drivers/net/usb/cdc_subset.mod.o
LD [M] drivers/net/usb/cdc_subset.ko
CC [M] drivers/net/usb/dm9601.mod.o
LD [M] drivers/net/usb/dm9601.ko
CC [M] drivers/net/usb/lan78xx.mod.o
LD [M] drivers/net/usb/lan78xx.ko
CC [M] drivers/net/usb/mcs7830.mod.o
LD [M] drivers/net/usb/mcs7830.ko
CC [M] drivers/net/usb/net1080.mod.o
LD [M] drivers/net/usb/net1080.ko
CC [M] drivers/net/usb/pegasus.mod.o
LD [M] drivers/net/usb/pegasus.ko
CC [M] drivers/net/usb/plusb.mod.o
LD [M] drivers/net/usb/plusb.ko
CC [M] drivers/net/usb/r8152.mod.o
LD [M] drivers/net/usb/r8152.ko
CC [M] drivers/net/usb/rtl8150.mod.o
LD [M] drivers/net/usb/rtl8150.ko
CC [M] drivers/net/usb/smsc75xx.mod.o
LD [M] drivers/net/usb/smsc75xx.ko
CC [M] drivers/net/usb/smsc95xx.mod.o
LD [M] drivers/net/usb/smsc95xx.ko
CC [M] drivers/net/usb/sr9800.mod.o
LD [M] drivers/net/usb/sr9800.ko
CC [M] drivers/net/usb/usbnet.mod.o
LD [M] drivers/net/usb/usbnet.ko
CC [M] drivers/net/usb/zaurus.mod.o
LD [M] drivers/net/usb/zaurus.ko
CC [M] drivers/net/veth.mod.o
LD [M] drivers/net/veth.ko
CC [M] drivers/net/vxlan.mod.o
LD [M] drivers/net/vxlan.ko
CC [M] drivers/net/wireless/ath/ath.mod.o
LD [M] drivers/net/wireless/ath/ath.ko
CC [M] drivers/net/wireless/ath/ath10k/ath10k_core.mod.o
LD [M] drivers/net/wireless/ath/ath10k/ath10k_core.ko
CC [M] drivers/net/wireless/ath/ath10k/ath10k_pci.mod.o
LD [M] drivers/net/wireless/ath/ath10k/ath10k_pci.ko
CC [M] drivers/net/wireless/broadcom/b43/b43.mod.o
LD [M] drivers/net/wireless/broadcom/b43/b43.ko
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.mod.o
LD [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.mod.o
LD [M] drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
CC [M] drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.mod.o
LD [M] drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
CC [M] drivers/net/wireless/intel/iwlwifi/iwlwifi.mod.o
LD [M] drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
CC [M] drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.mod.o
LD [M] drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
CC [M] drivers/net/wireless/marvell/mwifiex/mwifiex.mod.o
LD [M] drivers/net/wireless/marvell/mwifiex/mwifiex.ko
CC [M] drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.mod.o
LD [M] drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.ko
CC [M] drivers/net/wireless/ti/wl18xx/wl18xx.mod.o
LD [M] drivers/net/wireless/ti/wl18xx/wl18xx.ko
CC [M] drivers/net/wireless/ti/wlcore/wlcore.mod.o
LD [M] drivers/net/wireless/ti/wlcore/wlcore.ko
CC [M] drivers/net/wireless/ti/wlcore/wlcore_sdio.mod.o
LD [M] drivers/net/wireless/ti/wlcore/wlcore_sdio.ko
CC [M] drivers/nfc/s3fwrn5/s3fwrn5.mod.o
LD [M] drivers/nfc/s3fwrn5/s3fwrn5.ko
CC [M] drivers/nfc/s3fwrn5/s3fwrn5_i2c.mod.o
LD [M] drivers/nfc/s3fwrn5/s3fwrn5_i2c.ko
CC [M] drivers/ntb/hw/epf/ntb_hw_epf.mod.o
LD [M] drivers/ntb/hw/epf/ntb_hw_epf.ko
CC [M] drivers/ntb/ntb.mod.o
LD [M] drivers/ntb/ntb.ko
CC [M] drivers/ntb/ntb_transport.mod.o
LD [M] drivers/ntb/ntb_transport.ko
CC [M] drivers/nvme/host/nvme-core.mod.o
LD [M] drivers/nvme/host/nvme-core.ko
CC [M] drivers/nvme/host/nvme.mod.o
LD [M] drivers/nvme/host/nvme.ko
CC [M] drivers/phy/cadence/cdns-dphy.mod.o
LD [M] drivers/phy/cadence/cdns-dphy.ko
CC [M] drivers/phy/freescale/phy-fsl-imx8-mipi-dphy.mod.o
LD [M] drivers/phy/freescale/phy-fsl-imx8-mipi-dphy.ko
CC [M] drivers/phy/phy-can-transceiver.mod.o
LD [M] drivers/phy/phy-can-transceiver.ko
CC [M] drivers/phy/ti/phy-omap-usb2.mod.o
LD [M] drivers/phy/ti/phy-omap-usb2.ko
CC [M] drivers/platform/chrome/cros_ec_chardev.mod.o
LD [M] drivers/platform/chrome/cros_ec_chardev.ko
CC [M] drivers/platform/chrome/cros_ec_typec.mod.o
LD [M] drivers/platform/chrome/cros_ec_typec.ko
CC [M] drivers/power/supply/bq27xxx_battery_hdq.mod.o
LD [M] drivers/power/supply/bq27xxx_battery_hdq.ko
CC [M] drivers/power/supply/sbs-battery.mod.o
LD [M] drivers/power/supply/sbs-battery.ko
CC [M] drivers/pwm/pwm-cros-ec.mod.o
LD [M] drivers/pwm/pwm-cros-ec.ko
CC [M] drivers/regulator/vctrl-regulator.mod.o
LD [M] drivers/regulator/vctrl-regulator.ko
CC [M] drivers/remoteproc/pru_rproc.mod.o
LD [M] drivers/remoteproc/pru_rproc.ko
CC [M] drivers/remoteproc/ti_k3_dsp_remoteproc.mod.o
LD [M] drivers/remoteproc/ti_k3_dsp_remoteproc.ko
CC [M] drivers/remoteproc/ti_k3_m4_remoteproc.mod.o
LD [M] drivers/remoteproc/ti_k3_m4_remoteproc.ko
CC [M] drivers/remoteproc/ti_k3_r5_remoteproc.mod.o
LD [M] drivers/remoteproc/ti_k3_r5_remoteproc.ko
CC [M] drivers/rpmsg-kdrv/rpmsg_kdrv_switch.mod.o
LD [M] drivers/rpmsg-kdrv/rpmsg_kdrv_switch.ko
CC [M] drivers/rpmsg/rpmsg_char.mod.o
LD [M] drivers/rpmsg/rpmsg_char.ko
CC [M] drivers/rpmsg/rpmsg_pru.mod.o
LD [M] drivers/rpmsg/rpmsg_pru.ko
CC [M] drivers/rpmsg/virtio_rpmsg_bus.mod.o
LD [M] drivers/rpmsg/virtio_rpmsg_bus.ko
CC [M] drivers/rtc/rtc-ds1307.mod.o
LD [M] drivers/rtc/rtc-ds1307.ko
CC [M] drivers/rtc/rtc-pcf2127.mod.o
LD [M] drivers/rtc/rtc-pcf2127.ko
CC [M] drivers/rtc/rtc-pcf85363.mod.o
LD [M] drivers/rtc/rtc-pcf85363.ko
CC [M] drivers/rtc/rtc-rk808.mod.o
LD [M] drivers/rtc/rtc-rk808.ko
CC [M] drivers/rtc/rtc-rv8803.mod.o
LD [M] drivers/rtc/rtc-rv8803.ko
CC [M] drivers/rtc/rtc-rx8581.mod.o
LD [M] drivers/rtc/rtc-rx8581.ko
CC [M] drivers/scsi/hisi_sas/hisi_sas_main.mod.o
LD [M] drivers/scsi/hisi_sas/hisi_sas_main.ko
CC [M] drivers/scsi/hisi_sas/hisi_sas_v1_hw.mod.o
LD [M] drivers/scsi/hisi_sas/hisi_sas_v1_hw.ko
CC [M] drivers/scsi/hisi_sas/hisi_sas_v2_hw.mod.o
LD [M] drivers/scsi/hisi_sas/hisi_sas_v2_hw.ko
CC [M] drivers/scsi/libsas/libsas.mod.o
LD [M] drivers/scsi/libsas/libsas.ko
CC [M] drivers/scsi/mpt3sas/mpt3sas.mod.o
LD [M] drivers/scsi/mpt3sas/mpt3sas.ko
CC [M] drivers/scsi/raid_class.mod.o
LD [M] drivers/scsi/raid_class.ko
CC [M] drivers/scsi/scsi_transport_sas.mod.o
LD [M] drivers/scsi/scsi_transport_sas.ko
CC [M] drivers/slimbus/slim-qcom-ctrl.mod.o
LD [M] drivers/slimbus/slim-qcom-ctrl.ko
CC [M] drivers/slimbus/slimbus.mod.o
LD [M] drivers/slimbus/slimbus.ko
CC [M] drivers/soc/ti/pruss.mod.o
LD [M] drivers/soc/ti/pruss.ko
CC [M] drivers/soundwire/soundwire-bus.mod.o
LD [M] drivers/soundwire/soundwire-bus.ko
CC [M] drivers/soundwire/soundwire-qcom.mod.o
LD [M] drivers/soundwire/soundwire-qcom.ko
CC [M] drivers/spi/spidev.mod.o
LD [M] drivers/spi/spidev.ko
CC [M] drivers/ssb/ssb.mod.o
LD [M] drivers/ssb/ssb.ko
CC [M] drivers/tty/serial/8250/8250_pruss.mod.o
LD [M] drivers/tty/serial/8250/8250_pruss.ko
CC [M] drivers/usb/cdns3/cdns3-ti.mod.o
LD [M] drivers/usb/cdns3/cdns3-ti.ko
CC [M] drivers/usb/cdns3/cdns3.mod.o
LD [M] drivers/usb/cdns3/cdns3.ko
CC [M] drivers/usb/class/cdc-acm.mod.o
LD [M] drivers/usb/class/cdc-acm.ko
CC [M] drivers/usb/common/usb-common.mod.o
LD [M] drivers/usb/common/usb-common.ko
CC [M] drivers/usb/common/usb-conn-gpio.mod.o
LD [M] drivers/usb/common/usb-conn-gpio.ko
CC [M] drivers/usb/core/usbcore.mod.o
LD [M] drivers/usb/core/usbcore.ko
CC [M] drivers/usb/dwc3/dwc3-am62.mod.o
LD [M] drivers/usb/dwc3/dwc3-am62.ko
CC [M] drivers/usb/dwc3/dwc3-haps.mod.o
LD [M] drivers/usb/dwc3/dwc3-haps.ko
CC [M] drivers/usb/dwc3/dwc3-keystone.mod.o
LD [M] drivers/usb/dwc3/dwc3-keystone.ko
CC [M] drivers/usb/dwc3/dwc3-of-simple.mod.o
LD [M] drivers/usb/dwc3/dwc3-of-simple.ko
CC [M] drivers/usb/dwc3/dwc3.mod.o
LD [M] drivers/usb/dwc3/dwc3.ko
CC [M] drivers/usb/gadget/function/u_audio.mod.o
LD [M] drivers/usb/gadget/function/u_audio.ko
CC [M] drivers/usb/gadget/function/u_ether.mod.o
LD [M] drivers/usb/gadget/function/u_ether.ko
CC [M] drivers/usb/gadget/function/u_serial.mod.o
LD [M] drivers/usb/gadget/function/u_serial.ko
CC [M] drivers/usb/gadget/function/usb_f_acm.mod.o
LD [M] drivers/usb/gadget/function/usb_f_acm.ko
CC [M] drivers/usb/gadget/function/usb_f_ecm.mod.o
LD [M] drivers/usb/gadget/function/usb_f_ecm.ko
CC [M] drivers/usb/gadget/function/usb_f_ecm_subset.mod.o
LD [M] drivers/usb/gadget/function/usb_f_ecm_subset.ko
CC [M] drivers/usb/gadget/function/usb_f_eem.mod.o
LD [M] drivers/usb/gadget/function/usb_f_eem.ko
CC [M] drivers/usb/gadget/function/usb_f_fs.mod.o
LD [M] drivers/usb/gadget/function/usb_f_fs.ko
CC [M] drivers/usb/gadget/function/usb_f_hid.mod.o
LD [M] drivers/usb/gadget/function/usb_f_hid.ko
CC [M] drivers/usb/gadget/function/usb_f_mass_storage.mod.o
LD [M] drivers/usb/gadget/function/usb_f_mass_storage.ko
CC [M] drivers/usb/gadget/function/usb_f_midi.mod.o
LD [M] drivers/usb/gadget/function/usb_f_midi.ko
CC [M] drivers/usb/gadget/function/usb_f_ncm.mod.o
LD [M] drivers/usb/gadget/function/usb_f_ncm.ko
CC [M] drivers/usb/gadget/function/usb_f_obex.mod.o
LD [M] drivers/usb/gadget/function/usb_f_obex.ko
CC [M] drivers/usb/gadget/function/usb_f_printer.mod.o
LD [M] drivers/usb/gadget/function/usb_f_printer.ko
CC [M] drivers/usb/gadget/function/usb_f_rndis.mod.o
LD [M] drivers/usb/gadget/function/usb_f_rndis.ko
CC [M] drivers/usb/gadget/function/usb_f_serial.mod.o
LD [M] drivers/usb/gadget/function/usb_f_serial.ko
CC [M] drivers/usb/gadget/function/usb_f_ss_lb.mod.o
LD [M] drivers/usb/gadget/function/usb_f_ss_lb.ko
CC [M] drivers/usb/gadget/function/usb_f_uac1.mod.o
LD [M] drivers/usb/gadget/function/usb_f_uac1.ko
CC [M] drivers/usb/gadget/function/usb_f_uac2.mod.o
LD [M] drivers/usb/gadget/function/usb_f_uac2.ko
CC [M] drivers/usb/gadget/function/usb_f_uvc.mod.o
LD [M] drivers/usb/gadget/function/usb_f_uvc.ko
CC [M] drivers/usb/gadget/legacy/g_acm_ms.mod.o
LD [M] drivers/usb/gadget/legacy/g_acm_ms.ko
CC [M] drivers/usb/gadget/legacy/g_audio.mod.o
LD [M] drivers/usb/gadget/legacy/g_audio.ko
CC [M] drivers/usb/gadget/legacy/g_cdc.mod.o
LD [M] drivers/usb/gadget/legacy/g_cdc.ko
CC [M] drivers/usb/gadget/legacy/g_dbgp.mod.o
LD [M] drivers/usb/gadget/legacy/g_dbgp.ko
CC [M] drivers/usb/gadget/legacy/g_ether.mod.o
LD [M] drivers/usb/gadget/legacy/g_ether.ko
CC [M] drivers/usb/gadget/legacy/g_ffs.mod.o
LD [M] drivers/usb/gadget/legacy/g_ffs.ko
CC [M] drivers/usb/gadget/legacy/g_hid.mod.o
LD [M] drivers/usb/gadget/legacy/g_hid.ko
CC [M] drivers/usb/gadget/legacy/g_mass_storage.mod.o
LD [M] drivers/usb/gadget/legacy/g_mass_storage.ko
CC [M] drivers/usb/gadget/legacy/g_midi.mod.o
LD [M] drivers/usb/gadget/legacy/g_midi.ko
CC [M] drivers/usb/gadget/legacy/g_multi.mod.o
LD [M] drivers/usb/gadget/legacy/g_multi.ko
CC [M] drivers/usb/gadget/legacy/g_ncm.mod.o
LD [M] drivers/usb/gadget/legacy/g_ncm.ko
CC [M] drivers/usb/gadget/legacy/g_printer.mod.o
LD [M] drivers/usb/gadget/legacy/g_printer.ko
CC [M] drivers/usb/gadget/legacy/g_serial.mod.o
LD [M] drivers/usb/gadget/legacy/g_serial.ko
CC [M] drivers/usb/gadget/legacy/g_webcam.mod.o
LD [M] drivers/usb/gadget/legacy/g_webcam.ko
CC [M] drivers/usb/gadget/legacy/g_zero.mod.o
LD [M] drivers/usb/gadget/legacy/g_zero.ko
CC [M] drivers/usb/gadget/legacy/gadgetfs.mod.o
LD [M] drivers/usb/gadget/legacy/gadgetfs.ko
CC [M] drivers/usb/gadget/libcomposite.mod.o
LD [M] drivers/usb/gadget/libcomposite.ko
CC [M] drivers/usb/gadget/udc/udc-core.mod.o
LD [M] drivers/usb/gadget/udc/udc-core.ko
CC [M] drivers/usb/host/ehci-hcd.mod.o
LD [M] drivers/usb/host/ehci-hcd.ko
CC [M] drivers/usb/host/ehci-pci.mod.o
LD [M] drivers/usb/host/ehci-pci.ko
CC [M] drivers/usb/host/ehci-platform.mod.o
LD [M] drivers/usb/host/ehci-platform.ko
CC [M] drivers/usb/host/ohci-hcd.mod.o
LD [M] drivers/usb/host/ohci-hcd.ko
CC [M] drivers/usb/host/ohci-pci.mod.o
LD [M] drivers/usb/host/ohci-pci.ko
CC [M] drivers/usb/host/ohci-platform.mod.o
LD [M] drivers/usb/host/ohci-platform.ko
CC [M] drivers/usb/host/xhci-hcd.mod.o
LD [M] drivers/usb/host/xhci-hcd.ko
CC [M] drivers/usb/host/xhci-pci.mod.o
LD [M] drivers/usb/host/xhci-pci.ko
CC [M] drivers/usb/host/xhci-plat-hcd.mod.o
LD [M] drivers/usb/host/xhci-plat-hcd.ko
CC [M] drivers/usb/isp1760/isp1760.mod.o
LD [M] drivers/usb/isp1760/isp1760.ko
CC [M] drivers/usb/misc/usb3503.mod.o
LD [M] drivers/usb/misc/usb3503.ko
CC [M] drivers/usb/misc/usbtest.mod.o
LD [M] drivers/usb/misc/usbtest.ko
CC [M] drivers/usb/musb/musb_hdrc.mod.o
LD [M] drivers/usb/musb/musb_hdrc.ko
CC [M] drivers/usb/phy/phy-generic.mod.o
LD [M] drivers/usb/phy/phy-generic.ko
CC [M] drivers/usb/roles/roles.mod.o
LD [M] drivers/usb/roles/roles.ko
CC [M] drivers/usb/serial/cp210x.mod.o
LD [M] drivers/usb/serial/cp210x.ko
CC [M] drivers/usb/serial/ftdi_sio.mod.o
LD [M] drivers/usb/serial/ftdi_sio.ko
CC [M] drivers/usb/serial/option.mod.o
LD [M] drivers/usb/serial/option.ko
CC [M] drivers/usb/serial/pl2303.mod.o
LD [M] drivers/usb/serial/pl2303.ko
CC [M] drivers/usb/serial/usb_wwan.mod.o
LD [M] drivers/usb/serial/usb_wwan.ko
CC [M] drivers/usb/serial/usbserial.mod.o
LD [M] drivers/usb/serial/usbserial.ko
CC [M] drivers/usb/storage/usb-storage.mod.o
LD [M] drivers/usb/storage/usb-storage.ko
CC [M] drivers/usb/typec/hd3ss3220.mod.o
LD [M] drivers/usb/typec/hd3ss3220.ko
CC [M] drivers/usb/typec/tcpm/fusb302.mod.o
LD [M] drivers/usb/typec/tcpm/fusb302.ko
CC [M] drivers/usb/typec/tcpm/tcpm.mod.o
LD [M] drivers/usb/typec/tcpm/tcpm.ko
CC [M] drivers/usb/typec/tps6598x.mod.o
LD [M] drivers/usb/typec/tps6598x.ko
CC [M] drivers/usb/typec/typec.mod.o
LD [M] drivers/usb/typec/typec.ko
CC [M] drivers/video/backlight/lp855x_bl.mod.o
LD [M] drivers/video/backlight/lp855x_bl.ko
CC [M] drivers/w1/wire.mod.o
LD [M] drivers/w1/wire.ko
CC [M] drivers/watchdog/rti_wdt.mod.o
LD [M] drivers/watchdog/rti_wdt.ko
CC [M] fs/btrfs/btrfs.mod.o
LD [M] fs/btrfs/btrfs.ko
CC [M] fs/cifs/cifs.mod.o
LD [M] fs/cifs/cifs.ko
CC [M] fs/fuse/cuse.mod.o
LD [M] fs/fuse/cuse.ko
CC [M] fs/fuse/fuse.mod.o
LD [M] fs/fuse/fuse.ko
CC [M] fs/nfs/blocklayout/blocklayoutdriver.mod.o
LD [M] fs/nfs/blocklayout/blocklayoutdriver.ko
CC [M] fs/overlayfs/overlay.mod.o
LD [M] fs/overlayfs/overlay.ko
CC [M] lib/crc-ccitt.mod.o
LD [M] lib/crc-ccitt.ko
CC [M] lib/crypto/libarc4.mod.o
LD [M] lib/crypto/libarc4.ko
CC [M] lib/crypto/libchacha.mod.o
LD [M] lib/crypto/libchacha.ko
CC [M] lib/crypto/libdes.mod.o
LD [M] lib/crypto/libdes.ko
CC [M] lib/libcrc32c.mod.o
LD [M] lib/libcrc32c.ko
CC [M] lib/math/cordic.mod.o
LD [M] lib/math/cordic.ko
CC [M] lib/raid6/raid6_pq.mod.o
LD [M] lib/raid6/raid6_pq.ko
CC [M] lib/ts_bm.mod.o
LD [M] lib/ts_bm.ko
CC [M] lib/ts_fsm.mod.o
LD [M] lib/ts_fsm.ko
CC [M] lib/ts_kmp.mod.o
LD [M] lib/ts_kmp.ko
CC [M] net/802/garp.mod.o
LD [M] net/802/garp.ko
CC [M] net/802/mrp.mod.o
LD [M] net/802/mrp.ko
CC [M] net/802/p8022.mod.o
LD [M] net/802/p8022.ko
CC [M] net/802/psnap.mod.o
LD [M] net/802/psnap.ko
CC [M] net/802/stp.mod.o
LD [M] net/802/stp.ko
CC [M] net/8021q/8021q.mod.o
LD [M] net/8021q/8021q.ko
CC [M] net/bluetooth/bluetooth.mod.o
LD [M] net/bluetooth/bluetooth.ko
CC [M] net/bluetooth/hidp/hidp.mod.o
LD [M] net/bluetooth/hidp/hidp.ko
CC [M] net/bridge/br_netfilter.mod.o
LD [M] net/bridge/br_netfilter.ko
CC [M] net/bridge/bridge.mod.o
LD [M] net/bridge/bridge.ko
CC [M] net/bridge/netfilter/ebt_802_3.mod.o
LD [M] net/bridge/netfilter/ebt_802_3.ko
CC [M] net/bridge/netfilter/ebt_among.mod.o
LD [M] net/bridge/netfilter/ebt_among.ko
CC [M] net/bridge/netfilter/ebt_arp.mod.o
LD [M] net/bridge/netfilter/ebt_arp.ko
CC [M] net/bridge/netfilter/ebt_arpreply.mod.o
LD [M] net/bridge/netfilter/ebt_arpreply.ko
CC [M] net/bridge/netfilter/ebt_dnat.mod.o
LD [M] net/bridge/netfilter/ebt_dnat.ko
CC [M] net/bridge/netfilter/ebt_ip.mod.o
LD [M] net/bridge/netfilter/ebt_ip.ko
CC [M] net/bridge/netfilter/ebt_ip6.mod.o
LD [M] net/bridge/netfilter/ebt_ip6.ko
CC [M] net/bridge/netfilter/ebt_limit.mod.o
LD [M] net/bridge/netfilter/ebt_limit.ko
CC [M] net/bridge/netfilter/ebt_log.mod.o
LD [M] net/bridge/netfilter/ebt_log.ko
CC [M] net/bridge/netfilter/ebt_mark.mod.o
LD [M] net/bridge/netfilter/ebt_mark.ko
CC [M] net/bridge/netfilter/ebt_mark_m.mod.o
LD [M] net/bridge/netfilter/ebt_mark_m.ko
CC [M] net/bridge/netfilter/ebt_nflog.mod.o
LD [M] net/bridge/netfilter/ebt_nflog.ko
CC [M] net/bridge/netfilter/ebt_pkttype.mod.o
LD [M] net/bridge/netfilter/ebt_pkttype.ko
CC [M] net/bridge/netfilter/ebt_redirect.mod.o
LD [M] net/bridge/netfilter/ebt_redirect.ko
CC [M] net/bridge/netfilter/ebt_snat.mod.o
LD [M] net/bridge/netfilter/ebt_snat.ko
CC [M] net/bridge/netfilter/ebt_stp.mod.o
LD [M] net/bridge/netfilter/ebt_stp.ko
CC [M] net/bridge/netfilter/ebt_vlan.mod.o
LD [M] net/bridge/netfilter/ebt_vlan.ko
CC [M] net/bridge/netfilter/ebtable_broute.mod.o
LD [M] net/bridge/netfilter/ebtable_broute.ko
CC [M] net/bridge/netfilter/ebtable_filter.mod.o
LD [M] net/bridge/netfilter/ebtable_filter.ko
CC [M] net/bridge/netfilter/ebtable_nat.mod.o
LD [M] net/bridge/netfilter/ebtable_nat.ko
CC [M] net/bridge/netfilter/ebtables.mod.o
LD [M] net/bridge/netfilter/ebtables.ko
CC [M] net/can/can-bcm.mod.o
LD [M] net/can/can-bcm.ko
CC [M] net/can/can-gw.mod.o
LD [M] net/can/can-gw.ko
CC [M] net/can/can-raw.mod.o
LD [M] net/can/can-raw.ko
CC [M] net/can/can.mod.o
LD [M] net/can/can.ko
CC [M] net/dsa/dsa_core.mod.o
LD [M] net/dsa/dsa_core.ko
CC [M] net/hsr/hsr.mod.o
LD [M] net/hsr/hsr.ko
CC [M] net/ipv4/ah4.mod.o
LD [M] net/ipv4/ah4.ko
CC [M] net/ipv4/esp4.mod.o
LD [M] net/ipv4/esp4.ko
CC [M] net/ipv4/ip_tunnel.mod.o
LD [M] net/ipv4/ip_tunnel.ko
CC [M] net/ipv4/ipcomp.mod.o
LD [M] net/ipv4/ipcomp.ko
CC [M] net/ipv4/netfilter/arp_tables.mod.o
LD [M] net/ipv4/netfilter/arp_tables.ko
CC [M] net/ipv4/netfilter/arpt_mangle.mod.o
LD [M] net/ipv4/netfilter/arpt_mangle.ko
CC [M] net/ipv4/netfilter/arptable_filter.mod.o
LD [M] net/ipv4/netfilter/arptable_filter.ko
CC [M] net/ipv4/netfilter/ip_tables.mod.o
LD [M] net/ipv4/netfilter/ip_tables.ko
CC [M] net/ipv4/netfilter/ipt_REJECT.mod.o
LD [M] net/ipv4/netfilter/ipt_REJECT.ko
CC [M] net/ipv4/netfilter/iptable_filter.mod.o
LD [M] net/ipv4/netfilter/iptable_filter.ko
CC [M] net/ipv4/netfilter/iptable_mangle.mod.o
LD [M] net/ipv4/netfilter/iptable_mangle.ko
CC [M] net/ipv4/netfilter/iptable_nat.mod.o
LD [M] net/ipv4/netfilter/iptable_nat.ko
CC [M] net/ipv4/netfilter/nf_defrag_ipv4.mod.o
LD [M] net/ipv4/netfilter/nf_defrag_ipv4.ko
CC [M] net/ipv4/netfilter/nf_log_ipv4.mod.o
LD [M] net/ipv4/netfilter/nf_log_ipv4.ko
CC [M] net/ipv4/netfilter/nf_reject_ipv4.mod.o
LD [M] net/ipv4/netfilter/nf_reject_ipv4.ko
CC [M] net/ipv4/tunnel4.mod.o
LD [M] net/ipv4/tunnel4.ko
CC [M] net/ipv4/udp_tunnel.mod.o
LD [M] net/ipv4/udp_tunnel.ko
CC [M] net/ipv4/xfrm4_tunnel.mod.o
LD [M] net/ipv4/xfrm4_tunnel.ko
CC [M] net/ipv6/ah6.mod.o
LD [M] net/ipv6/ah6.ko
CC [M] net/ipv6/ip6_tunnel.mod.o
LD [M] net/ipv6/ip6_tunnel.ko
CC [M] net/ipv6/ip6_udp_tunnel.mod.o
LD [M] net/ipv6/ip6_udp_tunnel.ko
CC [M] net/ipv6/ipcomp6.mod.o
LD [M] net/ipv6/ipcomp6.ko
CC [M] net/ipv6/ipv6.mod.o
LD [M] net/ipv6/ipv6.ko
CC [M] net/ipv6/netfilter/ip6_tables.mod.o
LD [M] net/ipv6/netfilter/ip6_tables.ko
CC [M] net/ipv6/netfilter/ip6t_REJECT.mod.o
LD [M] net/ipv6/netfilter/ip6t_REJECT.ko
CC [M] net/ipv6/netfilter/ip6table_filter.mod.o
LD [M] net/ipv6/netfilter/ip6table_filter.ko
CC [M] net/ipv6/netfilter/ip6table_mangle.mod.o
LD [M] net/ipv6/netfilter/ip6table_mangle.ko
CC [M] net/ipv6/netfilter/ip6table_nat.mod.o
LD [M] net/ipv6/netfilter/ip6table_nat.ko
CC [M] net/ipv6/netfilter/nf_defrag_ipv6.mod.o
LD [M] net/ipv6/netfilter/nf_defrag_ipv6.ko
CC [M] net/ipv6/netfilter/nf_log_ipv6.mod.o
LD [M] net/ipv6/netfilter/nf_log_ipv6.ko
CC [M] net/ipv6/netfilter/nf_reject_ipv6.mod.o
LD [M] net/ipv6/netfilter/nf_reject_ipv6.ko
CC [M] net/ipv6/sit.mod.o
LD [M] net/ipv6/sit.ko
CC [M] net/ipv6/tunnel6.mod.o
LD [M] net/ipv6/tunnel6.ko
CC [M] net/ipv6/xfrm6_tunnel.mod.o
LD [M] net/ipv6/xfrm6_tunnel.ko
CC [M] net/key/af_key.mod.o
LD [M] net/key/af_key.ko
CC [M] net/llc/llc.mod.o
LD [M] net/llc/llc.ko
CC [M] net/mac80211/mac80211.mod.o
LD [M] net/mac80211/mac80211.ko
CC [M] net/netfilter/ipvs/ip_vs.mod.o
LD [M] net/netfilter/ipvs/ip_vs.ko
CC [M] net/netfilter/ipvs/ip_vs_rr.mod.o
LD [M] net/netfilter/ipvs/ip_vs_rr.ko
CC [M] net/netfilter/nf_conntrack.mod.o
LD [M] net/netfilter/nf_conntrack.ko
CC [M] net/netfilter/nf_conntrack_ftp.mod.o
LD [M] net/netfilter/nf_conntrack_ftp.ko
CC [M] net/netfilter/nf_conntrack_tftp.mod.o
LD [M] net/netfilter/nf_conntrack_tftp.ko
CC [M] net/netfilter/nf_log_common.mod.o
LD [M] net/netfilter/nf_log_common.ko
CC [M] net/netfilter/nf_nat.mod.o
LD [M] net/netfilter/nf_nat.ko
CC [M] net/netfilter/nf_nat_ftp.mod.o
LD [M] net/netfilter/nf_nat_ftp.ko
CC [M] net/netfilter/nf_nat_tftp.mod.o
LD [M] net/netfilter/nf_nat_tftp.ko
CC [M] net/netfilter/x_tables.mod.o
LD [M] net/netfilter/x_tables.ko
CC [M] net/netfilter/xt_CHECKSUM.mod.o
LD [M] net/netfilter/xt_CHECKSUM.ko
CC [M] net/netfilter/xt_CLASSIFY.mod.o
LD [M] net/netfilter/xt_CLASSIFY.ko
CC [M] net/netfilter/xt_IDLETIMER.mod.o
LD [M] net/netfilter/xt_IDLETIMER.ko
CC [M] net/netfilter/xt_LOG.mod.o
LD [M] net/netfilter/xt_LOG.ko
CC [M] net/netfilter/xt_MASQUERADE.mod.o
LD [M] net/netfilter/xt_MASQUERADE.ko
CC [M] net/netfilter/xt_addrtype.mod.o
LD [M] net/netfilter/xt_addrtype.ko
CC [M] net/netfilter/xt_comment.mod.o
LD [M] net/netfilter/xt_comment.ko
CC [M] net/netfilter/xt_conntrack.mod.o
LD [M] net/netfilter/xt_conntrack.ko
CC [M] net/netfilter/xt_cpu.mod.o
LD [M] net/netfilter/xt_cpu.ko
CC [M] net/netfilter/xt_iprange.mod.o
LD [M] net/netfilter/xt_iprange.ko
CC [M] net/netfilter/xt_ipvs.mod.o
LD [M] net/netfilter/xt_ipvs.ko
CC [M] net/netfilter/xt_length.mod.o
LD [M] net/netfilter/xt_length.ko
CC [M] net/netfilter/xt_limit.mod.o
LD [M] net/netfilter/xt_limit.ko
CC [M] net/netfilter/xt_mac.mod.o
LD [M] net/netfilter/xt_mac.ko
CC [M] net/netfilter/xt_mark.mod.o
LD [M] net/netfilter/xt_mark.ko
CC [M] net/netfilter/xt_multiport.mod.o
LD [M] net/netfilter/xt_multiport.ko
CC [M] net/netfilter/xt_nat.mod.o
LD [M] net/netfilter/xt_nat.ko
CC [M] net/netfilter/xt_pkttype.mod.o
LD [M] net/netfilter/xt_pkttype.ko
CC [M] net/netfilter/xt_policy.mod.o
LD [M] net/netfilter/xt_policy.ko
CC [M] net/netfilter/xt_sctp.mod.o
LD [M] net/netfilter/xt_sctp.ko
CC [M] net/netfilter/xt_tcpudp.mod.o
LD [M] net/netfilter/xt_tcpudp.ko
CC [M] net/nfc/nci/nci.mod.o
LD [M] net/nfc/nci/nci.ko
CC [M] net/nfc/nfc.mod.o
LD [M] net/nfc/nfc.ko
CC [M] net/qrtr/ns.mod.o
LD [M] net/qrtr/ns.ko
CC [M] net/qrtr/qrtr-smd.mod.o
LD [M] net/qrtr/qrtr-smd.ko
CC [M] net/qrtr/qrtr-tun.mod.o
LD [M] net/qrtr/qrtr-tun.ko
CC [M] net/qrtr/qrtr.mod.o
LD [M] net/qrtr/qrtr.ko
CC [M] net/rfkill/rfkill.mod.o
LD [M] net/rfkill/rfkill.ko
CC [M] net/sched/act_csum.mod.o
LD [M] net/sched/act_csum.ko
CC [M] net/sched/act_gact.mod.o
LD [M] net/sched/act_gact.ko
CC [M] net/sched/act_gate.mod.o
LD [M] net/sched/act_gate.ko
CC [M] net/sched/act_ipt.mod.o
LD [M] net/sched/act_ipt.ko
CC [M] net/sched/act_mirred.mod.o
LD [M] net/sched/act_mirred.ko
CC [M] net/sched/act_nat.mod.o
LD [M] net/sched/act_nat.ko
CC [M] net/sched/act_pedit.mod.o
LD [M] net/sched/act_pedit.ko
CC [M] net/sched/act_police.mod.o
LD [M] net/sched/act_police.ko
CC [M] net/sched/act_simple.mod.o
LD [M] net/sched/act_simple.ko
CC [M] net/sched/act_skbedit.mod.o
LD [M] net/sched/act_skbedit.ko
CC [M] net/sched/cls_basic.mod.o
LD [M] net/sched/cls_basic.ko
CC [M] net/sched/cls_cgroup.mod.o
LD [M] net/sched/cls_cgroup.ko
CC [M] net/sched/cls_flow.mod.o
LD [M] net/sched/cls_flow.ko
CC [M] net/sched/cls_flower.mod.o
LD [M] net/sched/cls_flower.ko
CC [M] net/sched/cls_fw.mod.o
LD [M] net/sched/cls_fw.ko
CC [M] net/sched/cls_route.mod.o
LD [M] net/sched/cls_route.ko
CC [M] net/sched/cls_rsvp.mod.o
LD [M] net/sched/cls_rsvp.ko
CC [M] net/sched/cls_rsvp6.mod.o
LD [M] net/sched/cls_rsvp6.ko
CC [M] net/sched/cls_tcindex.mod.o
LD [M] net/sched/cls_tcindex.ko
CC [M] net/sched/cls_u32.mod.o
LD [M] net/sched/cls_u32.ko
CC [M] net/sched/em_cmp.mod.o
LD [M] net/sched/em_cmp.ko
CC [M] net/sched/em_meta.mod.o
LD [M] net/sched/em_meta.ko
CC [M] net/sched/em_nbyte.mod.o
LD [M] net/sched/em_nbyte.ko
CC [M] net/sched/em_text.mod.o
LD [M] net/sched/em_text.ko
CC [M] net/sched/em_u32.mod.o
LD [M] net/sched/em_u32.ko
CC [M] net/sched/sch_cbq.mod.o
LD [M] net/sched/sch_cbq.ko
CC [M] net/sched/sch_cbs.mod.o
LD [M] net/sched/sch_cbs.ko
CC [M] net/sched/sch_choke.mod.o
LD [M] net/sched/sch_choke.ko
CC [M] net/sched/sch_codel.mod.o
LD [M] net/sched/sch_codel.ko
CC [M] net/sched/sch_drr.mod.o
LD [M] net/sched/sch_drr.ko
CC [M] net/sched/sch_dsmark.mod.o
LD [M] net/sched/sch_dsmark.ko
CC [M] net/sched/sch_etf.mod.o
LD [M] net/sched/sch_etf.ko
CC [M] net/sched/sch_fq_codel.mod.o
LD [M] net/sched/sch_fq_codel.ko
CC [M] net/sched/sch_gred.mod.o
LD [M] net/sched/sch_gred.ko
CC [M] net/sched/sch_hfsc.mod.o
LD [M] net/sched/sch_hfsc.ko
CC [M] net/sched/sch_htb.mod.o
LD [M] net/sched/sch_htb.ko
CC [M] net/sched/sch_ingress.mod.o
LD [M] net/sched/sch_ingress.ko
CC [M] net/sched/sch_mqprio.mod.o
LD [M] net/sched/sch_mqprio.ko
CC [M] net/sched/sch_multiq.mod.o
LD [M] net/sched/sch_multiq.ko
CC [M] net/sched/sch_netem.mod.o
LD [M] net/sched/sch_netem.ko
CC [M] net/sched/sch_prio.mod.o
LD [M] net/sched/sch_prio.ko
CC [M] net/sched/sch_qfq.mod.o
LD [M] net/sched/sch_qfq.ko
CC [M] net/sched/sch_red.mod.o
LD [M] net/sched/sch_red.ko
CC [M] net/sched/sch_sfb.mod.o
LD [M] net/sched/sch_sfb.ko
CC [M] net/sched/sch_sfq.mod.o
LD [M] net/sched/sch_sfq.ko
CC [M] net/sched/sch_taprio.mod.o
LD [M] net/sched/sch_taprio.ko
CC [M] net/sched/sch_tbf.mod.o
LD [M] net/sched/sch_tbf.ko
CC [M] net/sched/sch_teql.mod.o
LD [M] net/sched/sch_teql.ko
CC [M] net/sctp/sctp.mod.o
LD [M] net/sctp/sctp.ko
CC [M] net/sctp/sctp_diag.mod.o
LD [M] net/sctp/sctp_diag.ko
CC [M] net/wireless/cfg80211.mod.o
LD [M] net/wireless/cfg80211.ko
CC [M] net/xfrm/xfrm_algo.mod.o
LD [M] net/xfrm/xfrm_algo.ko
CC [M] net/xfrm/xfrm_ipcomp.mod.o
LD [M] net/xfrm/xfrm_ipcomp.ko
CC [M] net/xfrm/xfrm_user.mod.o
LD [M] net/xfrm/xfrm_user.ko
CC [M] samples/rpmsg/rpmsg_client_sample.mod.o
LD [M] samples/rpmsg/rpmsg_client_sample.ko
CC [M] sound/core/snd-hwdep.mod.o
LD [M] sound/core/snd-hwdep.ko
CC [M] sound/core/snd-rawmidi.mod.o
LD [M] sound/core/snd-rawmidi.ko
CC [M] sound/soc/codecs/snd-soc-pcm3168a-i2c.mod.o
LD [M] sound/soc/codecs/snd-soc-pcm3168a-i2c.ko
CC [M] sound/soc/codecs/snd-soc-pcm3168a.mod.o
LD [M] sound/soc/codecs/snd-soc-pcm3168a.ko
CC [M] sound/soc/codecs/snd-soc-simple-amplifier.mod.o
LD [M] sound/soc/codecs/snd-soc-simple-amplifier.ko
CC [M] sound/soc/codecs/snd-soc-tlv320aic31xx.mod.o
LD [M] sound/soc/codecs/snd-soc-tlv320aic31xx.ko
CC [M] sound/soc/codecs/snd-soc-tlv320aic3x.mod.o
LD [M] sound/soc/codecs/snd-soc-tlv320aic3x.ko
CC [M] sound/soc/codecs/snd-soc-wcd934x.mod.o
LD [M] sound/soc/codecs/snd-soc-wcd934x.ko
CC [M] sound/soc/codecs/snd-soc-wm8904.mod.o
LD [M] sound/soc/codecs/snd-soc-wm8904.ko
CC [M] sound/soc/codecs/snd-soc-wsa881x.mod.o
LD [M] sound/soc/codecs/snd-soc-wsa881x.ko
CC [M] sound/soc/generic/snd-soc-audio-graph-card.mod.o
LD [M] sound/soc/generic/snd-soc-audio-graph-card.ko
CC [M] sound/soc/generic/snd-soc-simple-card-utils.mod.o
LD [M] sound/soc/generic/snd-soc-simple-card-utils.ko
CC [M] sound/soc/generic/snd-soc-simple-card.mod.o
LD [M] sound/soc/generic/snd-soc-simple-card.ko
CC [M] sound/soc/ti/snd-soc-j721e-evm.mod.o
LD [M] sound/soc/ti/snd-soc-j721e-evm.ko
CC [M] sound/usb/snd-usb-audio.mod.o
LD [M] sound/usb/snd-usb-audio.ko
CC [M] sound/usb/snd-usbmidi-lib.mod.o
LD [M] sound/usb/snd-usbmidi-lib.ko
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo umount /media/ubuntu/root
[sudo] password for ubuntu:
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo mount /dev/sdb2 /home/ubuntu/rootfs
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- ti/k3-am625-sk.dtb
DTC arch/arm64/boot/dts/ti/k3-am625-sk.dtb
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/Image' /home/ubuntu/rootfs/
bin/ interfaces run/
boot/ lib/ sbin/
dev/ linuxrc serialcheck-master/
etc/ lost+found/ sys/
export media/ tmp/
home/ mnt/ usr/
include/ opt/ var/
init proc/ www/
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo rm -f /home/ubuntu/rootfs/boot/Image
Image Image-5.10.168-rt83-gc1a1291911
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo rm -f /home/ubuntu/rootfs/boot/*
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/Image' /home/ubuntu/rootfs/boot
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/dts/ti/k3-am625-sk.dtb' /home/ubuntu/rootfs/boot
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo make ARCH=arm64 INSTALL_MOD_PATH=/home/ubuntu/rootfs modules_install
arch/arm64/Makefile:25: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
INSTALL arch/arm64/crypto/aes-neon-blk.ko
INSTALL arch/arm64/crypto/aes-neon-bs.ko
INSTALL arch/arm64/crypto/chacha-neon.ko
INSTALL arch/arm64/crypto/crct10dif-ce.ko
INSTALL arch/arm64/crypto/sha3-ce.ko
INSTALL arch/arm64/crypto/sha512-arm64.ko
INSTALL arch/arm64/crypto/sha512-ce.ko
INSTALL arch/arm64/crypto/sm3-ce.ko
INSTALL arch/arm64/lib/xor-neon.ko
INSTALL crypto/af_alg.ko
INSTALL crypto/algif_hash.ko
INSTALL crypto/algif_rng.ko
INSTALL crypto/authenc.ko
INSTALL crypto/authencesn.ko
INSTALL crypto/blake2b_generic.ko
INSTALL crypto/cbc.ko
INSTALL crypto/ccm.ko
INSTALL crypto/cmac.ko
INSTALL crypto/ctr.ko
INSTALL crypto/des_generic.ko
INSTALL crypto/ecb.ko
INSTALL crypto/ecc.ko
INSTALL crypto/ecdh_generic.ko
INSTALL crypto/gcm.ko
INSTALL crypto/ghash-generic.ko
INSTALL crypto/md4.ko
INSTALL crypto/md5.ko
INSTALL crypto/seqiv.ko
INSTALL crypto/sha3_generic.ko
INSTALL crypto/sha512_generic.ko
INSTALL crypto/sm3_generic.ko
INSTALL crypto/sm4_generic.ko
INSTALL crypto/tcrypt.ko
INSTALL crypto/xor.ko
INSTALL crypto/xts.ko
INSTALL crypto/xxhash_generic.ko
INSTALL drivers/ata/ahci.ko
INSTALL drivers/ata/ahci_ceva.ko
INSTALL drivers/ata/ahci_platform.ko
INSTALL drivers/ata/ahci_qoriq.ko
INSTALL drivers/ata/ahci_xgene.ko
INSTALL drivers/ata/libahci.ko
INSTALL drivers/ata/libahci_platform.ko
INSTALL drivers/ata/libata.ko
INSTALL drivers/ata/pata_of_platform.ko
INSTALL drivers/ata/pata_platform.ko
INSTALL drivers/ata/sata_sil24.ko
INSTALL drivers/base/regmap/regmap-sdw.ko
INSTALL drivers/base/regmap/regmap-slimbus.ko
INSTALL drivers/base/regmap/regmap-spmi.ko
INSTALL drivers/bcma/bcma.ko
INSTALL drivers/block/nbd.ko
INSTALL drivers/bluetooth/btbcm.ko
INSTALL drivers/bluetooth/btintel.ko
INSTALL drivers/bluetooth/btqca.ko
INSTALL drivers/bluetooth/btrtl.ko
INSTALL drivers/bluetooth/btusb.ko
INSTALL drivers/bluetooth/hci_uart.ko
INSTALL drivers/char/hw_random/omap-rng.ko
INSTALL drivers/char/hw_random/optee-rng.ko
INSTALL drivers/char/hw_random/rng-core.ko
INSTALL drivers/char/ipmi/ipmi_devintf.ko
INSTALL drivers/char/ipmi/ipmi_msghandler.ko
INSTALL drivers/char/ipmi/ipmi_si.ko
INSTALL drivers/clk/clk-bd718x7.ko
INSTALL drivers/counter/counter.ko
INSTALL drivers/counter/ti-ecap-capture.ko
INSTALL drivers/crypto/ccree/ccree.ko
INSTALL drivers/crypto/sa2ul.ko
INSTALL drivers/crypto/ti/mcrc.ko
INSTALL drivers/extcon/extcon-palmas.ko
INSTALL drivers/extcon/extcon-ptn5150.ko
INSTALL drivers/extcon/extcon-usb-gpio.ko
INSTALL drivers/fpga/altera-freeze-bridge.ko
INSTALL drivers/fpga/fpga-bridge.ko
INSTALL drivers/fpga/fpga-region.ko
INSTALL drivers/fpga/of-fpga-region.ko
INSTALL drivers/gpio/gpio-altera.ko
INSTALL drivers/gpio/gpio-bd9571mwv.ko
INSTALL drivers/gpio/gpio-pisosr.ko
INSTALL drivers/gpio/gpio-tpic2810.ko
INSTALL drivers/gpio/gpio-wcd934x.ko
INSTALL drivers/gpu/drm/arm/mali-dp.ko
INSTALL drivers/gpu/drm/bridge/cadence/cdns-dsi.ko
INSTALL drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.ko
INSTALL drivers/gpu/drm/bridge/lontium-lt9611.ko
INSTALL drivers/gpu/drm/bridge/nwl-dsi.ko
INSTALL drivers/gpu/drm/bridge/simple-bridge.ko
INSTALL drivers/gpu/drm/bridge/synopsys/dw-hdmi-ahb-audio.ko
INSTALL drivers/gpu/drm/bridge/synopsys/dw-hdmi-cec.ko
INSTALL drivers/gpu/drm/bridge/synopsys/dw-hdmi.ko
INSTALL drivers/gpu/drm/bridge/thc63lvd1024.ko
INSTALL drivers/gpu/drm/bridge/ti-sn65dsi86.ko
INSTALL drivers/gpu/drm/drm_mipi_dbi.ko
INSTALL drivers/gpu/drm/panel/panel-lvds.ko
INSTALL drivers/gpu/drm/panel/panel-raydium-rm67191.ko
INSTALL drivers/gpu/drm/panel/panel-sitronix-st7703.ko
INSTALL drivers/gpu/drm/panel/panel-truly-nt35597.ko
INSTALL drivers/gpu/drm/rcar-du/rcar_dw_hdmi.ko
INSTALL drivers/gpu/drm/tiny/ili9225.ko
INSTALL drivers/hid/hid-multitouch.ko
INSTALL drivers/hid/i2c-hid/i2c-hid.ko
INSTALL drivers/hid/usbhid/usbhid.ko
INSTALL drivers/hwmon/ina2xx.ko
INSTALL drivers/hwmon/ina3221.ko
INSTALL drivers/hwmon/lm90.ko
INSTALL drivers/hwmon/pwm-fan.ko
INSTALL drivers/i2c/i2c-atr.ko
INSTALL drivers/iio/adc/max9611.ko
INSTALL drivers/iio/adc/qcom-spmi-adc5.ko
INSTALL drivers/iio/adc/qcom-vadc-common.ko
INSTALL drivers/iio/adc/ti_am335x_adc.ko
INSTALL drivers/iio/buffer/industrialio-triggered-buffer.ko
INSTALL drivers/iio/buffer/kfifo_buf.ko
INSTALL drivers/iio/common/cros_ec_sensors/cros_ec_sensors.ko
INSTALL drivers/iio/common/cros_ec_sensors/cros_ec_sensors_core.ko
INSTALL drivers/iio/light/cros_ec_light_prox.ko
INSTALL drivers/iio/light/isl29018.ko
INSTALL drivers/iio/pressure/cros_ec_baro.ko
INSTALL drivers/iio/pressure/mpl3115.ko
INSTALL drivers/input/keyboard/adc-keys.ko
INSTALL drivers/input/keyboard/matrix_keypad.ko
INSTALL drivers/input/misc/gpio_decoder.ko
INSTALL drivers/input/touchscreen/atmel_mxt_ts.ko
INSTALL drivers/input/touchscreen/edt-ft5x06.ko
INSTALL drivers/input/touchscreen/goodix.ko
INSTALL drivers/input/touchscreen/ili210x.ko
INSTALL drivers/input/touchscreen/pixcir_i2c_ts.ko
INSTALL drivers/input/touchscreen/ti_am335x_tsc.ko
INSTALL drivers/irqchip/irq-pruss-intc.ko
INSTALL drivers/md/dm-bio-prison.ko
INSTALL drivers/md/dm-bufio.ko
INSTALL drivers/md/dm-log.ko
INSTALL drivers/md/dm-mirror.ko
INSTALL drivers/md/dm-mod.ko
INSTALL drivers/md/dm-region-hash.ko
INSTALL drivers/md/dm-thin-pool.ko
INSTALL drivers/md/dm-zero.ko
INSTALL drivers/md/md-mod.ko
INSTALL drivers/md/persistent-data/dm-persistent-data.ko
INSTALL drivers/media/common/videobuf2/videobuf2-common.ko
INSTALL drivers/media/common/videobuf2/videobuf2-dma-contig.ko
INSTALL drivers/media/common/videobuf2/videobuf2-dma-sg.ko
INSTALL drivers/media/common/videobuf2/videobuf2-memops.ko
INSTALL drivers/media/common/videobuf2/videobuf2-v4l2.ko
INSTALL drivers/media/common/videobuf2/videobuf2-vmalloc.ko
INSTALL drivers/media/dvb-frontends/a8293.ko
INSTALL drivers/media/dvb-frontends/af9013.ko
INSTALL drivers/media/dvb-frontends/af9033.ko
INSTALL drivers/media/dvb-frontends/ascot2e.ko
INSTALL drivers/media/dvb-frontends/atbm8830.ko
INSTALL drivers/media/dvb-frontends/au8522_common.ko
INSTALL drivers/media/dvb-frontends/au8522_decoder.ko
INSTALL drivers/media/dvb-frontends/au8522_dig.ko
INSTALL drivers/media/dvb-frontends/bcm3510.ko
INSTALL drivers/media/dvb-frontends/cx22700.ko
INSTALL drivers/media/dvb-frontends/cx22702.ko
INSTALL drivers/media/dvb-frontends/cx24110.ko
INSTALL drivers/media/dvb-frontends/cx24113.ko
INSTALL drivers/media/dvb-frontends/cx24116.ko
INSTALL drivers/media/dvb-frontends/cx24117.ko
INSTALL drivers/media/dvb-frontends/cx24120.ko
INSTALL drivers/media/dvb-frontends/cx24123.ko
INSTALL drivers/media/dvb-frontends/cxd2099.ko
INSTALL drivers/media/dvb-frontends/cxd2820r.ko
INSTALL drivers/media/dvb-frontends/cxd2841er.ko
INSTALL drivers/media/dvb-frontends/cxd2880/cxd2880.ko
INSTALL drivers/media/dvb-frontends/dib0070.ko
INSTALL drivers/media/dvb-frontends/dib0090.ko
INSTALL drivers/media/dvb-frontends/dib3000mb.ko
INSTALL drivers/media/dvb-frontends/dib3000mc.ko
INSTALL drivers/media/dvb-frontends/dib7000m.ko
INSTALL drivers/media/dvb-frontends/dib7000p.ko
INSTALL drivers/media/dvb-frontends/dib8000.ko
INSTALL drivers/media/dvb-frontends/dib9000.ko
INSTALL drivers/media/dvb-frontends/dibx000_common.ko
INSTALL drivers/media/dvb-frontends/drx39xyj/drx39xyj.ko
INSTALL drivers/media/dvb-frontends/drxd.ko
INSTALL drivers/media/dvb-frontends/drxk.ko
INSTALL drivers/media/dvb-frontends/ds3000.ko
INSTALL drivers/media/dvb-frontends/dvb-pll.ko
INSTALL drivers/media/dvb-frontends/ec100.ko
INSTALL drivers/media/dvb-frontends/helene.ko
INSTALL drivers/media/dvb-frontends/horus3a.ko
INSTALL drivers/media/dvb-frontends/isl6405.ko
INSTALL drivers/media/dvb-frontends/isl6421.ko
INSTALL drivers/media/dvb-frontends/isl6423.ko
INSTALL drivers/media/dvb-frontends/itd1000.ko
INSTALL drivers/media/dvb-frontends/ix2505v.ko
INSTALL drivers/media/dvb-frontends/l64781.ko
INSTALL drivers/media/dvb-frontends/lg2160.ko
INSTALL drivers/media/dvb-frontends/lgdt3305.ko
INSTALL drivers/media/dvb-frontends/lgdt3306a.ko
INSTALL drivers/media/dvb-frontends/lgdt330x.ko
INSTALL drivers/media/dvb-frontends/lgs8gl5.ko
INSTALL drivers/media/dvb-frontends/lgs8gxx.ko
INSTALL drivers/media/dvb-frontends/lnbh25.ko
INSTALL drivers/media/dvb-frontends/lnbh29.ko
INSTALL drivers/media/dvb-frontends/lnbp21.ko
INSTALL drivers/media/dvb-frontends/lnbp22.ko
INSTALL drivers/media/dvb-frontends/m88ds3103.ko
INSTALL drivers/media/dvb-frontends/m88rs2000.ko
INSTALL drivers/media/dvb-frontends/mb86a16.ko
INSTALL drivers/media/dvb-frontends/mb86a20s.ko
INSTALL drivers/media/dvb-frontends/mn88443x.ko
INSTALL drivers/media/dvb-frontends/mn88472.ko
INSTALL drivers/media/dvb-frontends/mn88473.ko
INSTALL drivers/media/dvb-frontends/mt312.ko
INSTALL drivers/media/dvb-frontends/mt352.ko
INSTALL drivers/media/dvb-frontends/mxl5xx.ko
INSTALL drivers/media/dvb-frontends/nxt200x.ko
INSTALL drivers/media/dvb-frontends/nxt6000.ko
INSTALL drivers/media/dvb-frontends/or51132.ko
INSTALL drivers/media/dvb-frontends/or51211.ko
INSTALL drivers/media/dvb-frontends/rtl2830.ko
INSTALL drivers/media/dvb-frontends/rtl2832.ko
INSTALL drivers/media/dvb-frontends/rtl2832_sdr.ko
INSTALL drivers/media/dvb-frontends/s5h1409.ko
INSTALL drivers/media/dvb-frontends/s5h1411.ko
INSTALL drivers/media/dvb-frontends/s5h1420.ko
INSTALL drivers/media/dvb-frontends/s5h1432.ko
INSTALL drivers/media/dvb-frontends/s921.ko
INSTALL drivers/media/dvb-frontends/si2165.ko
INSTALL drivers/media/dvb-frontends/si2168.ko
INSTALL drivers/media/dvb-frontends/si21xx.ko
INSTALL drivers/media/dvb-frontends/sp2.ko
INSTALL drivers/media/dvb-frontends/sp8870.ko
INSTALL drivers/media/dvb-frontends/sp887x.ko
INSTALL drivers/media/dvb-frontends/stb0899.ko
INSTALL drivers/media/dvb-frontends/stb6000.ko
INSTALL drivers/media/dvb-frontends/stb6100.ko
INSTALL drivers/media/dvb-frontends/stv0288.ko
INSTALL drivers/media/dvb-frontends/stv0297.ko
INSTALL drivers/media/dvb-frontends/stv0299.ko
INSTALL drivers/media/dvb-frontends/stv0367.ko
INSTALL drivers/media/dvb-frontends/stv0900.ko
INSTALL drivers/media/dvb-frontends/stv090x.ko
INSTALL drivers/media/dvb-frontends/stv0910.ko
INSTALL drivers/media/dvb-frontends/stv6110.ko
INSTALL drivers/media/dvb-frontends/stv6110x.ko
INSTALL drivers/media/dvb-frontends/stv6111.ko
INSTALL drivers/media/dvb-frontends/tc90522.ko
INSTALL drivers/media/dvb-frontends/tda10021.ko
INSTALL drivers/media/dvb-frontends/tda10023.ko
INSTALL drivers/media/dvb-frontends/tda10048.ko
INSTALL drivers/media/dvb-frontends/tda1004x.ko
INSTALL drivers/media/dvb-frontends/tda10071.ko
INSTALL drivers/media/dvb-frontends/tda10086.ko
INSTALL drivers/media/dvb-frontends/tda18271c2dd.ko
INSTALL drivers/media/dvb-frontends/tda665x.ko
INSTALL drivers/media/dvb-frontends/tda8083.ko
INSTALL drivers/media/dvb-frontends/tda8261.ko
INSTALL drivers/media/dvb-frontends/tda826x.ko
INSTALL drivers/media/dvb-frontends/ts2020.ko
INSTALL drivers/media/dvb-frontends/tua6100.ko
INSTALL drivers/media/dvb-frontends/ves1820.ko
INSTALL drivers/media/dvb-frontends/ves1x93.ko
INSTALL drivers/media/dvb-frontends/zd1301_demod.ko
INSTALL drivers/media/dvb-frontends/zl10036.ko
INSTALL drivers/media/dvb-frontends/zl10039.ko
INSTALL drivers/media/dvb-frontends/zl10353.ko
INSTALL drivers/media/i2c/ds90ub953.ko
INSTALL drivers/media/i2c/ds90ub960.ko
INSTALL drivers/media/i2c/imx219.ko
INSTALL drivers/media/i2c/imx390.ko
INSTALL drivers/media/i2c/ov1063x.ko
INSTALL drivers/media/i2c/ov2312.ko
INSTALL drivers/media/i2c/ov2659.ko
INSTALL drivers/media/i2c/ov5640.ko
INSTALL drivers/media/i2c/ov5645.ko
INSTALL drivers/media/platform/cadence/cdns-csi2rx.ko
INSTALL drivers/media/platform/chips-media/wave5/wave5.ko
INSTALL drivers/media/platform/ti/cal/ti-cal.ko
INSTALL drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.ko
INSTALL drivers/media/platform/vxe-vxd/vxd-dec.ko
INSTALL drivers/media/platform/vxe-vxd/vxe-enc.ko
INSTALL drivers/media/spi/cxd2880-spi.ko
INSTALL drivers/media/tuners/e4000.ko
INSTALL drivers/media/tuners/fc0011.ko
INSTALL drivers/media/tuners/fc0012.ko
INSTALL drivers/media/tuners/fc0013.ko
INSTALL drivers/media/tuners/fc2580.ko
INSTALL drivers/media/tuners/it913x.ko
INSTALL drivers/media/tuners/m88rs6000t.ko
INSTALL drivers/media/tuners/max2165.ko
INSTALL drivers/media/tuners/mc44s803.ko
INSTALL drivers/media/tuners/msi001.ko
INSTALL drivers/media/tuners/mt2060.ko
INSTALL drivers/media/tuners/mt2063.ko
INSTALL drivers/media/tuners/mt20xx.ko
INSTALL drivers/media/tuners/mt2131.ko
INSTALL drivers/media/tuners/mt2266.ko
INSTALL drivers/media/tuners/mxl301rf.ko
INSTALL drivers/media/tuners/mxl5005s.ko
INSTALL drivers/media/tuners/mxl5007t.ko
INSTALL drivers/media/tuners/qm1d1b0004.ko
INSTALL drivers/media/tuners/qm1d1c0042.ko
INSTALL drivers/media/tuners/qt1010.ko
INSTALL drivers/media/tuners/r820t.ko
INSTALL drivers/media/tuners/si2157.ko
INSTALL drivers/media/tuners/tda18212.ko
INSTALL drivers/media/tuners/tda18218.ko
INSTALL drivers/media/tuners/tda18250.ko
INSTALL drivers/media/tuners/tda18271.ko
INSTALL drivers/media/tuners/tda827x.ko
INSTALL drivers/media/tuners/tda8290.ko
INSTALL drivers/media/tuners/tda9887.ko
INSTALL drivers/media/tuners/tea5761.ko
INSTALL drivers/media/tuners/tea5767.ko
INSTALL drivers/media/tuners/tua9001.ko
INSTALL drivers/media/tuners/tuner-simple.ko
INSTALL drivers/media/tuners/tuner-types.ko
INSTALL drivers/media/tuners/tuner-xc2028.ko
INSTALL drivers/media/tuners/xc4000.ko
INSTALL drivers/media/tuners/xc5000.ko
INSTALL drivers/media/usb/gspca/gspca_main.ko
INSTALL drivers/media/usb/uvc/uvcvideo.ko
INSTALL drivers/media/v4l2-core/v4l2-fwnode.ko
INSTALL drivers/media/v4l2-core/v4l2-mem2mem.ko
INSTALL drivers/mfd/ti_am335x_tscadc.ko
INSTALL drivers/mfd/wcd934x.ko
INSTALL drivers/misc/eeprom/at24.ko
INSTALL drivers/misc/eeprom/at25.ko
INSTALL drivers/misc/eeprom/eeprom_93xx46.ko
INSTALL drivers/misc/mytest.ko
INSTALL drivers/misc/pci_endpoint_test.ko
INSTALL drivers/misc/uacce/uacce.ko
INSTALL drivers/mtd/tests/mtd_nandbiterrs.ko
INSTALL drivers/mtd/tests/mtd_nandecctest.ko
INSTALL drivers/mtd/tests/mtd_oobtest.ko
INSTALL drivers/mtd/tests/mtd_pagetest.ko
INSTALL drivers/mtd/tests/mtd_readtest.ko
INSTALL drivers/mtd/tests/mtd_speedtest.ko
INSTALL drivers/mtd/tests/mtd_stresstest.ko
INSTALL drivers/mtd/tests/mtd_subpagetest.ko
INSTALL drivers/mtd/tests/mtd_torturetest.ko
INSTALL drivers/net/can/c_can/c_can.ko
INSTALL drivers/net/can/c_can/c_can_platform.ko
INSTALL drivers/net/can/dev/can-dev.ko
INSTALL drivers/net/can/flexcan.ko
INSTALL drivers/net/can/m_can/m_can.ko
INSTALL drivers/net/can/m_can/m_can_platform.ko
INSTALL drivers/net/dummy.ko
INSTALL drivers/net/ethernet/broadcom/bnx2x/bnx2x.ko
INSTALL drivers/net/ethernet/broadcom/tg3.ko
INSTALL drivers/net/ethernet/intel/e1000/e1000.ko
INSTALL drivers/net/ethernet/intel/e1000e/e1000e.ko
INSTALL drivers/net/ethernet/marvell/skge.ko
INSTALL drivers/net/ethernet/qualcomm/emac/qcom-emac.ko
INSTALL drivers/net/ethernet/qualcomm/qca_7k_common.ko
INSTALL drivers/net/ethernet/qualcomm/qcaspi.ko
INSTALL drivers/net/ethernet/qualcomm/qcauart.ko
INSTALL drivers/net/ethernet/qualcomm/rmnet/rmnet.ko
INSTALL drivers/net/ethernet/ti/icss_iep.ko
INSTALL drivers/net/ethernet/ti/icssg-prueth.ko
INSTALL drivers/net/ethernet/ti/prueth.ko
INSTALL drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.ko
INSTALL drivers/net/ipvlan/ipvlan.ko
INSTALL drivers/net/macvlan.ko
INSTALL drivers/net/macvtap.ko
INSTALL drivers/net/mdio.ko
INSTALL drivers/net/ntb_netdev.ko
INSTALL drivers/net/phy/marvell10g.ko
INSTALL drivers/net/phy/microchip.ko
INSTALL drivers/net/phy/realtek.ko
INSTALL drivers/net/phy/smsc.ko
INSTALL drivers/net/tap.ko
INSTALL drivers/net/usb/asix.ko
INSTALL drivers/net/usb/ax88179_178a.ko
INSTALL drivers/net/usb/cdc_eem.ko
INSTALL drivers/net/usb/cdc_ether.ko
INSTALL drivers/net/usb/cdc_ncm.ko
INSTALL drivers/net/usb/cdc_subset.ko
INSTALL drivers/net/usb/dm9601.ko
INSTALL drivers/net/usb/lan78xx.ko
INSTALL drivers/net/usb/mcs7830.ko
INSTALL drivers/net/usb/net1080.ko
INSTALL drivers/net/usb/pegasus.ko
INSTALL drivers/net/usb/plusb.ko
INSTALL drivers/net/usb/r8152.ko
INSTALL drivers/net/usb/rtl8150.ko
INSTALL drivers/net/usb/smsc75xx.ko
INSTALL drivers/net/usb/smsc95xx.ko
INSTALL drivers/net/usb/sr9800.ko
INSTALL drivers/net/usb/usbnet.ko
INSTALL drivers/net/usb/zaurus.ko
INSTALL drivers/net/veth.ko
INSTALL drivers/net/vxlan.ko
INSTALL drivers/net/wireless/ath/ath.ko
INSTALL drivers/net/wireless/ath/ath10k/ath10k_core.ko
INSTALL drivers/net/wireless/ath/ath10k/ath10k_pci.ko
INSTALL drivers/net/wireless/broadcom/b43/b43.ko
INSTALL drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
INSTALL drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
INSTALL drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
INSTALL drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
INSTALL drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex.ko
INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.ko
INSTALL drivers/net/wireless/ti/wl18xx/wl18xx.ko
INSTALL drivers/net/wireless/ti/wlcore/wlcore.ko
INSTALL drivers/net/wireless/ti/wlcore/wlcore_sdio.ko
INSTALL drivers/nfc/s3fwrn5/s3fwrn5.ko
INSTALL drivers/nfc/s3fwrn5/s3fwrn5_i2c.ko
INSTALL drivers/ntb/hw/epf/ntb_hw_epf.ko
INSTALL drivers/ntb/ntb.ko
INSTALL drivers/ntb/ntb_transport.ko
INSTALL drivers/nvme/host/nvme-core.ko
INSTALL drivers/nvme/host/nvme.ko
INSTALL drivers/phy/cadence/cdns-dphy.ko
INSTALL drivers/phy/freescale/phy-fsl-imx8-mipi-dphy.ko
INSTALL drivers/phy/phy-can-transceiver.ko
INSTALL drivers/phy/ti/phy-omap-usb2.ko
INSTALL drivers/platform/chrome/cros_ec_chardev.ko
INSTALL drivers/platform/chrome/cros_ec_typec.ko
INSTALL drivers/power/supply/bq27xxx_battery_hdq.ko
INSTALL drivers/power/supply/sbs-battery.ko
INSTALL drivers/pwm/pwm-cros-ec.ko
INSTALL drivers/regulator/vctrl-regulator.ko
INSTALL drivers/remoteproc/pru_rproc.ko
INSTALL drivers/remoteproc/ti_k3_dsp_remoteproc.ko
INSTALL drivers/remoteproc/ti_k3_m4_remoteproc.ko
INSTALL drivers/remoteproc/ti_k3_r5_remoteproc.ko
INSTALL drivers/rpmsg-kdrv/rpmsg_kdrv_switch.ko
INSTALL drivers/rpmsg/rpmsg_char.ko
INSTALL drivers/rpmsg/rpmsg_pru.ko
INSTALL drivers/rpmsg/virtio_rpmsg_bus.ko
INSTALL drivers/rtc/rtc-ds1307.ko
INSTALL drivers/rtc/rtc-pcf2127.ko
INSTALL drivers/rtc/rtc-pcf85363.ko
INSTALL drivers/rtc/rtc-rk808.ko
INSTALL drivers/rtc/rtc-rv8803.ko
INSTALL drivers/rtc/rtc-rx8581.ko
INSTALL drivers/scsi/hisi_sas/hisi_sas_main.ko
INSTALL drivers/scsi/hisi_sas/hisi_sas_v1_hw.ko
INSTALL drivers/scsi/hisi_sas/hisi_sas_v2_hw.ko
INSTALL drivers/scsi/libsas/libsas.ko
INSTALL drivers/scsi/mpt3sas/mpt3sas.ko
INSTALL drivers/scsi/raid_class.ko
INSTALL drivers/scsi/scsi_transport_sas.ko
INSTALL drivers/slimbus/slim-qcom-ctrl.ko
INSTALL drivers/slimbus/slimbus.ko
INSTALL drivers/soc/ti/pruss.ko
INSTALL drivers/soundwire/soundwire-bus.ko
INSTALL drivers/soundwire/soundwire-qcom.ko
INSTALL drivers/spi/spidev.ko
INSTALL drivers/ssb/ssb.ko
INSTALL drivers/tty/serial/8250/8250_pruss.ko
INSTALL drivers/usb/cdns3/cdns3-ti.ko
INSTALL drivers/usb/cdns3/cdns3.ko
INSTALL drivers/usb/class/cdc-acm.ko
INSTALL drivers/usb/common/usb-common.ko
INSTALL drivers/usb/common/usb-conn-gpio.ko
INSTALL drivers/usb/core/usbcore.ko
INSTALL drivers/usb/dwc3/dwc3-am62.ko
INSTALL drivers/usb/dwc3/dwc3-haps.ko
INSTALL drivers/usb/dwc3/dwc3-keystone.ko
INSTALL drivers/usb/dwc3/dwc3-of-simple.ko
INSTALL drivers/usb/dwc3/dwc3.ko
INSTALL drivers/usb/gadget/function/u_audio.ko
INSTALL drivers/usb/gadget/function/u_ether.ko
INSTALL drivers/usb/gadget/function/u_serial.ko
INSTALL drivers/usb/gadget/function/usb_f_acm.ko
INSTALL drivers/usb/gadget/function/usb_f_ecm.ko
INSTALL drivers/usb/gadget/function/usb_f_ecm_subset.ko
INSTALL drivers/usb/gadget/function/usb_f_eem.ko
INSTALL drivers/usb/gadget/function/usb_f_fs.ko
INSTALL drivers/usb/gadget/function/usb_f_hid.ko
INSTALL drivers/usb/gadget/function/usb_f_mass_storage.ko
INSTALL drivers/usb/gadget/function/usb_f_midi.ko
INSTALL drivers/usb/gadget/function/usb_f_ncm.ko
INSTALL drivers/usb/gadget/function/usb_f_obex.ko
INSTALL drivers/usb/gadget/function/usb_f_printer.ko
INSTALL drivers/usb/gadget/function/usb_f_rndis.ko
INSTALL drivers/usb/gadget/function/usb_f_serial.ko
INSTALL drivers/usb/gadget/function/usb_f_ss_lb.ko
INSTALL drivers/usb/gadget/function/usb_f_uac1.ko
INSTALL drivers/usb/gadget/function/usb_f_uac2.ko
INSTALL drivers/usb/gadget/function/usb_f_uvc.ko
INSTALL drivers/usb/gadget/legacy/g_acm_ms.ko
INSTALL drivers/usb/gadget/legacy/g_audio.ko
INSTALL drivers/usb/gadget/legacy/g_cdc.ko
INSTALL drivers/usb/gadget/legacy/g_dbgp.ko
INSTALL drivers/usb/gadget/legacy/g_ether.ko
INSTALL drivers/usb/gadget/legacy/g_ffs.ko
INSTALL drivers/usb/gadget/legacy/g_hid.ko
INSTALL drivers/usb/gadget/legacy/g_mass_storage.ko
INSTALL drivers/usb/gadget/legacy/g_midi.ko
INSTALL drivers/usb/gadget/legacy/g_multi.ko
INSTALL drivers/usb/gadget/legacy/g_ncm.ko
INSTALL drivers/usb/gadget/legacy/g_printer.ko
INSTALL drivers/usb/gadget/legacy/g_serial.ko
INSTALL drivers/usb/gadget/legacy/g_webcam.ko
INSTALL drivers/usb/gadget/legacy/g_zero.ko
INSTALL drivers/usb/gadget/legacy/gadgetfs.ko
INSTALL drivers/usb/gadget/libcomposite.ko
INSTALL drivers/usb/gadget/udc/udc-core.ko
INSTALL drivers/usb/host/ehci-hcd.ko
INSTALL drivers/usb/host/ehci-pci.ko
INSTALL drivers/usb/host/ehci-platform.ko
INSTALL drivers/usb/host/ohci-hcd.ko
INSTALL drivers/usb/host/ohci-pci.ko
INSTALL drivers/usb/host/ohci-platform.ko
INSTALL drivers/usb/host/xhci-hcd.ko
INSTALL drivers/usb/host/xhci-pci.ko
INSTALL drivers/usb/host/xhci-plat-hcd.ko
INSTALL drivers/usb/isp1760/isp1760.ko
INSTALL drivers/usb/misc/usb3503.ko
INSTALL drivers/usb/misc/usbtest.ko
INSTALL drivers/usb/musb/musb_hdrc.ko
INSTALL drivers/usb/phy/phy-generic.ko
INSTALL drivers/usb/roles/roles.ko
INSTALL drivers/usb/serial/cp210x.ko
INSTALL drivers/usb/serial/ftdi_sio.ko
INSTALL drivers/usb/serial/option.ko
INSTALL drivers/usb/serial/pl2303.ko
INSTALL drivers/usb/serial/usb_wwan.ko
INSTALL drivers/usb/serial/usbserial.ko
INSTALL drivers/usb/storage/usb-storage.ko
INSTALL drivers/usb/typec/hd3ss3220.ko
INSTALL drivers/usb/typec/tcpm/fusb302.ko
INSTALL drivers/usb/typec/tcpm/tcpm.ko
INSTALL drivers/usb/typec/tps6598x.ko
INSTALL drivers/usb/typec/typec.ko
INSTALL drivers/video/backlight/lp855x_bl.ko
INSTALL drivers/w1/wire.ko
INSTALL drivers/watchdog/rti_wdt.ko
INSTALL fs/btrfs/btrfs.ko
INSTALL fs/cifs/cifs.ko
INSTALL fs/fuse/cuse.ko
INSTALL fs/fuse/fuse.ko
INSTALL fs/nfs/blocklayout/blocklayoutdriver.ko
INSTALL fs/overlayfs/overlay.ko
INSTALL lib/crc-ccitt.ko
INSTALL lib/crypto/libarc4.ko
INSTALL lib/crypto/libchacha.ko
INSTALL lib/crypto/libdes.ko
INSTALL lib/libcrc32c.ko
INSTALL lib/math/cordic.ko
INSTALL lib/raid6/raid6_pq.ko
INSTALL lib/ts_bm.ko
INSTALL lib/ts_fsm.ko
INSTALL lib/ts_kmp.ko
INSTALL net/802/garp.ko
INSTALL net/802/mrp.ko
INSTALL net/802/p8022.ko
INSTALL net/802/psnap.ko
INSTALL net/802/stp.ko
INSTALL net/8021q/8021q.ko
INSTALL net/bluetooth/bluetooth.ko
INSTALL net/bluetooth/hidp/hidp.ko
INSTALL net/bridge/br_netfilter.ko
INSTALL net/bridge/bridge.ko
INSTALL net/bridge/netfilter/ebt_802_3.ko
INSTALL net/bridge/netfilter/ebt_among.ko
INSTALL net/bridge/netfilter/ebt_arp.ko
INSTALL net/bridge/netfilter/ebt_arpreply.ko
INSTALL net/bridge/netfilter/ebt_dnat.ko
INSTALL net/bridge/netfilter/ebt_ip.ko
INSTALL net/bridge/netfilter/ebt_ip6.ko
INSTALL net/bridge/netfilter/ebt_limit.ko
INSTALL net/bridge/netfilter/ebt_log.ko
INSTALL net/bridge/netfilter/ebt_mark.ko
INSTALL net/bridge/netfilter/ebt_mark_m.ko
INSTALL net/bridge/netfilter/ebt_nflog.ko
INSTALL net/bridge/netfilter/ebt_pkttype.ko
INSTALL net/bridge/netfilter/ebt_redirect.ko
INSTALL net/bridge/netfilter/ebt_snat.ko
INSTALL net/bridge/netfilter/ebt_stp.ko
INSTALL net/bridge/netfilter/ebt_vlan.ko
INSTALL net/bridge/netfilter/ebtable_broute.ko
INSTALL net/bridge/netfilter/ebtable_filter.ko
INSTALL net/bridge/netfilter/ebtable_nat.ko
INSTALL net/bridge/netfilter/ebtables.ko
INSTALL net/can/can-bcm.ko
INSTALL net/can/can-gw.ko
INSTALL net/can/can-raw.ko
INSTALL net/can/can.ko
INSTALL net/dsa/dsa_core.ko
INSTALL net/hsr/hsr.ko
INSTALL net/ipv4/ah4.ko
INSTALL net/ipv4/esp4.ko
INSTALL net/ipv4/ip_tunnel.ko
INSTALL net/ipv4/ipcomp.ko
INSTALL net/ipv4/netfilter/arp_tables.ko
INSTALL net/ipv4/netfilter/arpt_mangle.ko
INSTALL net/ipv4/netfilter/arptable_filter.ko
INSTALL net/ipv4/netfilter/ip_tables.ko
INSTALL net/ipv4/netfilter/ipt_REJECT.ko
INSTALL net/ipv4/netfilter/iptable_filter.ko
INSTALL net/ipv4/netfilter/iptable_mangle.ko
INSTALL net/ipv4/netfilter/iptable_nat.ko
INSTALL net/ipv4/netfilter/nf_defrag_ipv4.ko
INSTALL net/ipv4/netfilter/nf_log_ipv4.ko
INSTALL net/ipv4/netfilter/nf_reject_ipv4.ko
INSTALL net/ipv4/tunnel4.ko
INSTALL net/ipv4/udp_tunnel.ko
INSTALL net/ipv4/xfrm4_tunnel.ko
INSTALL net/ipv6/ah6.ko
INSTALL net/ipv6/ip6_tunnel.ko
INSTALL net/ipv6/ip6_udp_tunnel.ko
INSTALL net/ipv6/ipcomp6.ko
INSTALL net/ipv6/ipv6.ko
INSTALL net/ipv6/netfilter/ip6_tables.ko
INSTALL net/ipv6/netfilter/ip6t_REJECT.ko
INSTALL net/ipv6/netfilter/ip6table_filter.ko
INSTALL net/ipv6/netfilter/ip6table_mangle.ko
INSTALL net/ipv6/netfilter/ip6table_nat.ko
INSTALL net/ipv6/netfilter/nf_defrag_ipv6.ko
INSTALL net/ipv6/netfilter/nf_log_ipv6.ko
INSTALL net/ipv6/netfilter/nf_reject_ipv6.ko
INSTALL net/ipv6/sit.ko
INSTALL net/ipv6/tunnel6.ko
INSTALL net/ipv6/xfrm6_tunnel.ko
INSTALL net/key/af_key.ko
INSTALL net/llc/llc.ko
INSTALL net/mac80211/mac80211.ko
INSTALL net/netfilter/ipvs/ip_vs.ko
INSTALL net/netfilter/ipvs/ip_vs_rr.ko
INSTALL net/netfilter/nf_conntrack.ko
INSTALL net/netfilter/nf_conntrack_ftp.ko
INSTALL net/netfilter/nf_conntrack_tftp.ko
INSTALL net/netfilter/nf_log_common.ko
INSTALL net/netfilter/nf_nat.ko
INSTALL net/netfilter/nf_nat_ftp.ko
INSTALL net/netfilter/nf_nat_tftp.ko
INSTALL net/netfilter/x_tables.ko
INSTALL net/netfilter/xt_CHECKSUM.ko
INSTALL net/netfilter/xt_CLASSIFY.ko
INSTALL net/netfilter/xt_IDLETIMER.ko
INSTALL net/netfilter/xt_LOG.ko
INSTALL net/netfilter/xt_MASQUERADE.ko
INSTALL net/netfilter/xt_addrtype.ko
INSTALL net/netfilter/xt_comment.ko
INSTALL net/netfilter/xt_conntrack.ko
INSTALL net/netfilter/xt_cpu.ko
INSTALL net/netfilter/xt_iprange.ko
INSTALL net/netfilter/xt_ipvs.ko
INSTALL net/netfilter/xt_length.ko
INSTALL net/netfilter/xt_limit.ko
INSTALL net/netfilter/xt_mac.ko
INSTALL net/netfilter/xt_mark.ko
INSTALL net/netfilter/xt_multiport.ko
INSTALL net/netfilter/xt_nat.ko
INSTALL net/netfilter/xt_pkttype.ko
INSTALL net/netfilter/xt_policy.ko
INSTALL net/netfilter/xt_sctp.ko
INSTALL net/netfilter/xt_tcpudp.ko
INSTALL net/nfc/nci/nci.ko
INSTALL net/nfc/nfc.ko
INSTALL net/qrtr/ns.ko
INSTALL net/qrtr/qrtr-smd.ko
INSTALL net/qrtr/qrtr-tun.ko
INSTALL net/qrtr/qrtr.ko
INSTALL net/rfkill/rfkill.ko
INSTALL net/sched/act_csum.ko
INSTALL net/sched/act_gact.ko
INSTALL net/sched/act_gate.ko
INSTALL net/sched/act_ipt.ko
INSTALL net/sched/act_mirred.ko
INSTALL net/sched/act_nat.ko
INSTALL net/sched/act_pedit.ko
INSTALL net/sched/act_police.ko
INSTALL net/sched/act_simple.ko
INSTALL net/sched/act_skbedit.ko
INSTALL net/sched/cls_basic.ko
INSTALL net/sched/cls_cgroup.ko
INSTALL net/sched/cls_flow.ko
INSTALL net/sched/cls_flower.ko
INSTALL net/sched/cls_fw.ko
INSTALL net/sched/cls_route.ko
INSTALL net/sched/cls_rsvp.ko
INSTALL net/sched/cls_rsvp6.ko
INSTALL net/sched/cls_tcindex.ko
INSTALL net/sched/cls_u32.ko
INSTALL net/sched/em_cmp.ko
INSTALL net/sched/em_meta.ko
INSTALL net/sched/em_nbyte.ko
INSTALL net/sched/em_text.ko
INSTALL net/sched/em_u32.ko
INSTALL net/sched/sch_cbq.ko
INSTALL net/sched/sch_cbs.ko
INSTALL net/sched/sch_choke.ko
INSTALL net/sched/sch_codel.ko
INSTALL net/sched/sch_drr.ko
INSTALL net/sched/sch_dsmark.ko
INSTALL net/sched/sch_etf.ko
INSTALL net/sched/sch_fq_codel.ko
INSTALL net/sched/sch_gred.ko
INSTALL net/sched/sch_hfsc.ko
INSTALL net/sched/sch_htb.ko
INSTALL net/sched/sch_ingress.ko
INSTALL net/sched/sch_mqprio.ko
INSTALL net/sched/sch_multiq.ko
INSTALL net/sched/sch_netem.ko
INSTALL net/sched/sch_prio.ko
INSTALL net/sched/sch_qfq.ko
INSTALL net/sched/sch_red.ko
INSTALL net/sched/sch_sfb.ko
INSTALL net/sched/sch_sfq.ko
INSTALL net/sched/sch_taprio.ko
INSTALL net/sched/sch_tbf.ko
INSTALL net/sched/sch_teql.ko
INSTALL net/sctp/sctp.ko
INSTALL net/sctp/sctp_diag.ko
INSTALL net/wireless/cfg80211.ko
INSTALL net/xfrm/xfrm_algo.ko
INSTALL net/xfrm/xfrm_ipcomp.ko
INSTALL net/xfrm/xfrm_user.ko
INSTALL samples/rpmsg/rpmsg_client_sample.ko
INSTALL sound/core/snd-hwdep.ko
INSTALL sound/core/snd-rawmidi.ko
INSTALL sound/soc/codecs/snd-soc-pcm3168a-i2c.ko
INSTALL sound/soc/codecs/snd-soc-pcm3168a.ko
INSTALL sound/soc/codecs/snd-soc-simple-amplifier.ko
INSTALL sound/soc/codecs/snd-soc-tlv320aic31xx.ko
INSTALL sound/soc/codecs/snd-soc-tlv320aic3x.ko
INSTALL sound/soc/codecs/snd-soc-wcd934x.ko
INSTALL sound/soc/codecs/snd-soc-wm8904.ko
INSTALL sound/soc/codecs/snd-soc-wsa881x.ko
INSTALL sound/soc/generic/snd-soc-audio-graph-card.ko
INSTALL sound/soc/generic/snd-soc-simple-card-utils.ko
INSTALL sound/soc/generic/snd-soc-simple-card.ko
INSTALL sound/soc/ti/snd-soc-j721e-evm.ko
INSTALL sound/usb/snd-usb-audio.ko
INSTALL sound/usb/snd-usbmidi-lib.ko
DEPMOD 5.10.168-rt83-gc1a1291911
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ sudo umount /home/ubuntu/rootfs
ubuntu@ubuntu:~/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911$ history
594 history
595 export PATH=/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
596 echo $PATH
597 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- clean
598 cp '/home/ubuntu/SDK/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/mytest.c' ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/
599 vi ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/drivers/misc/Makefile
600 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
601 cd ./board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/
602 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- tisdk_am62xx-evm-rt_defconfig
603 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- Image
604 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
605 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- modules
606 sudo umount /media/ubuntu/root
607 sudo mount /dev/sdb2 /home/ubuntu/rootfs
608 make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- ti/k3-am625-sk.dtb
609 sudo rm -f /home/ubuntu/rootfs/boot/*
610 sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/Image' /home/ubuntu/rootfs/boot
611 sudo cp '/home/ubuntu/ti-processor-sdk-linux-rt-am62xx-evm-08.06.00.42/board-support/linux-rt-5.10.168+gitAUTOINC+c1a1291911-gc1a1291911/arch/arm64/boot/dts/ti/k3-am625-sk.dtb' /home/ubuntu/rootfs/boot
612 sudo make ARCH=arm64 INSTALL_MOD_PATH=/home/ubuntu/rootfs modules_install
613 sudo umount /home/ubuntu/rootfs
614 history
