Other Parts Discussed in Thread: AM3358,
Hi All:
我最近剛開始使用am3358 開發平台, 而我在使用yocto 的Bitbake 下
MACHINE=am335x-evm bitbake tisdk-rootfs-image
的時候出現了以下錯誤
ERROR: mobile-broadband-provider-info-1_20170310-r0 do_fetch: Fetcher failure: Unable to find revision befcbbc9867e742ac16415660b0b7521218a530c in branch master even from upstream
ERROR: mobile-broadband-provider-info-1_20170310-r0 do_fetch: Fetcher failure for URL: 'git://github.com/GNOME/mobile-broadband-provider-info.git;protocol=https'. Unable to fetch URL from any source.
ERROR: mobile-broadband-provider-info-1_20170310-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/zh/tisdk/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/temp/log.do_fetch.26992
ERROR: Task (/home/zh/tisdk/sources/oe-core/meta/recipes-connectivity/mobile-broadband-provider-info/mobile-broadband-provider-info_git.bb:do_fetch) failed with exit code '1'
我透過git 檢查https://github.com/GNOME/mobile-broadband-provider-info.git , 這個連結看起來是有效的, 不知道哪裡出現了問題.
不知道是否有人遇到相同的問題.
或是有人能指點我該如何解決這個問題
謝謝!!
