8168 DVRRDK syslink 下面的msgq_examples 编译运行
大家好
       我用DVRRDK编译DVRRDK_04.00.00.03/ti_tools/syslink/syslink_2_20_02_20/examples/archive/TI816X_linux_elf/ex02_messageq例子,也生成了HOST DSP VPSS和VIDEO端的可执行文件,但在用fw_load.out加载时,内核崩溃,错误如下:
Attached to slave procId 2.
BUG: Your driver calls ioremap() on system memory.  This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release.  Please fix your driver.
------------[ cut here ]------------
WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x194()
Modules linked in: syslink
Backtrace:
[<c0317fac>] (dump_backtrace+0x0/0x110) from [<c06690cc>] (dump_stack+0x18/0x1c)
 r6:c072bccf r5:000000d3 r4:00000000 r3:60000013
[<c06690b4>] (dump_stack+0x0/0x1c) from [<c033dadc>] (warn_slowpath_common+0x54/0x6c)
[<c033da88>] (warn_slowpath_common+0x0/0x6c) from [<c033db18>] (warn_slowpath_null+0x24/0x2c)
 r8:bf0ae364 r7:00000000 r6:00000000 r5:0008fe00 r4:0000c658
r3:00000009
VPSS VIDEO和DSP都报如上类似错误。
之前用fw_load.out加载编码应用没有问题,请问该怎么解决?十分感谢
x 出现错误。请重试或与管理员联系。
