Part Number: TDA4VM
rtos-sdk-0805-j784s4+tidl_j784s4_08_05_00_16
命令:./out/tidl_model_import.out /data_local/workdir/model/conv_board.txt
model_conv_board.txt
modelType = 2
numParamBits = 8
numFeatureBits = 8
inputNetFile = "/data_local/workdir/model/conv_board.onnx"
outputNetFile = "/data_local/workdir/out/tidl_net_out.bin"
outputParamsFile = "/data_local/workdir/out/tidl_io_out_"
perfSimConfig = ../../test/testvecs/config/import/device_config.cfg
inFileFormat = 2
inData = "/data_local/workdir/img/img.txt"
numFrames = 1
inWidth = 1920
inHeight = 608
inNumChannels = 3
inDataNorm = 1
inMean = 137.733 130.282 127.753
inScale = 0.031950 0.025250 0.024000
debugTraceLevel = 3
wrtieTraceLevel = 3
writeOutput = 2
compileConstraintsFlag = 83886080
ONNX模型 format ONNX v8 opset version onnx11
** TIDL Model Checker **
WARNING: [TIDL_E_DATAFLOW_INFO_NULL]Network compiler returned with error or didn't executed. This model can only be used on PC/Host emulation mode, it is not expected to work on target/EVM.
** 1 WARNINGS 1 ERRORS **
