ccs6.0.1仿真可以连接上下载时出现如下错误怎么解决
Other Parts Discussed in Thread: AM3358, UCD3138
CortxA8: Trouble Writing Memory Block at 0x4c0000e4 on Page 0 of Length 0x4: (Error -1065 @ 0x3D5A) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.507.0)
CortxA8: GEL: Error while executing OnTargetConnect(): Target failed to write 0x4C0000E4 at *((unsigned int *) (0x4C000000+0x0E4))=(unsigned int) 0x06 [AM335x_SK_1.2.gel:668] at DDR3_EMIF_Config() [AM335x_SK_1.2.gel:757] at AM3358_SK_Initialization() [AM335x_SK_1.2.gel:742] at OnTargetConnect() .
CortxA8: File Loader: Data verification failed at address 0x80000000 Please verify target memory and memory map.
CortxA8: Unable to terminate memory download: NULL buffer pointer at 0x3a9f
CortxA8: GEL: File: C:\ti\AM335X_StarterWare_02_00_00_07\binary\armv7a\cgt_ccs\am335x\evmskAM335x\irq_preemption\irqPreemption.out: a data verification error occurred, file load failed.
