大家好
目前我用的是CCS6版本 例子程序连接 www.deyisupport.com/.../74528.aspx
我用的CMD是例子事先设置好的命令K2.CMD
打开后 我仿真器配置为 如下面截图:
当我点击DEBUG时候 会出现如下错误
C66xx_0: Trouble Reading Memory Block at 0x7c00 on Page 0 of Length 0x4: (Error -1190 @ 0x7C00) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.507.0)
C66xx_0: File Loader: Data verification failed at address 0x00007C00 Please verify target memory and memory map.
C66xx_0: GEL: File: F:\EVM\66AK2H\example\cifae_KII_STK\GE\LE\GE.out: a data verification error occurred, file load failed.
