TDA4VM: fatal error #35: #error directive: invalid target
Part Number: TDA4VM
我在CCS中新建了一个空项目,然后把SDK中的DSP例子的头文件和源文件复制到了项目所在文件夹中,并且添加了include路径,对项目进行了编译,结果出现了图中的错误:
Compilation failure
subdir_rules.mk:9: recipe for target 'fft_example.obj' failed
"F:/ti-processor-sdk-rtos-j721e-evm-08_06_00_12/dsplib_c66x_3_4_0_0/packages/ti/dsplib/src/DSPF_dp_cholesky/DSPF_dp_cholesky.h", line 45: fatal error #35: #error directive: invalid target
1 catastrophic error detected in the compilation of "../fft_example.c".
Compilation terminated.
请问错误的解决方法是什么?
