DM6467 H.264 Encoder Problem
Hi,
I want to test the encoder and decoder on DM6467 platform.
My encoder version is "H.264 1080p@30 BP Encoder (v01.10.02) on DM6467"
My decoder version is "H.264 High Profile Decoder (v01.10.01) on DM6467"
My encoder function can run well by itself. The pseudo code is in below
>> H264FHDVENC_RMAN_setup();
>> H264VDEC_create(...);
>> H264FHDVENC_create(...);
>> for( i = 0 ; i < 300000; i++ )
>> readOnePicture();
>> H264FHDVENC_encode(...);
>> H264FHDVENC_delete();
>> H264VDEC_delete();
My decoder function can also run well by itself. The pseudo code is in below
>> readOneFrameStream();
>> H264VDEC_decode(...);
>> H264VDEC_delete();
but if I run the encoder and decoder at the same time,
The H264FHDVENC_encode() while be hanged in H264FHDVENC_TI_DMA_Wait() at the 2nd loop(when i==1).
>> readOnePicture();
>> H264FHDVENC_encode(...); // when i==0, it's ok. when i==1, it will be hanged in H264FHDVENC_TI_DMA_Wait()
>> H264VDEC_delete();
I am sure that the first frame was encoded and decoded successfully.
The program will stop while to encode the second frame.
What may I missed if I want to put encoder and decoder together?
Can you give some advice on how to solve this problem?
