TDA4VM: MCAL CAN发送一段报文后程序崩溃
Part Number: TDA4VM
    我根据MCAL CAN 例子上关掉了回环测试,来发送100ms/次报文,但每次报文发送到126帧时,代码稳定会跑飞程序崩溃,我用调试器单步调试也解决不了问题,
    请问有什么可能的原因或解决思路提供下么?万分火急十分感谢
Std_ReturnType CAN_transmit_msg(uint8 canHandle,uint32 id,uint8 lenth,uint8 *data)
    CanApp_Pdu.id           = id ;
    CanApp_Pdu.length       = lenth;
    CanApp_Pdu.swPduHandle  = 1U;
    CanApp_Pdu.sdu          = data;
    uint8  hth = 0;
    uint32 mask = 0x00000000U;
    Std_ReturnType status;
    CanApp_SetupCanFrame(canHandle, &hth, &mask);
    status = Can_Write(hth, &CanApp_Pdu);
    while ((CanIf_TxConfirmationCount != 1U))
        /* Wait for Tx Confirmation */
    CanIf_TxConfirmationCount = 0;
    if (status != E_OK)
        AppUtils_Printf(MSG_NORMAL,"Error In Can_Write.\n");
    return status;
static void CanApp_LoopbackTest(void)
    uint32               ctlr_cnt, mask = 0x00000000U, canMaxControllerCnt;
    uint8                loopCnt = 0U, hth = 0U;
    const Can_ConfigType *Can_ConfigPtr;
    Can_ConfigPtr = &CanConfigSet;
    canMaxControllerCnt = Can_ConfigPtr->CanMaxControllerCount;
    for (ctlr_cnt = 0U; ctlr_cnt < canMaxControllerCnt;ctlr_cnt++)
        /* Set Can frame */
        CanApp_SetupCanFrame(ctlr_cnt, &hth, &mask);
        /* Set Controller Mode to Start */
        status = Can_SetControllerMode(CanConfigSet_CanController_List_PC[ctlr_cnt]->ControllerId, CAN_CS_STARTED);
        if (status != E_OK)
            CanApp_TestPassed = E_NOT_OK;
    FLEXCAN_init();
    while (1)
         CAN_transmit_msg(0,0x550,7,test);
         Osal_delay(100);
int FLEXCAN_init()
    CanApp_Startup();
    CanApp_PowerAndClkSrc();
    CanApp_PlatformInit();
    CanApp_LoopbackTest();
    CanApp_SafetyApiTest();
    return 0;
* Copyright (c) 2019 Texas Instruments Incorporated
* All rights reserved not granted herein.
* Limited License.
* Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
* license under copyrights and patents it now or hereafter owns or controls to make,
* have made, use, import, offer to sell and sell ("Utilize") this software subject to the
* terms herein.  With respect to the foregoing patent license, such license is granted
* solely to the extent that any such patent is necessary to Utilize the software alone.
* The patent license shall not apply to any combinations which include this software,
* other than combinations with devices manufactured by or for TI ("TI Devices").
* No hardware patent is licensed hereunder.
* Redistributions must preserve existing copyright notices and reproduce this license
* (including the above copyright notice and the disclaimer and (if applicable) source
* code license limitations below) in the documentation and/or other materials provided
* with the distribution
* Redistribution and use in binary form, without modification, are permitted provided
* that the following conditions are met:
* *       No reverse engineering, decompilation, or disassembly of this software is
* permitted with respect to any software provided in binary form.
* *       any redistribution and use are licensed by TI for use only with TI Devices.
* *       Nothing shall obligate TI to provide you with source code for the software
* licensed and provided to you in object code.
* If software source code is provided to you, modification and redistribution of the
* source code are permitted provided that the following conditions are met:
* *       any redistribution and use of the source code, including any resulting derivative
* works, are licensed by TI for use only with TI Devices.
* *       any redistribution and use of any object code compiled from the source code
* and any resulting derivative works, are licensed by TI for use only with TI Devices.
* Neither the name of Texas Instruments Incorporated nor the names of its suppliers
* may be used to endorse or promote products derived from this software without
* specific prior written permission.
* DISCLAIMER.
* THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
* OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
* OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
  Project: CAN_CONFIG_J721E
  Date   : 2022-11-29 01:31:24
  This file is generated by EB Tresos
  Do not modify this file, otherwise the software may behave in unexpected way.
 *  INCLUDES
#include "Can.h"
#include "Can_Cfg.h"
/*Requirements : MCAL-2439, MCAL-2440, MCAL-2441 */
/*  Version checking  */
//  #if ((CAN_SW_MAJOR_VERSION != (3U))||(CAN_SW_MINOR_VERSION != (0U)))
//     #error "Version numbers of Can_Cfg.c and Can.h are inconsistent!"
// #endif
 *  GLOBAL DATA
#define CAN_START_SEC_CONFIG_DATA
#include "Can_MemMap.h"
/* Baud Rate Structure for all configsets */
CAN_CONFIG_DATA_SECTION_NON_CONST static Can_BaudConfigType
    CanConfigSet_CanController_0_CanControllerBaudrateConfig_0 =
    500U,      /* in Kbps */
    8U,       /* Prop Segement value */
    7U,          /* Phase Segment 1 */
    4U,          /* Phase Segment 2 */
    2U, /* Sync jump width */
    19U,  /* Sum of all timing parameters  */
    8U,   /* Controller BRP value for Baud */
	 /* Data phase Baudrate */
        5000U,     /* in Kbps */
        1U,        /* Prop Segement value */
        1U,           /* Phase Segment 1 */
        1U,           /* Phase Segment 2 */
        5U,  /* Sum of all timing parameters  */
        4U,   /* Controller BRP value for Baud */
        180U, /* Specifies the Transceiver Delay Compensation Offset in ns */
        (boolean)FALSE, /* Specifies if the bit rate switching shall be used */
    CanConfigSet_CanController_1_CanControllerBaudrateConfig_0 =
    500U,      /* in Kbps */
        500U,     /* in Kbps */
        2U,        /* Prop Segement value */
        2U,           /* Phase Segment 1 */
        3U,           /* Phase Segment 2 */
        1U,  /* Sync jump width */
        8U,  /* Sum of all timing parameters  */
    CanConfigSet_CanController_2_CanControllerBaudrateConfig_0 =
    500U,      /* in Kbps */
/*List of the Baudrate structures */
    *CanConfigSet_CanController_0_BaudRateConfigList[]=
    &CanConfigSet_CanController_0_CanControllerBaudrateConfig_0,
    *CanConfigSet_CanController_1_BaudRateConfigList[]=
    &CanConfigSet_CanController_1_CanControllerBaudrateConfig_0,
    *CanConfigSet_CanController_2_BaudRateConfigList[]=
    &CanConfigSet_CanController_2_CanControllerBaudrateConfig_0,
/* Controller structure defined here for all config sets */
CAN_CONFIG_DATA_SECTION_NON_CONST static Can_ControllerType
    CanConfigSet_CanController_0 =
    &CanConfigSet_CanController_0_CanControllerBaudrateConfig_0,  /* pointer to default Baud structure */
    CanConfigSet_CanController_0_BaudRateConfigList,  /* List of available Baudrate structs */
    CanConfigSet_CanController_1 =
    &CanConfigSet_CanController_1_CanControllerBaudrateConfig_0,  /* pointer to default Baud structure */
    CanConfigSet_CanController_1_BaudRateConfigList,  /* List of available Baudrate structs */
    CanConfigSet_CanController_2 =
    &CanConfigSet_CanController_2_CanControllerBaudrateConfig_0,  /* pointer to default Baud structure */
    CanConfigSet_CanController_2_BaudRateConfigList,  /* List of available Baudrate structs */
CAN_CONFIG_DATA_SECTION_CONST const struct Can_ControllerStruct_PC
    CanConfigSet_PC_CanController_0 =
    CanConf_CanController_CanController_0,      /* Id as provided by GUI */
    (boolean)TRUE,   /* Contoller is used=1 or not_used=0*/
    0x40500000U, /* Can Controller Base Address */
    CAN_TX_RX_PROCESSING_INTERRUPT,  /* Can Rx Processing Type */
    CAN_TX_RX_PROCESSING_INTERRUPT,  /* Can Tx Processing Type */
    (boolean)TRUE,/* BusOff  TRUE = Interrupt FALSE = Polling */
	CAN_CONTROLLER_INSTANCE_MCU_MCAN0,  /* Controller Instance */
	(boolean)TRUE,  /* CAN FD Mode Enable */
    CanConfigSet_PC_CanController_1 =
    CanConf_CanController_CanController_1,      /* Id as provided by GUI */
    0x40540000U, /* Can Controller Base Address */
	CAN_CONTROLLER_INSTANCE_MCU_MCAN1,  /* Controller Instance */
	(boolean)FALSE,  /* CAN FD Mode Enable */
    CanConfigSet_PC_CanController_2 =
    CanConf_CanController_CanController_2,      /* Id as provided by GUI */
    0x2708000U, /* Can Controller Base Address */
	CAN_CONTROLLER_INSTANCE_MCAN0,  /* Controller Instance */
/*List of the Controller structures */
    *CanConfigSet_CanController_List[]=
    &CanConfigSet_CanController_0,
    &CanConfigSet_CanController_1,
    &CanConfigSet_CanController_2,
    *CanConfigSet_CanController_List_PC[CAN_NUM_CONTROLLER]=
    &CanConfigSet_PC_CanController_0,
    &CanConfigSet_PC_CanController_1,
    &CanConfigSet_PC_CanController_2,
/* HW Filter structure for all configsets */
CAN_CONFIG_DATA_SECTION_NON_CONST static Can_HwFilterType
    CanConfigSet_CanHardwareObject_3_CanHwFilter_0 =
    177U,  /*CanHwFilterCode*/
    4294967295U,  /*Filter Mask*/
    CanConfigSet_CanHardwareObject_4_CanHwFilter_0 =
    176U,  /*CanHwFilterCode*/
    CanConfigSet_CanHardwareObject_5_CanHwFilter_0 =
    160U,  /*CanHwFilterCode*/
    CanConfigSet_CanHardwareObject_6_CanHwFilter_0 =
    193U,  /*CanHwFilterCode*/
    CanConfigSet_CanHardwareObject_8_CanHwFilter_0 =
    192U,  /*CanHwFilterCode*/
/*List of the HW Filter structures */
    *CanConfigSet_CanHardwareObject_3_HwFilterConfigList[]=
    &CanConfigSet_CanHardwareObject_3_CanHwFilter_0,
    *CanConfigSet_CanHardwareObject_4_HwFilterConfigList[]=
    &CanConfigSet_CanHardwareObject_4_CanHwFilter_0,
    *CanConfigSet_CanHardwareObject_5_HwFilterConfigList[]=
    &CanConfigSet_CanHardwareObject_5_CanHwFilter_0,
    *CanConfigSet_CanHardwareObject_6_HwFilterConfigList[]=
    &CanConfigSet_CanHardwareObject_6_CanHwFilter_0,
    *CanConfigSet_CanHardwareObject_8_HwFilterConfigList[]=
    &CanConfigSet_CanHardwareObject_8_CanHwFilter_0,
/* All the Mailbox objects(MB's) will be defined here for all config sets */
CAN_CONFIG_DATA_SECTION_NON_CONST static Can_MailboxType
    CanConfigSet_CanHardwareObject_0 =
    0U,  /*  CanHandleType 0=Full, 1=Basic */
    0U,  /* CanIdType 0=standard 1=Extended 2=Mixed*/
	0U,  /* HwHandle i.e Mailbox - Hw object in the controller */
    1U,   /* Length of the Mailbox */
    CAN_MAILBOX_DIRECTION_TX,  /* CanObjectType - Direction of Mailbox*/
    &CanConfigSet_PC_CanController_0,  /* Controller */
	NULL_PTR,  /* List of HW Filter structs */
    0U,   /* Hw Filter Count */
    204U,   /* Padding value for CAN FD message */
	(boolean)FALSE,   /* CanHardwareObjectUsesPolling */
    CanConfigSet_CanHardwareObject_1 =
    1U,  /* CanIdType 0=standard 1=Extended 2=Mixed*/
    3U,   /* Length of the Mailbox */
    CanConfigSet_CanHardwareObject_2 =
    &CanConfigSet_PC_CanController_1,  /* Controller */
    CanConfigSet_CanHardwareObject_3 =
    CAN_MAILBOX_DIRECTION_RX,  /* CanObjectType - Direction of Mailbox*/
    CanConfigSet_CanHardwareObject_3_HwFilterConfigList,  /* List of HW Filter structs */
    1U, /* Hw Filter Count */
    0U,   /* Padding value for CAN FD message */
    CanConfigSet_CanHardwareObject_4 =
    CanConfigSet_CanHardwareObject_4_HwFilterConfigList,  /* List of HW Filter structs */
    CanConfigSet_CanHardwareObject_5 =
    CanConfigSet_CanHardwareObject_5_HwFilterConfigList,  /* List of HW Filter structs */
    CanConfigSet_CanHardwareObject_6 =
    2U,   /* Length of the Mailbox */
    CanConfigSet_CanHardwareObject_6_HwFilterConfigList,  /* List of HW Filter structs */
    CanConfigSet_CanHardwareObject_7 =
    &CanConfigSet_PC_CanController_2,  /* Controller */
    CanConfigSet_CanHardwareObject_8 =
    CanConfigSet_CanHardwareObject_8_HwFilterConfigList,  /* List of HW Filter structs */
CAN_CONFIG_DATA_SECTION_CONST static const struct Can_MailboxStruct_PC
    CanConfigSet_PC_CanHardwareObject_0 =
    CanConf_CanHardwareObject_CanHardwareObject_0,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_1 =
    CanConf_CanHardwareObject_CanHardwareObject_1,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_2 =
    CanConf_CanHardwareObject_CanHardwareObject_2,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_3 =
    CanConf_CanHardwareObject_CanHardwareObject_3,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_4 =
    CanConf_CanHardwareObject_CanHardwareObject_4,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_5 =
    CanConf_CanHardwareObject_CanHardwareObject_5,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_6 =
    CanConf_CanHardwareObject_CanHardwareObject_6,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_7 =
    CanConf_CanHardwareObject_CanHardwareObject_7,  /* CanObjectId - Holds handle Id */
    CanConfigSet_PC_CanHardwareObject_8 =
    CanConf_CanHardwareObject_CanHardwareObject_8,  /* CanObjectId - Holds handle Id */
/* List of the Mailboxes */
    *CanConfigSet_CanHardwareObject_List[] =
    &CanConfigSet_CanHardwareObject_0,
    &CanConfigSet_CanHardwareObject_1,
    &CanConfigSet_CanHardwareObject_2,
    &CanConfigSet_CanHardwareObject_3,
    &CanConfigSet_CanHardwareObject_4,
    &CanConfigSet_CanHardwareObject_5,
    &CanConfigSet_CanHardwareObject_6,
    &CanConfigSet_CanHardwareObject_7,
    &CanConfigSet_CanHardwareObject_8,
CAN_CONFIG_DATA_SECTION_CONST const struct Can_MailboxStruct_PC
    *CanConfigSet_CanHardwareObject_List_PC[CAN_NUM_MAILBOXES] =
    &CanConfigSet_PC_CanHardwareObject_0,
    &CanConfigSet_PC_CanHardwareObject_1,
    &CanConfigSet_PC_CanHardwareObject_2,
    &CanConfigSet_PC_CanHardwareObject_3,
    &CanConfigSet_PC_CanHardwareObject_4,
    &CanConfigSet_PC_CanHardwareObject_5,
    &CanConfigSet_PC_CanHardwareObject_6,
    &CanConfigSet_PC_CanHardwareObject_7,
    &CanConfigSet_PC_CanHardwareObject_8,
/*Can Config struct */
CAN_CONFIG_DATA_SECTION_CONST const struct Can_ConfigType_s CanConfigSet =
    CanConfigSet_CanController_List, /* Controller List Pointer */
    (3U),  /* max Controllers */
    CanConfigSet_CanHardwareObject_List, /* Mailbox List Pointer */
    (9U),/* total number of mail boxes in this configset */
    .MaxBaudConfigID =
        [0] = 0U,
        [1] = 0U,
        [2] = 0U
    }, /* Baud rate structure id */
    NULL_PTR,  /* Reserved Param used for future use */
CAN_VAR_CONST_32_SECTION extern CONST(uint32, CAN_CONST)
    Can_MsgmemRAMBaseAddr[CAN_MAX_CONTROLLER] =
    0x40500000U, /* MCU MCAN0 */
    0x40540000U, /* MCU MCAN1 */
    0x2708000U, /* Main MCAN0 */
    0x2718000U, /* Main MCAN1 */
    0x2728000U, /* Main MCAN2 */
    0x2738000U, /* Main MCAN3 */
    0x2748000U, /* Main MCAN4 */
    0x2758000U, /* Main MCAN5 */
    0x2768000U, /* Main MCAN6 */
    0x2778000U, /* Main MCAN7 */
    0x2788000U, /* Main MCAN8 */
    0x2798000U, /* Main MCAN9 */
    0x27a8000U, /* Main MCAN10 */
    0x27b8000U, /* Main MCAN11 */
    0x27c8000U, /* Main MCAN12 */
    0x27d8000U, /* Main MCAN13 */
    Can_MCANSSBaseAddr[CAN_MAX_CONTROLLER] =
    0x40520000U, /* MCU_MCAN0_SS */
    0x40560000U, /* MCU_MCAN1_SS*/
    0x2700000U, /* MCAN0_SS */
    0x2710000U, /* MCAN1_SS*/
    0x2720000U, /* MCAN2_SS */
    0x2730000U, /* MCAN3_SS */
    0x2740000U, /* MCAN4_SS */
    0x2750000U, /* MCAN5_SS */
    0x2760000U, /* MCAN6_SS */
    0x2770000U, /* MCAN7_SS */
    0x2780000U, /* MCAN8_SS*/
    0x2790000U, /* MCAN9_SS*/
    0x27a0000U, /* MCAN10_SS */
    0x27b0000U, /* MCAN11_SS */
    0x27c0000U, /* MCAN12_SS*/
    0x27d0000U, /* MCAN13_SS */
    Can_MCANCoreRegBaseAddr[CAN_MAX_CONTROLLER] =
    0x40528000U, /* MCU_MCAN0_CFG */
    0x40568000U, /* MCU_MCAN1_CFG*/
    0x2701000U, /* MCAN0_CFG */
    0x2711000U, /* MCAN1_CFG*/
    0x2721000U, /* MCAN2_CFG */
    0x2731000U, /* MCAN3_CFG */
    0x2741000U, /* MCAN4_CFG */
    0x2751000U, /* MCAN5_CFG */
    0x2761000U, /* MCAN6_CFG */
    0x2771000U, /* MCAN7_CFG */
    0x2781000U, /* MCAN8_CFG*/
    0x2791000U, /* MCAN9_CFG*/
    0x27a1000U, /* MCAN10_CFG */
    0x27b1000U, /* MCAN11_CFG */
    0x27c1000U, /* MCAN12_CFG*/
    0x27d1000U, /* MCAN13_CFG */
    Can_MCANECCAggrRegBaseAddr[CAN_MAX_CONTROLLER] =
    0x40700000U, /* MCU_MCAN0_ECC_AGGR */
    0x40701000U, /* MCU_MCAN1_ECC_AGGR*/
    0x2A78000U, /* MCAN0_ECC_AGGR */
    0x2A79000U, /* MCAN1_ECC_AGGR */
    0x2A7A000U, /* MCAN2_ECC_AGGR*/
    0x2A7B000U, /* MCAN3_ECC_AGGR */
    0x2A7C000U, /* MCAN4_ECC_AGGR */
    0x2A7D000U, /* MCAN5_ECC_AGGR */
    0x2A7E000U, /* MCAN6_ECC_AGGR */
    0x2A7F000U, /* MCAN7_ECC_AGGR */
    0x2A40000U, /* MCAN8_ECC_AGGR */
    0x2A41000U, /* MCAN9_ECC_AGGR*/
    0x2A42000U, /* MCAN10_ECC_AGGR*/
    0x2A43000U, /* MCAN11_ECC_AGGR */
    0x2A44000U, /* MCAN12_ECC_AGGR */
    0x2A45000U, /* MCAN13_ECC_AGGR*/
#define  CAN_STOP_SEC_CONFIG_DATA
/*                          Function Definitions                              */
#define CAN_START_SEC_ISR_CODE
/** \brief MCU_MCAN0 Controller Instance ISR */
FUNC(void, CAN_CODE) Can_0_Int0ISR(void)
Can_IntISR_Function(CAN_CONTROLLER_INSTANCE_MCU_MCAN0, 0x40500000U);
/** \brief MCU_MCAN1 Controller Instance ISR */
FUNC(void, CAN_CODE) Can_1_Int0ISR(void)
Can_IntISR_Function(CAN_CONTROLLER_INSTANCE_MCU_MCAN1, 0x40540000U);
/** \brief MCAN0 Controller Instance ISR */
FUNC(void, CAN_CODE) Can_2_Int0ISR(void)
Can_IntISR_Function(CAN_CONTROLLER_INSTANCE_MCAN0, 0x2708000U);
#define CAN_STOP_SEC_ISR_CODE
 *  End of File: Can_Cfg.c
