Part Number: AM3354
TI工程师:你好!
AM3354处理器,最近升级了NandFlash,型号:MT29F8G08ABACAWP‐IT:C。uboot 和linux均可以正常启动,进入linux命令行报如下错误。 ECC 用 bch16 。
[ 22.820095] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.826433] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.832663] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.843072] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.856804] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.863069] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.873170] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.883136] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 22.892244] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 160 bytes from PEB 1754:58784, read only 160 bytes, retry
[ 23.020079] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.026457] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.032691] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.043796] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.061303] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.110077] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.151375] omap2-nand 8000000.nand: uncorrectable bit-flips found
[ 23.182113] omap2-nand 8000000.nand: uncorrectable bit-flips found
之前论坛也有其他工程提出类似问题,可能由于时间关系,相关链接已经失效。请帮忙提供解决方法。
之前相关问题链接:
