dei0 dei1 dei2都是bypass
dei0和dei2 每个 都输入2路1080p数据,输出一路1080p和cif数据
dei1处理一路1080p数据,输出一路1080p和cif数据
发现dei0和dei2的延时很大 dei1延时较小 ,结果如下
[m3vpss ] *** [DEI0 ] DEI Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time : 80 secs
[m3vpss ] Total Fields Processed : 644679
[m3vpss ] Total Fields FPS : 128 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max
[m3vpss ] -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 30 0 30 15 30 0 0 0 0 0 0 0 0 15 0 0 0 0 174 & 321 MMM
[m3vpss ] 1 | 30 0 30 15 30 0 0 0 0 0 0 0 0 15 0 0 0 0 170 & 319 MMM
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [DEI2 ] DEI Statistics ***
[m3vpss ]
[m3vpss ] Total Fields Processed : 322701
[m3vpss ] Total Fields FPS : 125 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 30 0 30 15 30 0 0 0 0 0 0 0 0 15 0 0 0 0 15 & 32 MMM
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [DEI1 ] DEI Statistics ***
[m3vpss ]
[m3vpss ] Total Fields Processed : 644568
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 30 0 30 15 30 0 0 0 0 0 0 0 0 15 0 0 0 0 196 & 321 MMM
[m3vpss ] 1 | 30 0 30 15 30 0 0 0 0 0 0 0 0 15 0 0 0 0 203 & 328 MMM
