我看例子里uart的串口模式是dma传输完成后都需要清零一次,可以不清零,然串口一直在dma模式吗?
我试了在初始化时配置成dma+fifo,后面不清零,然后,收到的数据就不能再发送了?
需要清。
The UART’s FIFO/THR is emptied before the UART DMA mode or eDMA event has been disabled. The UART has sent a DMA request and is waiting for data from the eDMA. The eDMA has processed this DMA request. However, the next paramSet is a Dummy Transfer. Therefore, the eDMA does not transfer any data to the UART. When the UART DMA mode is disabled and re-enabled, there has not been any change in the status of the UART FIFO/THR. As such, the UART does not re-issue a DMA request. This is how the UART IP was designed. Unfortunately, there are no bits in the UART that indicate whether a DMA request is still outstanding.
