AM3352: 使用SDK-08.02.00.24 开发u-boot下相关问题
Part Number: AM3352
您好:
  目前使用SDK8.02版本进行AM3352开发,遇到如下问题,还请各位工程师帮忙解答,感谢:
  1. U-BOOT下,写入和读取nand速度慢,写入大概只有360KB/S,读取大概960KB/S,已开启CONFIG_NAND_OMAP_GPMC_PREFETCH,和CONFIG_CMD_CACHE,但是速度没有太大提升;在kernel下速度很快,启动log如下:
CCC
U-Boot SPL 2021.01-00001-gc59bf25a38-dirty (Nov 29 2023 - 13:54:05 +0800)
Trying to boot from NAND
nand: using OMAP_ECC_BCH16_CODE_HW
use GPMC prefetch read.
Loading element from 0x00080000 (size 0x00000040) to 0x80800000
(持续打印:uncorrectable ECC errors)
U-Boot 2021.01-00001-gc59bf25a38-dirty (Nov 29 2023 - 13:54:05 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM: 512 MiB
Setting QCA7000 and wifi&ble power
WDT: Started with servicing (60s timeout)
NAND: nand: using OMAP_ECC_BCH16_CODE_HW
nand_base: device found, Manufacturer ID: 0x2c, Chip ID: 0x48
nand_base: Micron MT29F16G08ABACAWP
nand_base: 2048 MiB, SLC, erase size: 512 KiB, page size: 4096, OOB size: 224
2048 MiB
  2. U-BOOT下使用TFTP下载速度慢,速度大概只有1MB/S,进kernel后网络下载速度很快
link up on port 0, speed 100, full duplex
Using ethernet@4a100000 device
TFTP from server 192.168.0.8; our IP address is 192.168.0.10
Filename 'zImage.bin'.
Load address: 0x82000000
Loading: #################################################################
1 MiB/s
done
Bytes transferred = 5239296 (4ff200 hex)
  3. 在u-boot下下载rootfs到nand中,如果文件系统大于256M或者大文件写入(没有超过450M),nand写入失败,报错显示:
nand: error: invalid bit-flip location
 其他信息:
nand info:
=> nand info
Device 0: nand0, sector size 512 KiB
Page size 4096 b
OOB size 224 b
Erase size 524288 b
subpagesize 1024 b
options 0x4000400c
bbt options 0x00000000
nand配置:
/* NAND: device related configs */
#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_PAGE_COUNT  (CONFIG_SYS_NAND_BLOCK_SIZE / \
                     CONFIG_SYS_NAND_PAGE_SIZE)
#define CONFIG_SYS_NAND_PAGE_SIZE   4096
#define CONFIG_SYS_NAND_OOBSIZE     224
#define CONFIG_SYS_NAND_BLOCK_SIZE  (512*1024)
/* NAND: driver related configs */
#define CONFIG_SYS_NAND_BAD_BLOCK_POS   NAND_LARGE_BADBLOCK_POS
#define CONFIG_SYS_NAND_ECCPOS      {   \
             2,   3,   4,   5,   6,   7,   8,   9, \
             10,  11,  12,  13,  14,  15,  16,  17,  18,  19, \
             20,  21,  22,  23,  24,  25,  26,  27,  28,  29, \
             30,  31,  32,  33,  34,  35,  36,  37,  38,  39, \
             40,  41,  42,  43,  44,  45,  46,  47,  48,  49, \
             50,  51,  52,  53,  54,  55,  56,  57,  58,  59, \
             60,  61,  62,  63,  64,  65,  66,  67,  68,  69, \
             70,  71,  72,  73,  74,  75,  76,  77,  78,  79, \
             80,  81,  82,  83,  84,  85,  86,  87,  88,  89, \
             90,  91,  92,  93,  94,  95,  96,  97,  98,  99, \
            100, 101, 102, 103, 104, 105, 106, 107, 108, 109, \
            110, 111, 112, 113, 114, 115, 116, 117, 118, 119, \
            120, 121, 122, 123, 124, 125, 126, 127, 128, 129, \
            130, 131, 132, 133, 134, 135, 136, 137, 138, 139, \
            140, 141, 142, 143, 144, 145, 146, 147, 148, 149, \
            150, 151, 152, 153, 154, 155, 156, 157, 158, 159, \
            160, 161, 162, 163, 164, 165, 166, 167, 168, 169, \
            170, 171, 172, 173, 174, 175, 176, 177, 178, 179, \
            180, 181, 182, 183, 184, 185, 186, 187, 188, 189, \
            190, 191, 192, 193, 194, 195, 196, 197, 198, 199, \
            200, 201, 202, 203, 204, 205, 206, 207, 208, 209, \
#define CONFIG_SYS_NAND_ECCSIZE     512
#define CONFIG_SYS_NAND_ECCBYTES    26
#define CONFIG_SYS_NAND_ONFI_DETECTION
#define CONFIG_NAND_OMAP_ECCSCHEME  OMAP_ECC_BCH16_CODE_HW
  • Hi,
    我们向资深的工程师确认下给您答复。
    Thanks
  • Hi,
    @u-boot vs @kernel 之间GPMC-NAND RD/WR访问的速度差值是由于@kernel使用了DMA,而不是@u-boot.
    Thanks
  • 我了解,但是在u-boot上速度那么慢不应该把,同时SPL跳转到U-BOOT一直报ECC错误应该也不正常,还请帮忙查看一下?感谢!
  • 我尝试使用如下链接:https://e2echina.ti.com/support/processors/f/processors-forum/164012/am335x-nadn
    将NAND_GPMC_CONFIG从:
    // #define M_NAND_GPMC_CONFIG1  0x00000800
    // #define M_NAND_GPMC_CONFIG2  0x001e1e00
    // #define M_NAND_GPMC_CONFIG3  0x001e1e00
    // #define M_NAND_GPMC_CONFIG4  0x16051807
    // #define M_NAND_GPMC_CONFIG5  0x00151e1e
    // #define M_NAND_GPMC_CONFIG6  0x16000f80
    // #define M_NAND_GPMC_CONFIG7  0x00000008
    #define M_NAND_GPMC_CONFIG1 ( GPMCFCLKDIVIDER(0) | 0 /* TIMEPARAGRANULARITY */ | 0 /* MUXADDDATA */ | \
                                  DEVICETYPE_NAND | DEVICESIZE_8BIT | WAITPINSELECT(0) | WAITMONITORINGTIME(0) | \
                                  0 /* WAITWRITEMONITORING */ | 0 /* WAITREADMONITORING */ | ATTACHEDDEVICEPAGELENGTH(0) | \
                                  CLKACTIVATIONTIME(0) | 0 /* WRITETYPE */ | 0 /* WRITEMULTIPLE */ | 0 /* READTYPE */ | \
                                  0 /* READMULTIPLE */ | 0 /* WRAPBURST */ )
    /* CONFIG2: Chip Select */
    #define M_NAND_GPMC_CONFIG2 (CSWROFFTIME(_CSWOFF) | CSRDOFFTIME(_CSROFF) | CSONTIME(0) | 0 /* CSEXTRADELAY */ )
    /* CONFIG3: ADV/ALE */
    #define M_NAND_GPMC_CONFIG3 ( ADVWROFFTIME(_ADWOFF) | ADVRDOFFTIME(_ADROFF) | 0 /* ADVEXTRADELAY */ | ADVONTIME(_ADON) )
    /* CONFIG4: WE/OE */
    #define M_NAND_GPMC_CONFIG4 ( WEOFFTIME(_WEOFF) | 0 /* WEEXTRADELAY */ | WEONTIME(_WEON) | \
        OEOFFTIME(_OEOFF) | 0 /* OEEXTRADELAY */ | OEONTIME(_OEON) )
    /* CONFIG5: Cycle Timing */
    #define M_NAND_GPMC_CONFIG5 ( PAGEBURSTACCESSTIME(0) | RDACCESSTIME(_RDACC) | WRCYCLETIME(_WRCY) | RDCYCLETIME(_RDCY) )
    /* CONFIG6: Rest of the Pack */
    #define M_NAND_GPMC_CONFIG6 ( WRACCESSTIME(_WRACC) | (((_WBURST) &  0xf) << 16) | CYCLE2CYCLEDELAY(_CSHIGH) | \
                                 (1 << 7) | 0 /* CYCLE2CYCLEDIFFCSEN */ | BUSTURNAROUND(_BTURN) )
    /* CONFIG7: Address Mapping */
    #define M_NAND_GPMC_CONFIG7 MASKADDRESS(0x00) | (1 << 6) | BASEADDRESS(0x0)
    可有效提升NAND读写速度,修改后读取速度为:读:2.7MB/S, 写: 600KB/S;
    从测试上来看,似乎并没有从设备树上加载GPMC相关配置参数?
  • 好的感谢您提供的信息,我们看下后给到您答复哈。
  • 您好,
    除了 DMA 之外,NAND 器件 AC 参数调整、和 GPMC-NAN""Prefetch and Write-Posting Engine" "也可以帮助优化 GPMC-NAND 性能。
  • 您好,可以提供相关解决方案解决ECC错误这个问题吗?还有就是有相关U-BOOT 下 NAND使用DMA的示例吗?感谢!
  • 您好,
    方便分享下完整的boot log吗?
    Thanks
  • boot log:
    CCCCCCCC
    U-Boot SPL 2021.01-00004-g221b7b9eda-dirty (Dec 07 2023 - 15:18:30 +0800)
    omap-elm: uncorrectable ECC errors
    U-Boot 2021.01-00004-g221b7b9eda-dirty (Dec 07 2023 - 15:18:30 +0800)
    DRAM: 512 MiB
    2048 MiB
    Loading Environment from NAND... Scanning device for bad blocks
    Bad eraseblock 90 at 0x000002d00000
    Bad eraseblock 91 at 0x000002d80000
    [854]NAND read process: offset: 0x00280000, size: 0x00080000
    [1043]Nand read size: 524288, use time:189ms, read speed: 2705kB/s
    *** Warning - bad CRC, using default environment
    <ethaddr> not set. Validating first E-fuse MAC
    Net: DEBUG: modename: ti,am3352-cpsw-phy-sel, mode: 6
    DEBUG: cpsw_gmii_sel_am3352, mode: 6
    DEBUG: cpsw_gmii_sel_am3352, extern clk
    eth2: ethernet@4a100000, eth3: usb_ether
    Hit any key to stop autoboot: 0
    nand 写入异常log:
    NAND write: device 0 offset 0xd80000, size 0x14680000
    [4023370]NAND write process: offset: 0x00d80000, size: 0x14680000
    Skip bad block 0x02d00000
    Skip bad block 0x02d80000
    [4344265]NAND write to offset 0x12d80000 failed -5
    300417024 bytes written: ERROR
  • Hi,
    在使用 SDK 8.2的 NAND boot上发现一个问题。
    您这边能否升级到最新的 SDK 9.1?
    https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM335X/09.01.00.001
    以下两个修补程序需要应用于 SDK 9.1:
    1. mtd: nand: omap_gpmc: Fix NAND in SPL for AM335x
    git.ti.com/.../
    2. mtd: rawnand: omap_elm: Fix elm_init definition
    git.ti.com/.../
    Thanks
  • HI,
    我使用过SDK9.1的版本,但是SPL无法跳转到u-boot中,同时使用SDK8.2的SPL可以跳转到SDK9.1 的u-boot,使用SDK9.1的u-boot一样无法大文件写入,当大文件写入会触发芯片crash重启,nand写入速度没有提升。
  • 好的我们看下再给您答复。
  • Hi,
    请看上一条答复哦:
    git.ti.com/.../
    git.ti.com/.../
    Thanks
    Thanks
  • Hi, 感谢答复,使用最新的SDK9.1后SPL跳转U-BOOT没有报ECC错误了,但是nand文件写入仍有问题,还请帮忙查看,感谢!
    以下为LOG数据:
    => run uprootfs
    Filename 'am335xubiaa'.
    Loading: ################################################# 256 MiB
    1.5 MiB/s
    done
    Bytes transferred = 268435456 (10000000 hex)
    NAND erase.part: device 0 offset 0xd80000, size 0x7f280000
    Skipping bad block at 0x02d00000
    Skipping bad block at 0x02d80000
    Erasing at 0x7ff80000 -- 100% complete.
    OK
    NAND write: device 0 offset 0xd80000, size 0x10000000
    [642544]NAND write process: offset: 0x00d80000, size: 0x10000000
    [942579]NAND write to offset 0x10e80000 finish
    [942591]Nand write size: 0, use time:300046ms, write speed: 874kB/s
    268435456 bytes written: OK
    Filename 'am335xubiab'.
    Loading: ################################################## 70.5 MiB
    1.5 MiB/s
    done
    Bytes transferred = 73924608 (4680000 hex)
    NAND write: device 0 offset 0x10e80000, size 0x4680000
    [1080334]NAND write process: offset: 0x10e80000, size: 0x04680000
    data abort
    pc : [<9ff91094>] lr : [<9ff90a57>]
    reloc pc : [<8082f094>] lr : [<8082ea57>]
    sp : 9decd3a8 ip : 00000002 fp : 9def0500
    r10: 00000002 r9 : 9dee1ea0 r8 : 9dee79e8
    r7 : 9ffeb554 r6 : 9ffeaff0 r5 : 9dee8068 r4 : 9def0500
    r3 : 00000000 r2 : 9ffeb5d4 r1 : 9dee79f5 r0 : 07ff0002
    Flags: nZCv IRQs off FIQs on Mode SVC_32 (T)
    Code: f3bf 8f5f 4a0c 6813 (6218) 69db
    Resetting CPU ...
    CCCCCCCCg ...
    U-Boot SPL 2023.04-dirty (Dec 13 2023 - 17:41:11 +0800)
    GPMC use prefetch
    U-Boot 2023.04-dirty (Dec 13 2023 - 17:41:11 +0800)
    DRAM: 512 MiB
    Core: 152 devices, 16 uclasses, devicetree: separate
  • 好的我们看下后给您答复。
  • 您好,
    给您附上以下使用SDK 9.1 +以上回复中列出的两个最新patches时, 在AM335x GP EVM 上的NAND flashing log。
    -其中"nand write..." @u-boot 在将 u-boot 二进制文件刷写到 NAND 时正常工作。
    U-Boot SPL 2023.04-00001-ga6b09c3a4c-dirty (Dec 07 2023 - 14:29:54 -0600)
    Trying to boot from MMC1
    U-Boot 2023.04-00001-ga6b09c3a4c-dirty (Dec 07 2023 - 14:29:54 -0600)
    DRAM:  1 GiB
    Core:  156 devices, 17 uclasses, devicetree: separate
    WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
    NAND:  256 MiB
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
    Net:   eth2: ethernet@4a100000, eth3: usb_ether
    Hit any key to stop autoboot:  2  0
    => mtdparts
    device nand0 <nand.0>, # parts = 10
     #: name		size		offset		mask_flags
     0: NAND.SPL            0x00020000	0x00000000	0
     1: NAND.SPL.backup1    0x00020000	0x00020000	0
     2: NAND.SPL.backup2    0x00020000	0x00040000	0
     3: NAND.SPL.backup3    0x00020000	0x00060000	0
     4: NAND.u-boot-spl-os  0x00040000	0x00080000	0
     5: NAND.u-boot         0x00100000	0x000c0000	0
     6: NAND.u-boot-env     0x00020000	0x001c0000	0
     7: NAND.u-boot-env.backup10x00020000	0x001e0000	0
     8: NAND.kernel         0x00800000	0x00200000	0
     9: NAND.file-system    0x0f600000	0x00a00000	0
    active partition: nand0,0 - (NAND.SPL) 0x00020000 @ 0x00000000
    defaults:
    mtdids  : nand0=nand.0
    mtdparts: mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)
    => nand info
    Device 0: nand0, sector size 128 KiB
      Page size         2048 b
      OOB size            64 b
      Erase size      131072 b
      ecc strength         8 bits
      ecc step size      512 b
      subpagesize        512 b
      options       0x0000400c
      bbt options   0x00008000
    => nand erase.chip
    NAND erase.chip: device 0 whole chip
    Erasing at 0x0 --   0% complete.
    Erasing at 0x280000 --   1% complete.
    Erasing at 0x500000 --   2% complete.
    Erasing at 0x7a0000 --   3% complete.
    Erasing at 0xa20000 --   4% complete.
    Erasing at 0xcc0000 --   5% complete.
    Erasing at 0xf40000 --   6% complete.
    Erasing at 0x11e0000 --   7% complete.
    Erasing at 0x1460000 --   8% complete.
    Erasing at 0x1700000 --   9% complete.
    Erasing at 0x1980000 --  10% complete.
    Erasing at 0x1c20000 --  11% complete.
    Erasing at 0x1ea0000 --  12% complete.
    Erasing at 0x2140000 --  13% complete.
    Erasing at 0x23c0000 --  14% complete.
    Erasing at 0x2660000 --  15% complete.
    Erasing at 0x28e0000 --  16% complete.
    Erasing at 0x2b80000 --  17% complete.
    Erasing at 0x2e00000 --  18% complete.
    Erasing at 0x30a0000 --  19% complete.
    Erasing at 0x3320000 --  20% complete.
    Erasing at 0x35c0000 --  21% complete.
    Erasing at 0x3840000 --  22% complete.
    Erasing at 0x3ae0000 --  23% complete.
    Erasing at 0x3d60000 --  24% complete.
    Erasing at 0x3fe0000 --  25% complete.
    Erasing at 0x4280000 --  26% complete.
    Erasing at 0x4500000 --  27% complete.
    Erasing at 0x47a0000 --  28% complete.
    Erasing at 0x4a20000 --  29% complete.
    Erasing at 0x4cc0000 --  30% complete.
    Erasing at 0x4f40000 --  31% complete.
    Erasing at 0x51e0000 --  32% complete.
    Erasing at 0x5460000 --  33% complete.
    Erasing at 0x5700000 --  34% complete.
    Erasing at 0x5980000 --  35% complete.
    Erasing at 0x5c20000 --  36% complete.
    Erasing at 0x5ea0000 --  37% complete.
    Erasing at 0x6140000 --  38% complete.
    Erasing at 0x63c0000 --  39% complete.
    Erasing at 0x6660000 --  40% complete.
    Erasing at 0x68e0000 --  41% complete.
    Erasing at 0x6b80000 --  42% complete.
    Erasing at 0x6e00000 --  43% complete.
    Erasing at 0x70a0000 --  44% complete.
    Erasing at 0x7320000 --  45% complete.
    Erasing at 0x75c0000 --  46% complete.
    Erasing at 0x7840000 --  47% complete.
    Erasing at 0x7ae0000 --  48% complete.
    Erasing at 0x7d60000 --  49% complete.
    Erasing at 0x7fe0000 --  50% complete.
    Erasing at 0x8280000 --  51% complete.
    Erasing at 0x8500000 --  52% complete.
    Erasing at 0x87a0000 --  53% complete.
    Erasing at 0x8a20000 --  54% complete.
    Erasing at 0x8cc0000 --  55% complete.
    Erasing at 0x8f40000 --  56% complete.
    Erasing at 0x91e0000 --  57% complete.
    Erasing at 0x9460000 --  58% complete.
    Erasing at 0x9700000 --  59% complete.
    Erasing at 0x9980000 --  60% complete.
    Erasing at 0x9c20000 --  61% complete.
    Erasing at 0x9ea0000 --  62% complete.
    Erasing at 0xa140000 --  63% complete.
    Erasing at 0xa3c0000 --  64% complete.
    Erasing at 0xa660000 --  65% complete.
    Erasing at 0xa8e0000 --  66% complete.
    Erasing at 0xab80000 --  67% complete.
    Erasing at 0xae00000 --  68% complete.
    Erasing at 0xb0a0000 --  69% complete.
    Erasing at 0xb320000 --  70% complete.
    Erasing at 0xb5c0000 --  71% complete.
    Erasing at 0xb840000 --  72% complete.
    Erasing at 0xbae0000 --  73% complete.
    Erasing at 0xbd60000 --  74% complete.
    Erasing at 0xbfe0000 --  75% complete.
    Erasing at 0xc280000 --  76% complete.
    Erasing at 0xc500000 --  77% complete.
    Erasing at 0xc7a0000 --  78% complete.
    Erasing at 0xca20000 --  79% complete.
    Erasing at 0xccc0000 --  80% complete.
    Erasing at 0xcf40000 --  81% complete.
    Erasing at 0xd1e0000 --  82% complete.
    Erasing at 0xd460000 --  83% complete.
    Erasing at 0xd700000 --  84% complete.
    Erasing at 0xd980000 --  85% complete.
    Erasing at 0xdc20000 --  86% complete.
    Erasing at 0xdea0000 --  87% complete.
    Erasing at 0xe140000 --  88% complete.
    Erasing at 0xe3c0000 --  89% complete.
    Erasing at 0xe660000 --  90% complete.
    Erasing at 0xe8e0000 --  91% complete.
    Erasing at 0xeb80000 --  92% complete.
    Erasing at 0xee00000 --  93% complete.
    Erasing at 0xf0a0000 --  94% complete.
    Erasing at 0xf320000 --  95% complete.
    Erasing at 0xf5c0000 --  96% complete.
    Erasing at 0xf840000 --  97% complete.
    Erasing at 0xfae0000 --  98% complete.
    Erasing at 0xfd60000 --  99% complete.
    Erasing at 0xffe0000 -- 100% complete.
    OK
    => load mmc 0:1 ${loadaddr} MLO
    110364 bytes read in 13 ms (8.1 MiB/s)
    => nand write ${loadaddr} NAND.SPL ${filesize}
    NAND write: device 0 offset 0x0, size 0x1af1c
     110364 bytes written: OK
    => load mmc 0:1 ${loadaddr} u-boot.img
    1453536 bytes read in 101 ms (13.7 MiB/s)
    => nand write ${loadaddr} 0xC0000 ${filesize}
    NAND write: device 0 offset 0xc0000, size 0x162de0
     1453536 bytes written: OK
    => md.l 0x44e10040 1
    44e10040: 00400397                             ..@.
    Thanks
  • 你好,感谢答复,我们测试使用SDK8.2的,大文件写入NAND超过256M,会触发ECC error,但是使用分包即每次写入256M,是可以正常写入的;
    使用SDK9.1后,如果文件不超过256M,也可以正常写入,但是写完后,在写70M左右的数据后会触发reset,会是GPMC不支持NAND大容量写入吗?
    => run uprootfs
    1.5 MiB/s
    done
    OK
    268435456 bytes written: OK (写入256M没有问题)
    1.5 MiB/s
    done
    data abort(再继续写入70M数据,触发异常)
    Resetting CPU ...
  • 好的感谢您提供的信息,我们反馈给工程师看下,应该会在下周工作日给到您答复。
  • 您好,
    您说的使用分包即每次写入256M是什么意思?
    请问是否有在"SDK 9.1 +两个 u-boot patches"之上进行任何代码修改?
    您这边是否可以在kernel中测试 NAND 写入,来获取一些额外的数据点?
    Thanks
  • 您好,分包写入的意思就是:将文件系统按最大256M进行分包,如我现在使用的文件系统大小为:326M,那会分两个包一个是256M,另一个是70M,
    然后通过tftp进行下载并写入到nand里面:
    第一笔:
    1.5 MiB/s
    done
    第二笔:
    1.5 MiB/s
    done
    有做pin mux,board等相关函数修改,我现在的板子是没有eeprom的;
    这个我测试过write和read speed,写入或读取500M的数据是没有问题的,速度可以达到30M/S左右
  • 好的了解,我们确认下看看。
  • hi Cherry
     data abort问题找到了,主要是elm_cfg没有初始化,我在elm_config函数上增加数据打印发现elm_cfg没有初始化,数据为0;
    printf("elm config: 0x%X, ram address:0x%X\n", (u32)elm_cfg, (u32)&elm_cfg);
    elm config: 0x0, ram address:0x9FFE79D4
    在elm_init函数上同样增加数据打印,发现进入u-boot上没有有执行以下语句:
    void elm_init(void)
        elm_cfg = (struct elm *)ELM_BASE;
        elm_reset();
    执行的反而是inline void elm_init这个空函数:
    #ifdef ELM_BASE
    void elm_init(void);
    #else
    static inline void elm_init(void)
    #endif
    在去除宏定义,直接定义oid elm_init(void);函数后,nand可大文件写入,同时分包文件写入也不会触发data abort;
    应该是在omap_gpmc.c上引用omap_elm.h文件时,没有添加asm/arch/hardware.h文件,导致编译器条件编译inline那个空函数,我在omap_gpmc.c上修改如下后,可正常运行:
    #include <asm/arch/hardware.h>
    #include "omap_elm.h"
    如下测试多次,均为问题,供参考:
    => nand erase.part NAND.file-system
    OK
    => nand write 0x80200000 NAND.file-system 0x19000000
    NAND write: device 0 offset 0xd80000, size 0x19000000
    [828198]NAND write process: offset: 0x00d80000, size: 0x19000000
    [1294164]NAND write to offset 0x19e80000 finish
    [1294176]Nand write size: 0, use time:465978ms, write speed: 879kB/s
    419430400 bytes written: OK
    OK
    => nand write 0x80200000 NAND.file-system 0x1C200000
    NAND write: device 0 offset 0xd80000, size 0x1c200000
    [1825520]NAND write process: offset: 0x00d80000, size: 0x1c200000
    [2350011]NAND write to offset 0x1d080000 finish
    [2350024]Nand write size: 0, use time:524503ms, write speed: 878kB/s
    471859200 bytes written: OK
    => run uprootfs
    uprootfs uprootfs1
    => run uprootfs
    uprootfs uprootfs1
    => run uprootfs
    TFTP from server 192.168.0.8; our IP address is 192.68.0.10; sending through gateway 192.168.0.1
    Filename 'am335xubi.img'.
    Load address: 0x80200000
    Loading: *
    Abort
    => dhcp
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    Abort
    => setenv ipaddr 192.168.0.10
    => run uprootfs
    Loading: ################################################# 326.5 MiB
    6 MiB/s
    done
    Bytes transferred = 342360064 (14680000 hex)
    OK
    [4152044]NAND write process: offset: 0x00d80000, size: 0x14680000
    elm config: 0x48080000, ram address:0x9FFE79D4
    [4533866]NAND write to offset 0x15500000 finish
    [4533878]Nand write size: 0, use time:381833ms, write speed: 875kB/s
    342360064 bytes written: OK
    => <INTERRUPT>
    u-boot启动可以正常初始化elm_cfg指针:
    GPMC use prefetch
    目前测试nand写入速度可以达到2.5M/S,请问是否还有提升的空间?已经采用omap_prefetch_enable 写的操作。
  • Hi,
    好的问题找到了就好,关于写入速度是否能提升的问题我确认下给到您答复,英文论坛的链接给您也贴在这里:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1298750/am3352-develop-u-boot-using-sdk-08-02-00-24/4952868#4952868
    由于最近是假期,工程师的答复将会有所延迟,给您带来的不便敬请谅解。
    Thanks
  • 您好,十分感谢协助!
