Part Number: AM625
我按照链接文档构建debian文件系统
当我执行
sudo ./build.sh am62-bookworm-09.01.00.008
log日志查看到rootfs构建失败
> Building rootfs ..
I: automatically chosen mode: root
I: arm64 cannot be executed, falling back to qemu-user
I: automatically chosen format: directory
E: Sub-process test returned an error code (1)
W: Download is performed unsandboxed as root as file /home/AM62x/ti-bdebstrap/build/am62-bookworm-09.01.00.008/tisdk-am62-bookworm-am62xx-evm-rootfs/var/lib/apt/lists/partial couldn't be accessed by user _apt
I: running --setup-hook in shell: sh -c 'mkdir -p $1/etc/apt/sources.list.d/' exec /home/AM62x/ti-bdebstrap/build/am62-bookworm-09.01.00.008/tisdk-am62-bookworm-am62xx-evm-rootfs
I: running --setup-hook in shell: sh -c 'wget raw.githubusercontent.com/.../ti-debpkgs.sources -P $1/etc/apt/sources.list.d/' exec /home/AM62x/ti-bdebstrap/build/am62-bookworm-09.01.00.008/tisdk-am62-bookworm-am62xx-evm-rootfs
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 0.0.0.0, ::
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refused.
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443... failed: Connection refused.
E: command failed: wget raw.githubusercontent.com/.../ti-debpkgs.sources -P $1/etc/apt/sources.list.d/
W: listening on child socket failed:
E: mmdebstrap failed to run
2023-12-27 14:46:09,653 bdebstrap ERROR: mmdebstrap failed with exit code 25. See above for details.
> Cleaning up am62-bookworm-09.01.00.008
> Packaging am62-bookworm-09.01.00.008
我已确保构建主机Host可以wget获取
