Hello TI friend,
I have a question for you. The front view frame sync signal is provided by TDA4, and the front view camera sensor outputs to the deserializer (max96722) at 25fps, but the frame rate printed in the application (multi_camera) log is 20fps.
I did the following experiment:
When the sensor is configured to output at 30fps, the frame rate printed in the multi_camera log is 25fps.
When the sensor outputs at 25fps, I measured the frequency of the frame sync pin to be 20Hz.
Why don't the frame rates output by the sensor and printed by the multi_camera log correspond? Thank you.
Happy New Year!
