DM3730的SD卡性能测试
root@dm37x-evm:/lftb/filesystem_test_suite/scripts/common# ./filesystem_tests_scripts.sh -plat am37x -type perf -device /dev/mm
cblk0p1 -device_type mmc -fs_type vfat
|TRACE LOG|--- START PERFORMANCE TEST CASES ---|
|TEST START|mmc-4-0-003|
|TEST START TIME|Fri Dec 23 01:11:32 UTC 2011|
|TRACE LOG|DEVICE TYPE : MMC|
|TRACE LOG|DEVICE_NODE           : /dev/mmcblk0p1|
|TRACE LOG|FS_TYPE               : vfat|
|TRACE LOG|LOOP CNT(FOR STRESS)  : 1000|
./filesystem_tests_scripts.sh: line 597: ../../bin/am37x/filesystem_tests: not found
mkfs.vfat 2.11 (12 Mar 2005)
/dev/mmcblk0p1 on /mnt/filesystem type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
du: /mnt/filesystem/file_8192_100: No such file or directory
du: /mnt/filesystem/file_16384_100: No such file or directory
du: /mnt/filesystem/file_102400_100: No such file or directory
du: /mnt/filesystem/file_256000_100: No such file or directory
du: /mnt/filesystem/file_512000_100: No such file or directory
du: /mnt/filesystem/file_1048576_100: No such file or directory
du: /mnt/filesystem/file_5242880_100: No such file or directory
|TEST RESULT|FAIL|MMC-4-0-003|
|TEST END|MMC-4-0-003|
|TEST END TIME|Fri Dec 23 01:11:40 UTC 2011|
rm: cannot remove '/mnt/filesystem/*': No such file or directory
|TRACE LOG|--- END PERFORMANCE TEST CASES ---|
|TRACE LOG|-------- TEST SUMMARY  --------|
|TRACE LOG| Total Test Case executed: 1|
|TRACE LOG| Total Test Case Passed  : 0|
|TRACE LOG| Total Test Case failed  : 1|
如下,我这个是什么情况?求大师援助...
  • root@dm37x-evm:/lftb/filesystem_test_suite/scripts/common# ./filesystem_tests_scripts.sh -plat am37x -type perf -devic
    e /dev/mmcblk0p3 -device_type mmc -fs_type ext2
    |TEST START TIME|Fri Dec 23 02:24:33 UTC 2011|
    |TRACE LOG|DEVICE_NODE           : /dev/mmcblk0p3|
    |TRACE LOG|FS_TYPE               : ext2|
    mke2fs 1.41.14 (22-Dec-2010)
    Filesystem label=
    OS type: Linux
    Block size=4096 (log=2)
    Fragment size=4096 (log=2)
    Stride=0 blocks, Stripe width=0 blocks
    56784 inodes, 226918 blocks
    11345 blocks (5.00%) reserved for the super user
    First data block=0
    Maximum filesystem blocks=234881024
    7 block groups
    32768 blocks per group, 32768 fragments per group
    8112 inodes per group
    Superblock backups stored on blocks:
           32768, 98304, 163840
    Writing inode tables: done
    Writing superblocks and filesystem accounting information: done
    This filesystem will be automatically checked every 28 mounts or
    180 days, whichever comes first.  Use tune2fs -c or -i to override.
    /dev/mmcblk0p3 on /mnt/filesystem type ext2 (rw,relatime,errors=continue)
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 22 mounts or
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 25 mounts or
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 39 mounts or
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 38 mounts or
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 37 mounts or
    Filesystem label=
    OS type: Linux
    First data block=0
    7 block groups
    This filesystem will be automatically checked every 26 mounts or
    |TEST END TIME|Fri Dec 23 02:25:06 UTC 2011|
    rm: /mnt/filesystem/lost+found: is a directory
