Part Number: AM623
Dear,
I discovered that there is a delay in the transmission clock and data of am623 when measuring RGMII. We made sure that the internal delay was not activated on the phy side, however, the datasheet of am623 mentioned that "TXC is delayed internally before being driven to the RGMII[x]_TXC pin." It also stated that "This internal delay is always enabled". I would like to inquire if the delay is automatically turned on if no input is given, and if so, what is the default delay time?
Thanks for your help.
Best regards,
Tommy
