Part Number: TDA4VM
oot@at-virtual-machine:/mnt/hgfs/share/01-TI/03-PROJECT/ti-processor-sdk-rtos-j721e-evm-09_01_00_06# ./sdk_builder/scripts/setup_psdk_rtos.sh
Hit:4 mirrors.ustc.edu.cn/.../ubuntu jammy InRelease
Hit:1 mirrors.tuna.tsinghua.edu.cn/ubuntu jammy InRelease
Hit:2 mirrors.tuna.tsinghua.edu.cn/ubuntu jammy-updates InRelease
Hit:3 mirrors.tuna.tsinghua.edu.cn/ubuntu jammy-backports InRelease
Hit:5 security.ubuntu.com/ubuntu jammy-security InRelease
Reading package lists... Done
[dof] Creating/Updating system link to libDOF.so ...
Building dependency tree... Done
Reading state information... Done
Note, selecting 'libgraphviz-dev' instead of 'graphviz-dev'
bison is already the newest version (2:3.8.2+dfsg-1build1).
build-essential is already the newest version (12.9ubuntu3).
flex is already the newest version (2.6.4-8build2).
libpng-dev is already the newest version (1.6.37-3build5).
python3-pyelftools is already the newest version (0.27-1).
graphviz is already the newest version (2.42.2-6).
libgraphviz-dev is already the newest version (2.42.2-6).
mono-runtime is already the newest version (6.8.0.105+dfsg-3.2).
ninja-build is already the newest version (1.10.1-1).
pkgconf is already the newest version (1.8.0-1).
swig is already the newest version (4.0.2-1ubuntu1).
cmake is already the newest version (3.22.1-1ubuntu1.22.04.1).
curl is already the newest version (7.81.0-1ubuntu1.15).
git is already the newest version (1:2.34.1-1ubuntu1.10).
libgles2-mesa-dev is already the newest version (23.0.4-0ubuntu1~22.04.1).
libprotobuf-dev is already the newest version (3.12.4-1ubuntu7.22.04.1).
libprotoc-dev is already the newest version (3.12.4-1ubuntu7.22.04.1).
python3-distutils is already the newest version (3.10.8-1~22.04).
python3-setuptools is already the newest version (59.6.0-1.2ubuntu0.22.04.1).
u-boot-tools is already the newest version (2022.01+dfsg-2ubuntu2.5).
unzip is already the newest version (6.0-26ubuntu3.1).
libc6:i386 is already the newest version (2.35-0ubuntu3.6).
libncurses5 is already the newest version (6.3-2ubuntu0.1).
libtinfo5 is already the newest version (6.3-2ubuntu0.1).
protobuf-compiler is already the newest version (3.12.4-1ubuntu7.22.04.1).
python3-pip is already the newest version (22.0.2+dfsg-1ubuntu0.4).
0 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
[psdk linux tisdk-adas-image-j721e-evm.tar.xz] Checking ...
[psdk linux tisdk-adas-image-j721e-evm.tar.xz] Done
[psdk linux boot-adas-j721e-evm.tar.gz] Checking ...
[psdk linux boot-adas-j721e-evm.tar.gz] Done
export BIOS_VERSION=
export XDC_VERSION=
export GCC_ARCH64_VERSION=9.2-2019.12
export CGT_C6X_VERSION=8.3.7
export CGT_C7X_VERSION=3.1.0.LTS
export CGT_ARM_VERSION=
export CGT_ARMLLVM_VERSION=3.2.0.LTS
export NDK_VERSION=
export NS_VERSION=
export SYSCONFIG_VERSION=
export SYSCONFIG_BUILD=
./sdk_builder/scripts/setup_psdk_rtos.sh: line 228: source: .component_versions_j721e_env: cannot execute binary file
[ti-cgt-armllvm_] Checking ...
--2024-02-02 15:09:51-- dr-download.ti.com/.../ti_cgt_armllvm__linux-x64_installer.bin
Resolving dr-download.ti.com (dr-download.ti.com)... 2402:4f00:4001:182::358e, 2402:4f00:4001:1a6::358e, 23.7.166.231
Connecting to dr-download.ti.com (dr-download.ti.com)|2402:4f00:4001:182::358e|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2024-02-02 15:09:54 ERROR 404: Not Found.
chmod: cannot access '/root/ti/ti_cgt_armllvm__linux-x64_installer.bin': No such file or directory
./sdk_builder/scripts/setup_psdk_rtos.sh: line 250: /root/ti/ti_cgt_armllvm__linux-x64_installer.bin: No such file or directory
rm: cannot remove '/root/ti/ti_cgt_armllvm__linux-x64_installer.bin': No such file or directory
[ti-cgt-armllvm_] Done
[ti-cgt-c6000_] Checking ...
--2024-02-02 15:09:54-- dr-download.ti.com/.../ti_cgt_c6000__linux_installer_x86.bin
Resolving dr-download.ti.com (dr-download.ti.com)... 2402:4f00:4001:1a6::358e, 2402:4f00:4001:182::358e, 23.7.166.231
Connecting to dr-download.ti.com (dr-download.ti.com)|2402:4f00:4001:1a6::358e|:443... connected.
2024-02-02 15:09:56 ERROR 404: Not Found.
chmod: cannot access '/root/ti/ti_cgt_c6000__linux_installer_x86.bin': No such file or directory
./sdk_builder/scripts/setup_psdk_rtos.sh: line 263: /root/ti/ti_cgt_c6000__linux_installer_x86.bin: No such file or directory
rm: cannot remove '/root/ti/ti_cgt_c6000__linux_installer_x86.bin': No such file or directory
[ti-cgt-c6000_] Done
[ti-cgt-c7000_] Checking ...
--2024-02-02 15:09:56-- dr-download.ti.com/.../ti_cgt_c7000__linux-x64_installer.bin
2024-02-02 15:10:02 ERROR 404: Not Found.
chmod: cannot access '/root/ti/ti_cgt_c7000__linux-x64_installer.bin': No such file or directory
./sdk_builder/scripts/setup_psdk_rtos.sh: line 277: /root/ti/ti_cgt_c7000__linux-x64_installer.bin: No such file or directory
rm: cannot remove '/root/ti/ti_cgt_c7000__linux-x64_installer.bin': No such file or directory
[ti-cgt-c7000_] Done
[gcc-arm--x86_64-aarch64-none-elf] Checking ...
--2024-02-02 15:10:02-- developer.arm.com/.../gcc-arm--x86_64-aarch64-none-elf.tar.xz
Resolving developer.arm.com (developer.arm.com)... 223.119.248.67, 223.119.248.35
Connecting to developer.arm.com (developer.arm.com)|223.119.248.67|:443... connected.
2024-02-02 15:10:03 ERROR 404: Not Found.
tar: /root/ti/gcc-arm--x86_64-aarch64-none-elf.tar.xz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
rm: cannot remove '/root/ti/gcc-arm--x86_64-aarch64-none-elf.tar.xz': No such file or directory
[gcc-arm--x86_64-aarch64-none-elf] Done
[arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu] Checking ...
[arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu] Done
[gcc-arm--x86_64-arm-none-linux-gnueabihf] Checking ...
--2024-02-02 15:10:03-- developer.arm.com/.../gcc-arm--x86_64-arm-none-linux-gnueabihf.tar.xz
tar: /root/ti/gcc-arm--x86_64-arm-none-linux-gnueabihf.tar.xz: Cannot open: No such file or directory
rm: cannot remove '/root/ti/gcc-arm--x86_64-arm-none-linux-gnueabihf.tar.xz': No such file or directory
[gcc-arm--x86_64-arm-none-linux-gnueabihf] Done
[protobuf-3.20.2] Checking ...
[protobuf-3.20.2] Done
[core secdev] Checking ...
[core secdev] Checking ... Done
[ATF] Checking ...
HEAD is now at 2fcd408bb feat(ti): do not handle EAs in EL3
v2.8-226-g2fcd408bb
[ATF] Checking ... Done
[OPTEE] Checking ...
HEAD is now at 8e74d4761 Update CHANGELOG for 3.20.0
3.20.0
[OPTEE] Checking ... Done
[opkg-utils] Checking ...
[opkg-utils] Done
[glm] Checking ...
[glm] Done
[pip] Checking ...
Requirement already satisfied: pip in /root/.local/lib/python3.10/site-packages (23.3.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: pip.pypa.io/.../venv
[pip] Checking ... Done
[pip] Installing dependant python packages ...
Requirement already satisfied: pycryptodomex in /root/.local/lib/python3.10/site-packages (3.20.0)
Requirement already satisfied: meson in /root/.local/lib/python3.10/site-packages (1.3.1)
Requirement already satisfied: jsonschema in /root/.local/lib/python3.10/site-packages (4.21.1)
Requirement already satisfied: attrs>=22.2.0 in /root/.local/lib/python3.10/site-packages (from jsonschema) (23.2.0)
Requirement already satisfied: jsonschema-specifications>=2023.03.6 in /root/.local/lib/python3.10/site-packages (from jsonschema) (2023.12.1)
Requirement already satisfied: referencing>=0.28.4 in /root/.local/lib/python3.10/site-packages (from jsonschema) (0.33.0)
Requirement already satisfied: rpds-py>=0.7.1 in /root/.local/lib/python3.10/site-packages (from jsonschema) (0.17.1)
[pip] Installing dependant python packages ... Done
