我在定制的AM6442板卡上出现eth节点无法成功注册的情况,SDK版本:ti-processor-sdk-linux-rt-am64xx-evm-09.02.00.08,相同的板卡在ti-processor-sdk-linux-rt-am64xx-evm-08.06.00.42SDK版本中无该问题,能成功注册eth节点并进行网络通信;
报错信息如图所示,出现icssg-prueth icssg1-eth eth2: Failed to update Rx Flow ID -22的报错信息
请帮忙协助如何解决该问题;
以下是dts配置
// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */ /dts-v1/; #include <dt-bindings/phy/phy.h> #include <dt-bindings/mux/ti-serdes.h> #include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/net/ti-dp83867.h> #include "k3-am642.dtsi" / { compatible = "ti,am642-evm", "ti,am642"; model = "Texas Instruments AM642 EVM"; chosen { stdout-path = "serial2:115200n8"; bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; }; aliases { ethernet2 = &icssg1_emac0; ethernet3 = &icssg1_emac1; }; memory@80000000 { device_type = "memory"; /* 2G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>; }; reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; secure_ddr: optee@9e800000 { reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ alignment = <0x1000>; no-map; }; main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa0000000 0x00 0x100000>; no-map; }; main_r5fss0_core0_memory_region: r5f-memory@a0100000 { compatible = "shared-dma-pool"; reg = <0x00 0xa0100000 0x00 0xf00000>; no-map; }; main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa1000000 0x00 0x100000>; no-map; }; main_r5fss0_core1_memory_region: r5f-memory@a1100000 { compatible = "shared-dma-pool"; reg = <0x00 0xa1100000 0x00 0xf00000>; no-map; }; main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a2000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa2000000 0x00 0x100000>; no-map; }; main_r5fss1_core0_memory_region: r5f-memory@a2100000 { compatible = "shared-dma-pool"; reg = <0x00 0xa2100000 0x00 0xf00000>; no-map; }; main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a3000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa3000000 0x00 0x100000>; no-map; }; main_r5fss1_core1_memory_region: r5f-memory@a3100000 { compatible = "shared-dma-pool"; reg = <0x00 0xa3100000 0x00 0xf00000>; no-map; }; mcu_m4fss_dma_memory_region: m4f-dma-memory@a4000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa4000000 0x00 0x100000>; no-map; }; mcu_m4fss_memory_region: m4f-memory@a4100000 { compatible = "shared-dma-pool"; reg = <0x00 0xa4100000 0x00 0xf00000>; no-map; }; rtos_ipc_memory_region: ipc-memories@a5000000 { reg = <0x00 0xa5000000 0x00 0x00800000>; alignment = <0x1000>; no-map; }; }; evm_12v0: fixedregulator-evm12v0 { /* main DC jack */ compatible = "regulator-fixed"; regulator-name = "evm_12v0"; regulator-min-microvolt = <12000000>; regulator-max-microvolt = <12000000>; regulator-always-on; regulator-boot-on; }; vsys_5v0: fixedregulator-vsys5v0 { /* output of LM5140 */ compatible = "regulator-fixed"; regulator-name = "vsys_5v0"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; vin-supply = <&evm_12v0>; regulator-always-on; regulator-boot-on; }; vsys_3v3: fixedregulator-vsys3v3 { /* output of LM5140 */ compatible = "regulator-fixed"; regulator-name = "vsys_3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&evm_12v0>; regulator-always-on; regulator-boot-on; }; vdd_mmc1: fixed-regulator-sd { /* TPS2051BD */ compatible = "regulator-fixed"; regulator-name = "vdd_mmc1"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; enable-active-high; vin-supply = <&vsys_3v3>; }; vddb: fixedregulator-vddb { compatible = "regulator-fixed"; regulator-name = "vddb_3v3_display"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&vsys_3v3>; regulator-always-on; regulator-boot-on; }; mdio_mux: mux-controller { compatible = "gpio-mux"; #mux-control-cells = <0>; }; mdio_mux_1: mdio-mux-1 { compatible = "mdio-mux-multiplexer"; mux-controls = <&mdio_mux>; mdio-parent-bus = <&cpsw3g_mdio>; #address-cells = <1>; #size-cells = <0>; mdio@1 { reg = <0x1>; #address-cells = <1>; #size-cells = <0>; cpsw3g_phy3: ethernet-phy@3 { reg = <3>; }; }; }; icssg1_eth: icssg1-eth { compatible = "ti,am642-icssg-prueth"; pinctrl-names = "default"; pinctrl-0 = <&icssg1_rgmii1_pins_default>; sram = <&oc_sram>; ti,prus = <&pru1_0>, <&rtu1_0>, <&tx_pru1_0>, <&pru1_1>, <&rtu1_1>, <&tx_pru1_1>; firmware-name = "ti-pruss/am65x-sr2-pru0-prueth-fw.elf", "ti-pruss/am65x-sr2-rtu0-prueth-fw.elf", "ti-pruss/am65x-sr2-txpru0-prueth-fw.elf", "ti-pruss/am65x-sr2-pru1-prueth-fw.elf", "ti-pruss/am65x-sr2-rtu1-prueth-fw.elf", "ti-pruss/am65x-sr2-txpru1-prueth-fw.elf"; ti,pruss-gp-mux-sel = <2>, /* MII mode */ <2>, <2>, <2>, /* MII mode */ <2>, <2>; ti,mii-g-rt = <&icssg1_mii_g_rt>; ti,mii-rt = <&icssg1_mii_rt>; ti,pa-stats = <&icssg1_pa_stats>; iep = <&icssg1_iep0>, <&icssg1_iep1>; interrupt-parent = <&icssg1_intc>; interrupts = <24 0 2>, <25 1 3>; interrupt-names = "tx_ts0", "tx_ts1"; dmas = <&main_pktdma 0xc200 15>, /* egress slice 0 */ <&main_pktdma 0xc201 15>, /* egress slice 0 */ <&main_pktdma 0xc202 15>, /* egress slice 0 */ <&main_pktdma 0xc203 15>, /* egress slice 0 */ <&main_pktdma 0xc204 15>, /* egress slice 1 */ <&main_pktdma 0xc205 15>, /* egress slice 1 */ <&main_pktdma 0xc206 15>, /* egress slice 1 */ <&main_pktdma 0xc207 15>, /* egress slice 1 */ <&main_pktdma 0x4200 15>, /* ingress slice 0 */ <&main_pktdma 0x4201 15>, /* ingress slice 1 */ <&main_pktdma 0x4202 0>, /* mgmnt rsp slice 0 */ <&main_pktdma 0x4203 0>; /* mgmnt rsp slice 1 */ dma-names = "tx0-0", "tx0-1", "tx0-2", "tx0-3", "tx1-0", "tx1-1", "tx1-2", "tx1-3", "rx0", "rx1"; ethernet-ports { #address-cells = <1>; #size-cells = <0>; icssg1_emac0: port@0 { reg = <0>; phy-handle = <&icssg1_phy1>; phy-mode = "rgmii-txid"; ti,syscon-rgmii-delay = <&main_conf 0x4110>; /* Filled in by bootloader */ local-mac-address = [00 00 00 00 00 00]; }; icssg1_emac1: port@1 { reg = <1>; ti,syscon-rgmii-delay = <&main_conf 0x4114>; /* Filled in by bootloader */ local-mac-address = [00 00 00 00 00 00]; status = "disabled"; }; }; }; }; &main_r5fss0_core0 { mboxes = <&mailbox0_cluster2 &mbox_main_r5fss0_core0>; memory-region = <&main_r5fss0_core0_dma_memory_region>, <&main_r5fss0_core0_memory_region>; }; &main_r5fss0_core1 { mboxes = <&mailbox0_cluster2 &mbox_main_r5fss0_core1>; memory-region = <&main_r5fss0_core1_dma_memory_region>, <&main_r5fss0_core1_memory_region>; }; &main_r5fss1_core0 { mboxes = <&mailbox0_cluster4 &mbox_main_r5fss1_core0>; memory-region = <&main_r5fss1_core0_dma_memory_region>, <&main_r5fss1_core0_memory_region>; }; &main_r5fss1_core1 { mboxes = <&mailbox0_cluster4 &mbox_main_r5fss1_core1>; memory-region = <&main_r5fss1_core1_dma_memory_region>, <&main_r5fss1_core1_memory_region>; }; &mcu_m4fss { mboxes = <&mailbox0_cluster6 &mbox_m4_0>; memory-region = <&mcu_m4fss_dma_memory_region>, <&mcu_m4fss_memory_region>; }; &main_pmx0 { pinctrl-names = "default"; pinctrl-0 = <&main_fan_pins_default &main_watchdog_pins_default &main_isolate_io_pins_default &main_4g_reset_pins_default &main_5g_pins_default>; main_watchdog_pins_default: main_watchdog_pins_default { pinctrl-single,pins = < AM64X_IOPAD(0x011c, PIN_OUTPUT, 7) /* (AA13) PRG1_PRU1_GPO5.GPIO0_70 (watchdog WDI) */ >; }; main_fan_pins_default: main_fan_pins_default { pinctrl-single,pins = < /* set the pull-up, the fan is turned on by default */ AM64X_IOPAD(0x0024, PIN_OUTPUT_PULLUP, 7) /* (N18) OSPI0_D6.GPIO0_9 (fan) */ >; }; main_isolate_io_pins_default: main_isolate_io_pins_default { pinctrl-single,pins = < AM64X_IOPAD(0x0224, PIN_OUTPUT, 7) /* (C14) SPI1_CLK.GPIO1_49 */ AM64X_IOPAD(0x0228, PIN_OUTPUT, 7) /* (B15) SPI1_D0.GPIO1_50 */ AM64X_IOPAD(0x022c, PIN_OUTPUT, 7) /* (A15) SPI1_D1.GPIO1_51 */ AM64X_IOPAD(0x021c, PIN_OUTPUT, 7) /* (B14) SPI1_CS0.GPIO1_47 */ AM64X_IOPAD(0x00cc, PIN_INPUT, 7) /* (V13) PRG1_PRU0_GPO5.GPIO0_50 */ AM64X_IOPAD(0x0128, PIN_INPUT, 7) /* (U12) PRG1_PRU1_GPO8.GPIO0_73 */ AM64X_IOPAD(0x0268, PIN_INPUT, 7) /* (C18) I2C1_SCL.GPIO1_66 */ AM64X_IOPAD(0x026c, PIN_INPUT, 7) /* (B19) I2C1_SDA.GPIO1_67 */ >; }; main_4g_reset_pins_default: main_4g_reset_pins_default { pinctrl-single,pins = < AM64X_IOPAD(0x029c, PIN_OUTPUT, 7) /* (C20) MMC1_SDWP.GPIO1_78 */ >; }; main_5g_pins_default: main_5g_pins_default { pinctrl-single,pins = < AM64X_IOPAD(0x0214, PIN_OUTPUT, 7) /* (A13) SPI0_D0.GPIO1_45 (5G Reset) */ AM64X_IOPAD(0x0218, PIN_OUTPUT, 7) /* (A14) SPI0_D0.GPIO1_46 (5G Power) */ >; }; main_uart1_pins_default: main-uart1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0240, PIN_INPUT, 0) /* (E15) UART1_RXD */ AM64X_IOPAD(0x0244, PIN_OUTPUT, 0) /* (E14) UART1_TXD */ >; }; main_uart2_pins_default: main-uart2-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0238, PIN_INPUT, 3) /* (B16) UART0_CTSn.UART2_RXD */ AM64X_IOPAD(0x023c, PIN_OUTPUT, 3) /* (A16) UART0_RTSn.UART2_TXD */ >; }; main_uart3_pins_default: main-uart3-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0248, PIN_INPUT, 4) /* (D16) UART1_CTSn.UART3_RXD */ AM64X_IOPAD(0x024c, PIN_OUTPUT, 4) /* (E16) UART1_RTSn.UART3_TXD */ AM64X_IOPAD(0x0174, PIN_OUTPUT, 7) /* (R3) PRG0_PRU0_GPO5.GPIO1_5 */ >; }; main_uart6_pins_default: main-uart6-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x020c, PIN_INPUT, 5) /* (C13) SPI0_CS1.UART6_RXD */ AM64X_IOPAD(0x0220, PIN_OUTPUT, 5) /* (D14) SPI1_CS1.UART6_TXD */ AM64X_IOPAD(0x01c4, PIN_OUTPUT, 7) /* (P4) PRG0_PRU1_GPO5.GPIO1_25 */ >; }; main_led_pins_default: main_led_pins_default { pinctrl-single,pins = < AM64X_IOPAD(0x0034, PIN_OUTPUT, 7) /* (K17) OSPI0_CSn2.GPIO0_13 (som-led0) */ AM64X_IOPAD(0x0038, PIN_OUTPUT, 7) /* (L17) OSPI0_CSn3.GPIO0_14 (som-led1) */ AM64X_IOPAD(0x01d0, PIN_OUTPUT, 7) /* (R1) PRG0_PRU1_GPO8.GPIO1_28 (user-led0) */ AM64X_IOPAD(0x0180, PIN_OUTPUT, 7) /* (T2) PRG0_PRU0_GPO8.GPIO1_8 (user-led1) */ >; }; main_keys_pins_default: main_keys-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0278, PIN_INPUT, 7) /* (C19) EXTINTn.GPIO1_70 (user-key0) */ >; }; main_i2c0_pins_default: main-i2c0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0260, PIN_INPUT_PULLUP, 0) /* (A18) I2C0_SCL */ AM64X_IOPAD(0x0264, PIN_INPUT_PULLUP, 0) /* (B18) I2C0_SDA */ >; }; main_mmc1_pins_default: main-mmc1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0294, PIN_INPUT_PULLUP, 0) /* (J19) MMC1_CMD */ AM64X_IOPAD(0x028c, PIN_INPUT_PULLDOWN, 0) /* (L20) MMC1_CLK */ AM64X_IOPAD(0x0288, PIN_INPUT_PULLUP, 0) /* (K21) MMC1_DAT0 */ AM64X_IOPAD(0x0284, PIN_INPUT_PULLUP, 0) /* (L21) MMC1_DAT1 */ AM64X_IOPAD(0x0280, PIN_INPUT_PULLUP, 0) /* (K19) MMC1_DAT2 */ AM64X_IOPAD(0x027c, PIN_INPUT_PULLUP, 0) /* (K18) MMC1_DAT3 */ AM64X_IOPAD(0x0298, PIN_INPUT_PULLUP, 0) /* (D19) MMC1_SDCD */ AM64X_IOPAD(0x0290, PIN_INPUT, 0) /* MMC1_CLKLB */ >; }; main_uart0_pins_default: main-uart0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0230, PIN_INPUT, 0) /* (D15) UART0_RXD */ AM64X_IOPAD(0x0234, PIN_OUTPUT, 0) /* (C16) UART0_TXD */ >; }; mdio1_pins_default: mdio1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x01fc, PIN_OUTPUT, 4) /* (R2) PRG0_PRU1_GPO19.MDIO0_MDC */ AM64X_IOPAD(0x01f8, PIN_INPUT, 4) /* (P5) PRG0_PRU1_GPO18.MDIO0_MDIO */ >; }; rgmii1_pins_default: rgmii1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x01cc, PIN_INPUT, 4) /* (W5) PRG0_PRU1_GPO7.RGMII1_RD0 */ AM64X_IOPAD(0x01d4, PIN_INPUT, 4) /* (Y5) PRG0_PRU1_GPO9.RGMII1_RD1 */ AM64X_IOPAD(0x01d8, PIN_INPUT, 4) /* (V6) PRG0_PRU1_GPO10.RGMII1_RD2 */ AM64X_IOPAD(0x01f4, PIN_INPUT, 4) /* (V5) PRG0_PRU1_GPO17.RGMII1_RD3 */ AM64X_IOPAD(0x0188, PIN_INPUT, 4) /* (AA5) PRG0_PRU0_GPO10.RGMII1_RXC */ AM64X_IOPAD(0x0184, PIN_INPUT, 4) /* (W6) PRG0_PRU0_GPO9.RGMII1_RX_CTL */ AM64X_IOPAD(0x0124, PIN_OUTPUT, 4) /* (V15) PRG1_PRU1_GPO7.RGMII1_TD0 */ AM64X_IOPAD(0x012c, PIN_OUTPUT, 4) /* (V14) PRG1_PRU1_GPO9.RGMII1_TD1 */ AM64X_IOPAD(0x0130, PIN_OUTPUT, 4) /* (W14) PRG1_PRU1_GPO10.RGMII1_TD2 */ AM64X_IOPAD(0x014c, PIN_OUTPUT, 4) /* (AA14) PRG1_PRU1_GPO17.RGMII1_TD3 */ AM64X_IOPAD(0x00e0, PIN_OUTPUT, 4) /* (U14) PRG1_PRU0_GPO10.RGMII1_TXC */ AM64X_IOPAD(0x00dc, PIN_OUTPUT, 4) /* (U15) PRG1_PRU0_GPO9.RGMII1_TX_CTL */ >; }; rgmii2_pins_default: rgmii2-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0108, PIN_INPUT, 4) /* (W11) PRG1_PRU1_GPO0.RGMII2_RD0 */ AM64X_IOPAD(0x010c, PIN_INPUT, 4) /* (V11) PRG1_PRU1_GPO1.RGMII2_RD1 */ AM64X_IOPAD(0x0110, PIN_INPUT, 4) /* (AA12) PRG1_PRU1_GPO2.RGMII2_RD2 */ AM64X_IOPAD(0x0114, PIN_INPUT, 4) /* (Y12) PRG1_PRU1_GPO3.RGMII2_RD3 */ AM64X_IOPAD(0x0120, PIN_INPUT, 4) /* (U11) PRG1_PRU1_GPO6.RGMII2_RXC */ AM64X_IOPAD(0x0118, PIN_INPUT, 4) /* (W12) PRG1_PRU1_GPO4.RGMII2_RX_CTL */ AM64X_IOPAD(0x0134, PIN_OUTPUT, 4) /* (AA10) PRG1_PRU1_GPO11.RGMII2_TD0 */ AM64X_IOPAD(0x0138, PIN_OUTPUT, 4) /* (V10) PRG1_PRU1_GPO12.RGMII2_TD1 */ AM64X_IOPAD(0x013c, PIN_OUTPUT, 4) /* (U10) PRG1_PRU1_GPO13.RGMII2_TD2 */ AM64X_IOPAD(0x0140, PIN_OUTPUT, 4) /* (AA11) PRG1_PRU1_GPO14.RGMII2_TD3 */ AM64X_IOPAD(0x0148, PIN_OUTPUT, 4) /* (Y10) PRG1_PRU1_GPO16.RGMII2_TXC */ AM64X_IOPAD(0x0144, PIN_OUTPUT, 4) /* (Y11) PRG1_PRU1_GPO15.RGMII2_TX_CTL */ >; }; ospi0_pins_default: ospi0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0000, PIN_OUTPUT, 0) /* (N20) OSPI0_CLK */ AM64X_IOPAD(0x002c, PIN_OUTPUT, 0) /* (L19) OSPI0_CSn0 */ AM64X_IOPAD(0x000c, PIN_INPUT, 0) /* (M19) OSPI0_D0 */ AM64X_IOPAD(0x0010, PIN_INPUT, 0) /* (M18) OSPI0_D1 */ AM64X_IOPAD(0x0014, PIN_INPUT, 0) /* (M20) OSPI0_D2 */ AM64X_IOPAD(0x0018, PIN_INPUT, 0) /* (M21) OSPI0_D3 */ >; }; main_mcan0_pins_default: main-mcan0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0254, PIN_INPUT, 0) /* (B17) MCAN0_RX */ AM64X_IOPAD(0x0250, PIN_OUTPUT, 0) /* (A17) MCAN0_TX */ >; }; main_mcan1_pins_default: main-mcan1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x025c, PIN_INPUT, 0) /* (D17) MCAN1_RX */ AM64X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (C17) MCAN1_TX */ >; }; icssg0_mdio0_pins_default: icssg0-mdio0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0204, PIN_OUTPUT, 0) /* (P3) PRG0_MDIO0_MDC */ AM64X_IOPAD(0x0200, PIN_INPUT, 0) /* (P2) PRG0_MDIO0_MDIO */ >; }; icssg0_rgmii1_pins_default: icssg0-rgmii1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0160, PIN_INPUT, 2) /* (Y1) PRG0_PRU0_GPO0.PRG0_RGMII1_RD0 */ AM64X_IOPAD(0x0164, PIN_INPUT, 2) /* (R4) PRG0_PRU0_GPO1.PRG0_RGMII1_RD1 */ AM64X_IOPAD(0x0168, PIN_INPUT, 2) /* (U2) PRG0_PRU0_GPO2.PRG0_RGMII1_RD2 */ AM64X_IOPAD(0x016c, PIN_INPUT, 2) /* (V2) PRG0_PRU0_GPO3.PRG0_RGMII1_RD3 */ AM64X_IOPAD(0x0178, PIN_INPUT, 2) /* (T3) PRG0_PRU0_GPO6.PRG0_RGMII1_RXC */ AM64X_IOPAD(0x0170, PIN_INPUT, 2) /* (AA2) PRG0_PRU0_GPO4.PRG0_RGMII1_RX_CTL */ AM64X_IOPAD(0x018c, PIN_INPUT, 2) /* (Y3) PRG0_PRU0_GPO11.PRG0_RGMII1_TD0 */ AM64X_IOPAD(0x0190, PIN_INPUT, 2) /* (AA3) PRG0_PRU0_GPO12.PRG0_RGMII1_TD1 */ AM64X_IOPAD(0x0194, PIN_INPUT, 2) /* (R6) PRG0_PRU0_GPO13.PRG0_RGMII1_TD2 */ AM64X_IOPAD(0x0198, PIN_INPUT, 2) /* (V4) PRG0_PRU0_GPO14.PRG0_RGMII1_TD3 */ AM64X_IOPAD(0x01a0, PIN_INPUT, 2) /* (U4) PRG0_PRU0_GPO16.PRG0_RGMII1_TXC */ AM64X_IOPAD(0x019c, PIN_INPUT, 2) /* (T5) PRG0_PRU0_GPO15.PRG0_RGMII1_TX_CTL */ >; }; icssg0_rgmii2_pins_default: icssg0-rgmii2-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x01b0, PIN_INPUT, 2) /* (Y2) PRG0_PRU1_GPO0.PRG0_RGMII2_RD0 */ AM64X_IOPAD(0x01b4, PIN_INPUT, 2) /* (W2) PRG0_PRU1_GPO1.PRG0_RGMII2_RD1 */ AM64X_IOPAD(0x01b8, PIN_INPUT, 2) /* (V3) PRG0_PRU1_GPO2.PRG0_RGMII2_RD2 */ AM64X_IOPAD(0x01bc, PIN_INPUT, 2) /* (T4) PRG0_PRU1_GPO3.PRG0_RGMII2_RD3 */ AM64X_IOPAD(0x01c8, PIN_INPUT, 2) /* (R5) PRG0_PRU1_GPO6.PRG0_RGMII2_RXC */ AM64X_IOPAD(0x01c0, PIN_INPUT, 2) /* (W3) PRG0_PRU1_GPO4.PRG0_RGMII2_RX_CTL */ AM64X_IOPAD(0x01dc, PIN_INPUT, 2) /* (W4) PRG0_PRU1_GPO11.PRG0_RGMII2_TD0 */ AM64X_IOPAD(0x01e0, PIN_INPUT, 2) /* (Y4) PRG0_PRU1_GPO12.PRG0_RGMII2_TD1 */ AM64X_IOPAD(0x01e4, PIN_INPUT, 2) /* (T6) PRG0_PRU1_GPO13.PRG0_RGMII2_TD2 */ AM64X_IOPAD(0x01e8, PIN_INPUT, 2) /* (U6) PRG0_PRU1_GPO14.PRG0_RGMII2_TD3 */ AM64X_IOPAD(0x01f0, PIN_INPUT, 2) /* (AA4) PRG0_PRU1_GPO16.PRG0_RGMII2_TXC */ AM64X_IOPAD(0x01ec, PIN_INPUT, 2) /* (U5) PRG0_PRU1_GPO15.PRG0_RGMII2_TX_CTL */ >; }; icssg1_mdio1_pins_default: icssg1-mdio1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x015c, PIN_OUTPUT, 0) /* (Y6) PRG1_MDIO0_MDC */ AM64X_IOPAD(0x0158, PIN_INPUT, 0) /* (AA6) PRG1_MDIO0_MDIO */ >; }; icssg1_rgmii1_pins_default: icssg1-rgmii1-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x00b8, PIN_INPUT, 2) /* (Y7) PRG1_PRU0_GPO0.PRG1_RGMII1_RD0 */ AM64X_IOPAD(0x00bc, PIN_INPUT, 2) /* (U8) PRG1_PRU0_GPO1.PRG1_RGMII1_RD1 */ AM64X_IOPAD(0x00c0, PIN_INPUT, 2) /* (W8) PRG1_PRU0_GPO2.PRG1_RGMII1_RD2 */ AM64X_IOPAD(0x00c4, PIN_INPUT, 2) /* (V8) PRG1_PRU0_GPO3.PRG1_RGMII1_RD3 */ AM64X_IOPAD(0x00d0, PIN_INPUT, 2) /* (AA7) PRG1_PRU0_GPO6.PRG1_RGMII1_RXC */ AM64X_IOPAD(0x00c8, PIN_INPUT, 2) /* (Y8) PRG1_PRU0_GPO4.PRG1_RGMII1_RX_CTL */ AM64X_IOPAD(0x00e4, PIN_INPUT, 2) /* (AA8) PRG1_PRU0_GPO11.PRG1_RGMII1_TD0 */ AM64X_IOPAD(0x00e8, PIN_INPUT, 2) /* (U9) PRG1_PRU0_GPO12.PRG1_RGMII1_TD1 */ AM64X_IOPAD(0x00ec, PIN_INPUT, 2) /* (W9) PRG1_PRU0_GPO13.PRG1_RGMII1_TD2 */ AM64X_IOPAD(0x00f0, PIN_INPUT, 2) /* (AA9) PRG1_PRU0_GPO14.PRG1_RGMII1_TD3 */ AM64X_IOPAD(0x00f8, PIN_INPUT, 2) /* (V9) PRG1_PRU0_GPO16.PRG1_RGMII1_TXC */ AM64X_IOPAD(0x00f4, PIN_INPUT, 2) /* (Y9) PRG1_PRU0_GPO15.PRG1_RGMII1_TX_CTL */ >; }; icssg1_iep0_pins_default: icssg1-iep0-pins-default { pinctrl-single,pins = < AM64X_IOPAD(0x0104, PIN_OUTPUT, 2) /* (W7) PRG1_PRU0_GPO19.PRG1_IEP0_EDC_SYNC_OUT0 */ >; }; }; &main_i2c0 { pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; eeprom@50 { compatible = "atmel,24c02"; reg = <0x50>; pagesize = <8>; }; ds1340: rtc@68 { compatible = "dallas,ds1340"; reg = <0x68>; trickle-resistor-ohms = <250>; }; isl1280:rtc@6f{ compatible = "isil,isl1208"; reg = <0x6f>; uie-disabled; }; }; &main_uart0 { pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; }; &main_uart1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart1_pins_default>; }; &main_uart2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart2_pins_default>; }; &main_uart3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart3_pins_default>; rts-gpios = <&main_gpio1 5 GPIO_ACTIVE_LOW>; linux,rs485-enabled-at-boot-time; rs485-rx-during-tx; rs485-rts-active-low; uart-has-rtscts; }; &main_uart4 { status = "disabled"; }; &main_uart5 { status = "disabled"; }; &main_uart6 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart6_pins_default>; rts-gpios = <&main_gpio1 25 GPIO_ACTIVE_LOW>; linux,rs485-enabled-at-boot-time; rs485-rx-during-tx; rs485-rts-active-low; uart-has-rtscts; }; &mcu_uart0 { status = "disabled"; }; &mcu_uart1 { status = "disabled"; }; &main_i2c1 { status = "disabled"; }; /* mcu_gpio0 is reserved for mcu firmware usage */ &mcu_gpio0 { status = "reserved"; }; &mcu_i2c0 { status = "disabled"; }; &mcu_i2c1 { status = "disabled"; }; &mcu_spi0 { status = "disabled"; }; &mcu_spi1 { status = "disabled"; }; &sdhci0 { /* emmc */ bus-width = <8>; non-removable; ti,driver-strength-ohm = <50>; disable-wp; }; &sdhci1 { /* SD/MMC */ vmmc-supply = <&vdd_mmc1>; pinctrl-names = "default"; bus-width = <4>; pinctrl-0 = <&main_mmc1_pins_default>; ti,driver-strength-ohm = <50>; disable-wp; }; &usbss0 { ti,vbus-divider; ti,usb2-only; }; &usb0 { dr_mode = "host"; maximum-speed = "high-speed"; }; &cpsw3g { pinctrl-names = "default"; pinctrl-0 = <&mdio1_pins_default &rgmii1_pins_default &rgmii2_pins_default>; cpts@3d000 { ti,pps = <7 1>; }; }; &cpsw_port1 { phy-mode = "rgmii-rxid"; phy-handle = <&cpsw3g_phy0>; }; &cpsw_port2 { phy-mode = "rgmii-rxid"; phy-handle = <&cpsw3g_phy1>; }; &cpsw3g_mdio { cpsw3g_phy0: ethernet-phy@0 { reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; phy-address-broadcast-off; }; cpsw3g_phy1: ethernet-phy@1 { reg = <1>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; phy-address-broadcast-off; }; }; #define TS_OFFSET(pa, val) (0x4+(pa)*4) (0x10000 | val) ×ync_router { pinctrl-names = "default"; pinctrl-0 = <&mcu_cpts_pps>; /* Example of the timesync routing */ mcu_cpts_pps: mcu-cpts-pps { pinctrl-single,pins = < /* pps [cpts genf1] in22 -> out37 [cpts hw8_push] */ TS_OFFSET(37, 22) /* pps [cpts genf1] in22 -> out25 [SYNC1_OUT pin] */ TS_OFFSET(25, 22) >; }; }; &mailbox0_cluster2 { mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { ti,mbox-rx = <0 0 2>; ti,mbox-tx = <1 0 2>; }; mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 { ti,mbox-rx = <2 0 2>; ti,mbox-tx = <3 0 2>; }; }; &mailbox0_cluster3 { status = "disabled"; }; &mailbox0_cluster4 { mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 { ti,mbox-rx = <0 0 2>; ti,mbox-tx = <1 0 2>; }; mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 { ti,mbox-rx = <2 0 2>; ti,mbox-tx = <3 0 2>; }; }; &mailbox0_cluster5 { status = "disabled"; }; &mailbox0_cluster6 { mbox_m4_0: mbox-m4-0 { ti,mbox-rx = <0 0 2>; ti,mbox-tx = <1 0 2>; }; }; &mailbox0_cluster7 { status = "disabled"; }; &serdes_ln_ctrl { idle-states = <AM64_SERDES0_LANE0_PCIE0>; }; &serdes0 { serdes0_pcie_link: phy@0 { reg = <0>; cdns,num-lanes = <1>; #phy-cells = <0>; cdns,phy-type = <PHY_TYPE_PCIE>; resets = <&serdes_wiz0 1>; }; }; &pcie0_rc { phys = <&serdes0_pcie_link>; phy-names = "pcie-phy"; num-lanes = <1>; }; &pcie0_ep { phys = <&serdes0_pcie_link>; phy-names = "pcie-phy"; num-lanes = <1>; status = "disabled"; }; &tscadc0 { status = "okay"; adc { ti,adc-channels = <0 1 2 3 4 5 6 7>; }; }; &ospi0 { pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>; flash@0{ compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; spi-max-frequency = <25000000>; cdns,tshsl-ns = <60>; cdns,tsd2d-ns = <60>; cdns,tchsh-ns = <60>; cdns,tslch-ns = <60>; cdns,read-delay = <4>; cdns,phy-mode; #address-cells = <1>; #size-cells = <1>; }; }; &main_mcan0 { pinctrl-names = "default"; pinctrl-0 = <&main_mcan0_pins_default>; }; &main_mcan1 { pinctrl-names = "default"; pinctrl-0 = <&main_mcan1_pins_default>; }; &icssg0_mdio { pinctrl-names = "default"; pinctrl-0 = <&icssg0_mdio0_pins_default>; icssg0_phy1: ethernet-phy@2 { reg = <2>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; }; icssg0_phy2: ethernet-phy@3 { reg = <3>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; }; }; &icssg1_mdio { pinctrl-names = "default"; pinctrl-0 = <&icssg1_mdio1_pins_default>; icssg1_phy1: ethernet-phy@4 { reg = <4>; tx-internal-delay-ps = <250>; rx-internal-delay-ps = <2000>; }; }; &icssg1_iep0 { pinctrl-names = "default"; pinctrl-0 = <&icssg1_iep0_pins_default>; };
