Part Number: TMS320C6678
我加载6678的GEl文件后,直接成这个样子,不知道哪出了问题
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
C66xx_1: GEL Output: Setup_Memory_Map...
C66xx_1: GEL Output: Setup_Memory_Map... Done.
C66xx_2: GEL Output: Setup_Memory_Map...
C66xx_2: GEL Output: Setup_Memory_Map... Done.
C66xx_3: GEL Output: Setup_Memory_Map...
C66xx_3: GEL Output: Setup_Memory_Map... Done.
C66xx_4: GEL Output: Setup_Memory_Map...
C66xx_4: GEL Output: Setup_Memory_Map... Done.
C66xx_5: GEL Output: Setup_Memory_Map...
C66xx_5: GEL Output: Setup_Memory_Map... Done.
C66xx_6: GEL Output: Setup_Memory_Map...
C66xx_6: GEL Output: Setup_Memory_Map... Done.
C66xx_7: GEL Output: Setup_Memory_Map...
C66xx_7: GEL Output: Setup_Memory_Map... Done.
Connecting Target...
C66xx_0: GEL Output: DSP core #0
C66xx_0: GEL Output: No initialization performed since bootmode = 0x0000000F
C66xx_0: GEL Output: You can manually initialize with GlobalDefaultSetup
