Hi expert:
I have some questions about OSPI:
in OSPI0/1 Timing Requirements – Tap DDR Mode
How to set this parameter: T = OSPI_RD_DATA_CAPTURE_REG[DELAY_FLD]
Hi expert:
Hi expert:
I had read the document, but I'm still confused.
In this document, it said the OSPI_RD_DATA_CAPTURE_REG is set to delay the DQS.
But in TDA4VL-Q1 have a formula:
| 1.84 +(0.975T(1) ( R(2))) |
so why use this parameter to calculate the DDR Tap mode Setup time and Hold time.
TDA产品主要通过e2e英文论坛支持,建议您将问题发布在E2E英文技术论坛上(https://e2e.ti.com/support/processors-group/processors/f/processors-forum),将由资深的英文论坛工程师为您提供帮助。
