TDA3MA: SBLUtilsConfigModules MCASP1 ERROR
Part Number: TDA3MA
void SBLUtilsConfigModules(void)
    int32_t  retVal   = STW_SOK;
    uint32_t tblIndex = 0U;
    for (tblIndex = 0U;
         tblIndex < SBL_UTILS_NUM_ENTRIES_MODULE_ENABLE_TABLE;
         tblIndex++)
        if ((PMHAL_PRCM_MOD_DSS == gModuleEnableTable[tblIndex].moduleId) &&
            (PMHAL_PRCM_MODULE_MODE_ENABLED == gModuleEnableTable[tblIndex].moduleEnableMode))
            PMHALCMModuleEnableAllOptClock(PMHAL_PRCM_MOD_DSS);
        if (PMHAL_PRCM_MOD_GPIO1 == gModuleEnableTable[tblIndex].moduleId)
            PMHALCMModuleEnableAllOptClock(PMHAL_PRCM_MOD_GPIO1);
        if (PMHAL_PRCM_MOD_GPIO2 == gModuleEnableTable[tblIndex].moduleId)
            PMHALCMModuleEnableAllOptClock(PMHAL_PRCM_MOD_GPIO2);
        if (PMHAL_PRCM_MOD_GPIO3 == gModuleEnableTable[tblIndex].moduleId)
            PMHALCMModuleEnableAllOptClock(PMHAL_PRCM_MOD_GPIO3);
        if (PMHAL_PRCM_MOD_GPIO4 == gModuleEnableTable[tblIndex].moduleId)
            PMHALCMModuleEnableAllOptClock(PMHAL_PRCM_MOD_GPIO4);
        /* Set clock frequency to 48 MHz for MMC4 */
        if ((PMHAL_PRCM_MOD_MMC4 == gModuleEnableTable[tblIndex].moduleId) &&
            PMHALCMMuxParentSelect(PMHAL_PRCM_MUX_MMC4_GFCLK_MUX, PMHAL_PRCM_DIV_FUNC_48M_FCLK);
        retVal = PMHALModuleModeSet(
            (pmhalPrcmModuleId_t) gModuleEnableTable[tblIndex].moduleId,
            (pmhalPrcmModuleSModuleMode_t) gModuleEnableTable[tblIndex].moduleEnableMode,
            PM_TIMEOUT_INFINITE);
            100);
        if (STW_SOK != retVal)
            SBLLibPrintf(SBLLIB_TRACE_LEVEL_ERROR, "\n Module Enable Error - ");
            SBLLibPrintf(SBLLIB_TRACE_LEVEL_ERROR, gModuleEnableTable[tblIndex].moduleName);
            SBLLibPrintf(SBLLIB_TRACE_LEVEL_ERROR, " \n");
    SBLLibPrintf(SBLLIB_TRACE_LEVEL_INFO1,
                 "\n Module Enable Configuration Completed \n");
TDA3xMA  在 SBL内运行此函数在 配置  MCASP1  是会报错: Module Enable Error - MCASP1 ;
TI源代码内配置的超时时间为无限,程序会卡死,我修改为100,会打印上述错误。
这个错误不是必现的错误,重启时,时好时坏。
