Other Parts Discussed in Thread: TMDS64EVM
问题:当复制的文件超过300M时,系统崩溃,指向Memory
环境:
SDK:ti-processor-sdk-linux-am64xx-evm-08.06.00.42-Linux-x86-Install
CPU:AM6412
linux:5.10
memory:2G (MT40A1G16KNR-075:E)
步骤:
1.linux系统内创建一个超过300M的文件。
2.cp -prf file new ,此时复制文件到300M左右时,系统崩溃,指向memory。此问题,每次必现。
附件是log日志。
请教下哪里的问题?
[ 67.927754] =============================================================================
[ 67.935944] BUG kmalloc-256 (Not tainted): objects 21 > max 0
[ 67.941676] -----------------------------------------------------------------------------
[ 67.941676]
[ 67.951306] Disabling lock debugging due to kernel taint
[ 67.956609] INFO: Slab 0x00000000c49ddadd objects=21 used=21 fp=0x0000000000000000 flags=0x10200
[ 67.965380] CPU: 1 PID: 1652 Comm: cp Tainted: G B 5.10.168-g2c23e6c538 #5
[ 67.973538] Hardware name: Texas Instruments AM642 EVM (DT)
[ 67.979097] Call trace:
[ 67.981551] dump_backtrace+0x0/0x1b0
[ 67.985207] show_stack+0x18/0x38
[ 67.988518] dump_stack+0xe8/0x124
[ 67.991912] slab_err+0xac/0xd4
[ 67.995050] check_slab+0xe8/0xf0
[ 67.998358] alloc_debug_processing+0x60/0x1a0
[ 68.002794] ___slab_alloc.constprop.0+0x6c0/0x788
[ 68.007574] __slab_alloc.isra.0.constprop.0+0x2c/0x58
[ 68.012700] __kmalloc+0x5f8/0x6a0
[ 68.016098] iter_file_splice_write+0x74/0x388
[ 68.020530] direct_splice_actor+0x30/0x48
[ 68.024617] splice_direct_to_actor+0x108/0x258
[ 68.029137] do_splice_direct+0x8c/0xe8
[ 68.032967] do_sendfile+0x198/0x4b0
[ 68.036534] __arm64_sys_sendfile64+0x194/0x1a0
[ 68.041056] el0_svc_common.constprop.0+0x78/0x1c8
[ 68.045836] do_el0_svc+0x24/0xa0
[ 68.049147] el0_svc+0x14/0x20
[ 68.052194] el0_sync_handler+0xb0/0xb8
[ 68.056021] el0_sync+0x180/0x1c0
[ 68.059329] FIX kmalloc-256: Marking all objects used
[ 68.318152] Unable to handle kernel paging request at virtual address ffff8000111d02a0
[ 68.326084] Mem abort info:
[ 68.328882] ESR = 0x96000047
[ 68.331938] EC = 0x25: DABT (current EL), IL = 32 bits
[ 68.337244] SET = 0, FnV = 0
[ 68.340296] EA = 0, S1PTW = 0
[ 68.343434] Data abort info:
[ 68.346306] ISV = 0, ISS = 0x00000047
[ 68.350138] CM = 0, WnR = 1
[ 68.353107] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000083134000
[ 68.359799] [ffff8000111d02a0] pgd=00000000fffff003, p4d=00000000fffff003, pud=00000000ffffe003, pmd=00000000ffffc003, pte=0000000000000000
[ 68.372322] Internal error: Oops: 96000047 [#1] PREEMPT SMP
[ 68.377881] Modules linked in:
[ 68.380935] CPU: 0 PID: 1688 Comm: sleep Tainted: G B 5.10.168-g2c23e6c538 #5
[ 68.389353] Hardware name: Texas Instruments AM642 EVM (DT)
[ 68.394915] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 68.400921] pc : queued_spin_lock_slowpath+0x200/0x3a8
[ 68.406051] lr : _raw_spin_lock+0x74/0x80
[ 68.410049] sp : ffff80001195bb10
[ 68.413352] x29: ffff80001195bb10 x28: ffff80001195bce8
[ 68.418656] x27: ffff000006b2cd70 x26: 0000000000401000
[ 68.423959] x25: ffff0000059d3010 x24: ffff80001195bc38
[ 68.429262] x23: 00000000004ba000 x22: 0000000000000000
[ 68.434566] x21: 0000000000000000 x20: fffffe0000041328
[ 68.439869] x19: ffff00000904c000 x18: 0000000000000000
[ 68.445172] x17: 0000000000000000 x16: 0000000000000000
[ 68.450475] x15: 0000000000000000 x14: 0000000000000000
[ 68.455778] x13: 0000000000000000 x12: 0000000000000000
[ 68.461080] x11: 0000000000000000 x10: 0000000000040000
[ 68.466383] x9 : 0000000000000000 x8 : ffff00007fbdc280
[ 68.471686] x7 : ffff00000416ad40 x6 : ffff8000111d0280
[ 68.476989] x5 : ffff00007fbdc280 x4 : 0000000000000000
[ 68.482292] x3 : fffffe0000041328 x2 : ffff8000111d02a0
[ 68.487595] x1 : ffff8000111d02a0 x0 : ffff00007fbdc288
[ 68.492899] Call trace:
[ 68.495341] queued_spin_lock_slowpath+0x200/0x3a8
[ 68.500120] _raw_spin_lock+0x74/0x80
[ 68.503777] unmap_page_range+0x28c/0x838
[ 68.507775] unmap_single_vma+0x4c/0xa8
[ 68.511601] unmap_vmas+0x30/0x70
[ 68.514909] exit_mmap+0xc0/0x178
[ 68.518219] mmput+0x90/0x178
[ 68.521180] do_exit+0x29c/0xa28
[ 68.524399] do_group_exit+0x44/0xa0
[ 68.527965] __wake_up_parent+0x0/0x30
[ 68.531707] el0_svc_common.constprop.0+0x78/0x1c8
[ 68.536487] do_el0_svc+0x24/0xa0
[ 68.539796] el0_svc+0x14/0x20
[ 68.542843] el0_sync_handler+0xb0/0xb8
[ 68.546671] el0_sync+0x180/0x1c0
[ 68.549981] Code: 91002100 8b0200c2 f861d884 aa0203e1 (f8246828)
[ 68.556065] ---[ end trace 14fe0e7332c0f17b ]---
[ 68.560705] note: sleep[1688] exited with preempt_count 1
[ 68.566181] Unable to handle kernel paging request at virtual address ffff8000111d02a0
[ 68.574093] Mem abort info:
[ 68.576886] ESR = 0x96000047
[ 68.579939] EC = 0x25: DABT (current EL), IL = 32 bits
[ 68.585245] SET = 0, FnV = 0
[ 68.588297] EA = 0, S1PTW = 0
[ 68.591435] Data abort info:
[ 68.594306] ISV = 0, ISS = 0x00000047
[ 68.598137] CM = 0, WnR = 1
[ 68.601104] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000083134000
[ 68.607798] [ffff8000111d02a0] pgd=00000000fffff003, p4d=00000000fffff003, pud=00000000ffffe003, pmd=00000000ffffc003, pte=0000000000000000
[ 68.620314] Internal error: Oops: 96000047 [#2] PREEMPT SMP
[ 68.625871] Modules linked in:
[ 68.628923] CPU: 0 PID: 1694 Comm: sleep Tainted: G B D 5.10.168-g2c23e6c538 #5
[ 68.637340] Hardware name: Texas Instruments AM642 EVM (DT)
[ 68.642899] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 68.648896] pc : queued_spin_lock_slowpath+0x200/0x3a8
[ 68.654023] lr : _raw_spin_lock+0x74/0x80
[ 68.658019] sp : ffff800011c6bb10
[ 68.661323] x29: ffff800011c6bb10 x28: ffff800011c6bce8
[ 68.666627] x27: ffff000005938008 x26: 0000000000401000
[ 68.671930] x25: ffff000004d52010 x24: ffff800011c6bc38
[ 68.677233] x23: 00000000004ba000 x22: 0000000000000000
[ 68.682536] x21: 0000000000000000 x20: fffffdfffffc7928
[ 68.687839] x19: ffff0000071e4000 x18: 0000000000000000
[ 68.693142] x17: 0000000000000000 x16: 0000000000000000
[ 68.698445] x15: 0000000000000000 x14: 0000000000000000
[ 68.703748] x13: 0000000000000000 x12: 0000000000000000
[ 68.709050] x11: 0000000000000000 x10: 0000000000050000
[ 68.714353] x9 : 0000000000000010 x8 : ffff00007fbdc290
[ 68.719657] x7 : ffff00000688e940 x6 : ffff8000111d0280
[ 68.724959] x5 : ffff00007fbdc280 x4 : 0000000000000000
[ 68.730262] x3 : fffffdfffffc7928 x2 : ffff8000111d02a0
[ 68.735565] x1 : ffff8000111d02a0 x0 : ffff00007fbdc298
[ 68.740868] Call trace:
[ 68.743309] queued_spin_lock_slowpath+0x200/0x3a8
[ 68.748088] _raw_spin_lock+0x74/0x80
[ 68.751742] unmap_page_range+0x28c/0x838
[ 68.755741] unmap_single_vma+0x4c/0xa8
[ 68.759567] unmap_vmas+0x30/0x70
[ 68.762874] exit_mmap+0xc0/0x178
[ 68.766182] mmput+0x90/0x178
[ 68.769142] do_exit+0x29c/0xa28
[ 68.772361] do_group_exit+0x44/0xa0
[ 68.775927] __wake_up_parent+0x0/0x30
[ 68.779668] el0_svc_common.constprop.0+0x78/0x1c8
[ 68.784448] do_el0_svc+0x24/0xa0
[ 68.787756] el0_svc+0x14/0x20
[ 68.790803] el0_sync_handler+0xb0/0xb8
[ 68.794629] el0_sync+0x180/0x1c0
[ 68.797938] Code: 91002100 8b0200c2 f861d884 aa0203e1 (f8246828)
[ 68.804018] ---[ end trace 14fe0e7332c0f17c ]---
[ 68.808643] note: sleep[1694] exited with preempt_count 1
[ 68.814071] Unable to handle kernel paging request at virtual address 40a1134a824fecea
[ 68.821968] Mem abort info:
[ 68.824752] ESR = 0x96000004
[ 68.827796] EC = 0x25: DABT (current EL), IL = 32 bits
[ 68.833093] SET = 0, FnV = 0
[ 68.836137] EA = 0, S1PTW = 0
[ 68.839267] Data abort info:
[ 68.842137] ISV = 0, ISS = 0x00000004
[ 68.845959] CM = 0, WnR = 0
[ 68.848917] [40a1134a824fecea] address between user and kernel address ranges
[ 68.856036] Internal error: Oops: 96000004 [#3] PREEMPT SMP
[ 68.861592] Modules linked in:
[ 68.864642] CPU: 0 PID: 291 Comm: dlt_housekeeper Tainted: G B D 5.10.168-g2c23e6c538 #5
[ 68.873840] Hardware name: Texas Instruments AM642 EVM (DT)
[ 68.879399] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
[ 68.885397] pc : ___slab_alloc.constprop.0+0x11c/0x788
[ 68.890524] lr : ___slab_alloc.constprop.0+0xf0/0x788
[ 68.895560] sp : ffff800012253bb0
[ 68.898864] x29: ffff800012253bb0 x28: 0000000000000000
[ 68.904168] x27: ffff000000081480 x26: ffff000000083e80
[ 68.909472] x25: 0000000000000000 x24: 40a1134a824fece3
[ 68.914775] x23: dead000000000100 x22: ffff000000083e90
[ 68.920078] x21: ffff00007fbdf8e0 x20: 0000000000000cc0
[ 68.925381] x19: ffff00000688ad40 x18: 0000000000000000
[ 68.930684] x17: 0000000000000000 x16: 0000000000000000
[ 68.935987] x15: 0000000000000000 x14: 0000000000000000
[ 68.941290] x13: 0000000000000000 x12: 0000000000000000
[ 68.946593] x11: 40a1134a824feceb x10: 0000000000000000
[ 68.951896] x9 : 0000000000000000 x8 : 0000000000000000
[ 68.957199] x7 : 0000000000000000 x6 : 0000000000000000
[ 68.962502] x5 : fffffe0000043800 x4 : 0000000000000000
[ 68.967804] x3 : ffff000000083e80 x2 : 0000000000000001
[ 68.973106] x1 : 40a1134a824feceb x0 : 40a1134a824fecea
[ 68.978409] Call trace:
[ 68.980850] ___slab_alloc.constprop.0+0x11c/0x788
[ 68.985632] __slab_alloc.isra.0.constprop.0+0x2c/0x58
[ 68.990760] kmem_cache_alloc+0x5cc/0x660
[ 68.994762] getname_flags+0x34/0x178
[ 68.998414] getname+0x18/0x28
[ 69.001463] do_sys_openat2+0x188/0x2c8
[ 69.005290] do_sys_open+0x58/0xa0
[ 69.008684] __arm64_sys_openat+0x24/0x30
[ 69.012686] el0_svc_common.constprop.0+0x78/0x1c8
[ 69.017465] do_el0_svc+0x24/0xa0
[ 69.020772] el0_svc+0x14/0x20
[ 69.023819] el0_sync_handler+0xb0/0xb8
[ 69.027646] el0_sync+0x180/0x1c0
[ 69.030954] Code: 52800019 d1000420 f240003f 9a851000 (f9400000)
[ 69.037033] ---[ end trace 14fe0e7332c0f17d ]---
[ 69.041638] note: dlt_housekeeper[291] exited with preempt_count 1
[ 69.279054] Unable to handle kernel paging request at virtual address 6adfa5bf6d2d6204
[ 69.286960] Mem abort info:
[ 69.289744] ESR = 0x96000004
[ 69.292790] EC = 0x25: DABT (current EL), IL = 32 bits
[ 69.298087] SET = 0, FnV = 0
[ 69.301131] EA = 0, S1PTW = 0
[ 69.304260] Data abort info:
[ 69.307130] ISV = 0, ISS = 0x00000004
[ 69.310954] CM = 0, WnR = 0
[ 69.313912] [6adfa5bf6d2d6204] address between user and kernel address ranges
[ 69.321030] Internal error: Oops: 96000004 [#4] PREEMPT SMP
[ 69.326587] Modules linked in:
[ 69.329638] CPU: 0 PID: 291 Comm: dlt_housekeeper Tainted: G B D 5.10.168-g2c23e6c538 #5
[ 69.338835] Hardware name: Texas Instruments AM642 EVM (DT)
[ 69.344394] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
[ 69.350395] pc : try_grab_compound_head+0x178/0x288
[ 69.355262] lr : internal_get_user_pages_fast+0x3ec/0x840
[ 69.360645] sp : ffff8000122534a0
[ 69.363949] x29: ffff8000122534a0 x28: ffff000003f05d98
[ 69.369253] x27: 0000ffffb6794000 x26: 0000000084ffd003
[ 69.374556] x25: 0000ffffb6795000 x24: ffff800011078ae0
[ 69.379860] x23: 00e8000087ee3f43 x22: ffff000004ffdca0
[ 69.385163] x21: fffffdffffffb8c0 x20: 0000000000000001
[ 69.390466] x19: 0000ffffb6794000 x18: 0000000000000000
[ 69.395768] x17: 0000000000000000 x16: 0000000000000000
[ 69.401071] x15: 00000194087a360f x14: 0000000000000352
[ 69.406374] x13: 0000000000000352 x12: 0000000000000000
[ 69.411677] x11: 000000000000b83c x10: 00000000000009f0
[ 69.416980] x9 : ffff800012253700 x8 : 0000000000000001
[ 69.422283] x7 : 0000000000000000 x6 : 0000000000000000
[ 69.427585] x5 : ffff800012253630 x4 : 6adfa5bf6d2d61d0
[ 69.432888] x3 : 0000000000000041 x2 : 0000000000000005
[ 69.438190] x1 : 0000000000000001 x0 : 6adfa5bf6d2d61d1
[ 69.443493] Call trace:
[ 69.445934] try_grab_compound_head+0x178/0x288
[ 69.450456] internal_get_user_pages_fast+0x3ec/0x840
[ 69.455496] get_user_pages_fast+0x30/0x48
[ 69.459585] get_futex_key+0xac/0x4b8
[ 69.463239] futex_wake+0x58/0x198
[ 69.466632] do_futex+0x1b4/0xb60
[ 69.469940] mm_release+0xc8/0x110
[ 69.473334] exit_mm_release+0x28/0x38
[ 69.477075] do_exit+0x64c/0xa28
[ 69.480294] make_task_dead+0x50/0x80
[ 69.483950] die+0x200/0x240
[ 69.486825] die_kernel_fault+0x64/0x78
[ 69.490651] __do_kernel_fault+0x74/0x148
[ 69.494651] do_bad_area+0x5c/0x68
[ 69.498045] do_translation_fault+0x38/0x68
[ 69.502218] do_mem_abort+0x40/0xa0
[ 69.505699] el1_abort+0x48/0x70
[ 69.508920] el1_sync_handler+0xac/0xc8
[ 69.512745] el1_sync+0x88/0x140
[ 69.515967] ___slab_alloc.constprop.0+0x11c/0x788
[ 69.520748] __slab_alloc.isra.0.constprop.0+0x2c/0x58
[ 69.525875] kmem_cache_alloc+0x5cc/0x660
[ 69.529876] getname_flags+0x34/0x178
[ 69.533527] getname+0x18/0x28
[ 69.536576] do_sys_openat2+0x188/0x2c8
[ 69.540403] do_sys_open+0x58/0xa0
[ 69.543797] __arm64_sys_openat+0x24/0x30
[ 69.547798] el0_svc_common.constprop.0+0x78/0x1c8
[ 69.552577] do_el0_svc+0x24/0xa0
[ 69.555884] el0_svc+0x14/0x20
[ 69.558931] el0_sync_handler+0xb0/0xb8
[ 69.562757] el0_sync+0x180/0x1c0
[ 69.566066] Code: f9400400 d1000404 f240001f 9a951084 (b9403480)
[ 69.572148] ---[ end trace 14fe0e7332c0f17e ]---
[ 69.576751] Fixing recursive fault but reboot is needed!
[ 69.582332] Unable to handle kernel paging request at virtual address ffff8000111d0290
[ 69.590255] Mem abort info:
[ 69.593051] ESR = 0x96000047
[ 69.596104] EC = 0x25: DABT (current EL), IL = 32 bits
[ 69.601410] SET = 0, FnV = 0
[ 69.604463] EA = 0, S1PTW = 0
[ 69.607601] Data abort info:
[ 69.610472] ISV = 0, ISS = 0x00000047
[ 69.614303] CM = 0, WnR = 1
[ 69.617271] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000083134000
[ 69.623965] [ffff8000111d0290] pgd=00000000fffff003, p4d=00000000fffff003, pud=00000000ffffe003, pmd=00000000ffffc003, pte=0000000000000000
[ 69.636484] Internal error: Oops: 96000047 [#5] PREEMPT SMP
[ 69.642041] Modules linked in:
[ 69.645092] CPU: 0 PID: 1432 Comm: agetty Tainted: G B D 5.10.168-g2c23e6c538 #5
[ 69.653596] Hardware name: Texas Instruments AM642 EVM (DT)
[ 69.659156] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 69.665157] pc : queued_spin_lock_slowpath+0x200/0x3a8
[ 69.670285] lr : _raw_spin_lock+0x74/0x80
[ 69.674282] sp : ffff800011c93b10
[ 69.677586] x29: ffff800011c93b10 x28: ffff800011c93ce8
[ 69.682889] x27: ffff0000072a7428 x26: 0000000000401000
[ 69.688193] x25: ffff000008e80010 x24: ffff800011c93c38
[ 69.693496] x23: 000000000040d000 x22: 0000000000000000
[ 69.698799] x21: 0000000000000000 x20: fffffdfffff618a8
[ 69.704102] x19: ffff000005862000 x18: 0000000000000000
[ 69.709405] x17: 0000000000000000 x16: 0000000000000000
[ 69.714707] x15: 0000000000000000 x14: 0000000000000000
[ 69.720010] x13: 0000000000000000 x12: 0000000000000000
[ 69.725312] x11: 0000000000000000 x10: 0000000000060000
[ 69.730615] x9 : 0000000000000020 x8 : ffff00007fbdc2a0
[ 69.735919] x7 : ffff000006889e40 x6 : ffff8000111d0280
[ 69.741221] x5 : ffff00007fbdc280 x4 : 0000000000000000
[ 69.746523] x3 : fffffdfffff618a8 x2 : ffff8000111d0290
[ 69.751826] x1 : ffff8000111d0290 x0 : ffff00007fbdc2a8
[ 69.757128] Call trace:
[ 69.759570] queued_spin_lock_slowpath+0x200/0x3a8
[ 69.764349] _raw_spin_lock+0x74/0x80
[ 69.768003] unmap_page_range+0x28c/0x838
[ 69.772003] unmap_single_vma+0x4c/0xa8
[ 69.775828] unmap_vmas+0x30/0x70
[ 69.779136] exit_mmap+0xc0/0x178
[ 69.782444] mmput+0x90/0x178
[ 69.785403] do_exit+0x29c/0xa28
[ 69.788622] do_group_exit+0x44/0xa0
[ 69.792188] __wake_up_parent+0x0/0x30
[ 69.795930] el0_svc_common.constprop.0+0x78/0x1c8
[ 69.800710] do_el0_svc+0x24/0xa0
[ 69.804017] el0_svc+0x14/0x20
[ 69.807063] el0_sync_handler+0xb0/0xb8
[ 69.810888] el0_sync+0x180/0x1c0
[ 69.814196] Code: 91002100 8b0200c2 f861d884 aa0203e1 (f8246828)
[ 69.820277] ---[ end trace 14fe0e7332c0f17f ]---
[ 69.824893] note: agetty[1432] exited with preempt_count 1
[ 69.842984] Fixing recursive fault but reboot is needed!
[ 69.848301] Fixing recursive fault but reboot is needed!
[ 70.086980] Fixing recursive fault but reboot is needed!
[ 75.882006] Unable to handle kernel paging request at virtual address 24e8a8642edcc042
[ 75.889917] Mem abort info:
[ 75.892702] ESR = 0x96000004
[ 75.895748] EC = 0x25: DABT (current EL), IL = 32 bits
[ 75.901045] SET = 0, FnV = 0
[ 75.904089] EA = 0, S1PTW = 0
[ 75.907219] Data abort info:
[ 75.910089] ISV = 0, ISS = 0x00000004
[ 75.913912] CM = 0, WnR = 0
[ 75.916870] [24e8a8642edcc042] address between user and kernel address ranges
[ 75.923989] Internal error: Oops: 96000004 [#6] PREEMPT SMP
[ 75.929546] Modules linked in:
[ 75.932600] CPU: 0 PID: 196 Comm: timesync Tainted: G B D 5.10.168-g2c23e6c538 #5
[ 75.941191] Hardware name: Texas Instruments AM642 EVM (DT)
[ 75.946752] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
[ 75.952754] pc : ___slab_alloc.constprop.0+0x11c/0x788
[ 75.957882] lr : ___slab_alloc.constprop.0+0xf0/0x788
[ 75.962918] sp : ffff8000115cbb80
[ 75.966222] x29: ffff8000115cbb80 x28: 0000000000000000
[ 75.971526] x27: ffff000000003a80 x26: ffff000000000500
[ 75.976829] x25: 0000000000000000 x24: 24e8a8642edcc03b
[ 75.982132] x23: dead000000000100 x22: ffff000000000510
[ 75.987435] x21: ffff00007fbde900 x20: 0000000000002a20
[ 75.992738] x19: ffff000004e70040 x18: 0000000000000000
[ 75.998041] x17: 0000000000000000 x16: 0000000000000000
[ 76.003343] x15: 0000000000000000 x14: 0000000000000000
[ 76.008646] x13: 0000000000000000 x12: 0000000000000000
[ 76.013949] x11: 24e8a8642edcc043 x10: ffff800011440a90
[ 76.019252] x9 : ffff800011440a88 x8 : ffff000000401c60
[ 76.024555] x7 : 0000000000000000 x6 : 0000000000000000
[ 76.029858] x5 : fffffdfffff6aa00 x4 : 0000000000000000
[ 76.035161] x3 : ffff000000000500 x2 : 0000000000000001
[ 76.040463] x1 : 24e8a8642edcc043 x0 : 24e8a8642edcc042
[ 76.045765] Call trace:
[ 76.048207] ___slab_alloc.constprop.0+0x11c/0x788
[ 76.052989] __slab_alloc.isra.0.constprop.0+0x2c/0x58
[ 76.058116] __kmalloc+0x5f8/0x6a0
[ 76.061513] __tty_buffer_request_room+0x78/0x150
[ 76.066208] __tty_insert_flip_char+0x2c/0x88
[ 76.070557] uart_insert_char+0x80/0x150
[ 76.074472] serial8250_read_char+0x7c/0x1b0
[ 76.078732] serial8250_rx_chars+0x2c/0x80
[ 76.082821] serial8250_handle_irq.part.0+0x154/0x1a0
[ 76.087861] serial8250_handle_irq+0x1c/0x28
[ 76.092120] omap8250_irq+0x174/0x370
[ 76.095776] __handle_irq_event_percpu+0x54/0x178
[ 76.100469] handle_irq_event_percpu+0x34/0x90
[ 76.104901] handle_irq_event+0x48/0x90
[ 76.108729] handle_fasteoi_irq+0xb8/0x170
[ 76.112814] generic_handle_irq+0x30/0x48
[ 76.116813] __handle_domain_irq+0x64/0xc0
[ 76.120902] gic_handle_irq+0x58/0x128
[ 76.124642] el0_irq_naked+0x4c/0x54
[ 76.128211] Code: 52800019 d1000420 f240003f 9a851000 (f9400000)
[ 76.134300] ---[ end trace 14fe0e7332c0f180 ]---
[ 76.138905] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[ 76.145765] SMP: stopping secondary CPUs
[ 77.255136] SMP: failed to stop secondary CPUs 0-1
[ 77.259915] Kernel Offset: disabled
[ 77.263394] CPU features: 0x00040002,2000200c
[ 77.267738] Memory Limit: none
[ 77.270788] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
