Hello,
I ran a simple algorithm on C71 of the demo board. The algorithm does not run in the operating system and is called directly in the main function. And the program has been downloaded and debugged through CCS XDS110. The program runs at the address MSMCSRAM(0x70100000).The algorithm can be calculated and output normally.
Now I want to run the algorithm by loading it offline. Looking at some data, DSP C71 is started by loading binary files through A72.But I didn't see the detailed loading process.
Where can I find information about this?Or can you give some guidance.
Thanks.
