PROCESSOR-SDK-J721E: EthFw demo演示失败
Part Number: PROCESSOR-SDK-J721E
Other Parts Discussed in Thread: TDA4VM
板子型号:SD-TDAVM (板子上的丝印有J721EXSKG01EVM,TDA4VM EDGE AI KIT)
SDK版本:linux:ti-processor-sdk-linux-adas-j721e-evm-09_02_00_05-Linux-x86-Install.bin ;
                 RTOS:ti-processor-sdk-rtos-j721e-evm-09_02_00_05.tar.gz
使用的用户指南:software-dl.ti.com/.../ETHFW_DEMOS.html,备注:例程内部文档的指南无法打开,其它版本可以成功打开,因此参考的链接中的文档。
按照例程操作,无法找到IP地址,DHCP使用的是公司的服务器。ifconfig是能看到A核的IP地址,且能正常通信。使用ethfw例程,无法看到R核的IP地址,我们主要是在尝试R核的lwIP能够正常通信。
以下是运行 /opt/vision_apps/vision_apps_init.sh的Log。
请帮忙解答下,感谢!
5047.Log.txt
[MCU2_0]     10.231373 s: CIO: Init ... Done !!!
[MCU2_0]     10.231445 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0]     10.231483 s: CPU is running FreeRTOS
[MCU2_0]     10.231507 s: APP: Init ... !!!
[MCU2_0]     10.231527 s: SCICLIENT: Init ... !!!
[MCU2_0]     10.231729 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[MCU2_0]     10.231775 s: SCICLIENT: DMSC FW revision 0x9
[MCU2_0]     10.231801 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0]     10.231831 s: SCICLIENT: Init ... Done !!!
[MCU2_0]     10.231856 s: UDMA: Init ... !!!
[MCU2_0]     10.232838 s: UDMA: Init ... Done !!!
[MCU2_0]     10.232898 s: MEM: Init ... !!!
[MCU2_0]     10.232933 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 15728640 bytes !!!
[MCU2_0]     10.232993 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0]     10.233042 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ d9f00000 of size 1048576 bytes !!!
[MCU2_0]     10.233087 s: MEM: Init ... Done !!!
[MCU2_0]     10.233110 s: IPC: Init ... !!!
[MCU2_0]     10.233156 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0]     10.233207 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0]     21.252429 s: IPC: HLOS is ready !!!
[MCU2_0]     21.256761 s: IPC: Init ... Done !!!
[MCU2_0]     21.256824 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0]     21.329144 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0]     21.329287 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0]     21.329584 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0]     21.329643 s: ETHFW: Init ... !!!
[MCU2_0]     21.435727 s: ETHFW: Warning: Using 6 random MAC address(es)
[MCU2_0]     21.435856 s: ETHFW: Shared multicasts:
[MCU2_0]     21.435911 s: ETHFW:   01:00:5e:00:00:01
[MCU2_0]     21.435947 s: ETHFW:   01:00:5e:00:00:fb
[MCU2_0]     21.435980 s: ETHFW:   01:00:5e:00:00:fc
[MCU2_0]     21.436009 s: ETHFW:   33:33:00:00:00:01
[MCU2_0]     21.436040 s: ETHFW:   33:33:ff:1d:92:c2
[MCU2_0]     21.436069 s: ETHFW:   01:80:c2:00:00:00
[MCU2_0]     21.436099 s: ETHFW:   01:80:c2:00:00:03
[MCU2_0]     21.436199 s: ETHFW:   01:1b:19:00:00:00
[MCU2_0]     21.436242 s: ETHFW: CPSW recovery is not enabled
[MCU2_0]     21.436427 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0]     21.443466 s: Mdio_open: MDIO manual mode enabled
[MCU2_0]     21.443534 s:
[MCU2_0]     21.450371 s: CpswMacPort_setSgmiiInterface: MAC 2: SERDES PLL is not locked
[MCU2_0]     21.450436 s: : -9
[MCU2_0]     21.450467 s: CpswMacPort_setSgmiiInterface:
[MCU2_0]     21.450499 s: : -1
[MCU2_0]     21.450527 s: Assertion @ Line: 2330 in src/mod/cpsw_macport.c: BFALSE
[MCU2_1]     10.200945 s: CIO: Init ... Done !!!
[MCU2_1]     10.201014 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1]     10.201051 s: CPU is running FreeRTOS
[MCU2_1]     10.201074 s: APP: Init ... !!!
[MCU2_1]     10.201091 s: SCICLIENT: Init ... !!!
[MCU2_1]     10.201290 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[MCU2_1]     10.201333 s: SCICLIENT: DMSC FW revision 0x9
[MCU2_1]     10.201358 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1]     10.201383 s: SCICLIENT: Init ... Done !!!
[MCU2_1]     10.201405 s: UDMA: Init ... !!!
[MCU2_1]     10.202550 s: UDMA: Init ... Done !!!
[MCU2_1]     10.202608 s: MEM: Init ... !!!
[MCU2_1]     10.202643 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
[MCU2_1]     10.202701 s: MEM: Init ... Done !!!
[MCU2_1]     10.202721 s: IPC: Init ... !!!
[MCU2_1]     10.202775 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1]     10.202818 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1]     21.324723 s: IPC: HLOS is ready !!!
[MCU2_1]     21.329042 s: IPC: Init ... Done !!!
[MCU2_1]     21.329101 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1]     21.329142 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1]     21.329172 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1]     21.329544 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1]     21.329607 s: FVID2: Init ... !!!
[MCU2_1]     21.329669 s: FVID2: Init ... Done !!!
[MCU2_0]     21.436126 s: ETHFW: Reserved multicasts:
[MCU2_1]     21.329702 s: VHWA: DMPAC: Init ... !!!
[MCU2_1]     21.329726 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1]     21.329983 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]     21.330016 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1]     21.330144 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]     21.330170 s: VHWA: DOF Init ... !!!
[MCU2_1]     21.337696 s: VHWA: DOF Init ... Done !!!
[MCU2_1]     21.337765 s: VHWA: SDE Init ... !!!
[MCU2_1]     21.339967 s: VHWA: SDE Init ... Done !!!
[MCU2_1]     21.340024 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1]     21.340066 s:  VX_ZONE_INIT:Enabled
[MCU2_1]     21.340091 s:  VX_ZONE_ERROR:Enabled
[MCU2_1]     21.340112 s:  VX_ZONE_WARNING:Enabled
[MCU2_1]     21.341701 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MCU2-1
[MCU2_1]     21.341882 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_SDE
[MCU2_1]     21.342031 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_DOF
[MCU2_1]     21.342080 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
[MCU2_1]     21.342111 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1]     21.342358 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1]     21.342392 s: UDMA Copy: Init ... !!!
[MCU2_1]     21.343857 s: UDMA Copy: Init ... Done !!!
[MCU2_1]     21.343922 s: APP: Init ... Done !!!
[MCU2_1]     21.343951 s: APP: Run ... !!!
[MCU2_1]     21.343972 s: IPC: Starting echo test ...
[MCU2_1]     21.344186 s: APP: Run ... Done !!!
[MCU2_1]     21.345102 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1]     21.345189 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1]     21.345256 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0]     21.436157 s: ETHFW:   01:80:c2:00:00:0e
[C6x_1 ]     10.269439 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ]     10.269450 s: CPU is running FreeRTOS
[C6x_1 ]     10.269458 s: APP: Init ... !!!
[C6x_1 ]     10.269466 s: SCICLIENT: Init ... !!!
[C6x_1 ]     10.269640 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[C6x_1 ]     10.269651 s: SCICLIENT: DMSC FW revision 0x9
[C6x_1 ]     10.269661 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_1 ]     10.269671 s: SCICLIENT: Init ... Done !!!
[C6x_1 ]     10.269680 s: UDMA: Init ... !!!
[C6x_1 ]     10.270910 s: UDMA: Init ... Done !!!
[C6x_1 ]     10.270932 s: MEM: Init ... !!!
[C6x_1 ]     10.270944 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
[C6x_1 ]     10.270961 s: MEM: Init ... Done !!!
[C6x_1 ]     10.270970 s: IPC: Init ... !!!
[C6x_1 ]     10.270992 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ]     10.271007 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_1 ]     18.377351 s: IPC: HLOS is ready !!!
[C6x_1 ]     18.381056 s: IPC: Init ... Done !!!
[C6x_1 ]     18.381085 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ]     21.329142 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ]     21.329157 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ]     21.329582 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ]     21.329626 s:  VX_ZONE_INIT:Enabled
[C6x_1 ]     21.329637 s:  VX_ZONE_ERROR:Enabled
[C6x_1 ]     21.329647 s:  VX_ZONE_WARNING:Enabled
[C6x_1 ]     21.330613 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
[C6x_1 ]     21.330628 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ]     21.330926 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ]     21.330942 s: UDMA Copy: Init ... !!!
[C6x_1 ]     21.334008 s: UDMA Copy: Init ... Done !!!
[C6x_1 ]     21.334032 s: APP: Init ... Done !!!
[C6x_1 ]     21.334040 s: APP: Run ... !!!
[C6x_1 ]     21.334559 s: APP: Run ... Done !!!
[C6x_1 ]     21.334907 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
[C6x_1 ]     21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ]     21.344915 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ]     10.328597 s: CIO: Init ... Done !!!
[C6x_2 ]     10.328624 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ]     10.328635 s: CPU is running FreeRTOS
[C6x_2 ]     10.328643 s: APP: Init ... !!!
[C6x_2 ]     10.328651 s: SCICLIENT: Init ... !!!
[C6x_2 ]     10.328828 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[C6x_2 ]     10.328840 s: SCICLIENT: DMSC FW revision 0x9
[C6x_2 ]     10.328850 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_2 ]     10.328861 s: SCICLIENT: Init ... Done !!!
[C6x_2 ]     10.328871 s: UDMA: Init ... !!!
[C6x_2 ]     10.330093 s: UDMA: Init ... Done !!!
[C6x_2 ]     10.330116 s: MEM: Init ... !!!
[C6x_2 ]     10.330128 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
[C6x_2 ]     10.330146 s: MEM: Init ... Done !!!
[C6x_2 ]     10.330154 s: IPC: Init ... !!!
[C6x_2 ]     10.330176 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ]     10.330192 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_2 ]     18.946800 s: IPC: HLOS is ready !!!
[C6x_2 ]     18.950281 s: IPC: Init ... Done !!!
[C6x_2 ]     18.950310 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ]     21.329141 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ]     21.329157 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ]     21.329592 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ]     21.329639 s:  VX_ZONE_INIT:Enabled
[C6x_2 ]     21.329650 s:  VX_ZONE_ERROR:Enabled
[C6x_2 ]     21.329659 s:  VX_ZONE_WARNING:Enabled
[C6x_1 ]     10.269414 s: CIO: Init ... Done !!!
[C6x_2 ]     21.330631 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ]     21.330930 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ]     21.330947 s: UDMA Copy: Init ... !!!
[C6x_2 ]     21.334130 s: UDMA Copy: Init ... Done !!!
[C6x_2 ]     21.334153 s: APP: Init ... Done !!!
[C6x_2 ]     21.334162 s: APP: Run ... !!!
[C6x_2 ]     21.334170 s: IPC: Starting echo test ...
[C6x_2 ]     21.334773 s: APP: Run ... Done !!!
[C6x_1 ]     21.334049 s: IPC: Starting echo test ...
[C6x_2 ]     21.335109 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
[C6x_2 ]     21.335144 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ]     21.344936 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ]     10.495630 s: CIO: Init ... Done !!!
[C7x_1 ]     10.495644 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ]     10.495655 s: CPU is running FreeRTOS
[C7x_1 ]     10.495663 s: APP: Init ... !!!
[C7x_1 ]     10.495670 s: SCICLIENT: Init ... !!!
[C7x_1 ]     10.495844 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[C7x_1 ]     10.495858 s: SCICLIENT: DMSC FW revision 0x9
[C7x_1 ]     10.495868 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ]     10.495879 s: SCICLIENT: Init ... Done !!!
[C7x_1 ]     10.495888 s: UDMA: Init ... !!!
[C7x_1 ]     10.496808 s: UDMA: Init ... Done !!!
[C7x_1 ]     10.496819 s: MEM: Init ... !!!
[C7x_1 ]     10.496830 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ]     10.496851 s: MEM: Init ... Done !!!
[C7x_1 ]     10.496859 s: IPC: Init ... !!!
[C7x_1 ]     10.496874 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ]     10.496887 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ]     19.154583 s: IPC: HLOS is ready !!!
[C7x_1 ]     19.156400 s: IPC: Init ... Done !!!
[C7x_1 ]     19.156414 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ]     21.330616 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
[C7x_1 ]     21.329160 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ]     21.329248 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ]     21.329304 s:  VX_ZONE_INIT:Enabled
[C7x_1 ]     21.329316 s:  VX_ZONE_ERROR:Enabled
[C7x_1 ]     21.329326 s:  VX_ZONE_WARNING:Enabled
[C7x_1 ]     21.329563 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1
[C7x_1 ]     21.329632 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_2
[C7x_1 ]     21.329715 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_3
[C7x_1 ]     21.329800 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_4
[C7x_1 ]     21.329868 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_5
[C7x_1 ]     21.329935 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_6
[C7x_1 ]     21.329999 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_7
[C7x_1 ]     21.330067 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_8
[C7x_1 ]     21.330088 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
[C7x_1 ]     21.330101 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ]     21.330267 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ]     21.330280 s: APP: Init ... Done !!!
[C7x_1 ]     21.330290 s: APP: Run ... !!!
[C7x_1 ]     21.330299 s: IPC: Starting echo test ...
[C7x_1 ]     21.330401 s: APP: Run ... Done !!!
[C7x_1 ]     21.334914 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s]
[C7x_1 ]     21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ]     21.344952 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ]     21.329143 s: APP: Syncing with 5 CPUs ... Done !!!
[  821.480321] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
