编译时提示如下错误,请求帮忙解决
error #10008-D: cannot find file "stm_d.c66xx_elf.lib"
"./configPkgnker.cmd", line 170: error #10099-D: program will not fit into
available memory. run placement with alignment fails for section ".fardata"
size 0x56e8 . Available memory ranges:
L2SRAM size: 0x26000 unused: 0x6 max hole: 0x4
"./configPkgnker.cmd", line 168: error #10099-D: program will not fit into
available memory. placement with alignment fails for section ".const" size
0x4e47 . Available memory ranges:
"./configPkgnker.cmd", line 158: error #10099-D: program will not fit into
available memory. run placement with alignment fails for section ".stack"
>> Compilation failure
size 0x1000 . Available memory ranges:
"./configPkgnker.cmd", line 175: error #10099-D: program will not fit into
available memory. run placement with alignment fails for section ".cio"
size 0x127 . Available memory ranges:
"./configPkgnker.cmd", line 171: error #10099-D: program will not fit into
available memory. placement with alignment fails for section ".switch" size
0x67 . Available memory ranges:
"./configPkgnker.cmd", line 159: error #10099-D: program will not fit into
available memory. run placement with alignment fails for section "GROUP_1"
size 0x3c . Available memory ranges:
"./configPkgnker.cmd", line 165: error #10099-D: program will not fit into
available memory. placement with alignment fails for section ".cinit" size
0x1fec . Available memory ranges:
L2SRAM size: 0x26000 unused: 0x2 max hole: 0x2
error #10010: errors encountered during linking; "vlfft_evmc6678l.out" not
built
>> Compilation failure
built
