系统启动
你好:
    我在启动8168的板子,EZSDK代码是打印到下面的地方系统卡死不动了是怎么回事?
.init : 0xc0008000 - 0xc003c000 ( 208 kB)
.text : 0xc003c000 - 0xc04dc000 (4736 kB)
.data : 0xc04dc000 - 0xc05252c0 ( 293 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 1379.53 BogoMIPS (lpj=6897664)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
>>>>bw=0
omap_mux_init_signal: Setting signal mmc_pow 0x0008 -> 0x0008
omap_mux_init_signal: Setting signal mmc_clk 0x0000 -> 0x0000
omap_mux_init_signal: Setting signal mmc_cmd 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal mmc_dat0 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal mmc_dat1_sdirq 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal mmc_dat2_sdrw 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal mmc_dat3 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal mmc_sdcd 0x0000 -> 0x0008
omap_mux_init_signal: Setting signal mmc_sdwp 0x0000 -> 0x0008
NOR: Can't request GPMC CS
registered ti816x_gpio_vr device
omap_mux_init_signal: Setting signal gmii1_rxclk 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd0 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd1 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd2 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd3 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd4 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd5 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd6 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxd7 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxdv 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_gtxclk 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd0 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd1 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd2 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd3 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd4 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd5 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd6 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txd7 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txen 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_txclk 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_col 0x0008 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_crs 0x0000 -> 0x0001
omap_mux_init_signal: Setting signal gmii1_rxer 0x0008 -> 0x0001
registered ti816x_sr device
omap_mux_init_signal: Setting signal vin1_d9 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d10 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d11 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d12 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d13 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d14 0x0001 -> 0x0001
omap_mux_set_signal: Setting signal vin0_d20 0x0001 -> 0x0002
omap_mux_set_signal: Setting signal vin0_d21 0x0001 -> 0x0002
omap_mux_set_signal: Setting signal vin0_d22 0x0001 -> 0x0002
omap_mux_set_signal: Setting signal vin0_d23 0x0001 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d4 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d5 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d6 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d7 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d8 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d15 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vout0_r_cr0 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi5_data 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi5_bytstrt 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi5_pacval 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi5_pacerr 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vin1_clk1 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin0_hsync0 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vin0_vsync0 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vin0_fld0 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vin0_de0 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi7_dclk 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi7_data 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi7_bytstrt 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal tsi7_pacval 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vout0_r_cr1 0x0001 -> 0x0001
omap_mux_init_signal: Setting signal vin1_clk0 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d0 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d1 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d2 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_d3 0x0002 -> 0x0002
omap_mux_init_signal: Setting signal vin1_hsync0 0x0001 -> 0x0002
omap_mux_init_signal: Setting signal vin1_vsync0 0x0001 -> 0x0002
omap_mux_init_signal: Setting signal vin1_fld0 0x0001 -> 0x0002
omap_mux_init_signal: Setting signal vin1_de0 0x0001 -> 0x0002
omap_mux_init_signal: Setting signal vin1_hsync1 0x0001 -> 0x0003
omap_mux_init_signal: Setting signal vin1_vsync1 0x0001 -> 0x0003
omap_mux_init_signal: Setting signal vin1_fld1 0x0001 -> 0x0003
omap_mux_init_signal: Setting signal iic1_scl 0x0018 -> 0x0010
omap_mux_init_signal: Setting signal iic1_sda 0x0018 -> 0x0010
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
Backtrace:
[<c004acf8>] (dump_backtrace+0x0/0x110) from [<c039db20>] (dump_stack+0x18/0x1c)
r7:00000000 r6:c04f4d08 r5:c04f4d40 r4:00000000
[<c039db08>] (dump_stack+0x0/0x1c) from [<c005eab0>] (ti81xx_pcie_setup+0x1c/0x474)
[<c005ea94>] (ti81xx_pcie_setup+0x0/0x474) from [<c000c45c>] (pci_common_init+0x94/0x188)
r8:00000000 r7:00000000 r6:c04f4d08 r5:c04f4d40 r4:d246a8c0
[<c000c3c8>] (pci_common_init+0x0/0x188) from [<c005e978>] (ti81xx_pcie_probe+0x54/0x64)
r9:00000000 r8:c050b190 r7:d2465b00 r6:c04f4d08 r5:c04e1ad0
r4:c04e1ad0
[<c005e924>] (ti81xx_pcie_probe+0x0/0x64) from [<c0206b20>] (platform_drv_probe+0x20/0x24)
[<c0206b00>] (platform_drv_probe+0x0/0x24) from [<c0205a8c>] (driver_probe_device+0xd0/0x190)
[<c02059bc>] (driver_probe_device+0x0/0x190) from [<c0205bb4>] (__driver_attach+0x68/0x8c)
r7:d2465b00 r6:c04f4d08 r5:c04e1b04 r4:c04e1ad0
[<c0205b4c>] (__driver_attach+0x0/0x8c) from [<c0205238>] (bus_for_each_dev+0x50/0x84)
r7:d2465b00 r6:c04f4d08 r5:c0205b4c r4:00000000
[<c02051e8>] (bus_for_each_dev+0x0/0x84) from [<c02058b0>] (driver_attach+0x20/0x28)
r6:c04f4d08 r5:d242bfc0 r4:c002e04c
[<c0205890>] (driver_attach+0x0/0x28) from [<c0204b10>] (bus_add_driver+0xb4/0x234)
[<c0204a5c>] (bus_add_driver+0x0/0x234) from [<c0205eec>] (driver_register+0xb0/0x13c)
[<c0205e3c>] (driver_register+0x0/0x13c) from [<c0206e0c>] (platform_driver_register+0x4c/0x60)
r9:00000000 r8:c00135bc r7:00000013 r6:c0072e74 r5:d242bfc0
r4:c002e04c
[<c0206dc0>] (platform_driver_register+0x0/0x60) from [<c00135d0>] (ti81xx_pcie_rc_init+0x14/0x20)
[<c00135bc>] (ti81xx_pcie_rc_init+0x0/0x20) from [<c003c584>] (do_one_initcall+0xd0/0x1a4)
[<c003c4b4>] (do_one_initcall+0x0/0x1a4) from [<c000875c>] (kernel_init+0xac/0x17c)
[<c00086b0>] (kernel_init+0x0/0x17c) from [<c0072e74>] (do_exit+0x0/0x5e4)
r5:c00086b0 r4:00000000
Backtrace:
r7:00000000 r6:00000001 r5:d246a8c0 r4:00000000
[<c039db08>] (dump_stack+0x0/0x1c) from [<c005e9a0>] (ti81xx_pcie_scan+0x18/0x10c)
[<c005e988>] (ti81xx_pcie_scan+0x0/0x10c) from [<c000c474>] (pci_common_init+0xac/0x188)
r7:00000000 r6:00000001 r5:c04f4d40 r4:d246a8c0
r4:c04e1ad0
r4:c002e04c
pci_bus 0000:00: scanning bus
pci_bus 0000:00: fixups for bus
PCI: bus0: Fast back to back transfers enabled
pci_bus 0000:00: bus scan returning with max=00
pci_bus 0000:00: resource 0 [mem 0x20000000-0x2fffffff]
pci_bus 0000:00: resource 1 [io 0x40000000-0x402fffff]
bio: create slab <bio-0> at 0
regulator: VFB: 800 <--> 1025 mV at 1010 mV
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20809
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
TxFifo Empty intr disabled
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d301e000 using DMA, IRQ 18
Registered /proc/driver/musb_hdrc.0
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d3026800 using DMA, IRQ 19
Registered /proc/driver/musb_hdrc.1
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 341
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
0xc002e270
brd: module loaded
0xc002e274
loop: module loaded
0xc002e278
0xc002e27c
0xc002e280
0xc002e284
0xc002e288
0xc002e28c
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
0xc002e290
0xc002e294
0xc002e298
0xc002e29c
0xc002e2a0
0xc002e2a4
0xc002e2a8
omap2-nand driver initializing
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung )
Creating 4 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000040000000 : "File System"
0xc002e2ac
0xc002e2b0
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
0xc002e2b4
0xc002e2b8
usbcore: registered new interface driver cdc_ether
0xc002e2bc
usbcore: registered new interface driver dm9601
0xc002e2c0
0xc002e2c4
0xc002e2c8
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
0xc002e2cc
0xc002e2d0
0xc002e2d4
mice: PS/2 mouse device common for all mice
0xc002e2d8
0xc002e2dc
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
0xc002e2e0
i2c /dev entries driver
0xc002e2e4
Linux video capture interface: v2.00
0xc002e2e8
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
0xc002e2ec
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
0xc002e2f0
0xc002e2f4
0xc002e2f8
0xc002e2fc
0xc002e300
0xc002e304
0xc002e308
0xc002e30c
0xc002e310
0xc002e314
0xc002e318
0xc002e31c
0xc002e320
0xc002e324
0xc002e328
0xc002e32c
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
0xc002e330
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000
0xc002e334
0xc002e338
0xc002e33c
0xc002e340
0xc002e344
0xc002e348
usbcore: registered new interface driver snd-usb-audio
0xc002e34c
0xc002e350
0xc002e354
0xc002e358
0xc002e35c
asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
0xc002e360
ALSA device list:
#0: TI81XX EVM
0xc002e364
0xc002e368
0xc002e36c
0xc002e370
0xc002e374
0xc002e378
0xc002e37c
0xc002e380
TCP cubic registered
0xc002e384
NET: Registered protocol family 17
0xc002e388
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
0xc002e38c
0xc002e390
omap_voltage_late_init: Voltage driver support not added
0xc002e394
Power Management for TI81XX.
0xc002e398
smartreflex smartreflex: Driver initialized
0xc002e39c
0xc002e3a0
0xc002e3a4
0xc002e3a8
0xc002e3ac
0xc002e3b0
0xc002e3b4
0xc002e3b8
0xc002e3bc
0xc002e3c0
0xc002e3c4
0xc002e3c8
0xc002e3cc
0xc002e3d0
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
0xc002e3d4
0xc002e3d8
0xc002e3dc
mmc0: new high speed SD card at address 0260
mmcblk0: mmc0:0260 SD02G 1.84 GiB
mmcblk0: p1 p2
ata2: SATA link down (SStatus 0 SControl 300)
ata1: SATA link down (SStatus 0 SControl 300)
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 208K
INIT: version 2.86 booting
mount: mount point /mnt/.splash does not exist
Please wait: booting...
Error opening /dev/fb0: No such file or directory
Starting udev
udevd (73): /proc/73/oom_adj is deprecated, please use /proc/73/oom_score_adj instead.
Remounting root file system...
Caching udev devnodes
NET: Registered protocol family 10
logger: mount: mount point /media/ram does not exist
ALSA: Restoring mixer settings...
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
Configuring network interfaces... done.
Setting up IP spoofing protection: rp_filter.
Tue Aug 13 18:30:00 CST 2013
INIT: Entering runlevel: 5
Removing stale PID file /var/run/dbus/pid.
Starting system message bus: dbus.
Loading HDVICP2 Firmware
DM816X prcm_config_app version: 2.0.0.1
Doing PRCM settings...
PRCM for IVHD0 is in Progress, Please wait.....
BW Phy Addr : 0x48180600 Data : 0x00000002
AW Phy Addr : 0x48180600 Data : 0x00000002
Phy Addr : 0x48180c04 Data : 0x00000037
BW Phy Addr : 0x48180620 Data : 0x00070000
AW Phy Addr : 0x48180620 Data : 0x00070002
BW Phy Addr : 0x48180624 Data : 0x00030000
AW Phy Addr : 0x48180624 Data : 0x00010002
Phy Addr : 0x48180600 Data : 0x00000102
BW Phy Addr : 0x48180c10 Data : 0x00000007
AW Phy Addr : 0x48180c10 Data : 0x00000003
Phy Addr : 0x48180c14 Data : 0x00000004
BW Phy Addr : 0x58088000 Data : 0xeafffffe
AW Phy Addr : 0x58088000 Data : 0xeafffffe
BW Phy Addr : 0x58098000 Data : 0xeafffffe
AW Phy Addr : 0x58098000 Data : 0xeafffffe
BW Phy Addr : 0x48180c10 Data : 0x00000003
AW Phy Addr : 0x48180c10 Data : 0x00000000
Phy Addr : 0x48180c14 Data : 0x00000007
PRCM for IVHD0 is Done Successfully
PRCM for IVHD1 is in Progress, Please wait.....
BW Phy Addr : 0x48180700 Data : 0x00000002
AW Phy Addr : 0x48180700 Data : 0x00000002
Phy Addr : 0x48180d04 Data : 0x00000037
BW Phy Addr : 0x48180720 Data : 0x00070000
AW Phy Addr : 0x48180720 Data : 0x00050002
BW Phy Addr : 0x48180724 Data : 0x00030000
AW Phy Addr : 0x48180724 Data : 0x00010002
Phy Addr : 0x48180700 Data : 0x00000102
BW Phy Addr : 0x48180d10 Data : 0x00000007
AW Phy Addr : 0x48180d10 Data : 0x00000003
Phy Addr : 0x48180d14 Data : 0x00000004
BW Phy Addr : 0x5a088000 Data : 0xeafffffe
AW Phy Addr : 0x5a088000 Data : 0xeafffffe
BW Phy Addr : 0x5a098000 Data : 0xeafffffe
AW Phy Addr : 0x5a098000 Data : 0xeafffffe
BW Phy Addr : 0x48180d10 Data : 0x00000003
AW Phy Addr : 0x48180d10 Data : 0x00000000
Phy Addr : 0x48180d14 Data : 0x00000007
PRCM for IVHD1 is Done Successfully
PRCM for IVHD2 is in Progress, Please wait.....
BW Phy Addr : 0x48180800 Data : 0x00000002
AW Phy Addr : 0x48180800 Data : 0x00000002
Phy Addr : 0x48180e04 Data : 0x00000037
BW Phy Addr : 0x48180820 Data : 0x00070000
AW Phy Addr : 0x48180820 Data : 0x00050002
BW Phy Addr : 0x48180824 Data : 0x00030000
AW Phy Addr : 0x48180824 Data : 0x00010002
Phy Addr : 0x48180800 Data : 0x00000102
BW Phy Addr : 0x48180e10 Data : 0x00000007
AW Phy Addr : 0x48180e10 Data : 0x00000003
Phy Addr : 0x48180e14 Data : 0x00000004
BW Phy Addr : 0x53088000 Data : 0xeafffffe
AW Phy Addr : 0x53088000 Data : 0xeafffffe
BW Phy Addr : 0x53098000 Data : 0xeafffffe
AW Phy Addr : 0x53098000 Data : 0xeafffffe
BW Phy Addr : 0x48180e10 Data : 0x00000003
AW Phy Addr : 0x48180e10 Data : 0x00000000
Phy Addr : 0x48180e14 Data : 0x00000007
PRCM for IVHD2 is Done Successfully
PRCM Initialization completed
SysLink version : 2.20.02.20
SysLink module created on Date:Mar 25 2015 Time:03:20:09
Trace enabled
Trace SetFailureReason enabled
FIRMWARE: I2cInit will be done by M3
FIRMWARE: Memory map bin file not passed
Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [-mmap <memory_map_file>] [-i2c <0|1>]
===Mandatory arguments===
<Processor Id> 0: DSP, 1: Video-M3, 2: Vpss-M3
<Location of Firmware> firmware binary file
<start|stop> to start/stop the firmware
===Optional arguments===
-mmap input memory map bin file name
-i2c 0: i2c init not done by M3, 1(default): i2c init done by M3
FIRMWARE: isI2cInitRequiredOnM3: 1
FIRMWARE: Default memory configuration is used
Firmware Loader debugging not configured
Default FL_DEBUG: warning
Allowed FL_DEBUG levels: error, warning, info, debug, log
MemCfg: DCMM (Dynamically Configurable Memory Map) Version : 2.1.2.1
*** ElfLoader_load: Failed to write args! (ensure .args section is big enough)
Error [0x0] at Line no: 1961 in file /usr/local/ezsdk/5_05/component-sources/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/procMgr/common/loaders/Elf/ElfLoader.c
FIRMWARE: 1 start Successful
Loading HDVPSS (V4L2) Firmware
FIRMWARE: isI2cInitRequiredOnM3: 0
FIRMWARE: 2 start Successful
