C6678 多核启动,内存不稳定,数据跳动
   int i;
    if (CSL_chipReadReg(CSL_CHIP_DNUM) == 0)     {      CACHE_setL1PSize(CACHE_L1_32KCACHE);      CACHE_setL1DSize(CACHE_L1_0KCACHE);      CACHE_setL2Size(CACHE_0KCACHE);      //CACHE_invAllL1p(CACHE_WAIT);      //CACHE_wbInvAllL1d(CACHE_WAIT);      //CACHE_wbInvAllL2(CACHE_WAIT);     }     else     {      CACHE_setL1PSize(CACHE_L1_32KCACHE);      CACHE_setL1DSize(CACHE_L1_32KCACHE);      CACHE_setL2Size(CACHE_0KCACHE);      //CACHE_invAllL1p(CACHE_WAIT);      //CACHE_wbInvAllL1d(CACHE_WAIT);      //CACHE_wbInvAllL2(CACHE_WAIT);     }
 /*make other cores local memory cacheable and prefetchable*/  for(i=16; i<24; i++)   CGEM_regs->MAR[i]=1|(1<<CSL_CGEM_MAR0_PFX_SHIFT);
 /*make DDR cacheable and prefetchable*/  for(i=128; i<256; i++)  {   if ( i != 131)   {    CGEM_regs->MAR[i]=1|(1<<CSL_CGEM_MAR0_PFX_SHIFT);   }   else   {    CGEM_regs->MAR[i]=0;   }  }  /*make other space non-cacheable and non-prefetchable*/  for(i=24; i<128; i++)   CGEM_regs->MAR[i]=0;
 /*XMC memory address extension/mapping and memory protection*/  KeyStone_XM_cfg();
 //DSP core speed  //KeyStone_main_PLL_init (20, 1);  //for 50MHz input clock  KeyStone_main_PLL_init (12,1);  //for 100MHz input clock  //DDR speed = 66.67*20/1= 1333  KeyStone_DDR_PLL_init (20, 1);  Shannon_EVM_DDR_Init(666.667);  //for 1333Mbps  serdes_cfg.commonSetup.inputRefClock_MHz = 156.25;     TSC_init(); //initialize TSC to measure cycle
多核启动下,在上面代码后加入DDR3写操作,会出现DDR数据跳变,不稳定;加入一定延时再赋值,就比较稳定,求解答为什么这样?
  • 是在EVM上测试还是你们自做的板子上,如果是自设计的板子,需要修改DDR的配置,关于DDR配置在论坛上有很多帖子。
  • if (CSL_chipReadReg(CSL_CHIP_DNUM) == 0)
    else
    KeyStone_XM_cfg();
    //DSP core speed
    多核编程时,以上这些对DDR3、cache和PLL的设置,是应该一个核设置,还是每个核都要设置一次?
