你好:
在板子上有两块网卡,这两块网卡的IP可以设置成同一网段吗?
请参考:
https://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/213966/762565
On the DM816x board the dual EMAC is enabled by default. If you want to use both interfaces in one subnet (this generally wouldn't be the case), search the Internet for a general guide how to setup a Linux system for multiple interfaces on the same subnet, multiple default routes or something similar.
