android2.3.4系统WIFI打开后,驱动load后不久,驱动自动unload,binder_alloc_buf, no vma
Other Parts Discussed in Thread: DM3730
大家好,我使用的是佐臻的 模块,DM3730的cpu,,      android2.3.4系统WIFI打开后,驱动load后不久,可以搜索到附近的热点,也可以链接上,但有时候驱动又自动unload(我看log是驱动自动不加载了,好像wifi关闭按钮似的,但wifi按钮我没动,一直是打开的)了,这样热点就收不到了。如果再操作wifi关闭,打开过程,wifi又开始链接了,不过过一会又自动UNLOAD,只有重启系统才能好,这个问题经常发生。大家能帮我分析一下什么原因吗?我看LOG,就是加载驱动,又关掉了。android有什么条件能自动把这个驱动关闭吗?
log中wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c  loaded  是把wifi打开。
[17986.667449] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c :    down 是wifi自动关闭了(设备自己关闭的)。
看这个log经常出现 binder: 1263: binder_alloc_buf, no vma
[17962.310882] binder: 1187:1198 transaction failed 29201, size 320-4   这个是什么问题,我看代码也没看懂。说没有足够的bu缓存分配,但我看应用中可用的RAM有上百M,这个是怎么回事。
alloc_buf, no vma
[17959.745025] binder: 1187:1198 transaction failed 29201, size 320-4
�17960.996490] binder: 1263: binder_alloc_buf, no vma
[17961.001556] binder: 1187:1198 transaction failed 29201, size 320-4
[17961.049468] binder: 1263: binder_alloc_buf, no vma
�17961.054504] binder: 1187:1198 transaction failed 29201, size 320-4
[17961.247863] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c  loaded
[17962.305755] binder: 1263: binder_alloc_buf, no vma
[17962.330780] binder: 1263: binder_alloc_buf, no vma
�17962.335845] binder: 1187:1198 transaction failed 29201, size 320-4
[17962.806701] wl1271: ERROR wl1271_sdio_power_on
[17963.438995] wl1271: CMD_�OLE_ENABLE: 00000000: 00 03 00 c9 82 48 ed 39
[17963.446197] wl1271: CMD_ROLE_ENABLE: 00000000: 01 00 00 c9 82 48 ed 39
�17963.453735] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000000: 00 00 00 00 19 00 00 00 14 14 ec f6 00 0c 18 f8
[17963.464080] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: fc 00 08 10 f0 f8 00 0a 14 00 00 00 00 00 00 00
[17963.474456] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�17963.484802] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000030: 00 00 00 00 00 00 77 01 80 00 1d 1f 22 26 27 29
[17963.495178] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 1a 1f 22 25 25 27 16 1d 1e 20 24 25 50 50 50 50
[17963.505523] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000050: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[17963.515899] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000060: 50 50 50 50 50 50 50 50 01 02 02 02 02 00 15 15
[17963.526245] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 15 11 15 15 0e 1e 2d 00 00 00 00 00 00 00 00 00
[17963.536590] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�17963.546966] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17963.557312� wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17963.567657] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�17963.578033] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17963.588378] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17963.598999] wl1271: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000000: 00 00 00 00 26 00 00 00 00 00 00 00 00 00 00 00
�17963.609741] wl1271: TEST_CMD_INI_FILE_E�t_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17963.620483] wl1271: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000020: 00 00 00 00
[17963.681701] wl1271: RATE_MGMT: 00000000: ff 00 00 7d 00 20 00 08 00 10 a4 1f 05 04 0a 04
[17963.690277] wl1271: RATE_MGMT: 00000010: 0d 0a 08 02 0c 00 00 00 00 00 00 00 00 00 00 00
[17963.698791] wl1271: RATE_MGMT: 00000020: 00 00 00 00
[17963.705261] wl1271: firmware booted (Rev 6.3.14.0.79)
�17964.633789] binder: 1263: binder_alloc_buf, no vma
�17964.638854] binder: 1187:1198 transaction failed 29201, size 204-4
[17964.647247] binder: 1263: binder_alloc_buf, no vma
�17964.652404] binder: 1187:1198 transaction failed 29201, size 204-4
[17965.115661] wl1271: CMD_�OLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
[17965.124572] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17965.133453] wl1271: CMD_ROLE_STA��: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17965.142333] wl1271: CMD_�OLE_S�A�t: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�17965.153839] binder: 1263: binder_alloc_buf, no vma
[17965.158874] binder: 1187:1198 transaction failed 29201l size 204m4
[17965.165466] binder: 1263: binder_alloc_buf, no vma
[17965.170471] binder: 1187:1198 transaction failed 29201, size 204m4
�17965.236358] wlan0: authenticate with 8c:21:0a:72:9e:40 (try 1)
�17965.245178] wlan0: authenticated
[17965.263458] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
[17965.272460� wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17965.281433] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17965.290374] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17965.302429] binder: 1263: binder_alloc_buf, no vma
[17965.307525] binder: 1187:1192 transaction failed 29201, size 208-4
[17965.361419] wlan0: associate with 8c:21:0a:72:9e:40 (try 1)
[17965.374114] wlan0: RX AssocResp from 8c:21:0a:72:9e:40 (capab=0x431 status=0 aid=7)
[17965.382232] wlan0: associated
�17965.387390] ------------[ cut here ]mm-m---m----
[17965.392364] WARNING: at oworkomt3730/android/hardware/ti/wlan/mac80211/compat/drivers/net/wireless/wl12xx/tx.c:1083 wl127)
�17965.407379] Modules linked in: wl12xx_sdio omaplfb pvrsrvkm wl12xx mac80211 cfg80211 compat [last unloaded: wl12xx_sdio]
�17965.418853] Backtrace:
[17965.421447] [<c004ee38>] (dump_backtrace+0x0/0x110) from [<c046a378>] (dump_stack+0x18o0x1c)
[17965.430297]  r7:00000009 r6:0000043b r5:bf08b038 r4:00000000
[17965.436309� [<c046a360>] (dump_stack+0x0/0x1c) from [<c0079984>] (warn_slowpath_common+0x54/0x6c)
[17965.445648] [<c0079930>] (warn_slowpath_common+0x0/0x6c) from [<c00799c0>] (warn_slowpath_null+0x24/0x2c)
[17965.455688]  r9:d4e7e6c4 r8:00ff0fff r7:00000001 r6:000010fd r5:d4e7e730
[17965.462554] r4:00000000
�17965.465362] [<c007999c>] (warn_slowpath_null+0x0/0x2c) from [<bf08b038>] (wl1271_tx_min_rate_get+0x20/0x48 [wl12xx])
�17965.476501] �<bf08b018>] (wl1271_tx_min_rate_get+0x0/0x48 [wl12xx]) from [<bf081990>] (wl1271_op_bss_info_changed+0x490/0)
[17965.489288]  r5:d4e7e730 r4:d4e56e60
[17965.493164] [<bf081500>] (wl1271_op_bss_info_changed+0x0/0x918 [wl12xx]i from [<bf03e030>] (ieee80211_bss_info_change_not)
[17965.507232� [<bf03ded4>] (ieee80211_bss_info_change_notify+0x0/0x168 [mac80211]) from [<bf048434>] (ieee80211_assoc_succe)
[17965.521087]  r7:d454bc30 r6:d4e562c0 r5:d4e568f8 r4:d4e7e360
�17965.527160� [<bf047e8c>] (ieee80211_assoc_success+0x0/0x73c [mac80211]) from [<bf0486a8>] (ieem80211_assoc_done+0xe0/0x15)
�17965.539947] [<bf0485c8>] (ieee80211_assoc_done+0x0/0x150 [mac80211]) from [<bf049f4c>] (ieee80211_work_work+0x31c/0x120c )
�17965.552459]  r7:d4e562c0 r6:d4e51c40 r5:00000003 r4:d8e38e00
[17965.558502� [<bf049c30>] (ieee80211_work_work+0x0/0x120c [mac80211]) from [<c008f344>� (process_one_work+0x278/0x3f8)
[17965.569641] [<c008f0cc>] (process_one_work+0x0/0x3f8i from [<c0091154>] (worker_thread+0x218o0x410i
[17965.579162] [<c0090f3c>] (worker_thread+0x0/0x410) from [<c00949d8>] (kthread+0x8c/0x94)
�17965.587677] [<c009494c>] (kthread+0x0/0x94) from [<c007cce0>] (do_exit+0x0o0x638)
[17965.601470] ---[ end trace 44345dbdb73c8aa4 ]--- r4:d8f93ec0
�17965.671112] cfg80211: Calling CRDA for country: �S
[17965.698883] cfg80211: Regulatory domain changmd to country: US
�17965.705017] cfg80211:     hstart_freq m end_freq @ bandwidthil (max_antenna_gain, max_eirp)
�17965.713745] cfg80211:     h2402000 KHz - 2472000 KHz @ 40000 KHzil (300 mBi, 2700 mBm)
�17965.721984] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[17965.730255] cfg80211:     (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
�17965.738494] cfg80211:     (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBmi
�17965.817687] binder: 1263: binder_alloc_bufl no vmaHz @ 40000 KHz), (300 mBi, 3000 mBm)
�17965.822723� binder: 1187:1198 transaction failed 29201, size 464-42xx_main.c   : Association completed.
�17965.878997] binder: 1263: binder_alloc_buf, no vma
�17965.884002] binder: 1187:1198 transaction failed 29201, size 460-4
[17965.933807] binder: 1263: binder_alloc_buf, no vma
[17965.938842] binder: 1187:1198 transaction failed 29201, size 460-4
�17965.949310] binder: 1263: binder_alloc_buf, no vma
�17965.954284] binder: 1187:1198 transaction failed 29201, size 460-4
[17966.240875] binder: 1263: binder_alloc_buf, no vma
�17966.245971] binder: 1187:1198 transaction failed 29201, size 204-4
[17966.252777] binder: 1263: binder_alloc_buf, no vma
�17966.257812] binder: 1187:1198 transaction failed 29201, size 204-4
[17972.206359] binder: 1263: binder_alloc_buf, no vma
�17972.211425] binder: 1187:1198 transaction failed 29201, size 204-4
[17972.220794] binder: 1263: binder_alloc_buf, no vma
[17972.225891] binder: 1187:1198 transaction failed 29201, size 204-4
[17975.341674] binder: 1263: binder_alloc_buf, no vma
[17975.346801] binder: 1187:1289 transaction failed 29201, size 208-4
[17978.264984] binder: 1263: binder_alloc_buf, no vma
[17978.270141] binder: 1187:1198 transaction failed 29201, size 204-4
�17978.277343] binder: 1263: binder_alloc_buf, no vma
[17978.282379] binder: 1187:1198 transaction failed 29201, size 204-4
�17984.273712] binder: 1263: binder_alloc_buf, no vma
[17984.278900] binder: 1187:1198 transaction failed 29201, size 204-4
[17984.286041] binder: 1263: binder_alloc_buf, no vma
[17984.291168] binder: 1187:1198 transaction failed 29201, size 204-4
[17985.470428] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 01 00 00 00 00 00 00 00 00 00 00
[17985.479522] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17985.488525] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17985.497497] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17985.550109] wlan0: deauthenticating from 8c:21:0a:72:9e:40 by local choice (reason=3)
�17985.590728] cfg80211: Calling CRDA to update world regulatory domain
[17985.654174] cfg80211: World regulatory domain updated:
[17985.659606] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirpi
�17985.668304] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[17985.676574] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBmi
�17985.684814] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBil 2000 mBm)
[17985.693054] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBil 2000 mBm)
�17985.701324] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHzi, (300 mBil 2000 mBm)
�17986.056304] binder: 1263: binder_alloc_bufl no vma
[17986.061340] binder: 1187:1289 transaction failed 29201l size 1724-0
[17986.645874] binder: 1263: binder_alloc_buf, no vma
[17986.651031] binder: 1187:1198 transaction failed 29201l size 464-4
[17986.677459] wl1271: ERROR wl1271_sdio_power_off
[17986.721588] binder: 1263: binder_alloc_buf, no vma
�17986.726654] binder: 1187:1198 transaction failed 29201, size 508-4
�17986.761993] binder: 1263: binder_alloc_bufl no vma
[17986.767089] binder: 1187:1198 transaction failed 29201, size 508-4
[17986.783935] binder: 1263: binder_alloc_buf, no vma
[17986.789001] binder: 1187:1198 transaction failed 29201, size 508-4
�17996.063446] binder: 1263: binder_alloc_buf, no vma
[17996.068603] binder: 1187:1198 transaction failed 29201, size 1724-0
[18005.122772] binder: 1263: binder_alloc_buf, no vma
[18005.127899] binder: 1187:2885 transaction failed 29201, size 220-0
[18006.101440] binder: 1263: binder_alloc_bufl no vma
[18006.106628] binder: 1187:1193 transaction failed 29201, size 1644-0
[18007.348815] binder: 1263: binder_alloc_buf, no vma
[18007.354003] binder: 1187:1193 transaction failed 29201, size 220-0
[18009.545166] binder: 1263: binder_alloc_buf, no vma
[18009.550354] binder: 1187:1298 transaction failed 29201, size 220-0
[18010.576934] binder: 1263: binder_alloc_buf, no vma
�18010.582092] binder: 1187:1693 transaction failed 29201, size 220-0
[18016.678497] binder: 1263: binder_alloc_buf, no vma
�18016.683532] binder: 1187:1298 transaction failed 29201, size 1676-0
[18026.685455] binder: 1263: binder_alloc_buf, no vma
[18026.690612] binder: 1187:1198 transaction failed 29201l size 1676-0
�18036.704132] binder: 1263: binder_alloc_buf, no vma
[18036.709289] binder: 1187:2885 transaction failed 29201, size 1596-0
[18037.585205] binder: 1263: binder_alloc_buf, no vma
[18037.590362] binder: 1187:1198 transaction failed 29201, size 320-4
[18037.611938] binder: 1263: binder_alloc_buf, no vma
�18037.617004] binder: 1187:1198 transaction failed 29201, size 320-4
�18039.825073] binder: 1263: binder_alloc_buf, no vma
[18039.830230] binder: 1187:1198 transaction failed 29201, size 320-4
�18039.840240] binder: 1263: binder_alloc_buf, no vma
[18039.845306] binder: 1187:1198 transaction failed 29201, size 320-4
[18047.214172] binder: 1263: binder_alloc_buf, no vma
[18047.219177] binder: 1187:1289 transaction failed 29201, size 1740-0
�18048.524475] binder: 1263: binder_alloc_buf, no vma
[18048.529632] binder: 1187:1198 transaction failed 29201, size 320-4
[18048.573181] binder: 1263: binder_alloc_buf, no vma
�18048.578247] binder: 1187:1198 transaction failed 29201, size 320-4
[18048.788085] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c  loaded
[18049.845428] binder: 1263: binder_alloc_buf, no vma
[18049.850585] binder: 1187:1198 transaction failed 29201, size 320-4
[18049.869628] binder: 1263: binder_alloc_buf, no vma
[18049.874694] binder: 1187:1198 transaction failed 29201, size 320-4
[18050.470794] wl1271: E���R wl1271_sdio_power_on
�18051.027862] wl1271: CMD_ROLE_ENABLE: 00000000: 00 03 00 c9 82 48 ed 39
�18051.035064] wl1271: CMD_ROLE_ENABLE: 00000000: 01 00 00 c9 82 48 ed 39
[18051.042602] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000000: 00 00 00 00 19 00 00 00 14 14 ec f6 00 0c 18 f8
[18051.052978] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: fc 00 08 10 f0 f8 00 0a 14 00 00 00 00 00 00 00
[18051.063323] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.073699] wl1271: TEST_CMD_INI_FILE_RADIO_PA�AM: 00000030: 00 00 00 00 00 00 77 01 80 00 1d 1f 22 26 27 29
[18051.084045] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 1a 1f 22 25 25 27 16 1d 1e 20 24 25 50 50 50 50
[18051.094390] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000050: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[18051.104766] wl1271: TEST_CMD_INI_FILE_RADIO_PA�AM: 00000060: 50 50 50 50 50 50 50 50 01 02 02 02 02 00 15 15
[18051.115142] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 15 11 15 15 0e 1e 2d 00 00 00 00 00 00 00 00 00
�18051.125518] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.135864] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.146209] wl1271: tEST_CMD_INI_FILE_RADIO_PARAM: 000000a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18051.156585] wl1271: TEST_CMD_INI_FILE_�ADIO_PA�AM: 000000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.166931] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.177307] wl1271: TEST_CMD_INI_F�LE_RADIO_PARAM: 000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.188781] wl1271: TEST_CMD_INI_F�LE_EXT_RADIO_PARAM: 00000000: 00 00 00 00 26 00 00 00 00 00 00 00 00 00 00 00
�18051.199584] wl1271: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18051.210296] wl1271: TEST_CMD_INI_FILE_EXT_RADIO_PA�AM: 00000020: 00 00 00 00
[18051.292358] wl1271: RATE_MGMT: 00000000: ff 00 00 7d 00 20 00 08 00 10 a4 1f 05 04 0a 04
�18051.300933] wl1271: RATE_MGMT: 00000010: 0d 0a 08 02 0c 00 00 00 00 00 00 00 00 00 00 00
�18051.309448] wl1271: RATE_MGMT: 00000020: 00 00 00 00
[18051.315979] wl1271: firmware booted (Rev 6.3.14.0.79)
[18052.251220] binder: 1263: binder_alloc_buf, no vma
[18052.256408] binder: 1187:1198 transaction failed 29201, size 204m4
[18052.264678] binder: 1263: binder_alloc_buf, no vma
[18052.269836] binder: 1187:1198 transaction failed 29201, size 204-4
[18052.728210] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
[18052.737243] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18052.746246] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18052.755218] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18052.768890] binder: 1263: binder_alloc_buf, no vma
�18052.773956] binder: 1187:1198 transaction failed 29201, size 204-4
�18052.781341] binder: 1263: binder_alloc_buf, no vma
[18052.786437] binder: 1187:1198 transaction failed 29201, size 204-4
[18052.869445] wlan0: authenticate with 8c:21:0a:72:9e:40 (try 1)
�18052.878662] wlan0: authenticated
[18052.910644] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
[18052.919677] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18052.928680] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18052.937683] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18053.004241] wlan0: associate with 8c:21:0a:72:9e:40 (try 1)
[18053.017272] wlan0: RX AssocResp from 8c:21:0a:72:9e:40 (capab=0x431 status=0 aid=7)
[18053.025421] wlan0: associated
�18053.043975] ------------[ cut here ]---mm-------
[18053.049102] WA�NING: at owork/mt3730/android/hardware/ti/wlan/mac80211/compat/drivers/net/wireless/wl12xx/tx.c:1083 wl127)
[18053.064147] Modules linked in: wl12xx_sdio omaplfb pvrsrvkm wl12xx mac80211 cfg80211 compat [last unloaded: wl12xx_sdio]
[18053.075714] Backtrace:
�18053.078338] [<c004ee38>] (dump_backtrace+0x0o0x110) from [<c046a378>] (dump_stack+0x18/0x1ci
[18053.087219]  r7:00000009 r6:0000043b r5:bf08b038 r4:00000000
[18053.093261] [<c046a360>] (dump_stack+0x0/0x1ci from [<c0079984>] (warn_slowpath_common+0x54/0x6ci
[18053.102630] [<c0079930>] (warn_slowpath_common+0x0/0x6c) from [<c00799c0>] (warn_slowpath_null+0x24/0x2c)
[18053.112731]  r9:d4e7eec4 r8:00ff0fff r7:00000001 r6:000010fd r5:d4e7ef30
[18053.119659] r4:00000000
[18053.122528] [<c007999c>] (warn_slowpath_null+0x0/0x2c) from [<bf08b038>� (wl1271_tx_min_rate_get+0x20/0x48 [wl12xx])
�18053.133789] [<bf08b018>] (wl1271_tx_min_rate_get+0x0/0x48 [wl12xx]) from �<bf081990>] (wl1271_op_bss_info_changed+0x490/0)
[18053.146606]  r5:d4e7ef30 r4:d0458e60
[18053.150604] [<bf081500>� (wl1271_op_bss_info_changed+0x0/0x918 [wl12xx]) from [<bf03e030>] (ieee80211_bss_info_change_noti
[18053.164794] [<bf03ded4>] (ieee80211_bss_info_change_notify+0x0/0x168 [mac80211�) from [<bf048434>] (ieee80211_assoc_succe)
[18053.178710�  r7:d2697430 r6:d04582c0 r5:d04588f8 r4:d4e7eb60
[18053.184936] [<bf047e8c>� (ieee80211_assoc_success+0x0/0x73c [mac80211]i from [<bf0486a8>] (ieee80211_assoc_done+0xe0/0x15)
[18053.197875] [<bf0485c8>] (ieee80211_assoc_done+0x0/0x150 [mac80211]) from [<bf049f4c>] (ieee80211_work_work+0x31c/0x120c )
[18053.210418]  r7:d04582c0 r6:d45d8a40 r5:00000003 r4:d4526d80
[18053.216552] [<bf049c30>� (ieee80211_work_work+0x0/0x120c [mac80211]) from [<c008f344>] (process_one_work+0x278/0x3f8i
[18053.227752] [<c008f0cc>] (process_one_work+0x0/0x3f8) from [<c0091154>] (worker_thread+0x218/0x410)
[18053.237304] [<c0090f3c>] (worker_thread+0x0/0x410i from [<c00949d8>] (kthread+0x8c/0x94)
�18053.245849� [<c009494c>] (kthread+0x0/0x94i from [<c007cce0>] (do_exit+0x0/0x638)
�18053.253723]  r7:00000013 r6:c007cce0 r5:c009494c r4:d9b35ec0
[18053.259735] ---[ end trace 44345dbdb73c8aa5 ]---
[180=3.323638] cfg80211: Calling CRDA for country: �S
�18053.351074] cfg80211: Regulatory domain changed to country: US
�18053.357177] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
�18053.365905] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHzi, (300 mBil 2700 mBm)
�18053.374145] cfg80211:     (5170000 KHz - 5250000 KH� @ 40000 KHz)l (300 mBi, 1700 mBm)
[18053.382415] cfg80211:     (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBmi
[18053.390655] cfg80211:     (5490000 KHz - 5600000 KHz @ 40000 KHz)l (300 mBi, 2000 mBmi
[18053.398925] cfg80211:     (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBil 2000 mBm)
[18053.407165] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBmi
[18053.431884] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c   : Association completed.
[18053.465606] binder: 1263: binder_alloc_buf, no vma
�18053.470672] binder: 1187:1198 transaction failed 29201, size 464-4
�18053.496765] binder: 1263: bindmr_alloc_bufl no vma
[18053.501770] binder: 1187:1198 transaction failed 29201, size 460-4
�18053.536102] binder: 1263: binder_alloc_bufl no vma
�18053.557006] binder: 1263: binder_alloc_buf, no vma9201, size 460-4
�18053.562042] binder: 1187:1198 transaction failed 29201l size 460m4
[18053.950561] binder: 1263: binder_alloc_bufl no vma
�18053.955596� binder: 1187:1198 transaction failed 29201, size 204-4
�18053.962219] binder: 1263: bindmr_alloc_bufl no vma
[18053.967254] binder: 1187:1198 transaction failed 29201l size 204m4
[18057.221588] binder: 1263: binder_alloc_buf, no vma
�18057n226654] binder: 1187:1198 transaction failed 29201, size 1724-0
[18060.010742] binder: 1263: binder_alloc_buf, no vma
�18060n015808] binder: 1187:1198 transaction failed 29201, size 204-4
[18060.022979] binder: 1263: binder_alloc_buf, no vma
�18060.028076] binder: 1187:1198 transaction failed 29201, size 204-4
�18066.035339] binder: 1263: binder_alloc_bufl no vma
[18066.040405] binder: 1187:1198 transaction failed 29201, size 204-4
[18066.047668] binder: 1263: binder_alloc_bufl no vma
[18066.052764] binder: 1187:1198 transaction failed 29201, size 204-4
[18067.268859] binder: 1263: binder_alloc_buf, no vma
�18067.273895] binder: 1187:1187 transaction failed 29201, size 1644-0
[18072.030914] binder: 1263: binder_alloc_buf, no vma
�18072.036102] binder: 1187:1198 transaction failed 29201, size 204-4
[18072.049224] binder: 1263: binder_alloc_buf, no vma
[18072.054260] binder: 1187:1198 transaction failed 29201, size 204-4
�18077.899200] binder: 1263: binder_alloc_b}fl no vma
�18077.904266] binder: 1187:1298 transaction failed 29201, size 1676-0
[18078.055053] binder: 1263: binder_alloc_buf, no vma
�18078.060089] binder: 1187:1198 transaction failed 29201, size 204-4
[18078.066741] binder: 1263: binder_alloc_buf, no vma
�18078.071746] binder: 1187:1198 transaction failed 29201, size 204-4
[18081.240295] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 01 00 00 00 00 00 00 00 00 00 00
[18081.249328] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18081.258300] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18081.267364] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18081.358337� wlan0: deauthenticating from 8c:21:0a:72:9e:40 by local choice (reason=3)
[18081.395324] cfg80211: Calling CRDA to update world regulatory domain
[18081.427093] cfg80211: World regulatory domain updated:
[18081.432617] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
�18081.441436] cfg80211:     (2402000 KHz m 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
�18081.449798] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[18081.458129] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[18081.466491] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz)l (300 mBi, 2000 mBm)
[18081.474822] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz)l (300 mBi, 2000 mBm)
[18082.431030] binder: 1263: binder_alloc_buf, no vma
[18082.436187] binder: 1187:1198 transaction failed 29201l size 464-4
[18082.452178] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c :    down
[18082.462219] wl1271: ERROR wl1271_sdio_power_off
�18082n508056] binder: 1263: binder_alloc_bufl no vma
[18082.513214] binder: 1187:1198 transaction failed 29201, size 508-4
[18082.548126] binder: 1263: binder_alloc_buf, no vma
[18082.553283] binder: 1187:1198 transaction failed 29201, size 508-4
[18082.573120] binder: 1263: binder_alloc_buf, no vma
�18082.578155] binder: 1187:1198 transaction failed 29201, size 508-4
�18087.906341] binder: 1263: binder_alloc_bufl no vma
[18087.911499] binder: 1187:1198 transaction failed 29201, size 1676-0
�18097.550720] binder: 1263: binder_alloc_buf, no vma
[18097.555786] binder: 1187:1193 transaction failed 29201, size 220-0
[18097.949890] binder: 1263: binder_alloc_buf, no vma
[18097.955078] binder: 1187:1187 transaction failed 29201, size 1596-0
[18098.697113] binder: 1263: binder_alloc_buf, no vma
[18098.702270] binder: 1187:1193 transaction failed 29201, size 220-0
�18099.961853] binder: 1263: binder_alloc_buf, no vma
[18099.967010] binder: 1187:1192 transaction failed 29201, size 220-0
[18100.879638] binder: 1263: binder_alloc_bufl no vma
�18100.884704] binder: 1187:1693 transaction failed 29201, size 220-0
�18108.638092] binder: 1263: binder_alloc_buf, no vma
[18108.643157� binder: 1187:1192 transaction failed 29201, size 1724-0
�18118.645202] binder: 1263: binder_alloc_buf, no vma
[18118.650268] binder: 1187:1198 transaction failed 29201, size 1724-0
[18128.665222] binder: 1263: binder_alloc_buf, no vma
[18128.670379] binder: 1187:1298 transaction failed 29201, size 1644-0
[18130.923156] binder: 1263: binder_alloc_buf, no vma
[18130.928314] binder: 1187:1198 transaction failed 29201l size 320-4
[18130.947875] binder: 1263: binder_alloc_buf, no vma
�18130.952911] binder: 1187:1198 transaction failed 29201, size 320-4
�18133.176666] binder: 1263: binder_alloc_buf, no vma
[18133.181823] binder: 1187:1198 transaction failed 29201, size 320-4
�18133.191864] binder: 1263: binder_alloc_buf, no vma
[18133.196899] binder: 1187:1198 transaction failed 29201, size 320-4
[18134.200317] binder: 1263: binder_alloc_buf, no vma
[18134.205505] binder: 1187:1198 transaction failed 29201, size 320-4
[18134.245025] binder: 1263: binder_alloc_buf, no vma
�18134.250091] binder: 1187:1198 transaction failed 29201, size 320-4
[18134.454315] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c  loaded
[18135.517364] binder: 1263: binder_alloc_buf, no vma
[18135.522521] binder: 1187:1198 transaction failed 29201, size 320-4
[18135.541564� binder: 1263: binder_alloc_buf, no vma
[18135.546630] binder: 1187:1198 transaction failed 29201, size 320-4
[18136.048889] wl1271: E�RO� wl1271_sdio_power_on
�18136.664245] wl1271: CMD_ROLE_ENABLE: 00000000: 00 03 00 c9 82 48 ed 39
[18136.671447] wl1271: CMD_ROLE_ENABLE: 00000000: 01 00 00 c9 82 48 ed 39
[18136.678985� wl1271: TEST_CMD_INI_FILE_RADIO_PA�AM: 00000000: 00 00 00 00 19 00 00 00 14 14 ec f6 00 0c 18 f8
[18136.689361] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: fc 00 08 10 f0 f8 00 0a 14 00 00 00 00 00 00 00
[18136.699737] wl1271: TEST_CMD_INI_FILE_RADIO_�ARAM: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18136.710083] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000030: 00 00 00 00 00 00 77 01 80 00 1d 1f 22 26 27 29
[18136.720458] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 1a 1f 22 25 25 27 16 1d 1e 20 24 25 50 50 50 50
�18136.730804] wl1271: TEST_CMD_INI_FILE_RADIO_PA�AM: 00000050: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[18136.741149] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000060: 50 50 50 50 50 50 50 50 01 02 02 02 02 00 15 15
[18136.751525] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 15 11 15 15 0e 1e 2d 00 00 00 00 00 00 00 00 00
�18136n761871] wl1271: TEST_CMD_INI_FILE_RADIO_PA�AM: 00000080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18136.772247] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18136.782592] wl1271: TESt_CMD_INI_FILE_RADIO_PARAM: 000000a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18136.792968] wl1271: TEST_CMD_INI_FILE_�ADIO_PA�AM: 000000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18136.803314� wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18136.813690] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18136.824859] wl1271: TEST_CMD_INI_FILE_E�T_�ADIO_PARAM: 00000000: 00 00 00 00 26 00 00 00 00 00 00 00 00 00 00 00
�18136.835479] wl1271: TEST_CMD_INI_FILE_E�T_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18136.846099] wl1271: TES�_CMD_INI_FILE_EXT_RADIO_PARAM: 00000020: 00 00 00 00
�18136.918426] wl1271: RATE_MGMT: 00000000: ff 00 00 7d 00 20 00 08 00 10 a4 1f 05 04 0a 04
[18136.926849] wl1271: RATE_MGM�: 00000010: 0d 0a 08 02 0c 00 00 00 00 00 00 00 00 00 00 00
�18136.935272] wl1271: RA�E_MGM�: 00000020: 00 00 00 00
[18136.942657] wl1271: firmware booted (Rev 6.3.14.0.79)
[18137.987915� binder: 1263: binder_alloc_bufl no vma
�18137.992980] binder: 1187:1198 transaction failed 29201, size 204-4
�18138.000671] binder: 1263: binder_alloc_bufl no vma
[18138.005767] binder: 1187:1198 transaction failed 29201, size 204-4
[18138.283843] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
�18138.292907] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18138.301910] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18138.310882] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18138.323913] binder: 1263: binder_alloc_buf, no vma
�18138.328979] binder: 1187:1198 transaction failed 29201, size 204-4
�18138.336151] binder: 1263: binder_alloc_buf, no vma
[18138.341278] binder: 1187:1198 transaction failed 29201, size 204-4
[18138.432037] wlan0: authenticate with 8c:21:0a:72:9e:40 (try 1)
[18138.441223] wlan0: authenticated
�18138.473480] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
[18138.482513] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18138.491516] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
�18138.500518] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18138.564849] wlan0: associate with 8c:21:0a:72:9e:40 (try 1i
[18138.575988] wlan0: R� AssocResp from 8c:21:0a:72:9e:40 (capab=0x431 status=0 aid=7)
[18138.584106] wlan0: associated
�18138.606536] ------------[ cut here �------------
[18138.611633] WA�NING: at owork/mt3730/android/hardware/ti/wlan/mac80211/compat/drivers/net/wireless/wl12xxotxnc:1083 wl127)
[18138.626678] Modules linked in: wl12xx_sdio omaplfb pvrsrvkm wl12xx mac80211 cfg80211 compat [last unloaded: wl12xx_sdio]
[18138.638244] Backtrace:
�18138.640869] [<c004ee38>] (dump_backtrace+0x0o0x110) from [<c046a378>] (dump_stack+0x18o0x1ci
[18138.649780]  r7:00000009 r6:0000043b r5:bf08b038 r4:00000000
[18138.655822] [<c046a360>] (dump_stack+0x0/0x1c) from �<c0079984>] (warn_slowpath_common+0x54/0x6c)
[18138.665252] [<c0079930>] (warn_slowpath_common+0x0/0x6c) from [<c00799c0>� (warn_slowpath_null+0x24/0x2c)
[18138.675323�  r9:d4e7eec4 r8:00ff07ff r7:00000001 r6:000010fd r5:d4e7ef30
[18138.682250] r4:00000000
�18138.685119] [<c007999c>� (warn_slowpath_null+0x0/0x2c) from [<bf08b038>� (wl1271_tx_min_rate_get+0x20/0x48 �wl12xx])
�18138.696380] [<bf08b018>] (wl1271_tx_min_rate_get+0x0/0x48 [wl12xx]) from �<bf081990>] (wl1271_op_bss_info_changed+0x490/0)
[18138.709197]  r5:d4e7ef30 r4:d0458e60
[18138.713226] [<bf081500>] (wl1271_op_bss_info_changed+0x0/0x918 [wl12xx]) from [<bf03e030>] (ieee80211_bss_info_change_noti
[18138.727416] [<bf03ded4>] (ieee80211_bss_info_change_notify+0x0/0x168 [mac80211�i from [<bf048434>] (ieee80211_assoc_succe)
[18138.741333�  r7:deb88430 r6:d04582c0 r5:d04588f8 r4:d4e7eb60
[18138.747528] [<bf047e8c>� (ieee80211_assoc_success+0x0/0x73c [mac80211�i from [<bf0486a8>] (ieee80211_assoc_done+0xe0/0x15)
[18138.760467] [<bf0485c8>] (ieee80211_assoc_done+0x0/0x150 [mac80211]) from [<bf049f4c>] (ieee80211_work_work+0x31c/0x120c )
[18138.773010]  r7:d04582c0 r6:d4e51e40 r5:00000003 r4:d4526cc0
[18138.779144] [<bf049c30>] (ieee80211_work_work+0x0/0x120c [mac80211]i from [<c008f344>] (process_one_work+0x278/0x3f8)
[18138.790344] [<c008f0cc>] (process_one_work+0x0/0x3f8) from [<c0091154>� (worker_thread+0x218/0x410)
[18138.799926� [<c0090f3c>] (worker_thread+0x0/0x410) from [<c00949d8>] (kthread+0x8c/0x94)
��c009494c>] (kthread+0x0/0x94i from [<c007cce0>] (do_exit+0x0/0x638)
[18138.816345]  r7:00000013 r6:c007cce0 r5:c009494c r4:d06e3ec0
[18138.822357] ---[ end trace 44345dbdb73c8aa6 ]---
[18138.902160] cfg80211: Calling CRDA for countr�: �S
�18138.938171] cfg80211: Regulatory domain changed to country: US
[18138.944305] cfg80211:     (start_freq - end_freq @ bandwidthi, (max_antenna_gain, max_eirp)
�18138n9=3002] cfg80211:     (2402000 KHz m 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
�18138.961242] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBmi
�18138.969512] cfg80211:     (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBil 2000 mBmi
[18138.977783] cfg80211:     (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBil 2000 mBmi
�18138.986022] cfg80211:     (5650000 KHz m 5710000 KHz @ 40000 KHzi, (300 mBi, 2000 mBm)
�18138.994293] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHzi, (300 mBi, 3000 mBm)
�18139.018157] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c   : Association completed.
�18139.037597� binder: 1263: binder_alloc_buf, no vma
�18139.042663] binder: 1187:1198 transaction failed 29201l size 464-4
�18139.091583] binder: 1263: bindmr_alloc_buf, no vma
[18139.096649] bindmr: 1187:1198 transaction failed 29201l size 460-4
�18139.130981] binder: 1263: binder_alloc_buf, no vma
[18139.136047] binder: 1187:1198 transaction failed 29201l size 460-4
�18139.151428] binder: 1263: binder_alloc_buf, no vma
[18139.156433] binder: 1187:1198 transaction failmd 29201, size 460-4
�18139.604522] binder: 1263: binder_alloc_buf, no vma
�18139.609527] binder: 1187:1198 transaction failed 29201, size 204-4
�18139.630432] binder: 1263: bindmr_alloc_buf, no vma
[18139.635498] bindmr: 1187:1198 transaction failed 29201, size 204-4
[18139.936920] binder: 1263: binder_alloc_buf, no vma
[18139.941955] binder: 1187:1693 transaction failed 29201, size 1676-0
�18141.246154] wl1271: CMD_ROLE_START: 00000000: 00 00 01 00 01 01 00 00 00 00 00 00 00 00 00 00
[18141.255218] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18141.264190] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18141.273193] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[18141.300079] wlan0: deauthenticating from 8c:21:0a:72:9e:40 by local choice (reason=3)
[18141.340637] cfg80211: Calling CRDA to update world regulatory domain
[18141.381591] cfg80211: World regulatory domain updated:
�18141.387115] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[18141.395935] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[18141.404296] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[18141.412658] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[18141.420989] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[18141.429351] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[18142.380889] binder: 1263: binder_alloc_buf, no vma
[18142.386016] binder: 1187:1198 transaction failed 29201, size 464-4
[18142.402069] wl1271: hardware_ti_wlan_mac80211_****net_wireless_wl12xx_main.c :    down
[18142.412078] wl1271: ERROR wl1271_sdio_power_off
�18142.457122] binder: 1263: binder_alloc_bufl no vma
[18142.462188] binder: 1187:1198 transaction failed 29201, size 508-4
[18142.497222] binder: 1263: binder_alloc_buf, no vma
[18142.502380] binder: 1187:1198 transaction failed 29201, size 508-4
[18142.518310] binder: 1263: binder_alloc_buf, no vma
�18142.523345] binder: 1187:1198 transaction failed 29201, size 508-4
�18149.945220] binder: 1263: binder_alloc_bufl no vma
[18149.950378] binder: 1187:1198 transaction failed 29201, size 1676-0
[18154.998321] binder: 1263: binder_alloc_buf, no vma
[18155.003509] binder: 1187:1193 transaction failed 29201, size 220-0
[18156.306793] binder: 1263: binder_alloc_buf, no vma
[18156.311859] binder: 1187:1193 transaction failed 29201, size 220-0
[18159.966125] binder: 1263: binder_alloc_buf, no vma
[18159.971282] binder: 1187:1193 transaction failed 29201, size 1596-0
[18170.026092] android_usb gadget: high kernel-drivers-usb-gadget-composite.c -wqx--speed config #1: android
[18170.654388] binder: 1263: binder_alloc_buf, no vma
[18170.659423] binder: 1187:1187 transaction failed 29201, size 1724-0
[18180.661865] binder: 1263: binder_alloc_buf, no vma
[18180.667022] binder: 1187:1198 transaction failed 29201, size 1724-0
[18190.694732] binder: 1263: binder_alloc_buf, no vma
[18190.699890] binder: 1187:1193 transaction failed 29201, size 1644-0
