MCSDK编译错误问题请教
编译MCSDK,使用的版本号mcsdk-03.01.03.06-config.txt,编译命令为:MACHINE=k2hk-evm TOOLCHAIN_BRAND=linaro ARAGO_BRAND=mcsdk bitbake tisdk-server-rootfs-image
错误提示为:
| DEBUG: Executing shell function do_compile
| make -C /opt/workspace/ti/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/ti-edma3/2.11.13-r1/git/packages edma3_lld_tci6636k2h-evm_a15_libs PLATFORM=tci6636k2h-evm TARGET=a15 ;
| make[1]: Entering directory `/opt/workspace/ti/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/ti-edma3/2.11.13-r1/git/packages'
| make[1]: echo: Command not found
| make[1]: *** [edma3_lld_tci6636k2h-evm_a15_libs_drv] Error 127
| make[1]: Leaving directory `/opt/workspace/ti/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/ti-edma3/2.11.13-r1/git/packages'
| make: *** [edma3_lld_lib_target] Error 2
| ERROR: Function failed: do_compile (see /opt/workspace/ti/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/ti-edma3/2.11.13-r1/temp/log.do_compile.7795 for further information)
