.bss SECTION 编译报错
warning #10281-D: Section ".bss" requires a STATIC_BASE relative relocation, but is located at 0x0c038f98, which is probably out of range of the STATIC_BASE. STATIC_BASE is located at 0x0c01ffff. Might be required to correct   placement of ".bss" so it lies within 0x8000 of the STATIC_BASE.
我用的平台是C6678,所有section都放在MSMC中。
