我们现在的DM385开发板上外挂了一个tvp5151芯片,用来接CVBS摄像头,原理图如下:
tvp5151输出8bit 内嵌同步的CVBS(NTSC或PAL)信号到DM385的VIP1 PORTA的D0~D7位上,数据流如下:
tvp5151(cvbs) -> capture-> deinterlace -> encode -> send
软件版本使用的是dvr rdk 4.0,代码如下:
void MultiCh_createVcapVencVdis()
CaptureLink_CreateParams capturePrm;
DeiLink_CreateParams deiPrm;
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssToHostPrm;
IpcFramesInLinkRTOS_CreateParams ipcFramesInVideoFromHostPrm;
EncLink_CreateParams encPrm;
IpcBitsOutLinkRTOS_CreateParams ipcBitsOutVideoPrm;
IpcBitsInLinkHLOS_CreateParams ipcBitsInHostPrm;
CaptureLink_VipInstParams *pCaptureInstPrm;
CaptureLink_OutParams *pCaptureOutPrm;
VCAP_VIDEO_SOURCE_STATUS_S vidSourceStatus;
int i;
MULTICH_INIT_STRUCT(DeiLink_CreateParams, deiPrm);
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams, ipcFramesOutVpssToHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams, ipcFramesInVideoFromHostPrm);
MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams, ipcBitsOutVideoPrm);
MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams, ipcBitsInHostPrm);
gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE;
gVcapModuleContext.deiId[0] = SYSTEM_LINK_ID_DEI_0;
gVcapModuleContext.ipcFramesOutVpssToHostId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;
gVencModuleContext.ipcM3InId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0;
gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
MultiCh_detectBoard();
System_linkControl(SYSTEM_LINK_ID_M3VPSS,
SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
NULL,
0,
TRUE
System_linkControl(SYSTEM_LINK_ID_M3VIDEO,
SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
&systemVid_encDecIvaChMapTbl,
sizeof(SystemVideo_Ivahd2ChMap_Tbl),
TRUE
gVcapModuleContext.isWrbkCaptEnable = FALSE;
CaptureLink_CreateParams_Init(&capturePrm);
capturePrm.outQueParams[0].nextLink = gVcapModuleContext.deiId[0];
capturePrm.isPalMode = TRUE;
capturePrm.numVipInst = 1;
capturePrm.enableSdCrop = FALSE;
capturePrm.doCropInCapture = FALSE;
capturePrm.tilerEnable = FALSE;
capturePrm.numBufsPerCh = NUM_CAPTURE_BUFFERS;
capturePrm.overrideNumBufsInInstPrms = 1u;
pCaptureInstPrm = &capturePrm.vipInst[0];
pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P;
//pCaptureInstPrm->standard = SYSTEM_STD_D1;
pCaptureInstPrm->standard = SYSTEM_STD_MUX_4CH_D1;
pCaptureInstPrm->videoDecoderId = 0;
pCaptureInstPrm->numOutput = 1;
pCaptureInstPrm->numBufsPerCh = NUM_CAPTURE_BUFFERS;
pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA;
pCaptureInstPrm->videoIfMode = SYSTEM_CAPT_VIDEO_IF_MODE_8BIT;
pCaptureInstPrm->inScanFormat = SYSTEM_SF_INTERLACED;
pCaptureOutPrm = &pCaptureInstPrm->outParams[0];
pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV;
pCaptureOutPrm->scEnable = FALSE;
pCaptureOutPrm->scOutWidth = 0;
pCaptureOutPrm->scOutHeight = 0;
pCaptureOutPrm->outQueId = 0;
deiPrm.inQueParams.prevLinkId = gVcapModuleContext.captureId;
deiPrm.inQueParams.prevLinkQueId = 0;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.denominator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.denominator = 1;
for (i = 1; i < DEI_LINK_MAX_CH; i++)
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];
deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC] = FALSE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC] = TRUE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT] = FALSE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC_SECONDARY_OUT] = FALSE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC_TERTIARY_OUT] = FALSE;
deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink = gVcapModuleContext.ipcFramesOutVpssToHostId;
deiPrm.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC] = FALSE;
deiPrm.comprEnable = FALSE;
deiPrm.setVipScYuv422Format = FALSE;
deiPrm.enableDeiForceBypass = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.deiId[0];
ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcM3InId;
ipcFramesInVideoFromHostPrm.baseCreateParams.noNotifyMode = FALSE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssToHostId;
ipcFramesInVideoFromHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.encId;
EncLink_ChCreateParams *pLinkChPrm;
EncLink_ChDynamicParams *pLinkDynPrm;
VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
VENC_CHN_PARAMS_S *pChPrm;
for (i = 0; i < gVencModuleContext.vencConfig.numPrimaryChn; i++) {
pLinkChPrm = &encPrm.chCreateParams[i];
pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
pDynPrm = &pChPrm->dynamicParam;
pLinkChPrm->format = IVIDEO_H264HP;
pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[i];
pLinkChPrm->dataLayout = IVIDEO_PROGRESSIVE;
pLinkChPrm->fieldMergeEncodeEnable = FALSE;
pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
pLinkChPrm->rateControlPreset = IVIDEO_USER_DEFINED;
pLinkChPrm->enableSVCExtensionFlag = pChPrm->enableSVCExtensionFlag;
pLinkChPrm->numTemporalLayer = pChPrm->numTemporalLayer;
pLinkChPrm->enableHighSpeed = FALSE;
pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval;
pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate;
pLinkDynPrm->interFrameInterval = 1;
pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate;
pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
pLinkDynPrm->qpMin = pDynPrm->qpMin;
pLinkDynPrm->qpMax = pDynPrm->qpMax;
pLinkDynPrm->qpInit = pDynPrm->qpInit;
pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
encPrm.numBufPerCh[i] = 4;
encPrm.chCreateParams[0].defaultDynamicParams.inputFrameRate = 30;
encPrm.chCreateParams[1].defaultDynamicParams.inputFrameRate = 30;
encPrm.inQueParams.prevLinkQueId = 0;
encPrm.inQueParams.prevLinkId = gVencModuleContext.ipcM3InId;
encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId;
ipcBitsOutVideoPrm.baseCreateParams.noNotifyMode = FALSE;
ipcBitsOutVideoPrm.baseCreateParams.notifyNextLink = TRUE;
ipcBitsOutVideoPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcBitsOutVideoPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm);
vidSourceStatus.numChannels = 1;
vidSourceStatus.chStatus[0].chId = 0;
vidSourceStatus.chStatus[0].frameWidth = 720;
vidSourceStatus.chStatus[0].frameHeight = 288;
vidSourceStatus.chStatus[0].vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA;
vidSourceStatus.chStatus[0].isInterlaced = TRUE;
vidSourceStatus.chStatus[0].frameInterval = 20000;
vidSourceStatus.chStatus[0].isVideoDetect = FALSE;
Vcap_setVideoSourceStatus(&vidSourceStatus);
System_linkCreate(gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm));
System_linkCreate(gVcapModuleContext.deiId[0], &deiPrm, sizeof(deiPrm));
System_linkCreate(gVcapModuleContext.ipcFramesOutVpssToHostId, &ipcFramesOutVpssToHostPrm, sizeof(ipcFramesOutVpssToHostPrm));
System_linkCreate(gVencModuleContext.ipcM3InId, &ipcFramesInVideoFromHostPrm, sizeof(ipcFramesInVideoFromHostPrm));
System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));
System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm, sizeof(ipcBitsInHostPrm));
测试结果如下:
1. 当“pCaptureInstPrm->standard = SYSTEM_STD_D1”时,capture采不到视频;
2. 当“pCaptureInstPrm->standard = SYSTEM_STD_MUX_4CH_D1”时,capture可以采到视频,但deinterlace会出错;
麻烦各位帮忙看一下上面的哪些配置是错误的,到底该怎么配置才能让视频出来? 谢谢!
