CCS5.4编译链接时出现如下告警该如何解决?
请教:
是这样的:CCS5.4编译链接时出现如下告警该如何解决?网上说建立一个GROUP ,但是CCS5.4 工程里没有CMD文件,只有cfg文件,以下设置该加到哪里去呢?
请TI专家帮忙看看,谢谢!
GROUP (NEAR_DP_RELATIVE)
    .neardata
    .rodata
    .bss
} > BMEM
<Linking>
warning #10281-D: Section ".bss" requires a STATIC_BASE relative relocation, but is located at 0x0081ba80, which is probably out of range of the STATIC_BASE. STATIC_BASE is located at 0x0081ba80. Might be required to correct   placement of ".bss" so it lies within 0x8000 of the STATIC_BASE.
warning #10281-D: Section ".neardata" requires a STATIC_BASE relative relocation, but is located at 0x00823cf8, which is probably out of range of the STATIC_BASE. STATIC_BASE is located at 0x0081ba80. Might be required to correct   placement of ".neardata" so it lies within 0x8000 of the STATIC_BASE.
warning #10281-D: Section ".rodata" requires a STATIC_BASE relative relocation, but is located at 0x00823d34, which is probably out of range of the STATIC_BASE. STATIC_BASE is located at 0x0081ba80. Might be required to correct   placement of ".rodata" so it lies within 0x8000 of the STATIC_BASE.
'Finished building target: hyplnk_exampleProject.out'
    查看工程自动生成的memory文件,它已经加了group,看来不是group的问题。
    SECTIONS
        .text: load >> MSMCSRAM
        .ti.decompress: load > L2SRAM
        .stack: load > L2SRAM
        GROUP: load > L2SRAM
            .bss:
            .neardata:
            .rodata:
        .cinit: load > L2SRAM
  • lei wang22 说:
    请教:
    请TI专家帮忙看看,谢谢!
        .neardata
        .rodata
        .bss
    } > BMEM
    <Linking>
    为什么没有cmd文件?
  • 我说的不对,CCS5.4 C6678工程有linker.cmd,其内部有GROUP的建立,但是问题依旧。
        .neardata
        .rodata
        .bss
    } > BMEM
