Live555获得的帧数据是否可以通过IPC bits links
Live555获得的帧数据是否可以通过IPC bits links,能否用这种方式来显示?
live555 frame -> ipcBitsOutLinks ->ipcBitsInLinks -> decLinks ->displayLinks
  • 你好,
    我认为这个chain没有问题。
  • 流程: ipc out -> ipc video in -> dec -> dis 把live555的帧数往ipc out里面填充就可以了吗?就可以对live555在线直播了吗?我的代码是这样子:
    vooid* getFrame(handle,frame,userdata)
    Bitstream_Buf *pEmptyBuf = NULL;
    //Int32 status = TRUE;
    int chns[16] = {0};
    static UInt64 timestamp_base = 0;
    Bitstream_BufList emptyBufList;
    Bitstream_BufList fullBufList;
    IpcBitsOutLinkHLOS_BitstreamBufReqInfo reqInfo;
    UInt32 bitBufSize;
    UInt32 frameStartTime = 0;
    UInt32 frameEndTime = 0;
    UInt32 frameInterTime = 8;
    Int32 milliSecondsToSleep = 0;
    //Chains_Ctrl *chCfg = (Chains_Ctrl *) user_data;
    frameStartTime = OSA_getCurTimeInMsec();
    bitBufSize =1360*768/2;
    reqInfo.bufSize = bitBufSize;
    reqInfo.chNum = chns[0];
    IpcBitsOutLink_getEmptyVideoBitStreamBufs(SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0,
    &emptyBufList,
    &reqInfo);
    if(0 == emptyBufList.numBufs)
    return 0;
    fullBufList.numBufs = 0;
    pEmptyBuf = fullBufList.bufs[fullBufList.numBufs++] = emptyBufList.bufs[0];
    memcpy(pEmptyBuf->addr, frame->frameBuf,frame->frameSize);
    pEmptyBuf->fillLength = frame->frameSize;
    UInt64 curTimeStamp =timestamp_base++ * 16;
    pEmptyBuf->lowerTimeStamp = (UInt32)(curTimeStamp & 0xFFFFFFFF);
    pEmptyBuf->upperTimeStamp = (UInt32)((curTimeStamp >> 32)& 0xFFFFFFFF);
    if (fullBufList.numBufs)
    IpcBitsOutLink_putFullVideoBitStreamBufs(SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0,
    &fullBufList);
    milliSecondsToSleep = 1;
    frameEndTime = OSA_getCurTimeInMsec();
    milliSecondsToSleep = frameInterTime + frameStartTime - frameEndTime;
    if (milliSecondsToSleep > 0) {
    OSA_waitMsecs(milliSecondsToSleep);
    return 0;
    Chains_revDis()
    IpcBitsOutLinkRTOS_CreateParams ipcBitsInVideoPrm;
    IpcBitsInLinkHLOS_CreateParams ipcBitsOutHostPrm;
    //IpcLink_CreateParams ipcOutVpssPrm;
    //IpcLink_CreateParams ipcInVideoPrm;
    DecLink_CreateParams decPrm;
    SwMsLink_CreateParams swMsPrm;
    DisplayLink_CreateParams displayPrm;
    UInt32 swMsId;
    UInt32 displayId;
    UInt32 ipcOutVpssId;
    UInt32 ipcInVideoId;
    UInt32 decId;
    UInt32 ipcBitsInVideoId;
    UInt32 ipcBitsOutHostId;
    UInt8 i;
    myChains_ctrl =chainsCfg;
    //Chains_ipcBitsInit();
    printf("\n[#lqhPrint] my demo ");
    CHAINS_INIT_STRUCT(IpcLink_CreateParams,ipcOutVpssPrm);
    CHAINS_INIT_STRUCT(IpcLink_CreateParams,ipcInVideoPrm);
    swMsId = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0;
    //swMsId[1] = SYSTEM_LINK_ID_SW_MS_MULTI_INST_1;
    displayId = SYSTEM_LINK_ID_DISPLAY_0;
    //displayId[1] = SYSTEM_LINK_ID_DISPLAY_1;
    decId = SYSTEM_LINK_ID_VDEC_0;
    //ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;
    // ipcInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
    ipcBitsInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_IN_0;
    ipcBitsOutHostId = SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0;
    System_linkControl(
    SYSTEM_LINK_ID_M3VIDEO,
    SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
    &systemVid_encDecIvaChMapTbl,
    sizeof(SystemVideo_Ivahd2ChMap_Tbl),
    TRUE
    ipcBitsOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
    ipcBitsOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
    ipcBitsOutHostPrm.baseCreateParams.numOutQue = 1;
    ipcBitsOutHostPrm.baseCreateParams.numChPerOutQue[0] = 1;
    ipcBitsOutHostPrm.baseCreateParams.outQueParams[0].nextLink = ipcBitsInVideoId;
    ipcBitsOutHostPrm.baseCreateParams.notifyNextLink = FALSE;
    ipcBitsOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
    ipcBitsOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
    Chains_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutHostPrm,FALSE);
    ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkId = ipcBitsOutHostId;
    ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
    ipcBitsInVideoPrm.baseCreateParams.numOutQue = 1;
    ipcBitsInVideoPrm.baseCreateParams.numChPerOutQue[0] = 1;
    ipcBitsInVideoPrm.baseCreateParams.outQueParams[0].nextLink = decId;
    ipcBitsInVideoPrm.baseCreateParams.notifyNextLink = FALSE;
    ipcBitsInVideoPrm.baseCreateParams.notifyPrevLink = FALSE;
    ipcBitsInVideoPrm.baseCreateParams.noNotifyMode = TRUE;
    Chains_ipcBitsInitCreateParams_BitsInRTOS(&ipcBitsInVideoPrm,FALSE);
    ipcOutVpssPrm.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
    ipcOutVpssPrm.inQueParams.prevLinkQueId = 0;
    ipcOutVpssPrm.numOutQue = 1;
    ipcOutVpssPrm.numChPerOutQue[0] = 1;
    ipcOutVpssPrm.outQueParams[0].nextLink = ipcInVideoId;
    ipcOutVpssPrm.notifyNextLink = TRUE;
    ipcOutVpssPrm.notifyPrevLink = FALSE;
    ipcOutVpssPrm.noNotifyMode = FALSE;
    ipcOutVpssPrm.numChPerOutQue[0] = 0;
    ipcOutVpssPrm.equallyDivideChAcrossOutQues = FALSE;
    ipcInVideoPrm.inQueParams.prevLinkId = ipcOutVpssId;
    ipcInVideoPrm.inQueParams.prevLinkQueId = 0;
    ipcInVideoPrm.numOutQue = 1;
    ipcInVideoPrm.numChPerOutQue[0] = 1;
    ipcInVideoPrm.outQueParams[0].nextLink = decId;
    ipcInVideoPrm.notifyNextLink = TRUE;
    ipcInVideoPrm.notifyPrevLink = FALSE;
    ipcInVideoPrm.noNotifyMode = FALSE;
    ipcInVideoPrm.numChPerOutQue[0] = 0;
    ipcInVideoPrm.equallyDivideChAcrossOutQues = FALSE;
    for (i=0; i<chainsCfg->chRecNum; i++)
    decPrm.chCreateParams[i].format = chainsCfg->chCfg[i + chainsCfg->chCapNum].encFormat;
    decPrm.chCreateParams[i].profile = IH264VDEC_PROFILE_ANY;
    decPrm.chCreateParams[i].targetMaxWidth = chainsCfg->chCfg[i + chainsCfg->chCapNum].inWidth;
    decPrm.chCreateParams[i].targetMaxHeight = chainsCfg->chCfg[i + chainsCfg->chCapNum].inHeight;
    decPrm.chCreateParams[i].fieldMergeDecodeEnable = FALSE;
    decPrm.chCreateParams[i].algCreateStatus = DEC_LINK_ALG_CREATE_STATUS_CREATE;
    decPrm.chCreateParams[i].defaultDynamicParams.targetFrameRate = chainsCfg->chCfg[i + chainsCfg->chCapNum].encFrameRate;
    decPrm.chCreateParams[i].defaultDynamicParams.targetBitRate = chainsCfg->chCfg[i + chainsCfg->chCapNum].bitRate;
    decPrm.chCreateParams[i].numBufPerCh = 0;
    decPrm.chCreateParams[i].tilerEnable = TRUE;
    decPrm.inQueParams.prevLinkId = ipcBitsInVideoId;
    decPrm.inQueParams.prevLinkQueId = 0;
    decPrm.outQueParams.nextLink = swMsId;
    swMsPrm.numSwMsInst = 1;
    swMsPrm.swMsInstId[0] = SYSTEM_SW_MS_SC_INST_VIP1_SC;
    swMsPrm.inQueParams.prevLinkId = decId;
    swMsPrm.inQueParams.prevLinkQueId = 0;
    swMsPrm.outQueParams.nextLink = displayId;
    swMsPrm.lineSkipMode = FALSE;
    swMsPrm.enableLayoutGridDraw = TRUE;
    swMsPrm.layoutPrm.outputFPS = chainsCfg->chCfg[0+chainsCfg->chCapNum].encFrameRate;
    swMsPrm.maxInputQueLen = SYSTEM_SW_MS_DEFAULT_INPUT_QUE_LEN;
    swMsPrm.maxOutRes = chainsCfg->displayRes[0];
    swMsPrm.numOutBuf = 0;
    Chains_swMsGenerateLayoutParams(0, 2, &swMsPrm);
    displayPrm.numInputQueues = 1;
    displayPrm.activeQueue = 0;
    displayPrm.inQueParams[0].prevLinkId = swMsId;
    displayPrm.inQueParams[0].prevLinkQueId = 0;
    displayPrm.displayRes = chainsCfg->displayRes[0];
    displayPrm.forceFieldSeparatedInputMode = FALSE;
    if(chainsCfg->chRecNum > 0)
    printf("\n[#lqhPrint] Create ing ");
    //System_linkCreate(ipcOutVpssId,&ipcOutVpssPrm,sizeof(ipcOutVpssPrm));
    //System_linkCreate(ipcInVideoId,&ipcInVideoPrm,sizeof(ipcInVideoPrm));
    System_linkCreate(ipcBitsOutHostId,&ipcBitsOutHostPrm,sizeof(ipcBitsOutHostPrm));
    System_linkCreate(ipcBitsInVideoId,&ipcBitsInVideoPrm,sizeof(ipcBitsInVideoPrm));
    System_linkCreate(decId,&decPrm,sizeof(decPrm));
    System_linkCreate(swMsId,&swMsPrm,sizeof(swMsPrm));
    System_linkCreate(displayId,&displayPrm,sizeof(displayPrm));
    Vdis_start();
    System_linkStart(displayId);
    System_linkStart(swMsId);
    System_linkStart(decId);
    //System_linkStart(ipcOutVpssId);
    //System_linkStart(ipcInVideoId);
    System_linkStart(ipcBitsInVideoId);
    System_linkStart(ipcBitsOutHostId);
    rtspClientStart(chainsCfg);
    while(1)
    char ch;
    ch = Chains_menuRunTime();
    if(ch=='0')
    break;
    rtspClientstop();
    System_linkStop(ipcBitsOutHostId);
    System_linkStop(ipcBitsInVideoId);
    System_linkStop(decId);
    //System_linkStop(ipcOutVpssId);
    //System_linkStop(ipcInVideoId);
    System_linkStop(swMsId);
    Vdis_stop();
    System_linkStop(displayId);
    System_linkDelete(ipcBitsOutHostId);
    System_linkDelete(ipcBitsInVideoId);
    System_linkDelete(decId);
    System_linkDelete(swMsId);
    System_linkDelete(displayId);
    Chains_displayCtrlDeInit();
  • 是我写反了,因该是:
    改为这个:
    IpcBitsInLinkRTOS_CreateParams ipcBitsInVideoPrm;
    IpcBitsOutLinkHLOS_CreateParams ipcBitsOutHostPrm;
    又一个问题:
    &emptyBufList,
    &reqInfo);
    return 0;
    这上面的语句无法申请获得buffer?求指教!
  • 恩恩,我现在是这样子:
    SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0  =>
    SYSTEM_VIDEO_LINK_ID_IPC_BITS_IN_0 =>
    SYSTEM_LINK_ID_VDEC_0 =>
    SYSTEM_VIDEO_LINK_ID_IPC_OUT_M3_0 =>
     SYSTEM_VPSS_LINK_ID_IPC_IN_M3_0 =>
    SYSTEM_LINK_ID_SW_MS_MULTI_INST_0 =>
    这样子连这些link应该是没问题的吧?第一个link是这样子操作的:
    System_LinkQueInfo queInfo;
    queInfo.numCh = 1;
    queInfo.chInfo[0].bufType = SYSTEM_BUF_TYPE_VIDBITSTREAM;
    queInfo.chInfo[0].codingformat = chainsCfg->chCfg[0].encFormat;
    queInfo.chInfo[0].height = chainsCfg->chCfg[0].outHeight;
    queInfo.chInfo[0].width = chainsCfg->chCfg[0].outWidth;
    queInfo.chInfo[0].memType = SYSTEM_MT_TILEDMEM;
    queInfo.chInfo[0].dataFormat = SYSTEM_DF_YUV420P;
    queInfo.chInfo[0].scanFormat = SYSTEM_SF_PROGRESSIVE;
    Chains_ipcBitsInitCreateParams_BitsOutHLOS(&ipcBitsOutHostPrm,&queInfo);
    emptyBufList.numBufs =0 ;
    OSA_waitMsecs(8);
    &emptyBufList,
    &reqInfo);
    return 0;
    可我这样获取第一个link的缓冲区的时候,失败了,返回来 emptyBufList.numBufs =0的,不知道哪里出错了?能帮我看看吗?
  • live555 frame -> ipcBitsOutLinks ->ipcBitsInLinks -> decLinks ->ipcOut ->ipcIn ->displayLinks
  • 你这样做完全ok,我做过实验,从A8->ipcBitsOutlinks->ipcBitsInLinks->videoM3 decLink->videoM3 encLink->ipcBitsOutM3->ipcBitsInHost->A8这样是ok的;
  • 是的!我的成功出来了!
    A8(live555 client) ->IPC OUT(Bit Out) ->IPC IN (Video IN)  -> DecLink (Video)->(Video Out )(IPC ) -> (Vpass In)(IPC) SwMs -> Display
    原来是我忘记配置Ipc BitoutLink NotifyNextLink 以及NotifyMode!配置就可以了!IPC都需要配置 NotifyNextLink 以及NotifyMode!
  • 有一个问题我停止stop chain,按0然后结束当前demo
    [host] 97990: IPC_BITS_OUT : Delete Done !!!
    [m3vpss ] 102738: DISPLAY: Stop Done !!!
    [m3video] 102762: IPCBITSIN:Link[1000001a]:
    [m3video] RECV:1221 FREE:1221,DROPPED:0,AVGLATENCY:7
    [m3video] 102763: IPC_BITS_IN : Delete in progress !!!
    [m3video] 102763: IPC_BITS_IN : Delete Done !!!
    [m3video] 102763: DECODE: Stop in progress !!!
    [m3video] 102763: DECODE: Stop Done !!!
    [m3video] 102763: DECODE: Delete in progress !!!
    [m3video] !!!XDC RUNTIME ASSERT FAILED
    [m3video] xdc.runtime.Error @ ti.sdo.ipc.SharedRegion: line 302:
    [m3video] assertion failure: A_regionInvalid: Region is invalid
    出现了这样子错误是什么原因呢?视频已经播放出来了的。
  • 你好;
    你可以检查一下System_linkDelete 的link的注销的顺序,看是哪个link导致的;
