我选择的芯片是DM3730,仿真器XDS100V2, gel文件是am-dm37x_cortexA.gel
connect target时,出现下面的错误:
Cortex_A8_0: Trouble Writing Memory Block at 0x48004c10 on Page 0 of Length 0x4: (Error -1065 @ 0x48004C10) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
Cortex_A8_0: GEL: Error while executing OnTargetConnect(): target access failed at *((int *) 0x48004C10)=0x20 [am-dm37x_cortexA.gel:427] at Watchdog_disable() [am-dm37x_cortexA.gel:218] at OnTargetConnect() .
Cortex_A8_0: Trouble Reading Memory Block at 0xc003a518 on Page 0 of Length 0xd: (Error -1205 @ 0xC003A518) Device memory bus has an error and may be hung. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
Cortex_A8_0: Trouble Reading Memory Block at 0xc003a518 on Page 0 of Length 0x41: (Error -1203 @ 0x3D5B) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
Cortex_A8_0: Trouble Reading Register CP15_CONTROL_REGISTER: (Error -1203 @ 0x3D5B) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
Cortex_A8_0: Error: (Error -1203 @ 0x3D5B) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
