root@tl:/# insmod /lib/modules/3.3.0/kernel/drivers/dsp/syslink.ko TRACE=1 TRACE
FAILURE=1
[ 101.813824] SysLink version : 2.21.01.05
[ 101.813852] SysLink module created on Date:May 24 2015 Time:23:22:10
[ 101.826514] Trace enabled
[ 101.830585] Trace SetFailureReason enabled
root@tl:/# ./run.sh 执行后出现以下,然后在末尾光标一直闪,请问怎样解决?
+ ./slaveloader startup DSP server_dsp.xe674
Attached to slave procId 0.
Loading procId 0.
[ 119.491225] ------------[ cut here ]------------
[ 119.495966] WARNING: at arch/arm/mm/ioremap.c:241 __arm_ioremap_pfn_caller+0x180/0x27c()
[ 119.506585] Modules linked in: syslink(O)
[ 119.511000] Backtrace:
[ 119.513560] [<c000c1a8>] (dump_backtrace+0x0/0x110) from [<c04078a8>] (dump_stack+0x18/0x1c)
[ 119.525579] r6:c04d95ba r5:000000f1 r4:00000000 r3:20000093
[ 119.531752] [<c0407890>] (dump_stack+0x0/0x1c) from [<c0017f18>] (warn_slowpath_common+0x54/0x6c)
[ 119.543277] [<c0017ec4>] (warn_slowpath_common+0x0/0x6c) from [<c0017f54>] (warn_slowpath_null+0x24/0x2c)
