void IMG_dilate_bin_c
const unsigned char *restrict in_data,
unsigned char *restrict out_data,
const char *restrict mask,
int cols
int i;
unsigned long p0l, p3l, p6l;
unsigned p0, p1, p2, p3, p4, p5, p6, p7, p8, r;
/* Iterate over the input, processing 32 pixels per iteration. */
for (i = 0; i < cols; i += 4)
/* Load in our 34-bit by 3-bit context for applying the 3x3 mask. */
p0l = ((unsigned) in_data[i + 0] ) |
((unsigned) in_data[i + 1] << 8 ) |
((unsigned) in_data[i + 2] << 16) |
((unsigned) in_data[i + 3] << 24) |
((unsigned long)in_data[i + 4] << 32);
p3l = ((unsigned) in_data[i + cols + 0] ) |
((unsigned) in_data[i + cols + 1] << 8 ) |
((unsigned) in_data[i + cols + 2] << 16) |
((unsigned) in_data[i + cols + 3] << 24) |
((unsigned long)in_data[i + cols + 4] << 32);
p6l = ((unsigned) in_data[i + cols*2 + 0] ) |
((unsigned) in_data[i + cols*2 + 1] << 8 ) |
((unsigned) in_data[i + cols*2 + 2] << 16) |
((unsigned) in_data[i + cols*2 + 3] << 24) |
((unsigned long)in_data[i + cols*2 + 4] << 32);
/* Generate 3 offset copies of each row so that we can perform */
/* ANDs between pixels that are neighbors. */
p0 = p0l; p1 = p0l >> 1; p2 = p0l >> 2;
p3 = p3l; p4 = p3l >> 1; p5 = p3l >> 2;
p6 = p6l; p7 = p6l >> 1; p8 = p6l >> 2;
/* Now sum the filtered pixels together by ORing. */
r = 0;
if (mask[0] >= 0) r |= p0;
if (mask[1] >= 0) r |= p1;
if (mask[2] >= 0) r |= p2;
if (mask[3] >= 0) r |= p3;
if (mask[4] >= 0) r |= p4;
if (mask[5] >= 0) r |= p5;
if (mask[6] >= 0) r |= p6;
if (mask[7] >= 0) r |= p7;
if (mask[8] >= 0) r |= p8;
/* Write the result as four bytes. */
out_data[i + 0] = (r >> 0) & 0xFF;
out_data[i + 1] = (r >> 8) & 0xFF;
out_data[i + 2] = (r >> 16) & 0xFF;
out_data[i + 3] = (r >> 24) & 0xFF;
有明白的人吗???给我讲讲程序吧
