求助!在dm8127 dsp端只做数据搬运,运行会死掉
背景:使用hello world 算法例子,成功实现一个算法,该算法数据搬运较少
出现问题:在同样框架下换成另一个算法,该算法需要往内存存取大量数据,出现dsp运行一会死掉的问题
测试:于是我把算法全部停掉,dsp内只运行如下代码:
for ( j=0; j<480-4; j++)
for ( k=0; k<720-4; k++ )
// Gray = temp[j*720+k];
Gray = 255;
videncObj->addGuassian->pData[j*720*3+k*3+0]= Gray;
videncObj->addGuassian->pData[j*720*3+k*3+1]= Gray;
videncObj->addGuassian->pData[j*720*3+k*3+2]= Gray;
videncObj->pParams->testBuf[j*720*3+k*3+0]= Gray;
videncObj->pParams->testBuf[j*720*3+k*3+1]= Gray;
videncObj->pParams->testBuf[j*720*3+k*3+2]= Gray;
Vps_rprintf(" IVDCOPY_TI_process Gray: %d !!!\n",Gray);
dsp运行多帧后就会死掉,假如上述6次赋值,减少掉3次,只保留3次赋值或者1次赋值,则能够正常运行!有遇到类似情况的吗,如下是打印信息:
[host] After Ipc_startcallback status [0x00000000]
[m3vpss ] 1303: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1303: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2006: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2514: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 2243: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2515: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 2243: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 2244: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 2303: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3514: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3244: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 3303: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3575: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 3304: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[c6xdsp ] 3575: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 3304: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4244: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4575: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 4305: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 4304: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4305: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4305: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3vpss ] 4305: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4306: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 4306: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3vpss ] 4308: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 4309: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 4309: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 4309: SYSTEM: IPC init DONE !!!
[m3vpss ] Received character 's'
[m3vpss ] 4324: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 4325: MEM: Shared Region 1: Base = 0x85e00000, Length = 0x02200000 (34 MB)
[m3vpss ] 4327: SYSTEM : System Common Init Done !!!
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[c6xdsp ] 5575: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 5306: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 5575: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 5306: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[c6xdsp ] 5575: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 5307: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[c6xdsp ] 5576: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 5576: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 5576: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 5576: SYSTEM: IPC init DONE !!!
[c6xdsp ] 5580: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 5309: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 5580: MEM: Shared Region 1: Base = 0x85e00000, Length = 0x02200000 (34 MB)
[m3video] 5309: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[c6xdsp ] 5581: SYSTEM : System Common Init Done !!!
[m3video] 5309: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3video] 5310: SYSTEM: IPC init DONE !!!
[m3video] 5325: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 5325: MEM: Shared Region 1: Base = 0x85e00000, Length = 0x02200000 (34 MB)
[m3video] 5328: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
[c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out VA VNF_QUALITY TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
[m3vpss ] 5427: SYSTEM : System VPSS Init in progress !!!
[m3vide [c6xdsp ] 5785: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
INIT: Entering runlevel: 5
[c6xdsp ] 5785: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 5786: SYSTEM: ListElem Shared Addr = 0xbea24780
[c6xdsp ] 5787: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 5787: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 5787: SYSTEM: ListElem Shared Addr = 0xbea44180
[c6xdsp ] 5788: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 5788: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 5789: SYSTEM: ListElem Shared Addr = 0xbea63b80
[c6xdsp ] 5790: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 5790: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 5790: SYSTEM: ListElem Shared Addr = 0xbea83580
[c6xdsp ] 5791: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 5791: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 5791: SYSTEM: ListElem Shared Addr = 0xbea9d200
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5788: SYSTEM : Initializing Links !!!
inside autorun
[c6xdsp ] 5792: SYSTEM : FREE SPACE : System Heap = 78634288 B, Mbx = 10240 msgs)
[m3video] 5528: SYSTEM : System Video Init in progress !!!
[m3video] 5528: SYSTEM : System Video Init Done !!!
[c6xdsp ] zhou: start Create AlgLink_tskMain init LINE: 186
[m3video] 5528: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 5529: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5797: HELLOWORLD : HelloWorldLink_init LINE: 134 !!!
[m3video] 5529: SYSTEM: ListElem Shared Addr = 0xbeab6e80
[c6xdsp ] 5797: HELLOWORLD : HelloWorldLink_init LINE: 160 !!!
[m3video] 5532: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 5799: HELLOWORLD : HelloWorldLink_init LINE: 160 !!!
[m3video] 5533: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 5533: SYSTEM: ListElem Shared Addr = 0xbeaba380
[c6xdsp ] 5806: SYSTEM : zhou Initializing Links ... DONE !!!
[m3video] 5545: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 5545: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[c6xdsp ] 5807: SYSTEM : System DSP Init Done !!!
[m3video] 5545: SYSTEM: ListElem Shared Addr = 0xbeabd880
[m3video] 5548: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3video] 5549: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 5549: SYSTEM: ListElem Shared Addr = 0xbead7500
[m3video] 5551: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 5556: SYSTEM : FVID2 Init in progress DONE !!!
[m3video] 5552: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 5556: SYSTEM : Device Init in progress !!!
[m3video] 5553: SYSTEM : Initializing Links !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] CPIS_init DONE !!!!!!
[m3video] 5553: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3vpss ] initPrms.isI2cInitReq = 1
[m3video] 5553: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3video] 5553: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3video] 5554: SYSTEM : FREE SPACE : Bitstream Buffer = 35651456 B (33 MB)
[m3video] 5554: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 5555: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3video] 5612: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[m3vpss ]
Starting telnet daemon.
Starting syslogd/klogd: done
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root (automatic login)
root@dm814x-evm:~# mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 3169dda1, no volume label.
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
[m3vpss ] I2C2: Passed for address 0x36 !!!
[m3vpss ] I2C2: Passed for address 0x55 !!!
queue id:0
[m3vpss ] 8295: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 8323: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8323: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 8323: SYSTEM : Initializing Links !!!
[m3vpss ] 8324: SYSTEM : FREE SPACE : System Heap = 1555032 B, Mbx = 10240 msgs)
[m3vpss ] 8324: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 8324: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 8324: SYSTEM : FREE SPACE : Bitstream Buffer = 35651456 B (33 MB)
[m3vpss ] 8325: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] Received character 't'
[m3vpss ] 8458: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 't'
[c6xdsp ] Received character 't'
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 1: SYSTEM: IPC init in progress !!!
[host] 32: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 32: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 32: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 32: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 33: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 36: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 38: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 39: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 40: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 40: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 42: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 44: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 44: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 45: SYSTEM: IPC init DONE !!!
[host] 50: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 53: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 54: SYSTEM: ListElem Shared Addr = 0x40519180
[host] 55: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 57: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 59: SYSTEM: ListElem Shared Addr = 0x40532e00
[host] 62: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 64: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 65: SYSTEM: ListElem Shared Addr = 0x4054ca80
[host] 66: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 68: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 70: SYSTEM: ListElem Shared Addr = 0x4056c480
[host] 71: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 73: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 75: SYSTEM: ListElem Shared Addr = 0x4058be80
[host] 75: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4b88b000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4b88b000
##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 10
Creat queue id:131076
queue id:131076
queue id:65538
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[host]
Enable RAW Frame Write
[host] Opened file [/mnt/VID_CH00.yuv] for writing CH0
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]
********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 167: MCFW : CPU Revision [ES2.1] !!!
[host] 167: MCFW : Detected [UNKNOWN] Board !!!
[host] 167: MCFW : Base Board Revision [REV A] !!!
[host] FUN: MultiCh_createTriStreamFullFtr LINE: 491 [m3vpss ] VPS_DCTRL_INST_0
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
[m3vpss ] 9367: CAMERA: Create in progress !!!
[m3vpss ] 9367: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] 9378: CAMERA: VIP 0: VID DEC 268436736 (0x36): 8a559a98:ffff0000:8a55bf4c, AUD_STATUS -1974085184
[m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate.
[m3vpss ] Stream ID 1: chId = 0 VpsUtils_queCreate.
[m3vpss ] 9587: CAMERA: Create Done !!!
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[m3vpss ] 9675: CAMERA: Detect video in progress !!!
[m3vpss ] 9675: CAMERA: Detect video Done !!!
[m3vpss ] 9676: VNF:
[m3vpss ] Create in progress ... !!!
[m3vpss ] Input Channel CH0 of 1952 x 1112, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[m3vpss ] 9928: VNF:
[m3vpss ] Create ... DONE !!!
[m3vpss ] 10228: DUP : Create Done !!!
[m3vpss ] 10235: DUP : Create Done !!!
[m3vpss ] 10237: MERGE : Create Done !!!
[m3vpss ] DCC server task running
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[m3vpss ] {SWOSD} edma3Handle->chId = 37
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 10011: SWOSD : Create Done !!!
[m3vpss ] 10311: DUP : Create Done !!!
[m3vpss ] 10312: SCLR: Create in progress !!!
[m3vpss ] 10318: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 10318: SCLR : Co-effs Loading ... DONE !!!
[c6xdsp ] 10601: IPC_FRAMES_IN : Create in progress !!!
[c6xdsp ] 10601: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_23] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[c6xdsp ] 10601: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_23] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[c6xdsp ] 10602: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 10318: SCLR: Create Done !!!
[m3vpss ] 10325: DUP : Create Done !!!
[m3vpss ] 10326: IPC_FRAMES_OUT : Create in progress !!!
[c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
[c6xdsp ] 10604: IPC_FRAMES_IN : Create Done !!!
[c6xdsp ] 10604: NULL : Create Done !!!
[m3vpss ] 10329: IPC_FRAMES_OUT : Create Done !!!
[m3vpss ] 10334: IPC_FRAMES_OUT : Create in progress !!!
[c6xdsp ] 10609: IPC_FRAMES_IN : Create in progress !!!
[c6xdsp ] 10609: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_24] ...
[m3vpss ] 10337: IPC_FRAMES_OUT : Create Done !!!
[c6xdsp ] 10609: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_24] ...
[c6xdsp ] 10612: IPC_FRAMES_IN : Create Done !!!
[c6xdsp ] 10612: HELLOWORLD : Create in progress !!!
[c6xdsp ] FUN: HelloWorldLink_create LINE: 315
[c6xdsp ] FUN: HelloWorldLink_create LINE: 321
[c6xdsp ] FUN: HelloWorldLink_create LINE: 336
[c6xdsp ] FUN: HelloWorldLink_create LINE: 343
[c6xdsp ] 10613: HELLOWORLD : Algorithm Create in progress !!!
[c6xdsp ] FUN: HelloWorldLink_algCreate LINE: 87
[c6xdsp ] IVD_open maxWidth 720, maxHeight 480 !!!
[c6xdsp ] IVD_open pObj->algHndl 8fa0eb08 !!!
[c6xdsp ] IVD_control start !!!
[host] IpcFramesInLink_tskMain:Entered
[host] 1281: IPC_FRAMES_IN : Create in progress !!!
[host] 1281: SYSTEM: Opening ListMP [DSP_IPC_OUT_23] ...
[host] 1284: SYSTEM: Opening ListMP [DSP_IPC_IN_23] ...
[c6xdsp ] ArithInit bValidCfg !!! bValidCfg:1
[c6xdsp ] ArithInit succeed !!!
[c6xdsp ] CGaussianInit start !!! retVal:0
[c6xdsp ] CGaussianInit end !!! retVal:0
[c6xdsp ] IVD_control end !!! retVal:0
[c6xdsp ] 11039: HELLOWORLD : Algorithm Create Done !!!
[c6xdsp ] FUN: HelloWorldLink_create LINE: 357
[c6xdsp ] FUN: HelloWorldLink_create LINE: 366
[c6xdsp ] 11039: HELLOWORLD : Create Done !!!
[c6xdsp ] 11040: IPC_FRAMES_OUT : Create in progress !!!
[c6xdsp ] pObj->info.numQue: 1 !!!
[host] 1287: IPC_FRAMES_IN : Create Done !!!
[host] FUN: MultiCh_createTriStreamFullFtr LINE: 1202 [m3vpss ] 10489: FD : Alg Create Done !!!
[c6xdsp ] 11041: IPC_FRAMES_OUT : Create Done !!!
[m3vpss ] 10489: FD : Create Done !!!
[m3vpss ] 10782: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 10784: IPC_OUT_M3 : Create Done !!!
[m3video] 10785: IPC_IN_M3 : Create in progress !!!
[m3video] 10785: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 10785: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3video] 10789: IPC_IN_M3 : Create Done !!!
[m3video] 10789: ENCODE: Create in progress ... !!!
[m3video] 10853: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] 10960: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 1590: IPC_BITS_IN : Create in progress !!!
[host] 1590: IPC_BITS_IN : ListMPOpen start !!!
[host] 1590: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 1592: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 1593: IPC_BITS_IN : ListMPOpen done !!!
[host] 1594: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1595: IPC_BITS_IN : Create Done !!!
[m3vpss ] 11085: DISPLAY: Create in progress !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3video] 11071: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] SC2 displayInstId = 6
[m3vpss ] 11086: DISPLAY: Create Done !!!
[m3vpss ] 11087: DISPLAY: Create in progress !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4432
[m3video] 11072: ENCODE: All CH Create ... DONE !!!
[host] USECASE SETUP DONE
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3video] ENCLINK:HEAPID:0 USED:30472
[m3vpss ] SD displayInstId = 2
[m3video] 11075: ENCODE: Create ... DONE !!!
[m3vpss ] 11088: DISPLAY: Create Done !!!
[m3video] 10837: VSTAB : Alg Create Done !!!
[m3vpss ] 11089: DISPLAY: Start in progress !!!
[m3video] 10837: VSTAB : Create Done !!!
[m3video] 11076: IPC_BITS_OUT : Create in progress !!!
[m3video] 11079: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 11154: DISPLAY: Start Done !!!
[m3vpss ] 11155: DISPLAY: AUX PATH: 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 11155: DISPLAY: Start in progress !!!
[m3vpss ] 11203: DISPLAY: Start Done !!!
[m3vpss ] 11203: DISPLAY: SDDAC(SEC1): 20 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 10913: CAMERA: Start in progress !!!
[m3vpss ] 10913: CAMERA: Start Done !!!
[host]
Application Run Completed
[m3vpss ] 11044: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[host] ITT server task running !!!
[host]
ITT ittServer_run
[host] ITT Server Message initialization successful
[host]
ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <40333100>
[host] Posting message <40333100> in QId <20002>
[m3vpss ] count: 1000
[host] Response from M3 is : 1
[m3vpss ] Command 1 recived from HOST A8
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <23>
[m3vpss ] Command 2 recived from HOST A8
[m3vpss ] New DCC data of size <33603>
[m3video] Channel:1 inputframerate:30 targetfps:60
[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 536870977
[m3vpss ] count: 999
[host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3vpss ] count: 999
[m3vpss ] count: 998
[m3video] Channel:0 inputframerate:60 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
[m3vpss ] count: 997
[c6xdsp ] IVDCOPY_TI_process Gray: 255 !!!
[c6xdsp ] count: 1000
[host] FUN: Vcam_ipcFramesInCbFxn LINE: 1330
[host] MCFW_IPCFRAMES: Callback function:App_ipcFramesInCbFxn
[host] MCFW_IPCFRAMES:Received first frame notify...
[host] MCFW_IPCFRAMES:VIDFRAMELIST_INFO:FullFrameList numFullFrames:1
[host] MCFW_IPCFRAMES:VIDFRAME_INFO:chNum:0 fid:0 frameWidth:720 frameHeight:480 timeStamp:11337 virtAddr[0][0]:(nil) phyAddr[0][0]:0xb9d6fc80
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:INFO: periodic print.. [m3vpss ] count: 999
[m3vpss ] count: 996
[m3vpss ] count: 995
queue id:0
[host] MCFW_IPCFRAMES:Received first frame notify...ApproDrvInit: 7
queue id:131076
TimeOut occure in boot_proc.
Program exit.
Program exit.
[host]
Usecase is Active !!!
ApproDrvExit: 7
Error: WaitStreamReady Fail.
[host]
[host]
  • 你好,
    是否会和videncObj->pParams->testBuf有关系?这个buffer的地址是否在合理的区域?
  • 你好,
         确定是在合理区域,使用ipnc3.5,我在config_512M.bld文件中var DSP_DATA_SIZE              = 10*MB+74*MB;分配了,同时在FC_RMAN_IRES_c6xdsp.cfg文件中Program.global.DSP_HEAPEXT_MEM = 0x04b00000,空间够用,使用Int IVD_TI_alloc(const IALG_Params *algParams, IALG_Fxns **pf, IALG_MemRec memTab[])函数,分配
      size = 0;
                  uRegin_width = DETECTRECT_WIDTH_MAX1;////768
            uRegin_height = 576;
      size = 6*uRegin_width *uRegin_height* sizeof(unsigned char);  ////20140706
      memTab[14].size = size;
      memTab[14].alignment = 0;
      memTab[14].space = IALG_EXTERNAL;
      memTab[14].attrs = IALG_PERSIST;
    在IVD_TI_initObj函数里videncObj->pParams->testBuf = memTab[14].base;参考SWOSD流程。该地址打印出来处于合理区域,同时使用该例程能够运行一个数据量不用大量赋值的算法,正确输出结果。现在测试没有运行任何东西,单纯性的往内存存取数值,数量达到上述量时,dsp运行几帧timeout。如果不用for循环赋值,而是使用memcpy做搬运,则达到timeout时的临界量要比上述使用for循环赋值时大。
