你好,我想问一下,CCSV5为什么没有RTDX了啊?CCS3.3有,但是速度为一秒8K字节,这个速度太慢了,我想知道CCSV5是否有工具实现实时的数据交换?谢谢了
确实没有了。
As of 6/24/2010 RTDX is no longer supported. Alternative transports should be considered for the acquision of data, such as serial ports and ethernet. If you are currently using the technology and have no issues, there is no need to change. However, no action will be taken for support inqueries. |
