TDA4VM: 我们之前已经在sdk8.1上实现功能,但是是GP设备,最近我们需要更新到HS设备上,请问该怎么做,有没有对应的参考资料
Part Number: TDA4VM
我们的客户给我们提供了tiboot3.bin 和tifs.bin,这让设备系统能够起来,进入linux系统终端,但是相应的app均无法运行,包括ti基础的app程序。linux系统启动log如下: U-Boot SPL 2021.01-gd2bdf760-dirty (Dec 23 2022 - 11:05:16 +0800) Model: Texas Instruments K3 J721E SoC SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.2-v2021.09b (Terrific Llam') Trying to boot from MMC2 U-Boot 2021.01-00001-gd04a55ea-dirty (Feb 01 2023 - 02:49:19 +0800) SoC: J721E SR1.1 HS-SE Model: Texas Instruments K3 J721E SoC DRAM: 4 GiB MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 In: serial@2810000 Out: serial@2810000 Err: serial@2810000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 0 bytes read in 0 ms Loaded env from uEnv.txt Importing environment from mmc1 ... k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 1338800 bytes read in 67 ms (19.1 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 1338800 bytes: Success! 351180 bytes read in 28 ms (12 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 351180 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' Failed to load '/lib/firmware/j7-c66_0-fw' Failed to load '/lib/firmware/j7-c66_1-fw' 12980288 bytes read in 205 ms (60.4 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 12980288 bytes: Success! 19268096 bytes read in 783 ms (23.5 MiB/s) 100704 bytes read in 16 ms (6 MiB/s) 10581 bytes read in 13 ms (793.9 KiB/s) Failed to load '/boot/ramdisk.cpio.gz' ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 ERROR: reserving fdt memory region failed (addr=fe000000 size=1000000) ERROR: reserving fdt memory region failed (addr=fc000000 size=2000000) ERROR: reserving fdt memory region failed (addr=ac000000 size=200000) ERROR: reserving fdt memory region failed (addr=ac200000 size=1e00000) Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.65-gdcc6bedb2c (leadmove@leadmove) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain 4 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002810000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000) [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 16 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-ipc-shared-memory@af000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Carveout Heap: regions without no-map are not yet supported [ 0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fc000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node intercore-eth-r5f-memory@fc000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fe000000, size 16 MiB [ 0.000000] OF: reserved mem: initialized node eeprom-shadow-r5f-memory@fe000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000feffffff] [ 0.000000] node 0: [mem 0x00000000ff000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff] [ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472 [ 0.000000] Kernel command line: console=ttyS3,115200n8 earlycon=ns16550a,mmio32,0x02810000 root=PARTUUID=a3f42fe2-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB) [ 0.000000] Memory: 2777984K/4194304K available (10880K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 751K bss, 1416320K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a00b0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008410] Console: colour dummy device 80x25 [ 0.012971] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023641] pid_max: default: 32768 minimum: 301 [ 0.028388] LSM: Security Framework initializing [ 0.033132] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.040699] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.049631] rcu: Hierarchical SRCU implementation. [ 0.054691] Platform MSI: msi-controller@1820000 domain created [ 0.060941] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070239] EFI services will not be available. [ 0.074992] smp: Bringing up secondary CPUs ... [ 0.085933] Detected PIPT I-cache on CPU1 [ 0.085956] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.085967] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000 [ 0.085998] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.086051] smp: Brought up 1 node, 2 CPUs [ 0.115395] SMP: Total of 2 processors activated. [ 0.120200] CPU features: detected: 32-bit EL0 Support [ 0.125454] CPU features: detected: CRC32 instructions [ 0.139178] CPU: All CPU(s) started at EL2 [ 0.143374] alternatives: patching kernel code [ 0.148372] devtmpfs: initialized [ 0.156737] KASLR disabled due to lack of seed [ 0.161391] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.171353] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.178492] pinctrl core: initialized pinctrl subsystem [ 0.184046] DMI not present or invalid. [ 0.188250] NET: Registered protocol family 16 [ 0.193042] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.200405] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.208401] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.216676] thermal_sys: Registered thermal governor 'step_wise' [ 0.216678] thermal_sys: Registered thermal governor 'power_allocator' [ 0.223093] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.236720] ASID allocator initialised with 65536 entries [ 0.256681] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.263536] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.270294] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.277923] cryptd: max_cpu_qlen set to 1000 [ 0.283823] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.292604] vsys_3v3: supplied by evm_12v0 [ 0.296981] vsys_5v0: supplied by evm_12v0 [ 0.301291] vdd_mmc1: supplied by vsys_3v3 [ 0.305872] iommu: Default domain type: Translated [ 0.311001] SCSI subsystem initialized [ 0.314965] mc: Linux media interface: v0.10 [ 0.319333] videodev: Linux video capture interface: v2.00 [ 0.324959] pps_core: LinuxPPS API ver. 1 registered [ 0.330029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.339366] PTP clock support registered [ 0.343384] EDAC MC: Ver: 3.0.0 [ 0.347074] FPGA manager framework [ 0.350589] Advanced Linux Sound Architecture Driver Initialized. [ 0.357174] clocksource: Switched to clocksource arch_sys_counter [ 0.363589] VFS: Disk quotas dquot_6.6.0 [ 0.367642] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.377356] NET: Registered protocol family 2 [ 0.381942] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear) [ 0.390542] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.399326] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.407521] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.415311] TCP: Hash tables configured (established 32768 bind 32768) [ 0.422062] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.428957] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.436355] NET: Registered protocol family 1 [ 0.441053] RPC: Registered named UNIX socket transport module. [ 0.447114] RPC: Registered udp transport module. [ 0.451918] RPC: Registered tcp transport module. [ 0.456721] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.463306] PCI: CLS 0 bytes, default 64 [ 0.467638] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.477864] Initialise system trusted keyrings [ 0.482478] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.490761] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.496972] NFS: Registering the id_resolver key type [ 0.502190] Key type id_resolver registered [ 0.506463] Key type id_legacy registered [ 0.510582] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.517430] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.525087] 9p: Installing v9fs 9p2000 file system support [ 0.550207] Key type asymmetric registered [ 0.554393] Asymmetric key parser 'x509' registered [ 0.559391] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.566950] io scheduler mq-deadline registered [ 0.571575] io scheduler kyber registered [ 0.576693] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.582840] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.590890] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.597152] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.604868] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.612838] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.621867] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq [ 0.630842] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq [ 0.638551] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.651140] brd: module loaded [ 0.656994] loop: module loaded [ 0.660550] megasas: 07.714.04.00-rc1 [ 0.665539] libphy: Fixed MDIO Bus: probed [ 0.670154] tun: Universal TUN/TAP device driver, 1.6 [ 0.675539] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.681948] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.688026] sky2: driver version 1.30 [ 0.692205] VFIO - User Level meta-driver version: 0.3 [ 0.697831] i2c /dev entries driver [ 0.701909] sdhci: Secure Digital Host Controller Interface driver [ 0.708229] sdhci: Copyright(c) Pierre Ossman [ 0.712895] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.719142] ledtrig-cpu: registered to indicate activity on CPUs [ 0.725444] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.732538] optee: probing for conduit method. [ 0.737096] optee: revision 3.12 (3d47a131) [ 0.737349] optee: initialized driver [ 0.746386] NET: Registered protocol family 17 [ 0.750997] 9pnet: Installing 9P2000 support [ 0.755380] Key type dns_resolver registered [ 0.759817] Loading compiled-in X.509 certificates [ 0.767258] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.773604] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.781560] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.2-v2021.09b (Terrific Llam') [ 0.807357] random: fast init done [ 0.828648] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.836157] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 0.846147] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 0.854944] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 0.864772] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 0.875753] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps [ 0.883815] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 0.893695] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 0.900459] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 0.909457] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 0.919597] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 0.926365] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 0.934303] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 0.943696] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250 [ 0.952442] printk: console [ttyS3] enabled [ 0.952442] printk: console [ttyS3] enabled [ 0.960880] printk: bootconsole [ns16550a0] disabled [ 0.960880] printk: bootconsole [ns16550a0] disabled [ 0.971338] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250 [ 0.981591] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 0.992099] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 1.002252] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 1.012490] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 1.023207] scsi host0: ufshcd [ 1.069186] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.076833] davinci_mdio 46000f00.mdio: no live phy, scanning all [ 1.181303] davinci_mdio 46000f00.mdio: timed out waiting for user access [ 1.288174] davinci_mdio 46000f00.mdio: timed out waiting for idle [ 1.294347] davinci_mdio: probe of 46000f00.mdio failed with error -5 [ 1.300801] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.314384] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.323206] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.323304] mmc0: CQHCI version 5.10 [ 1.329419] mmc1: CQHCI version 5.10 [ 1.342009] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.348856] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.355673] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.362485] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.369268] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.373414] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.376260] ti-udma 285c0000.dma-controller: Channels: 17 (tchan: 4, rchan: 13, gp-rflow: 8) [ 1.393641] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 1.407818] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 1.414700] spi-nor: probe of spi0.0 failed with error -2 [ 1.422018] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 1.428893] spi-nor: probe of spi1.0 failed with error -2 [ 1.437763] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 1.443241] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 1.448291] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0 [ 1.454553] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 1.460977] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 1.467843] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 1.473182] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.474444] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 1.482078] davinci_mdio 46000f00.mdio: no live phy, scanning all [ 1.488414] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 1.499002] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0 [ 1.507159] cdns-ufshcd 4e84000.ufs: last intr at 1331473 us, last intr status=0x404 [ 1.514892] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 1.522429] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0 [ 1.531461] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 1.537460] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 1.543723] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 1.549810] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 1.555894] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 1.568066] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 1.574415] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 1.580763] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 1.587111] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 1.593456] davinci_mdio 46000f00.mdio: timed out waiting for user access [ 1.596253] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 1.606582] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 1.612932] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 1.619283] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 1.625630] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 1.631981] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 1.638326] cdns-ufshcd 4e84000.ufs: No record of pa_err [ 1.643669] cdns-ufshcd 4e84000.ufs: No record of dl_err [ 1.648975] cdns-ufshcd 4e84000.ufs: No record of nl_err [ 1.654281] cdns-ufshcd 4e84000.ufs: No record of tl_err [ 1.659584] cdns-ufshcd 4e84000.ufs: No record of dme_err [ 1.665011] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err [ 1.671206] cdns-ufshcd 4e84000.ufs: No record of fatal_err [ 1.676802] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1332593 us [ 1.683935] cdns-ufshcd 4e84000.ufs: No record of resume_fail [ 1.689684] cdns-ufshcd 4e84000.ufs: No record of suspend_fail [ 1.695515] cdns-ufshcd 4e84000.ufs: No record of dev_reset [ 1.700334] davinci_mdio 46000f00.mdio: timed out waiting for idle [ 1.701087] cdns-ufshcd 4e84000.ufs: No record of host_reset [ 1.707252] davinci_mdio: probe of 46000f00.mdio failed with error -5 [ 1.712887] cdns-ufshcd 4e84000.ufs: No record of task_abort [ 1.719353] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.738553] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.745961] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.753187] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.753227] mmc0: Command Queue Engine enabled [ 1.763551] mmc0: new HS200 MMC card at address 0001 [ 1.763701] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 1.768764] mmcblk0: mmc0:0001 DG4016 14.5 GiB [ 1.778567] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.782113] mmcblk0boot0: mmc0:0001 DG4016 partition 1 31.9 MiB [ 1.793769] mmcblk0boot1: mmc0:0001 DG4016 partition 2 31.9 MiB [ 1.799777] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 16.0 MiB, chardev (237:0) [ 1.801901] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 1.814427] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 1.821684] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 [ 1.822670] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 1.834383] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 1.841754] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 1.849062] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 1.857053] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 1.872638] ALSA device list: [ 1.875603] No soundcards found. [ 2.391969] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.400481] Waiting for root device PARTUUID=a3f42fe2-02... [ 2.440235] mmc1: new high speed SDHC card at address aaaa [ 2.446023] mmcblk1: mmc1:aaaa SL16G 14.8 GiB [ 2.458058] mmcblk1: p1 p2 [ 2.639604] EXT4-fs (mmcblk1p2): recovery complete [ 2.645418] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.653528] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.669116] devtmpfs: mounted [ 2.672383] Freeing unused kernel memory: 1856K [ 2.676932] Run /sbin/init as init process [ 3.003310] systemd[1]: System time before build time, advancing clock. [ 3.084383] NET: Registered protocol family 10 [ 3.089288] Segment Routing with IPv6 [ 3.125861] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -I) [ 3.147596] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 3.196653] systemd[1]: Set hostname to . [ 3.444875] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit f . [ 3.519153] random: systemd: uninitialized urandom read (16 bytes read) [ 3.525882] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 3.538207] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 3.548051] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.569248] random: systemd: uninitialized urandom read (16 bytes read) [ 3.576524] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.597246] random: systemd: uninitialized urandom read (16 bytes read) [ 3.604375] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.625348] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 3.649284] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 3.673277] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 3.693225] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 3.713223] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 3.733223] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 3.763490] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 3.785252] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 3.810091] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.833344] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.873651] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 3.881978] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.905447] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 3.925483] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.949409] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.969332] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.991448] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.016130] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.040060] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.067160] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 4.083623] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st…odes for the current kernel... [ 4.115647] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 4.141405] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 4.157338] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.169250] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.195712] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 4.215461] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.216681] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems 4.229736] cryptodev: driver 1.10 loaded. [0m... [ 4.240228] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 4.251519] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 4.271658] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 4.285522] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta… nodes for the current kernel. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 4.500652] systemd-journald[158]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started udev Coldplug all Devices. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Wait for Complete Device Initialization... Starting udev Kernel Device Manager... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ 5.010402] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 5.040434] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode [ 5.047835] remoteproc remoteproc0: 4d80800000.dsp is available [ 5.056688] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 5.068958] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode [ 5.076566] remoteproc remoteproc1: 4d81800000.dsp is available [ 5.092991] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2 [ 5.101575] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2 [ 5.113288] remoteproc remoteproc1: powering up 4d81800000.dsp [ 5.119208] remoteproc remoteproc0: powering up 4d80800000.dsp [ 5.125123] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2 [ 5.134671] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2 [ 5.147098] remoteproc remoteproc0: request_firmware failed: -2 [ 5.153072] remoteproc remoteproc1: request_firmware failed: -2 [ 5.164593] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 5.220753] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc [ 5.242687] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 5.251961] remoteproc remoteproc2: 64800000.dsp is available [ 5.258557] img_dec 4300000.video-decoder: decoder registered as /dev/video0 [ 5.263121] remoteproc remoteproc2: attaching to 64800000.dsp [ 5.277771] img_enc 4200000.video-encoder: encoder registered as /dev/video1 [ 5.285209] remoteproc remoteproc2: unsupported resource 65538 [ 5.297980] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1 [ 5.305662] PVR_K: 186: Read BVNC 22.104.208.318 from HW device registers [ 5.310344] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes [ 5.319014] PVR_K: 186: RGX Device registered with BVNC 22.104.208.318 [ 5.328217] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 5.334954] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 5.347198] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0 [ 5.365210] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 5.389235] platform 41000000.r5f: configured R5F for IPC-only mode [ 5.415220] virtio_rpmsg_bus virtio0: rpmsg host is online [ 5.417044] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 5.422917] remoteproc2#vdev0buffer: registered virtio0 (type 7) [ 5.433868] remoteproc remoteproc2: remote processor 64800000.dsp is now attached [ 5.470601] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 5.480152] remoteproc remoteproc3: 41000000.r5f is available [ 5.486004] remoteproc remoteproc3: attaching to 41000000.r5f [ 5.491921] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 5.498726] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 5.672099] virtio_rpmsg_bus virtio1: rpmsg host is online [ 5.684103] remoteproc3#vdev0buffer: registered virtio1 (type 7) [ 5.684238] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 5.691077] remoteproc remoteproc3: remote processor 41000000.r5f is now attached [ 5.701280] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 5.713542] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 5.751281] platform 41400000.r5f: configured R5F for IPC-only mode [ 5.989386] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000 [ 6.066446] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 6.123388] remoteproc remoteproc4: 41400000.r5f is available [ 6.199205] remoteproc remoteproc4: attaching to 41400000.r5f [ 6.291731] Unable to handle kernel paging request at virtual address ffff7fffb518f810 [ 6.308388] Mem abort info: [ 6.311532] ESR = 0x96000005 [ 6.314827] EC = 0x25: DABT (current EL), IL = 32 bits [ 6.327714] SET = 0, FnV = 0 [ 6.331099] EA = 0, S1PTW = 0 [ 6.335877] Data abort info: [ 6.338779] ISV = 0, ISS = 0x00000005 [ 6.343570] CM = 0, WnR = 0 [ 6.346558] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000082f30000 [ 6.355914] [ffff7fffb518f810] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000 [ 6.367802] Internal error: Oops: 96000005 [#1] PREEMPT SMP [ 6.373364] Modules linked in: snd_soc_j721e_evm ti_j721e_cpsw_virt_mac phy_can_transceiver ti_k3_r5_remoteproc(+) ti_am335x_tscadc cdns_mhdp8546 vxe_enc vxd_dec pruss j721e_csi2rx videobuf2_dma_sg pvrs6 [ 6.411563] CPU: 1 PID: 199 Comm: systemd-udevd Tainted: G O 5.10.65-gdcc6bedb2c #2 [ 6.420500] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 6.426318] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--) [ 6.432328] pc : rproc_handle_resources.constprop.0+0x94/0x168 [ 6.438149] lr : rproc_boot+0x334/0x670 [ 6.441970] sp : ffff80001340f7a0 [ 6.445271] x29: ffff80001340f7a0 x28: ffff800011304698 [ 6.450569] x27: ffff0008242e8000 x26: ffffffff9818f810 [ 6.455869] x25: ffff80001d000000 x24: ffff800010e1b0e8 [ 6.461166] x23: ffff0008242e8038 x22: 0000000000000000 [ 6.466467] x21: ffff80001123c520 x20: ffff0008242e8000 [ 6.471764] x19: 0000000000000000 x18: ffff0008214d7200 [ 6.477064] x17: 0000000000000000 x16: 0000000000000000 [ 6.482362] x15: 00001f5c06e186d0 x14: 01867ff200456da1 [ 6.487659] x13: 0d0388a860402c61 x12: ccac02cc2a602622 [ 6.492954] x11: 41ee4a020d1522c2 x10: 409c8c013a40468e [ 6.498251] x9 : ec56024280664182 x8 : 6884270024440000 [ 6.503548] x7 : 414045b048220400 x6 : ffff000826a26400 [ 6.508845] x5 : 0000000000000000 x4 : 0000000000000000 [ 6.514142] x3 : 0000000067e708ec x2 : 000000009818f810 [ 6.519438] x1 : ffff7fffb518f814 x0 : ffff80001d000000 [ 6.524739] Call trace: [ 6.527181] rproc_handle_resources.constprop.0+0x94/0x168 [ 6.532659] rproc_boot+0x334/0x670 [ 6.536136] rproc_add+0x88/0x158 [ 6.539446] k3_r5_probe+0x698/0xcf0 [ti_k3_r5_remoteproc] [ 6.544919] platform_drv_probe+0x54/0xa8 [ 6.548915] really_probe+0xec/0x3e0 [ 6.552478] driver_probe_device+0x58/0xb8 [ 6.556560] device_driver_attach+0x74/0x80 [ 6.560730] __driver_attach+0x58/0xe0 [ 6.564469] bus_for_each_dev+0x70/0xc0 [ 6.568294] driver_attach+0x24/0x30 [ 6.571859] bus_add_driver+0x14c/0x1f0 [ 6.575681] driver_register+0x64/0x120 [ 6.579505] __platform_driver_register+0x48/0x58 [ 6.584198] k3_r5_rproc_driver_init+0x20/0x10000 [ti_k3_r5_remoteproc] [ 6.590802] do_one_initcall+0x54/0x1b8 [ 6.594626] do_init_module+0x54/0x208 [ 6.598364] load_module+0x1f28/0x24c8 [ 6.602102] __do_sys_finit_module+0xb8/0xf8 [ 6.606361] __arm64_sys_finit_module+0x20/0x30 [ 6.610883] el0_svc_common.constprop.0+0x78/0x1c8 [ 6.615665] do_el0_svc+0x24/0x90 [ 6.618970] el0_svc+0x14/0x20 [ 6.622015] el0_sync_handler+0xb0/0xb8 [ 6.625840] el0_sync+0x180/0x1c0 [ 6.629146] Code: 128002b3 9102c021 97ffeb98 1400002e (b87a6b20) [ 6.635224] ---[ end trace ce3b38ca61bc6ed6 ]--- [ 7.037211] random: crng init done [ 7.040614] random: 7 urandom warning(s) missed due to ratelimiting [ OK ] Started Load/Save Random Seed. [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk0p10. Starting File System Check on /dev/mmcblk0p10... [ OK ] Found device /dev/mmcblk0p11. Starting File System Check on /dev/mmcblk0p11... [ OK ] Started File System Check on /dev/mmcblk0p10. Mounting /run/media/mmcblk0p10... [ OK ] Started File System Check on /dev/mmcblk0p11. [ 7.866149] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null) Mounting /run/media/mmcblk0p11... [ OK ] Mounted /run/media/mmcblk0p10. [ 7.912816] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted /run/media/mmcblk0p11. [ 8.092030] usbcore: registered new interface driver usbfs [ OK ] Found device /dev/mmcblk0p6.[ 8.112029] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 8.117670] usbcore: registered new interface driver hub [ 8.126828] usbcore: registered new device driver usb Starting File System Check on /dev/mmcblk0p6... [ 8.142816] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.151672] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ OK ] Found device /dev/mmcblk0p8. Starting File System Check on /dev/mmcblk0p8... [ 8.183804] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.194184] remoteproc remoteproc5: b034000.pru is available [ 8.201901] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.213432] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.244522] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ OK ] Found device /dev/mmcblk0p7. [ 8.253292] remoteproc remoteproc6: b004000.rtu is available Starting File System Check on /dev/mmcblk0p7... [ OK ] Started File System Check on /dev/mmcblk0p6. Mounting /run/media/mmcb[ 8.278707] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 lk0p6... [ 8.289752] remoteproc remoteproc7: b00a000.txpru is available [ 8.289888] remoteproc remoteproc8: b038000.pru is available [ 8.290027] remoteproc remoteproc9: b006000.rtu is available [ 8.290161] remoteproc remoteproc10: b00c000.txpru is available [ 8.290319] remoteproc remoteproc11: b134000.pru is available [ 8.290471] remoteproc remoteproc12: b104000.rtu is available [ 8.290596] remoteproc remoteproc13: b10a000.txpru is available [ 8.290697] remoteproc remoteproc14: b138000.pru is available [ 8.290850] remoteproc remoteproc15: b106000.rtu is available [ 8.290989] remoteproc remoteproc16: b10c000.txpru is available [ 8.292246] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.340302] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted /run/media/mmcblk0p6. [ OK ] Started File System Check on /dev/mmcblk0p8. Mounting /run/media/mmcblk0p8... [ 8.429492] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22 [ 8.475199] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Started File System Check on /dev/mmcblk0p7. [ OK ] Mounted /run/media/mmcblk0p8. Mounting /run/media/mmcblk0p7... [ 8.550282] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null) [ 8.562056] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22 [ OK ] Mounted /run/media/mmcblk0p7. [ OK ] Found device /dev/mmcblk0p5. [ 8.638003] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ OK ] Created slice system-weston.slice. [ 8.662490] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 Starting Start psplash boot splash screen... Starting File System Check on /dev/mmcblk0p5 8.693266] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller 0m... [ 8.720280] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [FAILED] Failed to start Start psplash boo[ 8.729627] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 t splash screen. See 'systemctl status psplash-start.servic[ 8.744177] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 e' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Found device /dev/mmcblk0p9. Starting File System Check on /dev/mmcblk0p9... [ 8.777020] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 8.786945] xhci-hcd xhci-hcd.2.auto: irq 623, io mem 0x06410000 [ 8.793686] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 8.802255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.810189] usb usb1: Product: xHCI Host Controller [ 8.815388] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd [ 8.821954] usb usb1: SerialNumber: xhci-hcd.2.auto [ OK ] Started File System Check on /dev/mmcblk0p5. Mounting /run/media/mmcblk0p5... [ 8.842165] hub 1-0:1.0: USB hub found [ 8.848365] hub 1-0:1.0: 1 port detected [ 8.854890] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.863160] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 8.870186] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.878506] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 8.886943] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 8.894137] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 8.902332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 8.910681] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.910684] usb usb2: Product: xHCI Host Controller [ 8.910688] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd [ 8.929386] usb usb2: SerialNumber: xhci-hcd.2.auto [ OK ] Found device /dev/mmcblk1p1.[ 8.935036] hub 2-0:1.0: USB hub found [ 8.943578] hub 2-0:1.0: 1 port detected [ 8.948919] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ OK ] Started File System Check on /dev/m[ 8.958780] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 mcblk0p9. [ 8.971243] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted /run/media/mmcblk0p5. Mounting /run/media/mmcblk0p9... Starting File System Check on /dev/mmcblk1p1... [ 9.033491] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted /run/media/mmcblk0p9. [ OK ] Started File System Check on /dev/mmcblk1p1. Mounting /run/media/mmcblk1p1... [ OK ] Mounted /run/media/mmcblk1p1. [FAILED] Failed to start udev Wait …omplete Device Initialization. See 'systemctl status systemd-udev-settle.service' for details. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API. [ OK ] Listening on dropbear.socket. Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting rc.pvr.service... Starting startwlan... Starting Login Service... Starting Update weston ini… based on the platform name... [ 126.247075] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filt[ 126.292682] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' ering Framework. [ OK ] Started rc.pvr.service. [ OK ] Started Update weston ini …ge based on the platform name. [ OK ] Started Telephony service. [ OK ] Reached target Network (Pre). [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. Starting Network Service... Starting weston.service... [ 126.399693] Intel(R) Wireless WiFi driver for Linux [ OK ] Started weston.service. Starting DEMO... Starting telnetd.service... [ OK ] Started DEMO. [ 126.465538] Bluetooth: Core ver 2.22 [ 126.472476] NET: Registered protocol family 31 [ 126.479061] Bluetooth: HCI device and connection manager initialized [ OK ] Started telnetd.service. [ 126.490949] Bluetooth: HCI socket layer initialized [ 126.505320] Bluetooth: L2CAP socket layer initialized [ 126.513330] Bluetooth: SCO socket layer initialized [ OK ] Started Login Service. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 126.604905] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 126.612528] Generic PHY fixed-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:00, irq=POLL) [ 126.652631] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma…ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Serial Getty on ttyS3. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston Wayland Compositor... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ 127.285536] PVR_K: 1174: RGX Firmware image 'rgx.fw.22.104.208.318' loaded [ OK ] Created slice User Slice of UID 0. Starting User Runtime Directory /run/user/0... [ OK ] Started User Runtime Directory /run/user/0. Starting User Manager for UID 0... [ 127.565919] startwlan.sh[1127]: Starting WLAN AP setup [ 127.592977] startwlan.sh[1221]: Starting WLAN AP se [ 127.594137] startwlan.sh[1222]: Starting WLAN AP se [ 127.636114] startwlan.sh[1222]: ddin [ 127.636566] startwlan.sh[1224]: ddin [ 127.757123] startwlan.sh[1224]: ommand failed: No such file or directory ( [ 127.757613] startwlan.sh[1225]: ommand failed: No such file or directory ( [ OK ] Started User Manager for UID 0. [ OK ] Started Session c1 of user root. [ 127.857659] startwlan.sh[1225]: onfiguratioCould not read interface wlp1s0 flags: No such device [ 127.857842] startwlan.sh[1225]: nl80211: Driver does not support authentication/association or connect commands [ 127.857905] startwlan.sh[1225]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0 [ 127.887334] startwlan.sh[1225]: Could not read interface wlp1s0 flags: No such device [ 127.887565] startwlan.sh[1225]: nl80211 driver initialization failed. [ 127.887642] startwlan.sh[1225]: wlp1s0: interface state UNINITIALIZED->DISABLED [ 127.887702] startwlan.sh[1225]: wlp1s0: AP-DISABLED [ 127.887761] startwlan.sh[1225]: wlp1s0: CTRL-EVENT-TERMINATING [ 127.887819] startwlan.sh[1225]: hostapd_free_hapd_data: Interface wlp1s0 wasn't started [ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon.. [ 128.655604] startwlan.sh[1243]: SIOCSIFADDR: No such device [ 128.670257] startwlan.sh[1243]: wlp1s0: ERROR while getting interface flags: No such device [ 128.679622] startwlan.sh[1243]: SIOCSIFNETMASK: No such device [ 128.690131] startwlan.sh[1243]: wlp1s0: ERROR while getting interface flags: No such device *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav-dev gstreamer1.0-libav gzip less libasm1 libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libidn2-0 libidn2-dev libmpc3 libmpfr6 libreadline-dev libreadline8 libunistring-dev libunistring2 m4-dev m4 make nettle-dev nettle parted python3-rfc3987 python3-strict-rfc3339 tar which zeromq If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove Where is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started startwlan. [ OK ] Started Print notice about GPLv3 packages. [ 129.815234] startwlan.sh[1437]: iperf3: error - unable to start listener for connections: Cannot assign requested address [ 129.896166] startwlan.sh[1437]: iperf3: exiting
  • 您好
    感谢您对TI产品的关注!为更加有效地解决您的问题,我们建议您将问题发布在E2E英文技术论坛上(https://e2e.ti.com/support/processors-group/processors/f/processors-forum),将由资深的英文论坛工程师为您提供帮助
  • root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh
    root@j7-evm:/opt/vision_apps# [MCU2_0]      3.995193 s: CIO: Init ... Done !!!
    [MCU2_0]      3.995264 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      3.995307 s: APP: Init ... !!!
    [MCU2_0]      3.995332 s: APP: Camera Power init ... !!!
    [MCU2_0]      3.995388 s: APP: Camera Power init done !!!
    [MCU2_0]      3.995423 s: SCICLIENT: Init ... !!!
    [MCU2_0]      3.995644 s: SCICLIENT: DMSC FW version [21.9.2-v2021.09b (Terrific Llam]
    [MCU2_0]      3.995697 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_0]      3.995748 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      3.995785 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      3.995812 s: UDMA: Init ... !!!
    [MCU2_0]      3.996879 s: UDMA: Init ... Done !!!
    [MCU2_0]      3.996944 s: MEM: Init ... !!!
    [MCU2_0]      3.996990 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
    [MCU2_0]      3.997066 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
    [MCU2_0]      3.997128 s: MEM: Init ... Done !!!
    [MCU2_0]      3.997155 s: ETHFW: Init ... !!!
    [MCU2_0]      4.013050 s: ETHFW: Shared multicasts (software fanout):
    [MCU2_0]      4.013121 s:   01:00:5e:00:00:01
    [MCU2_0]      4.013176 s:   01:00:5e:00:00:fb
    [MCU2_0]      4.013221 s:   01:00:5e:00:00:fc
    [MCU2_0]      4.013264 s:   33:33:00:00:00:01
    [MCU2_0]      4.013307 s:   33:33:ff:1d:92:c2
    [MCU2_0]      4.013350 s:   01:80:c2:00:00:00
    [MCU2_0]      4.013404 s:   01:80:c2:00:00:03
    [MCU2_0]      4.013449 s: ETHFW: Reserved multicasts:
    [MCU2_0]      4.013475 s:   01:80:c2:00:00:0e
    [MCU2_0]      4.013520 s:   01:1b:19:00:00:00
    [MCU2_0]      4.013762 s: EnetMcm: CPSW_9G on MAIN NAVSS
    [MCU2_0]      4.028087 s: CpswMacPort_checkSgmiiAutoNegStatus: MAC 1 ...
    [MCU2_0]      4.795998 s: CpswMacPort_checkSgmiiAutoNegStatus: MAC 1: st = -1, cnt = 100
    [MCU2_0]      4.796062 s: CpswMacPort_checkSgmiiStatus: MAC 1: SGMII auto-neggotiation failed: -1
    [MCU2_0]      4.796118 s: CpswMacPort_enableSgmiiPort: MAC 1: Failed to enable MAC port: -1
    [MCU2_0]      4.796172 s: Cpsw_openPortLinkNoPhy: Port 1: Failed to enable MAC port: -1
    [MCU2_0]      4.796223 s: Cpsw_handleLinkDown: Port 1: Link down
    [MCU2_0]      4.797723 s: Cpsw_ioctlInternal: Port 1: Failed to open port link: -1
    [MCU2_0]      4.797782 s: EnetPer_ioctl: cpsw9g: Failed to do IOCTL cmd 0x01000102: -1
    [MCU2_0]      4.797825 s: EnetMcm_enablePorts() failed to open MAC port: -1
    [MCU2_0]      4.797993 s: CpswMacPort_checkSgmiiAutoNegStatus: MAC 2 ...
    [MCU2_0]      4.805220 s: CpswMacPort_checkSgmiiAutoNegStatus: MAC 2: st = 0, cnt = 1
    [MCU2_0]      4.805288 s: CpswMacPort_checkSgmiiAutoNegStatus: MAC 2: st = 0, cnt = 0
    [MCU2_0]      4.805349 s: CpswMacPort_checkSgmiiStatus: MAC 2: SGMII link parter config port: link up: 1-Gbps Full-Duplex
    [MCU2_0]      4.807187 s:
    [MCU2_0] ETHFW Version   : 0.02.00
    [MCU2_0]      4.807266 s: ETHFW Build Date: Oct 30, 2022
    [MCU2_0]      4.807303 s: ETHFW Build Time: 14:36:59
    [MCU2_0]      4.807329 s: ETHFW Commit SHA: 86cedfa6
    [MCU2_0]      4.807398 s: ETHFW: Init ... DONE !!!
    [MCU2_0]      4.807432 s: IPC: Init ... !!!
    [MCU2_0]      4.807509 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0]      4.807564 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]      3.955289 s: CIO: Init ... Done !!!
    [MCU2_1]      3.955361 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      3.955403 s: APP: Init ... !!!
    [MCU2_1]      3.955428 s: SCICLIENT: Init ... !!!
    [MCU2_1]      3.955652 s: SCICLIENT: DMSC FW version [21.9.2-v2021.09b (Terrific Llam]
    [MCU2_1]      3.955704 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_1]      3.955738 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      3.955774 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      3.955802 s: UDMA: Init ... !!!
    [MCU2_1]      3.957017 s: UDMA: Init ... Done !!!
    [MCU2_1]      3.957081 s: MEM: Init ... !!!
    [MCU2_1]      3.957125 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
    [MCU2_1]      3.957215 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
    [MCU2_1]      3.957280 s: MEM: Init ... Done !!!
    [MCU2_1]      3.957305 s: IPC: Init ... !!!
    [MCU2_1]      3.957366 s: IPC: 8 CPUs participating in IPC !!!
    [MCU2_1]      3.957421 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]      4.058112 s: CIO: Init ... Done !!!
    [C6x_1 ]      4.058136 s: ### CPU Frequency = 1350000000 Hz
    [C6x_1 ]      4.058146 s: APP: Init ... !!!
    [C6x_1 ]      4.058154 s: SCICLIENT: Init ... !!!
    [C6x_1 ]      4.058350 s: SCICLIENT: DMSC FW version [21.9.2-v2021.09b (Terrific Llam]
    [C6x_1 ]      4.058362 s: SCICLIENT: DMSC FW revision 0x15
    [C6x_1 ]      4.058371 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_1 ]      4.058381 s: SCICLIENT: Init ... Done !!!
    [C6x_1 ]      4.058390 s: UDMA: Init ... !!!
    [C6x_1 ]      4.059610 s: UDMA: Init ... Done !!!
    [C6x_1 ]      4.059632 s: MEM: Init ... !!!
    [C6x_1 ]      4.059645 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
    [C6x_1 ]      4.059662 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_1 ]      4.059677 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
    [C6x_1 ]      4.059693 s: MEM: Init ... Done !!!
    [C6x_1 ]      4.059701 s: IPC: Init ... !!!
    [C6x_1 ]      4.059720 s: IPC: 8 CPUs participating in IPC !!!
    [C6x_1 ]      4.059734 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]     15.419534 s: IPC: HLOS is ready !!!
    [C6x_1 ]     15.423498 s: IPC: Init ... Done !!!
    [C6x_1 ]     15.423526 s: APP: Syncing with 7 CPUs ... !!!
    [C6x_2 ]      4.149126 s: CIO: Init ... Done !!!
    [C6x_2 ]      4.149152 s: ### CPU Frequency = 1350000000 Hz
    [C6x_2 ]      4.149163 s: APP: Init ... !!!
    [C6x_2 ]      4.149171 s: SCICLIENT: Init ... !!!
    [C6x_2 ]      4.149370 s: SCICLIENT: DMSC FW version [21.9.2-v2021.09b (Terrific Llam]
    [C6x_2 ]      4.149383 s: SCICLIENT: DMSC FW revision 0x15
    [C6x_2 ]      4.149392 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_2 ]      4.149402 s: SCICLIENT: Init ... Done !!!
    [C6x_2 ]      4.149412 s: UDMA: Init ... !!!
    [C6x_2 ]      4.150614 s: UDMA: Init ... Done !!!
    [C6x_2 ]      4.150635 s: MEM: Init ... !!!
    [C6x_2 ]      4.150648 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
    [C6x_2 ]      4.150666 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_2 ]      4.150681 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
    [C6x_2 ]      4.150697 s: MEM: Init ... Done !!!
    [C6x_2 ]      4.150706 s: IPC: Init ... !!!
    [C6x_2 ]      4.150726 s: IPC: 8 CPUs participating in IPC !!!
    [C6x_2 ]      4.150741 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_2 ]     16.083809 s: IPC: HLOS is ready !!!
    [C6x_2 ]     16.087538 s: IPC: Init ... Done !!!
    [C6x_2 ]     16.087565 s: APP: Syncing with 7 CPUs ... !!!
    [C7x_1 ]      4.710700 s: CIO: Init ... Done !!!
    [C7x_1 ]      4.710715 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]      4.710726 s: APP: Init ... !!!
    [C7x_1 ]      4.710733 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      4.710914 s: SCICLIENT: DMSC FW version [21.9.2-v2021.09b (Terrific Llam]
    [C7x_1 ]      4.710928 s: SCICLIENT: DMSC FW revision 0x15
    [C7x_1 ]      4.710938 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]      4.710948 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      4.710957 s: UDMA: Init ... !!!
    [C7x_1 ]      4.711859 s: UDMA: Init ... Done !!!
    [C7x_1 ]      4.711872 s: MEM: Init ... !!!
    [C7x_1 ]      4.711883 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ 100000000 of size 268435456 bytes !!!
    [C7x_1 ]      4.711903 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
    [C7x_1 ]      4.711920 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]      4.711937 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]      4.711954 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e4000000 of size 402653184 bytes !!!
    [C7x_1 ]      4.711972 s: MEM: Init ... Done !!!
    [C7x_1 ]      4.711980 s: IPC: Init ... !!!
    [C7x_1 ]      4.711993 s: IPC: 8 CPUs participating in IPC !!!
    [C7x_1 ]      4.712007 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     16.815661 s: IPC: HLOS is ready !!!
    [C7x_1 ]     16.817681 s: IPC: Init ... Done !!!
    [C7x_1 ]     16.817697 s: APP: Syncing with 7 CPUs ... !!!
    root@j7-evm:/opt/vision_apps# ls
    allocate_dma_sendfd.out              leadmove_lane_display_2_pipe_img.txt        user_out                                 vx_app_single_cam_cs2_1.out
    app_a72_spi_test.out                 leadmove_lane_display_3_data_ref_q_img.txt  vision_apps_init.sh                      vx_app_single_cam_getCamData.out
    app_avp.cfg                          leadmove_lane_display_4_pipe0_img.txt       vx_app_arm_fd_exchange_consumer.out      vx_app_single_cam_main_catpure_shm_1_img.txt
    app_avp2.cfg                         limits.conf                                 vx_app_arm_fd_exchange_producer.out      vx_app_single_cam_main_catpure_shm_2_pipe_img.txt
    app_avp3.cfg                         lmld                                        vx_app_arm_ipc.out                       vx_app_single_cam_main_catpure_shm_3_data_ref_q_img.txt
    app_avp4.cfg                         lmnets                                      vx_app_arm_mem.out                       vx_app_single_cam_main_catpure_shm_4_pipe0_img.txt
    app_c7x.cfg                          lmod                                        vx_app_arm_opengl_mosaic.out             vx_app_single_cam_producer.out
    app_dof.cfg                          opengles_demo.out                           vx_app_arm_remote_log.out                vx_app_srv_calibration.out
    app_encode.cfg                       opengles_disp_service.out                   vx_app_c7x_kernel.out                    vx_app_srv_camera.out
    app_fusion                           opengles_test.out                           vx_app_conformance.out                   vx_app_srv_camera_yuv.out
    app_intrinc_data_tda4_a.out          ptk_app_cfg                                 vx_app_csitx_csirx.out                   vx_app_srv_fileio.out
    app_intrinc_data_tda4_b.out          run_app_arm_fd_exchange.sh                  vx_app_cvt_m2m.out                       vx_app_stereo_depth.out
    app_lm_avp4.cfg                      run_app_c7x.sh                              vx_app_dense_optical_flow.out            vx_app_surround_radar_ogmap.out
    app_lm_ld_od_seg_cam.cfg             run_app_dof.sh                              vx_app_dof_sfm_fisheye.out               vx_app_test_framework.out
    app_lm_ld_od_seg_cam.cfg_ox08b       run_app_lm_avp_cam.sh                       vx_app_dvtest_capture_csitx.out          vx_app_tidl.out
    app_lm_ld_od_seg_cam.cfg_ox08b_1     run_app_lm_srv_cam.sh                       vx_app_front_csitx.out                   vx_app_tidl_1_img.txt
    app_lm_ld_od_seg_cam.cfg_ox08b_lmcc  run_app_multi_cam.sh                        vx_app_gpio_key.out                      vx_app_tidl_2_pipe_img.txt
    app_lm_ld_od_seg_cam_imx390.cfg      run_app_multi_emc.sh                        vx_app_gpu_csitx.out                     vx_app_tidl_3_data_ref_q_img.txt
    app_lm_ld_od_seg_cam_imx390_dp.cfg   run_app_sfm.sh                              vx_app_heap_stats.out                    vx_app_tidl_4_pipe0_img.txt
    app_lm_srv_camera.cfg                run_app_single_cam.sh                       vx_app_lidar_ogmap.out                   vx_app_tidl_avp.out
    app_lmnets_tda4                      run_app_single_cam_capture.sh               vx_app_lm_srv_camera.out                 vx_app_tidl_avp2.out
    app_multi_cam.cfg                    run_app_single_cam_capture_csitx.sh         vx_app_load_test.out                     vx_app_tidl_avp3.out
    app_multi_cam_emc.cfg                run_app_single_cam_consumer.sh              vx_app_m2m.out                           vx_app_tidl_avp4.out
    app_multi_dvtest.cfg                 run_app_single_cam_producer.sh              vx_app_m2m_display_a.out                 vx_app_tidl_avp4_1_img.txt
    app_oc.cfg                           run_app_srv.sh                              vx_app_multi_cam.out                     vx_app_tidl_avp4_2_pipe_img.txt
    app_oc_16bit.cfg                     run_app_srv_avp.sh                          vx_app_multi_cam_1_img.txt               vx_app_tidl_avp4_3_data_ref_q_img.txt
    app_od.cfg                           run_app_stereo.sh                           vx_app_multi_cam_2_pipe_img.txt          vx_app_tidl_avp4_4_pipe0_img.txt
    app_od_cam.cfg                       run_app_tidl.sh                             vx_app_multi_cam_3_data_ref_q_img.txt    vx_app_tidl_cam.out
    app_od_cam_display.cfg               run_app_tidl_16bit.sh                       vx_app_multi_cam_4_pipe0_img.txt         vx_app_tidl_lm_avp4.out
    app_pcie_video_sink.cfg              run_app_tidl_avp.sh                         vx_app_multi_cam_dvtest.out              vx_app_tidl_lm_lane_cam.out
    app_pcie_video_source.cfg            run_app_tidl_avp2.sh                        vx_app_multi_cam_emc.out                 vx_app_tidl_lm_ld_od_cam.out
    app_seg.cfg                          run_app_tidl_avp3.sh                        vx_app_multi_dvtest.out                  vx_app_tidl_od.out
    app_seg_16bit.cfg                    run_app_tidl_avp4.sh                        vx_app_only_csitx.out                    vx_app_tidl_od_cam.out
    app_seg_cam.cfg                      run_app_tidl_cam.sh                         vx_app_psnr_test.out                     vx_app_tidl_od_cam_display.out
    app_seg_cam_ti.cfg                   run_app_tidl_od.sh                          vx_app_rgb_csitx.out                     vx_app_tidl_seg.out
    app_sfm.cfg                          run_app_tidl_od_cam.sh                      vx_app_rtsp_h264_file.out                vx_app_tidl_seg_cam.out
    app_single_cam.cfg                   run_app_tidl_od_cam_display.sh              vx_app_rtsp_push_h264.out                vx_app_tidl_seg_cam_1_img.txt
    app_single_cam_getR5data.out         run_app_tidl_seg.sh                         vx_app_rtsp_pusher.out                   vx_app_tidl_seg_cam_2_pipe_img.txt
    app_single_cam_producer.cfg          run_app_tidl_seg_16bit.sh                   vx_app_rtsp_server.out                   vx_app_tidl_seg_cam_3_data_ref_q_img.txt
    app_srv.cfg                          run_app_tidl_seg_cam.sh                     vx_app_sde.out                           vx_app_tidl_seg_cam_4_pipe0_img.txt
    app_srv_avp_cfg                      run_app_tidl_vl.sh                          vx_app_sde_obstacle_detection.out        vx_app_tidl_vl.out
    app_stereo.cfg                       run_encode_came_to_file.sh                  vx_app_sfm.out                           vx_app_tutorial.out
    app_tidl_avp4.bin                    run_laneNet.sh                              vx_app_shm_read.out                      vx_app_valet_parking.out
    app_tidl_cam.cfg                     run_ld_od_Net.sh                            vx_app_single_cam.out                    vx_app_viss.out
    app_vl.cfg                           run_ld_od_Net_imx390.sh                     vx_app_single_cam_capture.out            vx_demo_display_rgba_file.out
    autorun.sh                           run_ld_od_Net_imx390_dp.sh                  vx_app_single_cam_capture_copy.out       vx_demo_draw_line.out
    demo_drm_display.out                 run_ld_od_Net_lmcc.sh                       vx_app_single_cam_capture_csitx.out      vx_demo_encode_camera_to_file.out
    demo_drm_display_double.out          run_ptk_demo.sh                             vx_app_single_cam_capture_display.out    vx_demo_encode_file_to_file.out
    demo_drm_display_nv12.out            run_rtsp_server.sh                          vx_app_single_cam_capture_display_2.out  vx_demos_lm_shm_cam_test.out
    demo_drm_display_page_flip.out       run_seg_cam.sh                              vx_app_single_cam_capture_dp.out         vx_demos_time_watermark_test.out
    dl_demos_app_tidl_seg_cam.md         run_uaes_rtsp.sh                            vx_app_single_cam_capture_emc.out        vx_demos_yuv_add_time_watermark.out
    dvtest.sh                            script.exp                                  vx_app_single_cam_capture_emc_test.out   vx_demos_yuv_overlay.out
    f.sh                                 singleop_test                               vx_app_single_cam_capture_m2m.out        vx_demos_yuv_overlay2.out
    get_dmafd_opengles_rendering.out     test_data                                   vx_app_single_cam_capture_psnr.out       vx_demos_yuv_recv_by_shm.out
    img_getfd_side.png                   uaes_rtsp_server.out                        vx_app_single_cam_capture_shm.out        vx_demos_yuv_send_by_shm.out
    leadmove_lane_display_1_img.txt      uase_rtsp_server.out                        vx_app_single_cam_consumer.out
    root@j7-evm:/opt/vision_apps# ./run_app_tidl.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    IPC: Init ... !!!
    file_deref_link: readlink failed for /sys/bus/platform/devices/5c00000.r5f
    _rpmsg_char_find_rproc: 5c00000.r5f device is mostly yet to be created!
    file_deref_link: readlink failed for /sys/bus/platform/devices/5d00000.r5f
    _rpmsg_char_find_rproc: 5d00000.r5f device is mostly yet to be created!
    IPC: ERROR: Unable to create TX channels for CPU [mcu2_0] !!!
    IPC: ERROR: Unable to create TX channels for CPU [mcu2_1] !!!
    APP: ERROR: IPC init failed !!!
    REMOTE_SERVICE: Init ... !!!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio1.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio3.rpmsg_chrdev.-1.21
    REMOTE_SERVICE: Init ... Done !!!
         0.000000 s: GTC Frequency = 0 MHz
    APP: Init ... Done !!!
         0.000000 s:  VX_ZONE_INIT:Enabled
         0.000000 s:  VX_ZONE_ERROR:Enabled
         0.000000 s:  VX_ZONE_WARNING:Enabled
         0.000000 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
         0.000000 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
         0.000000 s:  VX_ZONE_ERROR:[ownContextCreateCmdObj:161] context object descriptor [0] allocation failed
         0.000000 s:  VX_ZONE_ERROR:[vxCreateContext:946] context objection creation failed
         0.000000 s:  VX_ZONE_ERROR:[vxGetStatus:713] Reference is NULL
         0.000000 s:  VX_ZONE_ERROR:[tivxAddKernelTIDL:233] Unable to allocate user kernel ID
         0.000000 s:  VX_ZONE_ERROR:[vxSetReferenceName:659] Invalid reference
         0.000000 s:  VX_ZONE_ERROR:[vxMapUserDataObject:473] Invalid user data object reference
    ./run_app_tidl.sh: line 1:  1715 Segmentation fault      (core dumped) /opt/vision_apps/vx_app_tidl.out --cfg app_oc.cfg
    U-Boot SPL 2021.01-gd2bdf760-dirty (Dec 23 2022 - 11:05:16 +0800)
    Model: Texas Instruments K3 J721E SoC
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.2-v2021.09b (Terrific Llam')
    Trying to boot from MMC2
    U-Boot 2021.01-00001-gd04a55ea-dirty (Feb 01 2023 - 02:49:19 +0800)
    SoC:   J721E SR1.1 HS-SE
    DRAM:  4 GiB
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2810000
    Out:   serial@2810000
    Err:   serial@2810000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    1338800 bytes read in 67 ms (19.1 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 1338800 bytes: Success!
    351180 bytes read in 28 ms (12 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 351180 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    Failed to load '/lib/firmware/j7-c66_0-fw'
    Failed to load '/lib/firmware/j7-c66_1-fw'
    12980288 bytes read in 205 ms (60.4 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 12980288 bytes: Success!
    19268096 bytes read in 783 ms (23.5 MiB/s)
    100704 bytes read in 16 ms (6 MiB/s)
    10581 bytes read in 13 ms (793.9 KiB/s)
    Failed to load '/boot/ramdisk.cpio.gz'
    ## Flattened Device Tree blob at 88000000
       Booting using the fdt blob at 0x88000000
    ERROR: reserving fdt memory region failed (addr=fe000000 size=1000000)
    ERROR: reserving fdt memory region failed (addr=fc000000 size=2000000)
    ERROR: reserving fdt memory region failed (addr=ac000000 size=200000)
    ERROR: reserving fdt memory region failed (addr=ac200000 size=1e00000)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-gdcc6bedb2c (leadmove@leadmove) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain 4
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002810000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] OF: reserved mem: OVERLAP DETECTED!
    [    0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 16 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-ipc-shared-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Carveout Heap: regions without no-map are not yet supported
    [    0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fc000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node intercore-eth-r5f-memory@fc000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fe000000, size 16 MiB
    [    0.000000] OF: reserved mem: initialized node eeprom-shadow-r5f-memory@fe000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000feffffff]
    [    0.000000]   node   0: [mem 0x00000000ff000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
    [    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS3,115200n8 earlycon=ns16550a,mmio32,0x02810000 root=PARTUUID=a3f42fe2-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB)
    [    0.000000] Memory: 2777984K/4194304K available (10880K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 751K bss, 1416320K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a00b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008410] Console: colour dummy device 80x25
    [    0.012971] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023641] pid_max: default: 32768 minimum: 301
    [    0.028388] LSM: Security Framework initializing
    [    0.033132] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040699] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049631] rcu: Hierarchical SRCU implementation.
    [    0.054691] Platform MSI: msi-controller@1820000 domain created
    [    0.060941] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070239] EFI services will not be available.
    [    0.074992] smp: Bringing up secondary CPUs ...
    [    0.085933] Detected PIPT I-cache on CPU1
    [    0.085956] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.085967] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
    [    0.085998] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.086051] smp: Brought up 1 node, 2 CPUs
    [    0.115395] SMP: Total of 2 processors activated.
    [    0.120200] CPU features: detected: 32-bit EL0 Support
    [    0.125454] CPU features: detected: CRC32 instructions
    [    0.139178] CPU: All CPU(s) started at EL2
    [    0.143374] alternatives: patching kernel code
    [    0.148372] devtmpfs: initialized
    [    0.156737] KASLR disabled due to lack of seed
    [    0.161391] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.171353] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.178492] pinctrl core: initialized pinctrl subsystem
    [    0.184046] DMI not present or invalid.
    [    0.188250] NET: Registered protocol family 16
    [    0.193042] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.200405] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.208401] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.216676] thermal_sys: Registered thermal governor 'step_wise'
    [    0.216678] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.223093] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.236720] ASID allocator initialised with 65536 entries
    [    0.256681] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.263536] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.270294] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.277923] cryptd: max_cpu_qlen set to 1000
    [    0.283823] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.292604] vsys_3v3: supplied by evm_12v0
    [    0.296981] vsys_5v0: supplied by evm_12v0
    [    0.301291] vdd_mmc1: supplied by vsys_3v3
    [    0.305872] iommu: Default domain type: Translated
    [    0.311001] SCSI subsystem initialized
    [    0.314965] mc: Linux media interface: v0.10
    [    0.319333] videodev: Linux video capture interface: v2.00
    [    0.324959] pps_core: LinuxPPS API ver. 1 registered
    [    0.330029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.339366] PTP clock support registered
    [    0.343384] EDAC MC: Ver: 3.0.0
    [    0.347074] FPGA manager framework
    [    0.350589] Advanced Linux Sound Architecture Driver Initialized.
    [    0.357174] clocksource: Switched to clocksource arch_sys_counter
    [    0.363589] VFS: Disk quotas dquot_6.6.0
    [    0.367642] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.377356] NET: Registered protocol family 2
    [    0.381942] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.390542] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.399326] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.407521] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.415311] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.422062] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.428957] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.436355] NET: Registered protocol family 1
    [    0.441053] RPC: Registered named UNIX socket transport module.
    [    0.447114] RPC: Registered udp transport module.
    [    0.451918] RPC: Registered tcp transport module.
    [    0.456721] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.463306] PCI: CLS 0 bytes, default 64
    [    0.467638] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.477864] Initialise system trusted keyrings
    [    0.482478] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.490761] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.496972] NFS: Registering the id_resolver key type
    [    0.502190] Key type id_resolver registered
    [    0.506463] Key type id_legacy registered
    [    0.510582] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.517430] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.525087] 9p: Installing v9fs 9p2000 file system support
    [    0.550207] Key type asymmetric registered
    [    0.554393] Asymmetric key parser 'x509' registered
    [    0.559391] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.566950] io scheduler mq-deadline registered
    [    0.571575] io scheduler kyber registered
    [    0.576693] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.582840] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.590890] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.597152] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.604868] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.612838] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.621867] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.630842] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.638551] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.651140] brd: module loaded
    [    0.656994] loop: module loaded
    [    0.660550] megasas: 07.714.04.00-rc1
    [    0.665539] libphy: Fixed MDIO Bus: probed
    [    0.670154] tun: Universal TUN/TAP device driver, 1.6
    [    0.675539] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.681948] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.688026] sky2: driver version 1.30
    [    0.692205] VFIO - User Level meta-driver version: 0.3
    [    0.697831] i2c /dev entries driver
    [    0.701909] sdhci: Secure Digital Host Controller Interface driver
    [    0.708229] sdhci: Copyright(c) Pierre Ossman
    [    0.712895] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.719142] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.725444] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.732538] optee: probing for conduit method.
    [    0.737096] optee: revision 3.12 (3d47a131)
    [    0.737349] optee: initialized driver
    [    0.746386] NET: Registered protocol family 17
    [    0.750997] 9pnet: Installing 9P2000 support
    [    0.755380] Key type dns_resolver registered
    [    0.759817] Loading compiled-in X.509 certificates
    [    0.767258] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.773604] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.781560] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.2-v2021.09b (Terrific Llam')
    [    0.807357] random: fast init done
    [    0.828648] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.836157] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.846147] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.854944] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    0.864772] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    0.875753] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    [    0.883815] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    0.893695] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.900459] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.909457] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    0.919597] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.926365] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.934303] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    0.943696] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    0.952442] printk: console [ttyS3] enabled
    [    0.960880] printk: bootconsole [ns16550a0] disabled
    [    0.971338] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250
    [    0.981591] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    0.992099] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    1.002252] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    1.012490] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    1.023207] scsi host0: ufshcd
    [    1.069186] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.076833] davinci_mdio 46000f00.mdio: no live phy, scanning all
    [    1.181303] davinci_mdio 46000f00.mdio: timed out waiting for user access
    [    1.288174] davinci_mdio 46000f00.mdio: timed out waiting for idle
    [    1.294347] davinci_mdio: probe of 46000f00.mdio failed with error -5
    [    1.300801] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.314384] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.323206] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.323304] mmc0: CQHCI version 5.10
    [    1.329419] mmc1: CQHCI version 5.10
    [    1.342009] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.348856] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.355673] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.362485] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.369268] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.373414] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.376260] ti-udma 285c0000.dma-controller: Channels: 17 (tchan: 4, rchan: 13, gp-rflow: 8)
    [    1.393641] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.407818] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    1.414700] spi-nor: probe of spi0.0 failed with error -2
    [    1.422018] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    1.428893] spi-nor: probe of spi1.0 failed with error -2
    [    1.437763] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.443241] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.448291] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.454553] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.460977] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.467843] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.473182] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.474444] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.482078] davinci_mdio 46000f00.mdio: no live phy, scanning all
    [    1.488414] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.499002] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    1.507159] cdns-ufshcd 4e84000.ufs: last intr at 1331473 us, last intr status=0x404
    [    1.514892] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    1.522429] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    1.531461] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    1.537460] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    1.543723] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    1.549810] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    1.555894] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    1.568066] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    1.574415] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    1.580763] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    1.587111] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    1.593456] davinci_mdio 46000f00.mdio: timed out waiting for user access
    [    1.596253] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    1.606582] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    1.612932] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    1.619283] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    1.625630] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    1.631981] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    1.638326] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    1.643669] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    1.648975] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    1.654281] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    1.659584] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    1.665011] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    1.671206] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    1.676802] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1332593 us
    [    1.683935] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    1.689684] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    1.695515] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    1.700334] davinci_mdio 46000f00.mdio: timed out waiting for idle
    [    1.701087] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    1.707252] davinci_mdio: probe of 46000f00.mdio failed with error -5
    [    1.712887] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    1.719353] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.738553] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.745961] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.753187] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.753227] mmc0: Command Queue Engine enabled
    [    1.763551] mmc0: new HS200 MMC card at address 0001
    [    1.763701] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.768764] mmcblk0: mmc0:0001 DG4016 14.5 GiB
    [    1.778567] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.782113] mmcblk0boot0: mmc0:0001 DG4016 partition 1 31.9 MiB
    [    1.793769] mmcblk0boot1: mmc0:0001 DG4016 partition 2 31.9 MiB
    [    1.799777] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 16.0 MiB, chardev (237:0)
    [    1.801901] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    1.814427] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    1.821684]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
    [    1.822670] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    1.834383] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    1.841754] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    1.849062] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    1.857053] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    1.872638] ALSA device list:
    [    1.875603]   No soundcards found.
    [    2.391969] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.400481] Waiting for root device PARTUUID=a3f42fe2-02...
    [    2.440235] mmc1: new high speed SDHC card at address aaaa
    [    2.446023] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    2.458058]  mmcblk1: p1 p2
    [    2.639604] EXT4-fs (mmcblk1p2): recovery complete
    [    2.645418] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.653528] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.669116] devtmpfs: mounted
    [    2.672383] Freeing unused kernel memory: 1856K
    [    2.676932] Run /sbin/init as init process
    [    3.003310] systemd[1]: System time before build time, advancing clock.
    [    3.084383] NET: Registered protocol family 10
    [    3.089288] Segment Routing with IPv6
    [    3.125861] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -I)
    [    3.147596] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    3.196653] systemd[1]: Set hostname to <j7-evm>.
    [    3.444875] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit f .
    [    3.519153] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.525882] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.538207] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.548051] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.569248] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.576524] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.597246] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.604375] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.625348] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.649284] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.673277] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.693225] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.713223] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.733223] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.763490] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.785252] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.810091] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.833344] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.873651] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.881978] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.905447] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.925483] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.949409] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.969332] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.991448] systemd[1]: Mounting Huge Pages File System...
    [    4.016130] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.040060] systemd[1]: Mounting Kernel Debug File System...
    [    4.067160] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.083623] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    4.115647] systemd[1]: Starting Start psplash boot splash screen...
    [    4.141405] systemd[1]: Starting RPC Bind...
    [    4.157338] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.169250] systemd[1]: Starting Journal Service...
    [    4.195712] systemd[1]: Starting Load Kernel Modules...
    [    4.215461] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.216681] cryptodev: loading out-of-tree module taints kernel.
             Starting Remount Root and Kernel File Systems   4.229736] cryptodev: driver 1.10 loaded.
    [0m...
    [    4.240228] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    4.251519] systemd[1]: Starting udev Coldplug all Devices...
    [    4.271658] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.285522] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.500652] systemd-journald[158]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    5.010402] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    5.040434] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    5.047835] remoteproc remoteproc0: 4d80800000.dsp is available
    [    5.056688] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    5.068958] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    5.076566] remoteproc remoteproc1: 4d81800000.dsp is available
    [    5.092991] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2
    [    5.101575] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2
    [    5.113288] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    5.119208] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    5.125123] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2
    [    5.134671] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2
    [    5.147098] remoteproc remoteproc0: request_firmware failed: -2
    [    5.153072] remoteproc remoteproc1: request_firmware failed: -2
    [    5.164593] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    5.220753] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    5.242687] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    5.251961] remoteproc remoteproc2: 64800000.dsp is available
    [    5.258557] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    5.263121] remoteproc remoteproc2: attaching to 64800000.dsp
    [    5.277771] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    5.285209] remoteproc remoteproc2: unsupported resource 65538
    [    5.297980] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    5.305662] PVR_K:  186: Read BVNC 22.104.208.318 from HW device registers
    [    5.310344] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    5.319014] PVR_K:  186: RGX Device registered with BVNC 22.104.208.318
    [    5.328217] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    5.334954] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.347198] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [    5.365210]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    5.389235] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.415220] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.417044] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    5.422917]  remoteproc2#vdev0buffer: registered virtio0 (type 7)
    [    5.433868] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
    [    5.470601] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.480152] remoteproc remoteproc3: 41000000.r5f is available
    [    5.486004] remoteproc remoteproc3: attaching to 41000000.r5f
    [    5.491921] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.498726]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.672099] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.684103]  remoteproc3#vdev0buffer: registered virtio1 (type 7)
    [    5.684238] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.691077] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    5.701280] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    5.713542] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.751281] platform 41400000.r5f: configured R5F for IPC-only mode
    [    5.989386] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    6.066446] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    6.123388] remoteproc remoteproc4: 41400000.r5f is available
    [    6.199205] remoteproc remoteproc4: attaching to 41400000.r5f
    [    6.291731] Unable to handle kernel paging request at virtual address ffff7fffb518f810
    [    6.308388] Mem abort info:
    [    6.311532]   ESR = 0x96000005
    [    6.314827]   EC = 0x25: DABT (current EL), IL = 32 bits
    [    6.327714]   SET = 0, FnV = 0
    [    6.331099]   EA = 0, S1PTW = 0
    [    6.335877] Data abort info:
    [    6.338779]   ISV = 0, ISS = 0x00000005
    [    6.343570]   CM = 0, WnR = 0
    [    6.346558] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000082f30000
    [    6.355914] [ffff7fffb518f810] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
    [    6.367802] Internal error: Oops: 96000005 [#1] PREEMPT SMP
    [    6.373364] Modules linked in: snd_soc_j721e_evm ti_j721e_cpsw_virt_mac phy_can_transceiver ti_k3_r5_remoteproc(+) ti_am335x_tscadc cdns_mhdp8546 vxe_enc vxd_dec pruss j721e_csi2rx videobuf2_dma_sg pvrs6
    [    6.411563] CPU: 1 PID: 199 Comm: systemd-udevd Tainted: G           O      5.10.65-gdcc6bedb2c #2
    [    6.420500] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [    6.426318] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
    [    6.432328] pc : rproc_handle_resources.constprop.0+0x94/0x168
    [    6.438149] lr : rproc_boot+0x334/0x670
    [    6.441970] sp : ffff80001340f7a0
    [    6.445271] x29: ffff80001340f7a0 x28: ffff800011304698
    [    6.450569] x27: ffff0008242e8000 x26: ffffffff9818f810
    [    6.455869] x25: ffff80001d000000 x24: ffff800010e1b0e8
    [    6.461166] x23: ffff0008242e8038 x22: 0000000000000000
    [    6.466467] x21: ffff80001123c520 x20: ffff0008242e8000
    [    6.471764] x19: 0000000000000000 x18: ffff0008214d7200
    [    6.477064] x17: 0000000000000000 x16: 0000000000000000
    [    6.482362] x15: 00001f5c06e186d0 x14: 01867ff200456da1
    [    6.487659] x13: 0d0388a860402c61 x12: ccac02cc2a602622
    [    6.492954] x11: 41ee4a020d1522c2 x10: 409c8c013a40468e
    [    6.498251] x9 : ec56024280664182 x8 : 6884270024440000
    [    6.503548] x7 : 414045b048220400 x6 : ffff000826a26400
    [    6.508845] x5 : 0000000000000000 x4 : 0000000000000000
    [    6.514142] x3 : 0000000067e708ec x2 : 000000009818f810
    [    6.519438] x1 : ffff7fffb518f814 x0 : ffff80001d000000
    [    6.524739] Call trace:
    [    6.527181]  rproc_handle_resources.constprop.0+0x94/0x168
    [    6.532659]  rproc_boot+0x334/0x670
    [    6.536136]  rproc_add+0x88/0x158
    [    6.539446]  k3_r5_probe+0x698/0xcf0 [ti_k3_r5_remoteproc]
    [    6.544919]  platform_drv_probe+0x54/0xa8
    [    6.548915]  really_probe+0xec/0x3e0
    [    6.552478]  driver_probe_device+0x58/0xb8
    [    6.556560]  device_driver_attach+0x74/0x80
    [    6.560730]  __driver_attach+0x58/0xe0
    [    6.564469]  bus_for_each_dev+0x70/0xc0
    [    6.568294]  driver_attach+0x24/0x30
    [    6.571859]  bus_add_driver+0x14c/0x1f0
    [    6.575681]  driver_register+0x64/0x120
    [    6.579505]  __platform_driver_register+0x48/0x58
    [    6.584198]  k3_r5_rproc_driver_init+0x20/0x10000 [ti_k3_r5_remoteproc]
    [    6.590802]  do_one_initcall+0x54/0x1b8
    [    6.594626]  do_init_module+0x54/0x208
    [    6.598364]  load_module+0x1f28/0x24c8
    [    6.602102]  __do_sys_finit_module+0xb8/0xf8
    [    6.606361]  __arm64_sys_finit_module+0x20/0x30
    [    6.610883]  el0_svc_common.constprop.0+0x78/0x1c8
    [    6.615665]  do_el0_svc+0x24/0x90
    [    6.618970]  el0_svc+0x14/0x20
    [    6.622015]  el0_sync_handler+0xb0/0xb8
    [    6.625840]  el0_sync+0x180/0x1c0
    [    6.629146] Code: 128002b3 9102c021 97ffeb98 1400002e (b87a6b20)
    [    6.635224] ---[ end trace ce3b38ca61bc6ed6 ]---
    [    7.037211] random: crng init done
    [    7.040614] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p10.
             Starting File System Check on /dev/mmcblk0p10...
    [  OK  ] Found device /dev/mmcblk0p11.
             Starting File System Check on /dev/mmcblk0p11...
    [  OK  ] Started File System Check on /dev/mmcblk0p10.
             Mounting /run/media/mmcblk0p10...
    [  OK  ] Started File System Check on /dev/mmcblk0p11.
    [    7.866149] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p11...
    [  OK  ] Mounted /run/media/mmcblk0p10.
    [    7.912816] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p11.
    [    8.092030] usbcore: registered new interface driver usbfs
    [  OK  ] Found device /dev/mmcblk0p6.[    8.112029] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    8.117670] usbcore: registered new interface driver hub
    [    8.126828] usbcore: registered new device driver usb
             Starting File System Check on /dev/mmcblk0p6...
    [    8.142816] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.151672] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Found device /dev/mmcblk0p8.
             Starting File System Check on /dev/mmcblk0p8...
    [    8.183804] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.194184] remoteproc remoteproc5: b034000.pru is available
    [    8.201901] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.213432] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.244522] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Found device /dev/mmcblk0p7.
    [    8.253292] remoteproc remoteproc6: b004000.rtu is available
             Starting File System Check on /dev/mmcblk0p7...
    [  OK  ] Started File System Check on /dev/mmcblk0p6.
             Mounting /run/media/mmcb[    8.278707] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    lk0p6...
    [    8.289752] remoteproc remoteproc7: b00a000.txpru is available
    [    8.289888] remoteproc remoteproc8: b038000.pru is available
    [    8.290027] remoteproc remoteproc9: b006000.rtu is available
    [    8.290161] remoteproc remoteproc10: b00c000.txpru is available
    [    8.290319] remoteproc remoteproc11: b134000.pru is available
    [    8.290471] remoteproc remoteproc12: b104000.rtu is available
    [    8.290596] remoteproc remoteproc13: b10a000.txpru is available
    [    8.290697] remoteproc remoteproc14: b138000.pru is available
    [    8.290850] remoteproc remoteproc15: b106000.rtu is available
    [    8.290989] remoteproc remoteproc16: b10c000.txpru is available
    [    8.292246] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.340302] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p6.
    [  OK  ] Started File System Check on /dev/mmcblk0p8.
             Mounting /run/media/mmcblk0p8...
    [    8.429492] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [    8.475199] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk0p7.
    [  OK  ] Mounted /run/media/mmcblk0p8.
             Mounting /run/media/mmcblk0p7...
    [    8.550282] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    8.562056] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [  OK  ] Mounted /run/media/mmcblk0p7.
    [  OK  ] Found device /dev/mmcblk0p5.
    [    8.638003] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Created slice system-weston.slice.
    [    8.662490] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
             Starting File System Check on /dev/mmcblk0p5    8.693266] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    0m...
    [    8.720280] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [FAILED] Failed to start Start psplash boo[    8.729627] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    t splash screen.
    See 'systemctl status psplash-start.servic[    8.744177] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    e' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Found device /dev/mmcblk0p9.
             Starting File System Check on /dev/mmcblk0p9...
    [    8.777020] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [    8.786945] xhci-hcd xhci-hcd.2.auto: irq 623, io mem 0x06410000
    [    8.793686] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    8.802255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.810189] usb usb1: Product: xHCI Host Controller
    [    8.815388] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [    8.821954] usb usb1: SerialNumber: xhci-hcd.2.auto
    [  OK  ] Started File System Check on /dev/mmcblk0p5.
             Mounting /run/media/mmcblk0p5...
    [    8.842165] hub 1-0:1.0: USB hub found
    [    8.848365] hub 1-0:1.0: 1 port detected
    [    8.854890] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.863160] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [    8.870186] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [    8.878506] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [    8.886943] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [    8.894137] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    8.902332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    8.910681] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.910684] usb usb2: Product: xHCI Host Controller
    [    8.910688] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [    8.929386] usb usb2: SerialNumber: xhci-hcd.2.auto
    [  OK  ] Found device /dev/mmcblk1p1.[    8.935036] hub 2-0:1.0: USB hub found
    [    8.943578] hub 2-0:1.0: 1 port detected
    [    8.948919] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Started File System Check on /dev/m[    8.958780] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    mcblk0p9.
    [    8.971243] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p5.
             Mounting /run/media/mmcblk0p9...
             Starting File System Check on /dev/mmcblk1p1...
    [    9.033491] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p9.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [FAILED] Failed to start udev Wait …omplete Device Initialization.
    See 'systemctl status systemd-udev-settle.service' for details.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlan...
             Starting Login Service...
             Starting Update weston ini… based on the platform name...
    [  126.247075] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filt[  126.292682] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    ering Framework.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Started Telephony service.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting Network Service...
             Starting weston.service...
    [  126.399693] Intel(R) Wireless WiFi driver for Linux
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  126.465538] Bluetooth: Core ver 2.22
    [  126.472476] NET: Registered protocol family 31
    [  126.479061] Bluetooth: HCI device and connection manager initialized
    [  OK  ] Started telnetd.service.
    [  126.490949] Bluetooth: HCI socket layer initialized
    [  126.505320] Bluetooth: L2CAP socket layer initialized
    [  126.513330] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  126.604905] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  126.612528] Generic PHY fixed-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:00, irq=POLL)
    [  126.652631] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston Wayland Compositor...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  127.285536] PVR_K:  1174: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Started User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  127.565919] startwlan.sh[1127]: Starting WLAN AP setup
    [  127.592977] startwlan.sh[1221]: Starting WLAN AP se
    [  127.594137] startwlan.sh[1222]: Starting WLAN AP se
    [  127.636114] startwlan.sh[1222]: ddin
    [  127.636566] startwlan.sh[1224]: ddin
    [  127.757123] startwlan.sh[1224]: ommand failed: No such file or directory (
    [  127.757613] startwlan.sh[1225]: ommand failed: No such file or directory (
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of user root.
    [  127.857659] startwlan.sh[1225]: onfiguratioCould not read interface wlp1s0 flags: No such device
    [  127.857842] startwlan.sh[1225]: nl80211: Driver does not support authentication/association or connect commands
    [  127.857905] startwlan.sh[1225]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
    [  127.887334] startwlan.sh[1225]: Could not read interface wlp1s0 flags: No such device
    [  127.887565] startwlan.sh[1225]: nl80211 driver initialization failed.
    [  127.887642] startwlan.sh[1225]: wlp1s0: interface state UNINITIALIZED->DISABLED
    [  127.887702] startwlan.sh[1225]: wlp1s0: AP-DISABLED
    [  127.887761] startwlan.sh[1225]: wlp1s0: CTRL-EVENT-TERMINATING
    [  127.887819] startwlan.sh[1225]: hostapd_free_hapd_data: Interface wlp1s0 wasn't started
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [  128.655604] startwlan.sh[1243]: SIOCSIFADDR: No such device
    [  128.670257] startwlan.sh[1243]: wlp1s0: ERROR while getting interface flags: No such device
    [  128.679622] startwlan.sh[1243]: SIOCSIFNETMASK: No such device
    [  128.690131] startwlan.sh[1243]: wlp1s0: ERROR while getting interface flags: No such device
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started startwlan.
    [  OK  ] Started Print notice about GPLv3 packages.
    [  129.815234] startwlan.sh[1437]: iperf3: error - unable to start listener for connections: Cannot assign requested address
    [  129.896166] startwlan.sh[1437]: iperf3: exiting
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS3
    你好,这是app运行log,与启动的log,帮忙分析指明下调查方向。另外,英文论坛发不了帖子,中文论坛也需要1小时才能发一句话
  • 您好
    从你提供的Linux系统启动日志来看,有几个关键点需要关注:
    1.  ‌U-Boot启动过程‌:
      • U-Boot SPL 和 U-Boot 主版本已经加载,并且识别了SoC(J721E)和DRAM(4 GiB)。
      • 尝试从MMC2启动,但后续提到从mmc1加载环境变量。
    2. ‌boot.scr文件加载失败‌:
      • 在尝试加载'boot.scr'时失败了,只读取了0字节。这通常意味着该文件不存在、损坏或路径不正确。'boot.scr'是U-Boot的脚本文件,用于引导Linux内核和其他必要组件。
    3. ‌文件系统和app无法运行‌:
      • 由于'boot.scr'加载失败,可能导致Linux系统无法正确加载其根文件系统或必要的启动脚本,从而导致所有app无法运行。
    针对这些问题,我建议采取以下步骤进行排查和解决:
    • ‌检查boot.scr文件‌:
      • 确认'boot.scr'文件是否存在于预期的MMC设备中。
      • 检查文件是否完整且未损坏。
      • 如果可能,尝试手动编辑或重新生成'boot.scr'文件。
    • ‌检查MMC设备‌:
      • 确保MMC设备已正确连接并被系统识别。
      • 使用U-Boot命令(如mmc list和mmc dev)检查MMC设备状态。
    • ‌检查文件系统‌:
      • 验证根文件系统和所有必要的挂载点是否已正确配置。
      • 检查文件系统的完整性和一致性。
    • ‌检查tiboot3.bin和tifs.bin‌:
      • 确保这些文件是针对你的HS设备版本和Linux发行版定制的。
      • 检查它们是否已正确烧录到设备上。
    此外,考虑到你正在从GP设备更新到HS设备,请确保你的所有软件和硬件配置都已针对HS设备进行了适当的更新和测试。这包括驱动程序、固件、操作系统和应用程序。
