Part Number: SK-AM62A-LP
TI support, 你好!
我有SK-AM62A-LP开发板,想在上面跑基于TIOVX和TIDL的vision app演示程序,我找到了如下的文档:
但是
1) 我不确定这个文档是否适用于SK-AM62A-LP?如果不适用,能否提供相关文档?
2) 相关的Processor SDK RTOS包的下载路径能否提供?
Regards,
Hailong
TI support, 你好!
但是
Regards,
Hailong
您好
1) TI 有过答复,目前 vision_apps/应用程序不是为AM62A构建的
2)这款评估板相关的软件资源都在产品页的Order & start development部分
我找到了如下帖子:
请问这里说的为am62a构建ti vision app,是什么情况呢?
also this one:
我在TDA4的PSDK_RTOS里找到了如下的目录。请问这个跟AM62有什么关系,可以用来构建在AM62上跑的vision app吗?
also include @Jianzhong Xu
I see your faq post at https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1304287/faq-am62a7-how-to-use-the-isp-on-am62a
but is there any existing document to instruct all these step by step? say in such a fashion like below:
1) set up environment / download packages
2) prepare the vision app
3) build
4) run
Best,
Hailong
