TMS320C6748问题
Other Parts Discussed in Thread: TMS320C6748
我想请教一下,TMS320C6748的DVDD3318_A、DVDD3318_B、DVDD3318_C使用3.3V和1.8V不同的供电电压有什么区别啊?另外这三个供电必须是独立供电的吗,能使用一个电源供电呢?
  • 数据手册里有说明
    These groups can be operated at 3.3V or 1.8V nominal. The three groups can be operated at independent voltages but all pins withina group will operate at the same voltage. Group A operates at the voltage of power supply DVDD3318_A. Group B operates at the voltage of power supply DVDD3318_B. Group C operates at the voltage of power supply DVDD3318_C.
    三个group是互相独立的,可以使用1.8v或者3.3v, 但每个group里必须使用同一种电压。
