Part Number: AM6412
Hello TI support team:
I have a problem in building project using SDK with CCS projects on AM64X. If the amount of data code is relatively large, then have the building error, the information is:
C:/ti/mcu_plus_sdk_am64x_09_02_00_50/source/kernel/freertos/lib\freertos.am64x.a53-smp.gcc-aarch64.debug.lib(portASM.obj): in function `vPortRestoreTaskContext':
/nightlybuilds/mcupsdk_internal/jenkins/mcu_plus_sdk_am64x_09_02_00_50/source/kernel/freertos/portable_smp/GCC/ARM_CA53/portASM.S:390:(.vecs+0x80c): relocation truncated to fit: R_AARCH64_LD_PREL_LO19 against `.text.HwiP_defaultExcHandler'
How to solve this problem?
Best regards,
David wang
