AM3352: AM335x U-boot时报错
Part Number: AM3352
专家好!
我目前使用ti-processor-sdk-linux-am335x-evm-09.03.05.02-Linux-x86-Install.bin
u-boot和kernel编译已经通过,但是放到板子上执行的时候报:不能初始化定时器,
具体错误如下:
U-Boot SPL 2023.04 (Jan 03 2025 - 14:14:26 +0800)
Trying to boot from MMC1
U-Boot 2023.04 (Jan 03 2025 - 14:14:26 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM: 512 MiB
Core: 161 devices, 18 uclasses, devicetree: separate
Could not initialize timer (err -19)
resetting ...
还请指导一下,非常感谢!
秦龙
  • 我正在使用AM335x Linux SDK 9.3.5.2附加u-boot日志,并在AM335x GP EVM上从SD引导。
    您的测试中使用了哪个电路板?
    U-Boot SPL 2023.04 (Jan 10 2025 - 16:44:18 -0600)
    U-Boot 2023.04 (Jan 10 2025 - 16:44:18 -0600)
    DRAM:  1 GiB
    Core:  156 devices, 17 uclasses, devicetree: separate
    WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
    NAND:  256 MiB
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
    <ethaddr> not set. Validating first E-fuse MAC
    Net:   eth2: ethernet@4a100000, eth3: usb_ether
    Hit any key to stop autoboot:  2  0
    => md.l 0x44e10040 1
    44e10040: 00400397                             ..@.
    => dm tree
     Class     Index  Probed  Driver                Name
     root          0  [ + ]   root_driver           root_driver
     rsa_mod_ex    0  [   ]   mod_exp_sw            |-- mod_exp_sw
     simple_bus    0  [ + ]   simple_bus            |-- ocp
     simple_bus    1  [ + ]   simple_bus            |   |-- l4_wkup@44c00000
     simple_bus    2  [   ]   simple_bus            |   |   |-- segment@0
     simple_bus    3  [   ]   simple_bus            |   |   |-- segment@100000
     simple_bus    4  [ + ]   simple_bus            |   |   `-- segment@200000
     simple_bus    5  [ + ]   ti_sysc               |   |       |-- target-module@0
     simple_bus    6  [ + ]   simple_bus            |   |       |   `-- prcm@0
     simple_bus    7  [   ]   simple_bus            |   |       |       |-- clocks
     clk           0  [   ]   fixed_clock           |   |       |       |   |-- clock-clk-32768
     clk           1  [   ]   fixed_clock           |   |       |       |   |-- clock-clk-rc32k
     clk           2  [   ]   fixed_clock           |   |       |       |   |-- clock-virt-19200000
     clk           3  [   ]   fixed_clock           |   |       |       |   |-- clock-virt-24000000
     clk           4  [   ]   fixed_clock           |   |       |       |   |-- clock-virt-25000000
     clk           5  [   ]   fixed_clock           |   |       |       |   |-- clock-virt-26000000
     clk           6  [   ]   fixed_clock           |   |       |       |   |-- clock-tclkin
     clk           7  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-dpll-ddr-m2-div2
     clk           8  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-dpll-per-m2-div4-wkupdm
     clk           9  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-dpll-per-m2-div4
     clk          10  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-clk-24mhz
     clk          11  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-clkdiv32k
     clk          12  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l3-gclk
     clk          13  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-dpll-core-m4-div2
     clk          14  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l4-rtc-gclk
     clk          15  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l4hs-gclk
     clk          16  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l3s-gclk
     clk          17  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l4fw-gclk
     clk          18  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-l4ls-gclk
     clk          19  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-sysclk-div
     clk          20  [   ]   fixed_factor_clock    |   |       |       |   |-- clock-cpsw-125mhz-gclk
     clk          21  [   ]   fixed_factor_clock    |   |       |       |   `-- clock-mmc
     simple_bus    8  [   ]   ti_omap4_cm           |   |       |       |-- clock@0
     clk          22  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@38
     clk          23  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@1c
     clk          24  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@24
     clk          25  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@120
     clk          26  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@e8
     clk          27  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          28  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@18
     clk          29  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@14c
     clk          30  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@38
     clk          31  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@1c
     clk          32  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@24
     clk          33  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@120
     clk          34  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@e8
     clk          35  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          36  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@18
     clk          37  [   ]   ti_ctrl_clk           |   |       |       |   `-- clock@14c
     simple_bus    9  [ + ]   ti_omap4_cm           |   |       |       |-- clock@400
     clk          38  [ + ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          39  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@14
     clk          40  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@b0
     clk          41  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          42  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@14
     clk          43  [   ]   ti_ctrl_clk           |   |       |       |   `-- clock@b0
     simple_bus   10  [   ]   ti_omap4_cm           |   |       |       |-- clock@600
     clk          44  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          45  [   ]   ti_ctrl_clk           |   |       |       |   `-- clock@0
     simple_bus   11  [   ]   ti_omap4_cm           |   |       |       |-- clock@800
     clk          46  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          47  [   ]   ti_ctrl_clk           |   |       |       |   `-- clock@0
     simple_bus   12  [   ]   ti_omap4_cm           |   |       |       |-- clock@900
     clk          48  [   ]   ti_ctrl_clk           |   |       |       |   |-- clock@0
     clk          49  [   ]   ti_ctrl_clk           |   |       |       |   `-- clock@0
     simple_bus   13  [   ]   ti_omap4_cm           |   |       |       `-- clock@a00
     clk          50  [   ]   ti_ctrl_clk           |   |       |           |-- clock@0
     clk          51  [   ]   ti_ctrl_clk           |   |       |           `-- clock@0
     simple_bus   14  [ + ]   ti_sysc               |   |       |-- target-module@7000
     gpio          0  [ + ]   gpio_omap             |   |       |   `-- gpio@0
     simple_bus   15  [ + ]   ti_sysc               |   |       |-- target-module@9000
     serial        0  [ + ]   omap_serial           |   |       |   `-- serial@0
     simple_bus   16  [   ]   ti_sysc               |   |       |-- target-module@b000
     simple_bus   17  [   ]   ti_sysc               |   |       |-- target-module@d000
     simple_bus   18  [   ]   ti_sysc               |   |       |-- target-module@10000
     simple_bus   19  [   ]   simple_bus            |   |       |   `-- scm@0
     simple_bus   20  [   ]   simple_bus            |   |       |       `-- scm_conf@0
     simple_bus   21  [   ]   simple_bus            |   |       |           `-- clocks
     clk          52  [   ]   fixed_factor_clock    |   |       |               |-- clock-adc-tsc-fck
     clk          53  [   ]   fixed_factor_clock    |   |       |               |-- clock-dcan0-fck
     clk          54  [   ]   fixed_factor_clock    |   |       |               |-- clock-dcan1-fck
     clk          55  [   ]   fixed_factor_clock    |   |       |               |-- clock-mcasp0-fck
     clk          56  [   ]   fixed_factor_clock    |   |       |               |-- clock-mcasp1-fck
     clk          57  [   ]   fixed_factor_clock    |   |       |               |-- clock-smartreflex0-fck
     clk          58  [   ]   fixed_factor_clock    |   |       |               |-- clock-smartreflex1-fck
     clk          59  [   ]   fixed_factor_clock    |   |       |               |-- clock-sha0-fck
     clk          60  [   ]   fixed_factor_clock    |   |       |               |-- clock-aes0-fck
     clk          61  [   ]   fixed_factor_clock    |   |       |               `-- clock-rng-fck
     simple_bus   22  [   ]   ti_sysc               |   |       |-- target-module@35000
     simple_bus   23  [   ]   ti_sysc               |   |       `-- target-module@3e000
     simple_bus   24  [   ]   simple_bus            |   |-- interconnect@48000000
     simple_bus   25  [   ]   simple_bus            |   |   |-- segment@0
     simple_bus   26  [   ]   ti_sysc               |   |   |   |-- target-module@22000
     serial        1  [   ]   omap_serial           |   |   |   |   `-- serial@0
     simple_bus   27  [   ]   ti_sysc               |   |   |   |-- target-module@24000
     simple_bus   28  [   ]   ti_sysc               |   |   |   |-- target-module@2a000
     simple_bus   29  [   ]   ti_sysc               |   |   |   |-- target-module@30000
     simple_bus   30  [   ]   ti_sysc               |   |   |   |-- target-module@38000
     simple_bus   31  [   ]   ti_sysc               |   |   |   |-- target-module@3c000
     simple_bus   32  [   ]   ti_sysc               |   |   |   |-- target-module@4c000
     gpio          1  [   ]   gpio_omap             |   |   |   |   `-- gpio@0
     simple_bus   33  [   ]   ti_sysc               |   |   |   |-- target-module@60000
     simple_bus   34  [   ]   ti_sysc               |   |   |   |-- target-module@80000
     simple_bus   35  [   ]   ti_sysc               |   |   |   |-- target-module@c8000
     simple_bus   36  [   ]   ti_sysc               |   |   |   `-- target-module@ca000
     simple_bus   37  [   ]   simple_bus            |   |   |-- segment@100000
     simple_bus   38  [   ]   ti_sysc               |   |   |   |-- target-module@9c000
     simple_bus   39  [   ]   ti_sysc               |   |   |   |-- target-module@a0000
     simple_bus   40  [   ]   ti_sysc               |   |   |   |-- target-module@a6000
     simple_bus   41  [   ]   ti_sysc               |   |   |   |-- target-module@a8000
     simple_bus   42  [   ]   ti_sysc               |   |   |   |-- target-module@aa000
     simple_bus   43  [   ]   ti_sysc               |   |   |   |-- target-module@ac000
     gpio          2  [   ]   gpio_omap             |   |   |   |   `-- gpio@0
     simple_bus   44  [   ]   ti_sysc               |   |   |   |-- target-module@ae000
     gpio          3  [   ]   gpio_omap             |   |   |   |   `-- gpio@0
     simple_bus   45  [   ]   ti_sysc               |   |   |   |-- target-module@cc000
     simple_bus   46  [   ]   ti_sysc               |   |   |   |-- target-module@d0000
     simple_bus   47  [   ]   ti_sysc               |   |   |   `-- target-module@d8000
     simple_bus   48  [   ]   simple_bus            |   |   |-- segment@200000
     simple_bus   49  [   ]   simple_bus            |   |   `-- segment@300000
     simple_bus   50  [   ]   ti_sysc               |   |       |-- target-module@0
     simple_bus   51  [   ]   ti_sysc               |   |       |-- target-module@2000
     simple_bus   52  [   ]   ti_sysc               |   |       |-- target-module@4000
     simple_bus   53  [   ]   ti_sysc               |   |       |-- target-module@e000
     simple_bus   54  [   ]   ti_sysc               |   |       `-- target-module@10000
     simple_bus   55  [   ]   simple_bus            |   |-- interconnect@47c00000
     simple_bus   56  [   ]   simple_bus            |   |   `-- segment@0
     simple_bus   57  [   ]   simple_bus            |   |-- interconnect@4a000000
     simple_bus   58  [   ]   simple_bus            |   |   `-- segment@0
     simple_bus   59  [   ]   ti_sysc               |   |       `-- target-module@100000
     simple_bus   60  [   ]   simple_bus            |   |-- interconnect@4b140000
     simple_bus   61  [   ]   simple_bus            |   |   `-- segment@0
     simple_bus   62  [   ]   ti_sysc               |   |-- target-module@49000000
     simple_bus   63  [   ]   ti_sysc               |   |-- target-module@49800000
     simple_bus   64  [   ]   ti_sysc               |   |-- target-module@49900000
     simple_bus   65  [   ]   ti_sysc               |   |-- target-module@49a00000
     simple_bus   66  [   ]   ti_sysc               |   |-- target-module@47810000
     i2c           0  [   ]   i2c_omap              |   |-- i2c@44e0b000
     i2c           1  [   ]   i2c_omap              |   |-- i2c@4802a000
     mmc           0  [ + ]   omap_hsmmc            |   |-- mmc@48060000
     blk           0  [ + ]   mmc_blk               |   |   |-- mmc@48060000.blk
     partition     0  [ + ]   blk_partition         |   |   |   |-- mmc@48060000.blk:1
     partition     1  [ + ]   blk_partition         |   |   |   `-- mmc@48060000.blk:2
     bootdev       0  [   ]   mmc_bootdev           |   |   `-- mmc@48060000.bootdev
     watchdog      0  [ + ]   omap3_wdt             |   |-- wdt@44e35000
     misc          0  [ + ]   ti-musb-wrapper       |   |-- usb@47400000
     usb           0  [ + ]   ti-musb-peripheral    |   |   |-- usb@47401000
     ethernet      1  [ + ]   usb_ether             |   |   |   `-- usb_ether
     bootdev       2  [   ]   eth_bootdev           |   |   |       `-- usb_ether.bootdev
     usb           0  [   ]   ti-musb-host          |   |   `-- usb@47401800
     ethernet      0  [ + ]   eth_cpsw              |   |-- ethernet@4a100000
     bootdev       1  [   ]   eth_bootdev           |   |   `-- ethernet@4a100000.bootdev
     simple_bus   67  [   ]   ti_sysc               |   |-- target-module@53100000
     simple_bus   68  [   ]   ti_sysc               |   |-- target-module@53500000
     simple_bus   69  [   ]   ti_sysc               |   `-- target-module@56000000
     bootstd       0  [   ]   bootstd_drv           |-- bootstd
     bootmeth      0  [   ]   bootmeth_distro       |   |-- distro
     bootmeth      1  [   ]   bootmeth_efi          |   |-- efi
     bootmeth      2  [   ]   bootmeth_pxe          |   |-- pxe
     bootmeth      3  [   ]   vbe_simple            |   `-- vbe_simple
     timer         0  [ + ]   omap_timer            `-- timer@0
    => pri
    arch=arm
    baudrate=115200
    board=am335x
    board_name=A33515BB
    board_rev=1.6A
    board_serial=16174P160564
    boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
    boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
    boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
    boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
    boot_fdt=try
    boot_net_usb_start=usb start
    boot_prefixes=/ /boot/
    boot_script_dhcp=boot.scr.uimg
    boot_scripts=boot.scr.uimg boot.scr
    boot_syslinux_conf=extlinux/extlinux.conf
    boot_targets=mmc0 mmc1 nand0 usb0 pxe dhcp
    bootcmd=run findfdt; run init_console; run finduuid; run distro_bootcmd
    bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
    bootcmd_mmc0=devnum=0; run mmc_boot
    bootcmd_mmc1=devnum=1; run mmc_boot
    bootcmd_nand=run nandboot
    bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
    bootcmd_usb0=devnum=0; run usb_boot
    bootcount=1
    bootdelay=2
    bootm_size=0x10000000
    console=ttyO0,115200n8
    cpu=armv7
    dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x200;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 1 1;spl-os-image fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1
    dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x200;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 0 1;spl-os-image fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1
    dfu_alt_info_nand=SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0 3;SPL.backup3 part 0 4;u-boot part 0 5;u-boot-spl-os part 0 6;kernel part 0 8;rootfs part 0 9
    dfu_alt_info_ram=kernel ram 0x80200000 0x4000000;fdt ram 0x80f80000 0x80000;ramdisk ram 0x81000000 0x4000000
    distro_bootcmd=extension_need_init=; setenv extension_overlay_addr ${fdtoverlay_addr_r}; for target in ${boot_targets}; do run bootcmd_${target}; done
    dtboaddr=0x89000000
    efi_dtb_prefixes=/ /dtb/ /dtb/current/
    eth1addr=d0:ff:50:56:e6:b3
    eth2addr=d0:ff:50:56:e6:b1
    eth3addr=de:ad:be:ef:00:01
    ethaddr=d0:ff:50:56:e6:b1
    extension_apply=if fdt addr -q ${fdt_addr_r}; then extension apply all; fi
    extension_init=echo Extension init...; if ${extension_need_init}; then extension_need_init=false; extension scan; fi
    extension_overlay_cmd=load ${devtype} ${devnum}:${distro_bootpart} ${extension_overlay_addr} ${prefix}${extension_overlay_name}
    fdt_addr_r=0x88000000
    fdtaddr=0x88000000
    fdtcontroladdr=bdf2be20
    fdtfile=undefined
    fdtoverlay_addr_r=0x89000000
    findfdt=if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then setenv fdtfile am335x-boneblack.dtb; fi; if test $board_name = A335PBGL; then setenv fdtfile am335x-pocketbeagle.dtb; fi; if test $board_name = BBBW; then setenv fdtfile am335x-boneblack-wireless.dtb; fi; if test $board_name = BBG1; then setenv fdtfile am335x-bonegreen.dtb; fi; if test $board_name = BBGW; then setenv fdtfile am335x-bonegreen-wireless.dtb; fi; if test $board_name = BBBL; then setenv fdtfile am335x-boneblue.dtb; fi; if test $board_name = BBEN; then setenv fdtfile am335x-sancloud-bbe.dtb; fi; if test $board_name = BBELITE; then setenv fdtfile am335x-sancloud-bbe-lite.dtb; fi; if test $board_name = BBE_EX_WIFI; then setenv fdtfile am335x-sancloud-bbe-extended-wifi.dtb; fi; if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi; if test $board_name = A335_ICE; then setenv fdtfile am335x-icev2.dtb; if test $ice_mii = mii; then setenv pxe_label_override Pruss; fi;fi; if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi;
    finduuid=part uuid mmc 0:2 uuid
    ice_mii=mii
    init_console=if test $board_name = A335_ICE; then setenv console ttyO3,115200n8;else setenv console ttyO0,115200n8;fi;
    kernel_addr_r=0x82000000
    load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
    loadaddr=0x82000000
    loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz
    mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
    mtdids=nand0=nand.0
    mtdparts=mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),2m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)
    nandargs=setenv bootargs console=${console} ${optargs} root=${nandroot} rootfstype=${nandrootfstype}
    nandboot=echo Booting from nand ...; run nandargs; nand read ${fdtaddr} NAND.u-boot-spl-os; nand read ${loadaddr} NAND.kernel; bootz ${loadaddr} - ${fdtaddr}
    nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048
    nandrootfstype=ubifs rootwait
    netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
    netboot=echo Booting from network ...; setenv autoload no; dhcp; run netloadimage; run netloadfdt; run netargs; bootz ${loadaddr} - ${fdtaddr}
    netloadfdt=tftp ${fdtaddr} ${fdtfile}
    netloadimage=tftp ${loadaddr} ${bootfile}
    nfsopts=nolock
    partitions=uuid_disk=${uuid_gpt_disk};name=bootloader,start=384K,size=1792K,uuid=${uuid_gpt_bootloader};name=rootfs,start=2688K,size=-,uuid=${uuid_gpt_rootfs}
    pxefile_addr_r=0x80100000
    ramargs=setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype}
    ramboot=echo Booting from ramdisk ...; run ramargs; bootz ${loadaddr} ${rdaddr} ${fdtaddr}
    ramdisk_addr_r=0x88080000
    ramroot=/dev/ram0 rw
    ramrootfstype=ext2
    rdaddr=0x88080000
    rootpath=/export/rootfs
    scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
    scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
    scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; run extension_init; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; run extension_apply; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
    scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing...; fi
    scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
    scriptaddr=0x80000000
    serial#=16174P160564
    soc=am33xx
    spiargs=setenv bootargs console=${console} ${optargs} root=${spiroot} rootfstype=${spirootfstype}
    spiboot=echo Booting from spi ...; run spiargs; sf probe ${spibusno}:0; sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootz ${loadaddr}
    spibusno=0
    spiimgsize=0x362000
    spiroot=/dev/mtdblock4 rw
    spirootfstype=jffs2
    spisrcaddr=0xe0000
    static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
    stderr=serial@0
    stdin=serial@0
    stdout=serial@0
    usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
    usbnet_devaddr=de:ad:be:ef:00:01
    vendor=ti
    ver=U-Boot 2023.04 (Jan 10 2025 - 16:44:18 -0600)
    Environment size: 8893/131068 bytes
