TDA4VE-Q1: V4L2 encode function
Part Number: TDA4VE-Q1
Hello, I would like to ask if you  can provide  code examples,supports two different image input formats,the function is as follows:
1、Using v4l2 as encoding function on tda4ve, input NV12 image of 1280*720, output by encoding H265 data of 1280*720
2、Using v4l2 as encoding function on tda4ve, input YUV422 UYVY image of 1280*720, output by encoding H265 data of 1280*720
