Part Number: AM6421
我是用SysCfg配置两个UART的时候,如下图所示:
当两个UART都配置成HLD的时候编译没问题,但两个UART都配置成LLD的时候,编译出错,请问是什么问题?
完整错误日志如下:
**** Build of configuration Debug for project ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang ****
"C:\\ti\\ccs1271\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
Building file: "../example.syscfg"
Invoking: SysConfig
"C:/ti/ccs1271/ccs/utils/sysconfig_1.20.0/sysconfig_cli.bat" --script "C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/example.syscfg" -o "syscfg" -s "C:/ti/mcu_plus_sdk_am64x_10_00_00_20/.metadata/product.json" --context "r5fss1-0" --part Default --package ALV --compiler ticlang
Running script...
Validating...
info: PARALLEL_UART_FFT_A(/drivers/uart/uart) baudRate: Actual Baudrate Possible: 2000000 (0 % error)
info: PARALLEL_UART_FFT_B(/drivers/uart/uart) baudRate: Actual Baudrate Possible: 2000000 (0 % error)
Generating Code (example.syscfg)...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_dpl_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_dpl_config.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_drivers_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_drivers_config.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_drivers_open_close.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_drivers_open_close.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_pinmux_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_power_clock_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_board_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_board_config.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_board_open_close.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_board_open_close.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_config.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_config.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_open_close.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_open_close.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_soc.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_lwipif.c...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\ti_enet_lwipif.h...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\linker.cmd...
Writing C:\Erdong\D\09Compass\Test\erdong\ipc_notify_echo_1\ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang\Debug\syscfg\linker_defines.h...
Finished building: "../example.syscfg"
Building file: "syscfg/ti_drivers_open_close.c"
Invoking: Arm Compiler
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_drivers_open_close.d_raw" -MT"syscfg/ti_drivers_open_close.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_drivers_open_close.o" "syscfg/ti_drivers_open_close.c"
subdir_rules.mk:46: recipe for target 'syscfg/ti_drivers_open_close.o' failed
syscfg/ti_drivers_open_close.c:288:19: error: redefinition of 'gUartDmaChCfg'
UART_UdmaChConfig gUartDmaChCfg[CONFIG_UART_NUM_DMA_LLD_INSTANCES] =
syscfg/ti_drivers_open_close.c:252:19: note: previous definition is here
1 error generated.
gmake: *** [syscfg/ti_drivers_open_close.o] Error 1
Building file: "syscfg/ti_dpl_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_dpl_config.d_raw" -MT"syscfg/ti_dpl_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_dpl_config.o" "syscfg/ti_dpl_config.c"
Finished building: "syscfg/ti_dpl_config.c"
Building file: "syscfg/ti_drivers_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_drivers_config.d_raw" -MT"syscfg/ti_drivers_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_drivers_config.o" "syscfg/ti_drivers_config.c"
Finished building: "syscfg/ti_drivers_config.c"
Building file: "../ipc_notify_echo.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"ipc_notify_echo.d_raw" -MT"ipc_notify_echo.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"ipc_notify_echo.o" "../ipc_notify_echo.c"
Finished building: "../ipc_notify_echo.c"
Building file: "syscfg/ti_pinmux_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_pinmux_config.d_raw" -MT"syscfg/ti_pinmux_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_pinmux_config.o" "syscfg/ti_pinmux_config.c"
Finished building: "syscfg/ti_pinmux_config.c"
Building file: "syscfg/ti_power_clock_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_power_clock_config.d_raw" -MT"syscfg/ti_power_clock_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_power_clock_config.o" "syscfg/ti_power_clock_config.c"
Finished building: "syscfg/ti_power_clock_config.c"
Building file: "syscfg/ti_board_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_board_config.d_raw" -MT"syscfg/ti_board_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_board_config.o" "syscfg/ti_board_config.c"
Finished building: "syscfg/ti_board_config.c"
Building file: "syscfg/ti_board_open_close.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_board_open_close.d_raw" -MT"syscfg/ti_board_open_close.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_board_open_close.o" "syscfg/ti_board_open_close.c"
Finished building: "syscfg/ti_board_open_close.c"
Building file: "syscfg/ti_enet_config.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_enet_config.d_raw" -MT"syscfg/ti_enet_config.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_enet_config.o" "syscfg/ti_enet_config.c"
Finished building: "syscfg/ti_enet_config.c"
Building file: "syscfg/ti_enet_open_close.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_enet_open_close.d_raw" -MT"syscfg/ti_enet_open_close.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_enet_open_close.o" "syscfg/ti_enet_open_close.c"
Finished building: "syscfg/ti_enet_open_close.c"
Building file: "syscfg/ti_enet_soc.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_enet_soc.d_raw" -MT"syscfg/ti_enet_soc.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_enet_soc.o" "syscfg/ti_enet_soc.c"
Finished building: "syscfg/ti_enet_soc.c"
Building file: "syscfg/ti_enet_lwipif.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_enet_lwipif.d_raw" -MT"syscfg/ti_enet_lwipif.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"syscfg/ti_enet_lwipif.o" "syscfg/ti_enet_lwipif.c"
Finished building: "syscfg/ti_enet_lwipif.c"
Building file: "../parallel_fft.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"parallel_fft.d_raw" -MT"parallel_fft.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"parallel_fft.o" "../parallel_fft.c"
subdir_rules.mk:9: recipe for target 'parallel_fft.o' failed
../parallel_fft.c:143:29: error: use of undeclared identifier 'gUartHandle'; did you mean 'gUartHandleLld'?
transferOK = UART_write(gUartHandle[PARALLEL_UART_FFT_A], &trans);
gUartHandleLld
C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg\ti_drivers_open_close.h:87:23: note: 'gUartHandleLld' declared here
extern UARTLLD_Handle gUartHandleLld[CONFIG_UART_NUM_LLD_INSTANCES];
../parallel_fft.c:152:29: error: use of undeclared identifier 'gUartHandle'; did you mean 'gUartHandleLld'?
transferOK = UART_write(gUartHandle[PARALLEL_UART_FFT_B], &trans);
gUartHandleLld
../parallel_fft.c:170:28: error: use of undeclared identifier 'gUartHandle'; did you mean 'gUartHandleLld'?
transferOK = UART_read(gUartHandle[PARALLEL_UART_FFT_A], &transA);
gUartHandleLld
../parallel_fft.c:180:28: error: use of undeclared identifier 'gUartHandle'; did you mean 'gUartHandleLld'?
transferOK = UART_read(gUartHandle[PARALLEL_UART_FFT_B], &transB);
gUartHandleLld
4 errors generated.
gmake: *** [parallel_fft.o] Error 1
Building file: "../main.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Source" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/Core/Include" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/examples/benchmarks/benchmark_demo/common" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source/cmsis/DSP/Include" -I"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am64x_10_00_00_20/source" -DSOC_AM64X -D_DEBUG_=1 -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"main.d_raw" -MT"main.o" -I"C:/Erdong/D/09Compass/Test/erdong/ipc_notify_echo_1/ipc_notify_echo_am64x-evm_r5fss1-0_nortos_ti-arm-clang/Debug/syscfg" -o"main.o" "../main.c"
Finished building: "../main.c"
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
