DSP MMU Faults
Other Parts Discussed in Thread: DM3730
Hi!
我使用的芯片是DM3730,我运行APP的时候,出现“DSP MMU Error Fault!  MMU_IRQSTATUS = [0x1]. Virtual DSP addr reference that generated the interrupt = [0x8c2000e0].”
我的内存分配是:
var mem_ext = [
    comment:    "RESET_VECTOR: off-chip memory for the reset vector table",
    base:       0x87500000,
    len:        0x00001000,//1KB
    space:      "code/data"
    comment:    "DSPLINK: off-chip memory reserved for DSPLINK code and data",
    base:       0x87501000,
    len:        0x000FF000,//1020KB
    space:      "code/data"
    comment:    "DDRALGHEAP: off-chip memory for dynamic algmem allocation",
    base:       0x87600000,
    len:        0x04000000,//64MB
    space:      "code/data"
    comment:    "DDR2: off-chip memory for application code and data",
    base:       0x8B600000,
    len:        0x00C00000,//12M  0x8C200000
    space:      "code/data"
    comment:    "L4CORE: L4-Core Interconnect Address Space",
    base:       0x48000000,
    len:        0x01000000,//16MB
    space:      "data"
    comment:    "L4PER: L4-Peripheral Interconnect Address Space",
    base:       0x49000000,
    len:        0x00100000,
    space:      "data"
我查阅了processors.wiki.ti.com/.../DSP_MMU_Faults
我对“the memory range to map to the DSP MMU”是指什么内存啊?我该怎么解决这个问题尼?
希望能尽快回复,感谢万分!
